Environment
vitual environment from Anaconda:
- python 3.7.5
- pytorch 1.3.1
- tensorrt 6.0.1.5
- onnx 1.6.0
- protobuf 3.9.2
with
- Ubuntu 16.04
- RTX2080TI on driver 410.79
- CUDA 10.0
- cudnn 7.6.3
Problem Description
1. Pytorch2ONNX
Use default opset 9 to convert. Some warnings occur:
TracerWarning: torch.tensor results are registered as constants in the trace. You can safely ignore this warning if you use this function to create tensors out of constant variables that would be the same every time you call this function. In any other case, this might cause the trace to be incorrect.
x_size = torch.tensor(x.shape)
TracerWarning: Converting a tensor to a Python integer might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
UserWarning: You are trying to export the model with onnx:Upsample for ONNX opset version 9. This operator might cause results to not match the expected results by PyTorch.
ONNX's Upsample/Resize operator did not match Pytorch's Interpolation until opset 11. Attributes to determine how to transform the input were added in onnx:Resize in opset 11 to support Pytorch's behavior (like coordinate_transformation_mode and nearest_mode).
We recommend using opset 11 and above for models using this operator.
"" + str(_export_onnx_opset_version) + ". "
Anyway, it might convert successfully.
onnx.checker.check_model()
passed, and model’s structure, visualized by Netron, looks fine to me.
2. ONNX2TRT
onnx_file.seek(0)
if not parser.parse(onnx_file.read()):
print("Error:", parser.get_error(0))
onnx_file.close()
The aboved code I used to parse the onnx model. It seems that TRT parser could parse the onnx model. When I log TRT output by setting trt.Logger(trt.Logger.INFO), TRT could correctly output my onnx model’s content, like
[TensorRT] INFO: 292:Constant -> (4)
[TensorRT] INFO: 293:Upsample -> (1, 3, -1, -1)
[TensorRT] INFO: 294:Conv -> (1, 64, -1, -1)
[TensorRT] INFO: 295:BatchNormalization -> (1, 64, -1, -1)
[TensorRT] INFO: 296:Relu -> (1, 64, -1, -1)
[TensorRT] INFO: 297:MaxPool -> (1, 64, -1, -1)
[TensorRT] INFO: 298:Conv -> (1, 64, -1, -1)
[TensorRT] INFO: 299:BatchNormalization -> (1, 64, -1, -1)
[TensorRT] INFO: 300:Relu -> (1, 64, -1, -1)
[TensorRT] INFO: 301:Conv -> (1, 64, -1, -1)
[TensorRT] INFO: 302:BatchNormalization -> (1, 64, -1, -1)
[TensorRT] INFO: 303:Relu -> (1, 64, -1, -1)
[TensorRT] INFO: 304:Conv -> (1, 256, -1, -1)
[TensorRT] INFO: 305:BatchNormalization -> (1, 256, -1, -1)
[TensorRT] INFO: 306:Conv -> (1, 256, -1, -1)
[TensorRT] INFO: 307:BatchNormalization -> (1, 256, -1, -1)
Saddly, TRT internal error accurs. I totally have no idea about this error.
[TensorRT] INTERNAL ERROR: Assertion failed: validateInputsCutensor(src, dst)
../rtSafe/cuda/cutensorReformat.cpp:226
Aborting...
[TensorRT] ERROR: ../rtSafe/cuda/cutensorReformat.cpp (226) - Assertion Error in executeCutensor: 0 (validateInputsCutensor(src, dst))
Looking forward to your kind response.
