Hi Dears,
I tried to build the TensorRT engine based on ONNX model by using trtexec. The ONNX models are ByteTrack tracking models, with different base networks, such as yolox_x and yolox_s. But when I built the ByteTrack with yolox_s (linked down below) by the command of trtexec --onnx=bytetrack_s.onnx --useDLACore=0 --fp16 --allowGPUFallback
, I came across the following error.
Module_id 33 Severity 2 : NVMEDIA_DLA 684
Module_id 33 Severity 2 : Failed to bind input tensor. err : 0x00000b
Module_id 33 Severity 2 : NVMEDIA_DLA 2866
Module_id 33 Severity 2 : Failed to bind input tensor args. status: 0x000007
[02/08/2022-12:25:03] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 942, GPU 6818 (MiB)
[02/08/2022-12:25:03] [E] Error[1]: [nvdlaUtils.cpp::submit::198] Error Code 1: DLA (Failure to submit program to DLA engine.)
[02/08/2022-12:25:03] [E] Error[2]: [builder.cpp::buildSerializedNetwork::417] Error Code 2: Internal Error (Assertion enginePtr != nullptr failed.)
[02/08/2022-12:25:03] [E] Engine could not be created from network
[02/08/2022-12:25:03] [E] Building engine failed
[02/08/2022-12:25:03] [E] Failed to create engine from model.
[02/08/2022-12:25:03] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8203] # /storage/rekor_home/wma_projects/trtexec/trtexec --onnx=bytetrack_s.onnx --useDLACore=0 --fp16 --allowGPUFallback
https://drive.google.com/file/d/1tMnnG1nS3MYNm5AGq3SRxV7zcgXKBZv3/view?usp=sharing
This error does not happen to Bytetrack model with yolox_x. This error seems not clear to get guide to solution. Could you guys supply some help or advice?
Thank you!
