Thank you for your reply. There are still problems following your steps.
I had tried to check the onnx model and it runs well.
According to your request, this is the complete log collected:
&&&& RUNNING TensorRT.trtexec [TensorRT v8001] # ./trtexec --onnx=../data/iharm/iharm_onnx.onnx --verbose
[05/16/2022-11:14:32] [I] === Model Options ===
[05/16/2022-11:14:32] [I] Format: ONNX
[05/16/2022-11:14:32] [I] Model: ../data/iharm/iharm_onnx.onnx
[05/16/2022-11:14:32] [I] Output:
[05/16/2022-11:14:32] [I] === Build Options ===
[05/16/2022-11:14:32] [I] Max batch: explicit
[05/16/2022-11:14:32] [I] Workspace: 16 MiB
[05/16/2022-11:14:32] [I] minTiming: 1
[05/16/2022-11:14:32] [I] avgTiming: 8
[05/16/2022-11:14:32] [I] Precision: FP32
[05/16/2022-11:14:32] [I] Calibration:
[05/16/2022-11:14:32] [I] Refit: Disabled
[05/16/2022-11:14:32] [I] Sparsity: Disabled
[05/16/2022-11:14:32] [I] Safe mode: Disabled
[05/16/2022-11:14:32] [I] Restricted mode: Disabled
[05/16/2022-11:14:32] [I] Save engine:
[05/16/2022-11:14:32] [I] Load engine:
[05/16/2022-11:14:32] [I] NVTX verbosity: 0
[05/16/2022-11:14:32] [I] Tactic sources: Using default tactic sources
[05/16/2022-11:14:32] [I] timingCacheMode: local
[05/16/2022-11:14:32] [I] timingCacheFile:
[05/16/2022-11:14:32] [I] Input(s)s format: fp32:CHW
[05/16/2022-11:14:32] [I] Output(s)s format: fp32:CHW
[05/16/2022-11:14:32] [I] Input build shapes: model
[05/16/2022-11:14:32] [I] Input calibration shapes: model
[05/16/2022-11:14:32] [I] === System Options ===
[05/16/2022-11:14:32] [I] Device: 0
[05/16/2022-11:14:32] [I] DLACore:
[05/16/2022-11:14:32] [I] Plugins:
[05/16/2022-11:14:32] [I] === Inference Options ===
[05/16/2022-11:14:32] [I] Batch: Explicit
[05/16/2022-11:14:32] [I] Input inference shapes: model
[05/16/2022-11:14:32] [I] Iterations: 10
[05/16/2022-11:14:32] [I] Duration: 3s (+ 200ms warm up)
[05/16/2022-11:14:32] [I] Sleep time: 0ms
[05/16/2022-11:14:32] [I] Streams: 1
[05/16/2022-11:14:32] [I] ExposeDMA: Disabled
[05/16/2022-11:14:32] [I] Data transfers: Enabled
[05/16/2022-11:14:32] [I] Spin-wait: Disabled
[05/16/2022-11:14:32] [I] Multithreading: Disabled
[05/16/2022-11:14:32] [I] CUDA Graph: Disabled
[05/16/2022-11:14:32] [I] Separate profiling: Disabled
[05/16/2022-11:14:32] [I] Time Deserialize: Disabled
[05/16/2022-11:14:32] [I] Time Refit: Disabled
[05/16/2022-11:14:32] [I] Skip inference: Disabled
[05/16/2022-11:14:32] [I] Inputs:
[05/16/2022-11:14:32] [I] === Reporting Options ===
[05/16/2022-11:14:32] [I] Verbose: Enabled
[05/16/2022-11:14:32] [I] Averages: 10 inferences
[05/16/2022-11:14:32] [I] Percentile: 99
[05/16/2022-11:14:32] [I] Dump refittable layers:Disabled
[05/16/2022-11:14:32] [I] Dump output: Disabled
[05/16/2022-11:14:32] [I] Profile: Disabled
[05/16/2022-11:14:32] [I] Export timing to JSON file:
[05/16/2022-11:14:32] [I] Export output to JSON file:
[05/16/2022-11:14:32] [I] Export profile to JSON file:
[05/16/2022-11:14:32] [I] === Device Information ===
[05/16/2022-11:14:32] [I] Selected Device: Xavier
[05/16/2022-11:14:32] [I] Compute Capability: 7.2
[05/16/2022-11:14:32] [I] SMs: 8
[05/16/2022-11:14:32] [I] Compute Clock Rate: 1.377 GHz
[05/16/2022-11:14:32] [I] Device Global Memory: 15816 MiB
[05/16/2022-11:14:32] [I] Shared Memory per SM: 96 KiB
[05/16/2022-11:14:32] [I] Memory Bus Width: 256 bits (ECC disabled)
[05/16/2022-11:14:32] [I] Memory Clock Rate: 1.377 GHz
[05/16/2022-11:14:32] [I] TensorRT version: 8001
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::ScatterND version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::Proposal version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::Split version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[05/16/2022-11:14:32] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[05/16/2022-11:14:34] [I] [TRT] [MemUsageChange] Init CUDA: CPU +354, GPU +0, now: CPU 372, GPU 5115 (MiB)
[05/16/2022-11:14:34] [I] Start parsing network model
[05/16/2022-11:14:34] [I] [TRT] ----------------------------------------------------------------
[05/16/2022-11:14:34] [I] [TRT] Input filename: ../data/iharm/iharm_onnx.onnx
[05/16/2022-11:14:34] [I] [TRT] ONNX IR version: 0.0.6
[05/16/2022-11:14:34] [I] [TRT] Opset version: 12
[05/16/2022-11:14:34] [I] [TRT] Producer name: pytorch
[05/16/2022-11:14:34] [I] [TRT] Producer version: 1.7
[05/16/2022-11:14:34] [I] [TRT] Domain:
[05/16/2022-11:14:34] [I] [TRT] Model version: 0
[05/16/2022-11:14:34] [I] [TRT] Doc string:
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::GridAnchorRect_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::ScatterND version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::BatchedNMSDynamic_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::EfficientNMS_ONNX_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::EfficientNMS_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::Split version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[05/16/2022-11:14:34] [V] [TRT] Adding network input: input_img with dtype: float32, dimensions: (1, 3, 1080, 1920)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: input_img for ONNX tensor: input_img
