Erros message nvidia [drm:nvidia_drm_gem_import_nvkms_memory [nvidia_drm]
When I enable modesetting with nvidia 375.20 I get this error message in dmesg
[drm:nvidia_drm_gem_import_nvkms_memory [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to import NVKMS memory to GEM object
I have Fedora 25 and I am using Xorg.
nvidia-bug-report.log.gz (95.2 KB)
dmesg shows
[ 59.221776] [drm:nvidia_drm_gem_prime_fence_init [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fencing init: 0x00000004
[ 59.222613] [drm:nvidia_drm_gem_prime_fence_init [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fencing init: 0x00000004
[ 59.222971] [drm:nvidia_drm_gem_prime_fence_init [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fencing init: 0x00000004
I believe this is related to GBM and EGL handling on Wayland. Recent gnome uses only Wayland by default. I am on Debian (Sid), so everything is up to date.
nvidia-bug-report.log.gz (106 KB)
Do you run latest kernel (staging) any chance?
There was recently big refactoring around fenceing infrastructure that might cause module ABIs break,
notably fence_ functions becoming dma_fence_ functions along with some other minor tweaks.
Not sure why it wouldn’t whine about missing symbols properly, but I guess it might be the case.
My kernel is 4.8.0, which is stable, the mainline kernel is 4.9.
I attached nvidia-bug-report.log.gz with all information on my environment.
Still present with nvidia 375.26 and kernel kernel-4.8.14-300.fc25.x86_64. Kernel mode setting is enabled.
[ 19.055857] [drm:nvidia_drm_gem_import_nvkms_memory [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to import NVKMS memory to GEM object
[ 19.127648] [drm:nvidia_drm_gem_import_nvkms_memory [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to import NVKMS memory to GEM object
[ 19.129347] [drm:nvidia_drm_gem_import_nvkms_memory [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to import NVKMS memory to GEM object
same here, but in this post
https://devtalk.nvidia.com/default/topic/952109/linux/kms-only-in-one-card-in-dual-card-config/post/5064084/#5064084
Same here:
[12872.942387] [drm:nvidia_drm_gem_prime_fence_force_signal [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000300] Failed to lookup gem object for fence attach: 0x00000004
[12873.073506] [drm:nvidia_drm_gem_prime_fence_force_signal [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000300] Failed to lookup gem object for fence attach: 0x00000004
[12873.074589] [drm:nvidia_drm_gem_prime_fence_force_signal [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000300] Failed to lookup gem object for fence attach: 0x00000004
Linux ERD228-01 4.13.0-36-generic #40~16.04.1-Ubuntu SMP Fri Feb 16 23:25:58 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Seen on fedora 31 w/ nvidia 440.44 kernel 5.3.16-300.fc31.x86_64
[ 2433.533786] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000004
[ 2433.559944] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000004
[ 2433.560694] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000004
[ 2433.561094] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000004
Still exist using kernel 5.7.11-200.fc32.x86_64 (Fedora Workstation 32)
$ nvidia-installer --version
nvidia-installer: version 450.57
$ rpm -qa | grep nvidia
nvidia-settings-450.57-1.fc32.x86_64
nvidia-driver-NVML-450.57-1.fc32.x86_64
nvidia-texture-tools-2.0.8-22.fc32.x86_64
nvidia-kmod-common-450.57-1.fc32.noarch
nvidia-driver-cuda-libs-450.57-1.fc32.x86_64
nvidia-libXNVCtrl-450.57-1.fc32.x86_64
nvidia-xconfig-450.57-1.fc32.x86_64
nvidia-driver-450.57-1.fc32.x86_64
nvidia-query-resource-opengl-1.0.0-7.fc32.x86_64
nvidia-driver-NvFBCOpenGL-450.57-1.fc32.x86_64
nvidia-persistenced-450.57-1.fc32.x86_64
nvidia-query-resource-opengl-lib-1.0.0-7.fc32.x86_64
nvidia-driver-devel-450.57-1.fc32.x86_64
akmod-nvidia-450.57-1.fc32.x86_64
nvidia-driver-libs-450.57-1.fc32.x86_64
nvidia-modprobe-450.57-1.fc32.x86_64
nvidia-texture-tools-devel-2.0.8-22.fc32.x86_64
kmod-nvidia-5.7.11-200.fc32.x86_64-450.57-1.fc32.x86_64
nvidia-driver-cuda-450.57-1.fc32.x86_64
$ cat /var/log/messages | grep 0x00000006
Aug 5 09:01:43 fcw32 kernel: [drm:nv_drm_dumb_map_offset [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for mapping: 0x00000006
Aug 5 09:02:48 fcw32 kernel: [drm:nv_drm_dumb_map_offset [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for mapping: 0x00000006
Aug 5 09:08:27 fcw32 kernel: [drm:nv_drm_dumb_map_offset [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for mapping: 0x00000006
Is there any workaround?
My external monitor wasn’t able to switch on but detected using xrandr. Just blank and could not enable.
$ xrandr --output DP-1-9 --mode 1280x1024 --crtc 4 --verbose
crtc 4: 1280x1024 75.02 +0+0 “DP-1-9”
xrandr: Configure crtc 4 failed
tried with other crtc number but still failed.
Facing with the exact same error under Ubuntu 18.04.5 as well. Any updates regarding this issue?
I’ve removed this nvidia driver package :
and change to xorg nvidia package :
xorg-x11-drv-nvidia-devel-450.66-1.fc32.x86_64
nvidia-libXNVCtrl-devel-450.66-1.fc32.x86_64
xorg-x11-drv-nvidia-cuda-libs-450.66-1.fc32.x86_64
xorg-x11-drv-nvidia-libs-450.66-1.fc32.x86_64
xorg-x11-drv-nvidia-kmodsrc-450.66-1.fc32.x86_64
The error seems to be gone and I can use my external monitor. Attaching 3 external monitors with docking.
Hmm, looks like similar problem here I got too.
Driver Version: 450.119.03. GeForce GTX 1050.
[   59.030031] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x0000000a
[   59.030035] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x0000001f
[   59.030037] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000016
[   59.030039] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000012
[   59.030041] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x0000002a
[   59.030043] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000004
[   59.030045] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000020
[   59.030047] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000022
[   59.030048] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000021
[   59.030193] [drm:nv_drm_gem_fence_attach_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for fence attach: 0x00000004
