File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py”, line 6941, in raise_from_not_ok_status
six.raise_from(core._status_to_exception(e.code, message), None)
File “”, line 3, in raise_from
tensorflow.python.framework.errors_impl.ResourceExhaustedError: failed to allocate memory [Op:Mul]
Apparently it’s a memory error and I can’t find a way to fix it
The ResourceExhaustedError indicates that you are running out of memory.
Please double-check this by monitoring the system status with the following command at the same time:
$ sudo tegrastats
Since inference requires physical GPU memory, you will need to reduce the model complexity if OOM occurs.
Gracias por la colaboración.
En este momento me surge una duda, Si aumento la capacidad de memoria de la tarjeta micro SD, ¿De esta manera puedo solucionar el error?