[05/16/2022-11:14:34] [V] [TRT] Adding network input: input_mask with dtype: float32, dimensions: (1, 1, 1080, 1920)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: input_mask for ONNX tensor: input_mask
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 388
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 389
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 391
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 392
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 394
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 395
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 397
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 398
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 400
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 401
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 403
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 404
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 406
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 407
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 409
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 410
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 412
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 413
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 415
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 416
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 418
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 419
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 421
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 422
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 424
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 425
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 427
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 428
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 429
[05/16/2022-11:14:34] [W] [TRT] onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 430
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 431
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 432
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 433
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 434
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 435
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 436
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: 437
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: dbp1.conv_attention.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: dbp1.conv_attention.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: dbp1.to_rgb.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: dbp1.to_rgb.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.conv_attention.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.conv_attention.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.to_rgb.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.to_rgb.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.0.upconv.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.0.upconv.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.1.upconv.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.1.upconv.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.background_gate.attention_transform.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.background_gate.attention_transform.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.background_gate.attention_transform.2.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.background_gate.attention_transform.2.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.foreground_gate.attention_transform.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.foreground_gate.attention_transform.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.foreground_gate.attention_transform.2.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.foreground_gate.attention_transform.2.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.mask_blurring.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.mix_gate.attention_transform.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.mix_gate.attention_transform.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.mix_gate.attention_transform.2.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.attention.mix_gate.attention_transform.2.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.upconv.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: decoder.up_blocks.2.upconv.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block0.convs.block.0.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block0.convs.block.0.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block0.convs.block.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block0.convs.block.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block1.convs.block.0.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block1.convs.block.0.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block1.convs.block.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Importing initializer: encoder.block1.convs.block.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_0 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_0 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_0 [Constant] outputs: [141 -> (1, 3, 1, 1)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Sub_1 [Sub]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: input_img
