Description
When importing an ONNX model that has a constant boolean tensor (in a form of an initializer), the slicing over this tensor with a step size >1 is not performed correctly.
The issue seems to be specific to constant boolean and step size > 1. I tried removing any of them and the problem went away.
Code Examples
The following code slices a tensor of shape [4,4,4] with step size of 2, i.e., tensor[0:4:2,:,:], but the result is incorrect compared to those of PyTorch and NumPy.
import torch
import onnx
import numpy as np
def run_trt(inputs, input_names, y_tch):
# assume output names are ["o0"]
# copy-paste from https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/index.html#import_model_python
import tensorrt as trt
logger = trt.Logger(trt.Logger.WARNING)
builder = trt.Builder(logger)
network = builder.create_network(
1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH))
parser = trt.OnnxParser(network, logger)
success = parser.parse_from_file("output.onnx")
for idx in range(parser.num_errors):
print(parser.get_error(idx))
assert success
config = builder.create_builder_config()
config.set_memory_pool_limit(
trt.MemoryPoolType.WORKSPACE, 1 << 20) # 1 MiB
serialized_engine = builder.build_serialized_network(network, config)
runtime = trt.Runtime(logger)
engine = runtime.deserialize_cuda_engine(serialized_engine)
context = engine.create_execution_context()
buffers = [None] * engine.num_bindings
inputs_cuda = [x.cuda() for x in inputs]
for x_cuda, name in zip(inputs_cuda, input_names):
input_idx = engine[name]
buffers[input_idx] = x_cuda.data_ptr()
y_cuda = torch.zeros_like(torch.from_numpy(y_tch)).cuda()
output_idx = engine['o0']
buffers[output_idx] = y_cuda.data_ptr()
context.execute_v2(buffers)
return y_cuda.cpu().numpy()
def main():
class Model(torch.nn.Module):
def __init__(self) -> None:
super().__init__()
self.b = torch.rand(size=[4, 4, 4]) > 0.5
self.b = torch.nn.Parameter(self.b, requires_grad=False)
def forward(self):
y = self.b[0:4:2, :, :]
# y = torch.where(y, torch.zeros_like(x), x)
return y
# inputs = (torch.rand(size=[2, 4, 4]), )
inputs = ()
model = Model()
y_tch = model(*inputs).numpy()
# input_names = ["i0"]
input_names = []
torch.onnx.export(model, inputs, "output.onnx", verbose=True,
input_names=input_names, output_names=["o0"], opset_version=14)
onnx.checker.check_model("output.onnx", full_check=True)
y_trt = run_trt(inputs, input_names, y_tch)
np.testing.assert_allclose(y_tch, model.b.numpy()[0:4:2, :, :],
err_msg='Torch v.s. NumPy failed')
np.testing.assert_allclose(y_tch, y_trt, err_msg='Torch v.s. TRT failed')
main()
The visualization of the model:
The output:
AssertionError:
Not equal to tolerance rtol=1e-07, atol=0
Mismatched elements: 14 / 32 (43.8%)
x: array([[[False, True, False, True],
[ True, False, False, True],
[ True, False, True, True],...
y: array([[[ True, True, True, True],
[ True, True, False, False],
[ True, True, True, True],...
Note that this model doesn’t have any inputs because it is minimized for bug reproducing. It will still trigger the same bug if more layers/inputs are added, for example, we can change the code to:
def main():
super().__init__()
def forward(self, x):
return y
# inputs = ()
model = Model()
# input_names = []
# np.testing.assert_allclose(y_tch, model.b.numpy()[0:4:2, :, :],
# err_msg='Torch v.s. NumPy failed')
The model looks like:
And the error:
AssertionError:
Mismatched elements: 15 / 32 (46.9%)
Max absolute difference: 0.98568505
Max relative difference: 1.
x: array([[[0. , 0.477325, 0.983834, 0. ],
[0.829976, 0. , 0.290815, 0. ],
[0. , 0. , 0. , 0.343628],...
y: array([[[0. , 0. , 0. , 0. ],
[0. , 0. , 0.290815, 0.773806],
[0. , 0. , 0. , 0. ],...
Environment
TensorRT Version: 8.4.0.6
GPU Type: RTX2080
Nvidia Driver Version: 495.29.05
CUDA Version: 11.5
CUDNN Version: 8.3.0
Operating System + Version: Ubuntu 1804
Python Version (if applicable): 3.8
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.11.0
Baremetal or Container (if container which image + tag): Container built on top of nvcr.io/nvidia/tensorrt@21.11-py3
Relevant Files
ONNX file of the first model
output.onnx.zip (1.0 KB)
Steps To Reproduce
Run the provided python script.
Full error log (of the first code snippet)
/workspace/.venv/trt-8.4.0.6/lib/python3.8/site-packages/torch/onnx/utils.py:363: UserWarning: No input args
warnings.warn("No input args")
Warning: Constant folding - Only steps=1 can be constant folded for opset >= 10 onnx::Slice op. Constant folding not applied.
graph(%b : Bool(4, 4, 4, strides=[16, 4, 1], requires_grad=0, device=cpu)):
%1 : Long(1, strides=[1], device=cpu) = onnx::Constant[value={0}]() # test.py:444:0
%2 : Long(1, strides=[1], device=cpu) = onnx::Constant[value={0}]() # test.py:444:0
%3 : Long(1, strides=[1], device=cpu) = onnx::Constant[value={4}]() # test.py:444:0
%4 : Long(1, strides=[1], device=cpu) = onnx::Constant[value={2}]() # test.py:444:0
%o0 : Bool(2, 4, 4, strides=[32, 4, 1], requires_grad=0, device=cpu) = onnx::Slice(%b, %2, %3, %1, %4) # test.py:444:0
return (%o0)
[05/27/2022-17:11:17] [TRT] [W] onnx2trt_utils.cpp:365: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[05/27/2022-17:11:18] [TRT] [W] TensorRT was linked against cuBLAS/cuBLAS LT 11.8.0 but loaded cuBLAS/cuBLAS LT 11.7.3
[05/27/2022-17:11:18] [TRT] [W] TensorRT was linked against cuDNN 8.3.2 but loaded cuDNN 8.3.0
File "test.py", line 464, in <module>
main()
File "test.py", line 461, in main
File "/workspace/.venv/trt-8.4.0.6/lib/python3.8/site-packages/numpy/testing/_private/utils.py", line 1530, in assert_allclose
assert_array_compare(compare, actual, desired, err_msg=str(err_msg),
File "/workspace/.venv/trt-8.4.0.6/lib/python3.8/site-packages/numpy/testing/_private/utils.py", line 844, in assert_array_compare
raise AssertionError(msg)
AssertionError:
Mismatched elements: 17 / 32 (53.1%)
x: array([[[False, True, True, True],
[False, True, True, True],...
