DGX Station A100
• DeepStream Version
6.0.0
NA
• TensorRT Version
NA
NA
questions
I used these Dockerfile and the docker-compose.yaml file and ran docker-compose up on my DGX station
then docker exec -it docker-test /bin/bash --login
to open a shell
then ran gst-inspect-1.0 -b
I got
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.861: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.864: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.864: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.864: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.865: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.878: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.878: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.881: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.881: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.881: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.884: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.885: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.887: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 15:56:19.888: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
Blacklisted files:
libnvdsgst_udp.so
libnvdsgst_infer.so
Total count: 14 blacklisted files
NA
Observations:
the output of nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Aug_15_21:14:11_PDT_2021
Cuda compilation tools, release 11.4, V11.4.120
Build cuda_11.4.r11.4/compiler.30300941_0
root@docker:/home/nvidia#
I’m fairly new to this so If I understand correctly cuda is there (because nvcc is returning stuff) but clearly libcuda.so.1, librivermax.so.0 and libtritonserver.so
I think I could get away without the other to but I think I can’t be without libcuda.so
Can you please give me some guidance on this.
Cheers,
Ganindu.
[UPDATE]
I did
- [step 1] `ldd /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/<plugin_name>.so’
then - [step 2]
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/compat
to locate paths forlibcuda.so libcuda.so.1
and then - [step 3]
ldconfig
to resolve
and again step 1 to check. and the libcuda.so dependency was solved
Afterwards I noticed that nvstreammux
was missing, but then I noticed that in /opt/nvidia/deepstream/deepstream/sources/apps/apps-common
directory the sources were there for the streammux and attempted to build deepstream-test1 (which built successfully) and then after cd
in to that directory, tried running ./deepstream-test1-app ../../../../samples/streams/sample_720p.h264
and I got the following error
nvbufsurftransform:cuInit failed : 100
(gst-plugin-scanner:11519): GStreamer-WARNING **: 12:54:32.457: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:11521): GStreamer-WARNING **: 12:54:32.479: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
One element could not be created. Exiting.
I believe this should be a straightforward thing to do because there is no customisation involved.
but I understand this might be a unique case to us because we have a non standard setup (our AGX xavier is sending a RTSP stream on the same local network the dgx is on). We want to run that (receive that stream to begin with) in the deepstream container for prototyping and development.
as the common use case we assume that the DGX will be used to create the models which then get pruned and converted into target engine files that run on edge devices.
At this point we are just seeing what are the possibilities to finally end up with a more standard development pipeline and a deployment pipeline.
Cheers,
Ganindu.
