Failed to convert TensorRT engine using Tao deploy library
• Hardware (T4/V100/Xavier/Nano/etc) Jetsom AGX Xavier
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) Efficientdet-tf1
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Tao deploy is installed to AGX Xavier locally using the following commands.
apt install libopenmpi-dev
pip install nvidia_tao_deploy==5.0.0.423.dev0
pip install https://files.pythonhosted.org/packages/f7/7a/ac2e37588fe552b49d8807215b7de224eef60a495391fdacc5fa13732d11/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
pip install https://files.pythonhosted.org/packages/0d/05/6caf40aefc7ac44708b2dcd5403870181acc1ecdd93fa822370d10cc49f3/nvidia_eff-0.6.2-py38-none-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
All are installed successfully.
But run the following command,
efficientdet_tf1 gen_trt_engine -m model.onnx -r ./export --data_type fp16 --batch_size 1 --engine_file ./export/model.onnx_b1_fp16.engine -k nvidia_tao gave me errors as
atic@atic-desktop:/opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/Rectitude_efficientdet$ efficientdet_tf1 gen_trt_engine -m model.onnx -r ./export --data_type fp16 --batch_size 1 --engine_file ./export/model.onnx_b1_fp16.engine -k nvidia_tao
2023-11-04 20:06:48,881 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.common.logging.status_logging 198: Log file already exists at /opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/Rectitude_efficientdet/export/status.json
2023-11-04 20:06:48,882 [TAO Toolkit] [INFO] root 174: Starting efficientdet_tf1 gen_trt_engine.
[11/04/2023-20:06:49] [TRT] [I] [MemUsageChange] Init CUDA: CPU +181, GPU +0, now: CPU 220, GPU 4672 (MiB)
[11/04/2023-20:06:51] [TRT] [I] [MemUsageChange] Init builder kernel library: CPU +131, GPU +140, now: CPU 370, GPU 4827 (MiB)
2023-11-04 20:06:52,356 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 40: List inputs:
2023-11-04 20:06:52,357 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 41: Input 0 -> input.
2023-11-04 20:06:52,357 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 42: [512, 512, 3].
2023-11-04 20:06:52,357 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 42: 1.
[11/04/2023-20:06:52] [TRT] [W] onnx2trt_utils.cpp:367: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[11/04/2023-20:06:56] [TRT] [I] No importer registered for op: EfficientNMS_TRT. Attempting to import as plugin.
[11/04/2023-20:06:56] [TRT] [I] Searching for plugin: EfficientNMS_TRT, plugin_version: 1, plugin_namespace:
[11/04/2023-20:06:56] [TRT] [W] builtin_op_importers.cpp:4714: Attribute class_agnostic not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
[11/04/2023-20:06:56] [TRT] [I] Successfully created plugin: EfficientNMS_TRT
2023-11-04 20:06:56,311 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 68: Network Description
2023-11-04 20:06:56,312 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 71: Input 'input' with shape (1, 512, 512, 3) and dtype DataType.FLOAT
2023-11-04 20:06:56,318 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 73: Output 'num_detections' with shape (1, 1) and dtype DataType.INT32
2023-11-04 20:06:56,318 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 73: Output 'detection_boxes' with shape (1, 100, 4) and dtype DataType.FLOAT
2023-11-04 20:06:56,318 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 73: Output 'detection_scores' with shape (1, 100) and dtype DataType.FLOAT
