Following is the info from terminal.
ONNX IR version: 0.0.4
Opset version: 8
Producer name: OnnxMLTools
Producer version: 1.3.2
Domain: onnxml
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.4) than this parser was built against (0.0.3).
While parsing node number 3 [Pad → “legacy_padded_tensor”]:
— Begin node —
input: “eltwise1”
output: “legacy_padded_tensor”
op_type: “Pad”
attribute {
ints: 0
ints: 0
ints: 0
ints: 0
ints: 0
ints: 0
ints: 0
ints: 0
type: INTS
attribute {
f: -3.4028235e+38
type: FLOAT
domain: “”
— End node —
ERROR: C:\p4sw\sw\gpgpu\MachineLearning\DIT\release\5.0\parsers\onnxOpenSource\builtin_op_importers.cpp:1116 In function importPad:
[8] Assertion failed: mode == “constant” && value == 0
ERROR: failed to parse onnx file
I am using onnx model converted from caffe model. (TensorRT doesn’t support caffe slice, so I couldn’t use caffe model directly.)
Original caffe model proto: Conv → Slice → Eltwise → Pooling → ..
Using onnxmltools it converted to: Conv → Split → Max → Pad → MaxPool → …
When infer Pad layer, above error occured.
Hope any suggestions.
