I have replaced nvidia with a competitors one to get system running, so I can not generate now with Your skript the logs You asks. But I can provide the logs from System and on request more information. Issue accourse after upgrade from fedora 33 to 34.
I use NVIDIA GPU GeForce GTX 1660 (TU116-A) at PCI:45:0:0 (GPU-0)
tested with this drivers:
NVIDIA-Linux-x86_64-465.24.02
NVIDIA-Linux-x86_64-465.27
[drm:__nv_drm_gem_nvkms_memory_prime_get_sg_table [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00002d00] Failed to get memory pages for NvKmsKapiMemory 0x00000000bcbe86fe
BUG: kernel NULL pointer dereference, address: 000000000000000c
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 0 P4D 0
Oops: 0000 [#1] SMP NOPTI
CPU: 6 PID: 2312 Comm: gnome-shell Tainted: P OE 5.11.16-300.fc34.x86_64 #1
Hardware name: Micro-Star International Co., Ltd. MS-7C35/MEG X570 UNIFY (MS-7C35), BIOS A.80 01/22/2021
RIP: 0010:drm_gem_map_dma_buf+0x3f/0xb0 [drm]
Code: 00 00 83 fe 03 74 6d 48 8b 87 40 01 00 00 48 8b 40 38 48 85 c0 74 6f 41 89 f5 e8 5c 8d 8f cc 49 89 c4 48 3d 00 f0 ff ff 77 21 <8b> 50 0c 48 8b 7b 08 41 b8 20 00 00 00 44 89 e9 48 8b 30 e8 d9 70
RSP: 0018:ffffb9b3c70afcf8 EFLAGS: 00010207
RAX: 0000000000000000 RBX: ffff9bd8a423b5a0 RCX: 0000000000000000
RDX: ffff9bdf5eba6ba0 RSI: ffff9bdf5eb98ac0 RDI: ffff9bdf5eb98ac0
RBP: ffff9bd8a423b5a0 R08: 0000000000000000 R09: ffffb9b3c70afa98
R10: ffffb9b3c70afa90 R11: ffffffff8db44f08 R12: 0000000000000000
R13: 0000000000000000 R14: ffff9bd880efc000 R15: ffff9bd840fefdd8
FS: 00007fc5f2873d80(0000) GS:ffff9bdf5eb80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 000000000000000c CR3: 00000001961b8000 CR4: 0000000000350ee0
Call Trace:
dma_buf_map_attachment+0x7e/0xf0
drm_gem_prime_import_dev+0x64/0x150 [drm]
drm_gem_prime_fd_to_handle+0x196/0x1d0 [drm]
? drm_prime_destroy_file_private+0x20/0x20 [drm]
drm_ioctl_kernel+0x86/0xd0 [drm]
drm_ioctl+0x20f/0x3c0 [drm]
radeon_drm_ioctl+0x49/0x80 [radeon]
__x64_sys_ioctl+0x82/0xb0
do_syscall_64+0x33/0x40
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7fc5f6a8c4eb
Code: ff ff ff 85 c0 79 9b 49 c7 c4 ff ff ff ff 5b 5d 4c 89 e0 41 5c c3 66 0f 1f 84 00 00 00 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 55 b9 0c 00 f7 d8 64 89 01 48
RSP: 002b:00007ffcd26af708 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00007ffcd26af74c RCX: 00007fc5f6a8c4eb
RDX: 00007ffcd26af74c RSI: 00000000c00c642e RDI: 0000000000000012
RBP: 00000000c00c642e R08: 00007ffcd26af7f0 R09: 00007fc5f6b58a00
R10: 0000000000000000 R11: 0000000000000246 R12: 000056553779d410
R13: 0000000000000012 R14: 0000000000100000 R15: 00007ffcd26aff00
Modules linked in: rfcomm snd_seq_dummy snd_hrtimer xt_CHECKSUM xt_MASQUERADE xt_conntrack ipt_REJECT nf_reject_ipv4 ip6table_mangle ip6table_nat ip6table_filter ip6_tables iptable_mangle iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_filter bridge stp llc cmac bnep sunrpc squashfs vfat fat loop intel_rapl_msr intel_rapl_common usblp snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio iwlmvm snd_hda_codec_hdmi snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation mac80211 snd_soc_core snd_compress snd_pcm_dmaengine edac_mce_amd soundwire_cadence libarc4 snd_hda_codec kvm_amd snd_hda_core ucsi_ccg ccp ac97_bus snd_seq btusb typec_ucsi typec iwlwifi snd_seq_device btrtl snd_hwdep snd_pcm btbcm kvm btintel snd_timer irqbypass bluetooth rapl snd cfg80211 k10temp i2c_piix4 joydev soundcore pcspkr wmi_bmof ecdh_generic i2c_nvidia_gpu ecc rfkill binfmt_misc zram ip_tables dm_crypt hid_logitech_hidpp nvidia_drm(POE)
nvidia_modeset(POE) nvidia(POE) hid_logitech_dj radeon i2c_algo_bit drm_ttm_helper ttm drm_kms_helper crct10dif_pclmul crc32_pclmul crc32c_intel cec nvme mxm_wmi drm ghash_clmulni_intel sp5100_tco e1000e r8169 nvme_core wmi pinctrl_amd fuse
—[ end trace 186b69729a9a88bc ]—
5.11.16-300.fc34.x86_64 …ernel01.iad2.fedoraproject.org) (gcc (GCC) 11.0.1 20210324 (Red Hat 11.0.1-0), GNU ld version 2.35.1-41.fc34) #1 SMP Wed Apr 21 13:18:33 UTC 2021
journal_gnome-shell.txt (12.9 KB)
journal_nvidia.txt (3.5 MB)
nvidia_issue_fc34.txt (17.6 KB)
