PC with a RTX 3090. OS: Windows 11. Environment running in WSL2 and Ubuntu 20.04.
• DeepStream Version
DeepStreamSDK 6.2.0
• TensorRT Version
8.5.2-1+cuda11.8
528.02
Question
• How to reproduce the issue? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Dockerfile:
FROM nvcr.io/nvidia/deepstream:6.2-samples
RUN apt-get update && apt install -y libssl1.1
libgstreamer1.0-0
gstreamer1.0-tools
gstreamer1.0-plugins-good
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly
gstreamer1.0-libav
libgstreamer-plugins-base1.0-dev
libgstrtspserver-1.0-0
libjansson4
libyaml-cpp-dev
libjsoncpp-dev
protobuf-compiler
gcc
make
git
python3
RUN apt-get install -y nvidia-container-toolkit-base
RUN /opt/nvidia/deepstream/deepstream/user_additional_install.sh
Run Docker image:
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.2 custom-deepstream
Once I have the docker container running, I tried running an example, but I get the following error:
/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app# deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
0:00:00.044685806 355 0x5602f1260300 WARN GST_ELEMENT_FACTORY gstelementfactory.c:458:gst_element_factory_make: no such element factory "nvinfer"!
** ERROR: <create_primary_gie_bin:129>: Failed to create 'primary_gie'
** ERROR: <create_primary_gie_bin:193>: create_primary_gie_bin failed
** ERROR: <create_pipeline:1485>: create_pipeline failed
** ERROR: <main:697>: Failed to create pipeline
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
App run failed
I have checked the /opt/nvidia/deepstream/deepstream-6.2/lib/gst-plugins directory and the plugin is there:
Can you help me please?
Thank you,
Mikel
