How to set up Deepstream 6.3 in a docker container
• Hardware Platform (Jetson / GPU) Nvidia Geforce RTX 2050
• DeepStream Version 6.3
• NVIDIA GPU Driver Version (valid for GPU only) 535.146.02
The following is my Dockerfile:
FROM nvcr.io/nvidia/deepstream:6.3-triton-multiarch
RUN apt-get update &&
apt-get install -y python3.8 python3.8-distutils &&
update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.8 1 &&
update-alternatives --set python3 /usr/bin/python3.8 &&
apt-get install -y python3.8-venv python3.8-dev &&
apt-get install -y python3-pip libgstreamer1.0-dev
apt-get install -y
python3.8
python3.8-distutils
libssl1.1
libssl-dev
libgstreamer1.0-0
gstreamer1.0-tools
gstreamer1.0-plugins-good
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly
gstreamer1.0-libav
libgstreamer-plugins-base1.0-dev
libgstrtspserver-1.0-0
libjansson4
libyaml-cpp-dev
RUN pip3 install opencv-python
RUN pip3 install torch
RUN pip3 install Pillow
RUN pip3 install torchvision
COPY . /app
WORKDIR /app
RUN pip3 install pyds
ENTRYPOINT [“python3”, “emotion.py”, “file:////home/isham/projects/deepstream_imentiv/stock1-short-wxsabew8_ttDDk6ra.mp4”, “frames_1”]
And when i run this, iam getting an error :
Frames will be saved in frames_1
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.069: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstde265.so’: libde265.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.082: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstx265.so’: libx265.so.179: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.189: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.193: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.193: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvpx.so’: libvpx.so.6: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.245: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.258: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.284: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstlibav.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.297: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.300: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.308: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.318: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.323: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.326: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.327: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.329: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.330: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.331: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.653: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.655: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_xfer.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.656: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.657: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.658: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.659: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_videotestsrc.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.660: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpeg.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.660: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.661: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.663: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.673: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so’: libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:23): GStreamer-WARNING **: 07:14:03.715: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
Creating Pipeline
Creating streamux
Unable to create NvStreamMux
File “emotion.py”, line 578, in
sys.exit(main(sys.argv))
File “emotion.py”, line 434, in main
pipeline.add(streammux)
TypeError: Argument 1 does not allow None as a value
Iam able to run the same in deespstream without docker and getting required output,but when i tried this in Docker method it doesn’t work.
1.install nvidia-container-toolkit in host via the following link
2.Modify the dockerfile as follows
RUN apt-get install --reinstall -y gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly libavresample-dev libavresample4 libavutil-dev libavutil56 libavcodec-dev libavcodec58 libavformat-dev libavformat58 libavfilter7 libde265-dev libde265-0 libx264-155 libx265-179 libvpx6 libmpeg2encpp-2.1-0 libmpeg2-4 libmpg123-0
RUN apt-get install -y python3-gi python3-dev python3-gst-1.0 python-gi-dev libglib2.0-dev libglib2.0-dev-bin libgirepository1.0-dev libcairo2-dev
RUN wget https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/releases/download/v1.1.8/pyds-1.1.8-py3-none-linux_x86_64.whl && \
    pip3 install ./pyds-1.1.8-py3-none-linux_x86_64.whl
  1. run docker with --gpus all, Here is a general way.
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY "your image"
sorry, i didnt get you. what will be my image in the last command:
Did you specify the tag when building the image?
You can use the docker images command to view.
If not, you can replace image name with IMAGE ID
i think this method worked partially.
when i run
(base) isham@aspire5:~/projects/imentiv_deepstream$ sudo docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY deepstream
DeepStreamSDK 6.3.0
*** LICENSE AGREEMENT ***
By using this software you agree to fully comply with the terms and conditions
of the License Agreement. The License Agreement is located at
/opt/nvidia/deepstream/deepstream/LicenseAgreement.pdf. If you do not agree
to the terms and conditions of the License Agreement do not use the software.
== Triton Inference Server ==
NVIDIA Release 23.03 (build 56086596)
Triton Server Version 2.32.0
Copyright (c) 2018-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
root@aspire5:/app# nvidia-smi
Fri Dec 29 12:29:00 2023
| NVIDIA-SMI 535.146.02 Driver Version: 535.146.02 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2050 Off | 00000000:01:00.0 Off | N/A |
| N/A 50C P0 N/A / 30W | 7MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
root@aspire5:/app# python3 emotion.py file:////app/stock1-short-wxsabew8_ttDDk6ra.mp4 stock
Frames will be saved in stock
(gst-plugin-scanner:124): GStreamer-WARNING **: 12:30:30.785: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
1 : file:////app/stock1-short-wxsabew8_ttDDk6ra.mp4
Starting pipeline
Authorization required, but no authorization protocol specified
**PERF: {‘stream0’: 0.0}
after this, it freeze.
Allow external applications to connect to the host’s X display:
xhost +
