I’ve followed the instructions described here DetectNet_v2 - NVIDIA Docs but I’m getting errors trying to convert both TrafficCamNet | NVIDIA NGC and TAO Pretrained DetectNet V2 | NVIDIA NGC
strangely I get different error. For trafficcamnet
tao model detectnet_v2 export -m ./trafficcamnet/resnet18_trafficcamnet.tlt -o ./trafficcamnet/resnet18_trafficcamnet.onnx
I get the error
~/.tao_mounts.json wasn't found. Falling back to obtain mount points and docker configs from ~/.tao_mounts.json.
Please note that this will be deprecated going forward.
2023-12-06 13:19:08,449 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2023-12-06 13:19:08,511 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 361: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2023-12-06 13:19:08,550 [TAO Toolkit] [INFO] root 99: No mount points were found in the /home/omri/.tao_mounts.json file.
2023-12-06 13:19:08,550 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 267:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/omri/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
2023-12-06 13:19:08,550 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 275: Printing tty value True
2023-12-06 03:19:09.478620: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2023-12-06 03:19:09,507 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Using TensorFlow backend.
2023-12-06 03:19:10,272 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:10,291 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:10,293 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:11,195 [TAO Toolkit] [INFO] matplotlib.font_manager 1633: generated new fontManager
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:12,146 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:12,164 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:12,165 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:19:12,461 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.export.app 264: Saving exported model to ./trafficcamnet/resnet18_trafficcamnet.onnx
2023-12-06 03:19:12,461 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.export.keras_exporter 119: Setting the onnx export route to keras2onnx
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/export.py", line 42, in <module>
raise e
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/export.py", line 26, in <module>
launch_export(Exporter, backend="onnx")
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/export/app.py", line 323, in launch_export
run_export(Exporter, args, backend)
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/export/app.py", line 286, in run_export
exporter.set_keras_backend_dtype()
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/export/keras_exporter.py", line 132, in set_keras_backend_dtype
tmp_keras_file_name = get_decoded_filename(self.model_path,
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py", line 400, in get_decoded_filename
raise ValueError("Cannot find input file name.")
ValueError: Cannot find input file name.
Execution status: FAIL
2023-12-06 13:19:22,017 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 337: Stopping container.
and for
tao model detectnet_v2 export -m resnet18.hdf5 -o resnet18.onnx
The error is
2023-12-06 13:18:29,642 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2023-12-06 13:18:29,701 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 361: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2023-12-06 13:18:29,735 [TAO Toolkit] [INFO] root 99: No mount points were found in the /home/omri/.tao_mounts.json file.
2023-12-06 13:18:29,735 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 267:
terminal.
2023-12-06 13:18:29,735 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 275: Printing tty value True
2023-12-06 03:18:30.668258: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2023-12-06 03:18:30,697 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2023-12-06 03:18:31,467 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:18:31,486 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:18:31,488 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:18:32,392 [TAO Toolkit] [INFO] matplotlib.font_manager 1633: generated new fontManager
2023-12-06 03:18:33,358 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:18:33,375 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:18:33,377 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2023-12-06 03:18:33,680 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.export.app 264: Saving exported model to resnet18.onnx
2023-12-06 03:18:33,681 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.export.keras_exporter 119: Setting the onnx export route to keras2onnx
raise e
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/export/keras_exporter.py", line 134, in set_keras_backend_dtype
model_input_dtype = get_model_input_dtype(tmp_keras_file_name)
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/core/export/app.py", line 68, in get_model_input_dtype
with h5py.File(keras_hdf5_file, mode="r") as f:
File "/usr/local/lib/python3.8/dist-packages/h5py/_hl/files.py", line 312, in __init__
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File "/usr/local/lib/python3.8/dist-packages/h5py/_hl/files.py", line 142, in make_fid
fid = h5f.open(name, flags, fapl=fapl)
File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
File "h5py/h5f.pyx", line 78, in h5py.h5f.open
OSError: Unable to open file (unable to open file: name = 'resnet18.hdf5', errno = 2, error message = 'No such file or directory', flags = 0, o_flags = 0)
2023-12-06 13:18:38,332 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 337: Stopping container.
I’ve checked that both files have the correct path