2023-11-04 20:06:56,319 [TAO Toolkit] [INFO] nvidia_tao_deploy.cv.efficientdet_tf1.engine_builder 73: Output 'detection_classes' with shape (1, 100) and dtype DataType.INT32
2023-11-04 20:06:56,320 [TAO Toolkit] [INFO] nvidia_tao_deploy.engine.builder 143: TensorRT engine build configurations:
2023-11-04 20:06:56,320 [TAO Toolkit] [INFO] nvidia_tao_deploy.engine.builder 156:
2023-11-04 20:06:56,320 [TAO Toolkit] [INFO] nvidia_tao_deploy.engine.builder 158:   BuilderFlag.FP16
2023-11-04 20:06:56,320 [TAO Toolkit] [INFO] nvidia_tao_deploy.engine.builder 172:   BuilderFlag.TF32
2023-11-04 20:06:56,321 [TAO Toolkit] [INFO] root 174: type object 'tensorrt.tensorrt.BuilderFlag' has no attribute 'ENABLE_TACTIC_HEURISTIC'
  File "</usr/local/lib/python3.8/dist-packages/nvidia_tao_deploy/cv/efficientdet_tf1/scripts/gen_trt_engine.py>", line 3, in <module>
  File "<frozen cv.efficientdet_tf1.scripts.gen_trt_engine>", line 182, in <module>
  File "<frozen cv.common.decorators>", line 63, in _func
  File "<frozen cv.common.decorators>", line 48, in _func
  File "<frozen cv.efficientdet_tf1.scripts.gen_trt_engine>", line 70, in main
  File "<frozen engine.builder>", line 287, in create_engine
  File "<frozen engine.builder>", line 185, in _logger_info_IBuilderConfig
AttributeError: type object 'tensorrt.tensorrt.BuilderFlag' has no attribute 'ENABLE_TACTIC_HEURISTIC'
2023-11-04 20:06:57,088 [WARNING] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: Telemetry data couldn't be sent, but the command ran successfully.
2023-11-04 20:06:57,089 [WARNING] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: [Error]: Uninitialized
2023-11-04 20:06:57,090 [WARNING] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: Execution status: FAIL
Why failed in conversion?
Can you share the tensorrt version in your Xaiver?
TensorRT version is as follow. thank you
TensorRT Version : 8.4.1-1+cuda11.4
Please download 8.5.3 version for aarch platform, then untar it and export LD_LIBRARY_PATH, then retry.
Thank you. I’ll try.
I’m converting on Jetson device, installed with latest Jetpack.
Package: nvidia-jetpack
Version: 5.0.2-b231
• TensorRT Version : 8.4.1-1+cuda11.4
• NVIDIA GPU Driver Version (valid for GPU only) 11.4
TensorRT and GPU Driver are already included when installed with SDKManager.
Converting to TensorRT engine was done on actual deployment platform. So I shouldn’t test with TensorRT 8.5 version.
There are several ways to use TRT8.5 version.
  1. The easiest way is to use the docker mentioned in the github GitHub - NVIDIA/tao_deploy: Package for deploying deep learning models from TAO Toolkit. For example,
    $ docker run --runtime=nvidia -it --rm nvcr.io/nvidia/l4t-tensorrt:r8.5.2.2-devel /bin/bash
  2. Install TensorRT with JetPack 5.1.2 . Download from JetPack SDK | NVIDIA Developer
  3. As mentioned above, you can download aarch verison
    of TRT8.5. Step: Go to https://developer.nvidia.com/tensorrt-getting-started → Click “Download now” → TensorRT 8.5 GA Update 2 for ARM SBSA → * TensorRT 8.5 GA Update 2 for Ubuntu 20.04 and CUDA 11.8 TAR Package
    i.e.,
    Download https://developer.nvidia.com/downloads/compute/machine-learning/tensorrt/secure/8.5.3/tars/TensorRT-8.5.3.1.Ubuntu-20.04.aarch64-gnu.cuda-11.8.cudnn8.6.tar.gz
    Then,
    $ tar zxvf TensorRT-8.5.3.1.Ubuntu-20.04.aarch64-gnu.cuda-11.8.cudnn8.6.tar.gz
    $ pip install TensorRT-8.5.3.1.Ubuntu-20.04.aarch64-gnu.cuda-11.8.cudnn8.6/TensorRT-8.5.3.1/python/tensorrt-8.5.3.1-cp38-none-linux_aarch64.whl
    $ export LD_LIBRARY_PATH=/path/to/TensorRT-8.5.3.1/lib/:$LD_LIBRARY_PATH
    Then retry.
