dGPU
• DeepStream Version
6.0
• TensorRT Version
8.0.1
510.52
Questions
I was wondering if there’s any way to run DeepStream using Docker (WSL2) on Windows? There are a couple of plugins that I’m unable to load:
$ docker run --rm -it --gpus=all nvcr.io/nvidia/deepstream:6.0-samples
root@28f0234c4578:/opt/nvidia/deepstream/deepstream-6.0# nvidia-smi
Mon Feb 28 05:24:23 2022
| NVIDIA-SMI 510.52 Driver Version: 511.79 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 On | N/A |
| 0% 33C P8 20W / 310W | 341MiB / 8192MiB | 14% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
root@28f0234c4578:/opt/nvidia/deepstream/deepstream-6.0# gst-inspect-1.0 | grep nvds
(gst-plugin-scanner:15): GStreamer-WARNING **: 05:24:32.546: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:15): GStreamer-WARNING **: 05:24:32.550: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so: undefined symbol: cuGraphicsEGLRegisterImage
(gst-plugin-scanner:15): GStreamer-WARNING **: 05:24:32.552: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:15): GStreamer-WARNING **: 05:24:32.568: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so: undefined symbol: cuGraphicsEGLRegisterImage
(gst-plugin-scanner:15): GStreamer-WARNING **: 05:24:32.577: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so: undefined symbol: cuGraphicsEGLRegisterImage
nvdsgst_videotemplate: nvdsvideotemplate: NvDsVideoTemplate plugin for Transform/In-Place use-cases
nvdsgst_speech: nvdsasr: DS ASR Plugin for speech use-cases
nvdsgst_audiotemplate: nvdsaudiotemplate: DS AUDIO template Plugin for Transform IP use-cases
nvdsgst_jpegdec: nvjpegdec: JPEG image decoder
nvdsgst_dewarper: nvdewarper: nvdewarper
nvdsgst_multistream: nvstreamdemux: Stream demultiplexer
nvdsgst_multistream: nvstreammux: Stream multiplexer
nvdsgst_inferaudio: nvinferaudio: NvInfer Audio plugin
nvdsgst_nvblender: nvblender: Compositor
nvdsgst_text_to_speech: nvds_text_to_speech: DS Text To Speech Plugin for Conversational AI use cases
nvdsgst_dsexample: dsexample: DsExample plugin
nvdsgst_logger: nvdslogger: Nvdslogger
nvdsgst_multistreamtiler: nvmultistreamtiler: Stream Tiler DS
nvdsgst_osd: nvdsosd: NvDsOsd plugin
nvdsgst_msgconv: nvmsgconv: Message Converter
nvdsgst_eglglessink: nveglglessink: EGL/GLES vout Sink
nvdsgst_tracker: nvtracker: NvTracker plugin
nvdsgst_segvisual: nvsegvisual: nvsegvisual
nvdsgst_msgbroker: nvmsgbroker: Message Broker
nvdsgst_ofvisual: nvofvisual: nvofvisual
nvdsgst_dsanalytics: nvdsanalytics: DsAnalytics plugin
nvdsgst_of: nvof: nvof