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 141
[05/16/2022-11:14:34] [V] [TRT] Sub_1 [Sub] inputs: [input_img -> (1, 3, 1080, 1920)[FLOAT]], [141 -> (1, 3, 1, 1)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: 141 for ONNX node: 141
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Sub_1 for ONNX node: Sub_1
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 142 for ONNX tensor: 142
[05/16/2022-11:14:34] [V] [TRT] Sub_1 [Sub] outputs: [142 -> (1, 3, 1080, 1920)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_2 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_2 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_2 [Constant] outputs: [143 -> (1, 3, 1, 1)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Div_3 [Div]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 142
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 143
[05/16/2022-11:14:34] [V] [TRT] Div_3 [Div] inputs: [142 -> (1, 3, 1080, 1920)[FLOAT]], [143 -> (1, 3, 1, 1)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: 143 for ONNX node: 143
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Div_3 for ONNX node: Div_3
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 144 for ONNX tensor: 144
[05/16/2022-11:14:34] [V] [TRT] Div_3 [Div] outputs: [144 -> (1, 3, 1080, 1920)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_4 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 144
[05/16/2022-11:14:34] [V] [TRT] Searching for input: input_mask
[05/16/2022-11:14:34] [V] [TRT] Concat_4 [Concat] inputs: [144 -> (1, 3, 1080, 1920)[FLOAT]], [input_mask -> (1, 1, 1080, 1920)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_4 for ONNX node: Concat_4
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 145 for ONNX tensor: 145
[05/16/2022-11:14:34] [V] [TRT] Concat_4 [Concat] outputs: [145 -> (1, 4, 1080, 1920)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_5 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_5 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_5 [Constant] outputs: [147 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Shape_6 [Shape]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 145
[05/16/2022-11:14:34] [V] [TRT] Shape_6 [Shape] inputs: [145 -> (1, 4, 1080, 1920)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Shape_6 for ONNX node: Shape_6
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 148 for ONNX tensor: 148
[05/16/2022-11:14:34] [V] [TRT] Shape_6 [Shape] outputs: [148 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_7 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_7 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_7 [Constant] outputs: [149 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_8 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_8 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_8 [Constant] outputs: [150 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_9 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_9 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_9 [Constant] outputs: [151 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Slice_10 [Slice]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 148
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 150
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 151
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 149
[05/16/2022-11:14:34] [V] [TRT] Slice_10 [Slice] inputs: [148 -> (4)[INT32]], [150 -> (1)[INT32]], [151 -> (1)[INT32]], [149 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Slice_10 for ONNX node: Slice_10
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 152 for ONNX tensor: 152
[05/16/2022-11:14:34] [V] [TRT] Slice_10 [Slice] outputs: [152 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_11 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 152
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 429
[05/16/2022-11:14:34] [V] [TRT] Concat_11 [Concat] inputs: [152 -> (2)[INT32]], [429 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: 429 for ONNX node: 429
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_11 for ONNX node: Concat_11
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 154 for ONNX tensor: 154
[05/16/2022-11:14:34] [V] [TRT] Concat_11 [Concat] outputs: [154 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_12 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_12 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_12 [Constant] outputs: [155 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Resize_13 [Resize]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 147
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 155
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 154
[05/16/2022-11:14:34] [V] [TRT] Resize_13 [Resize] inputs: [145 -> (1, 4, 1080, 1920)[FLOAT]], [147 -> ()[FLOAT]], [155 -> ()[FLOAT]], [154 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Resize_13 for ONNX node: Resize_13
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 156 for ONNX tensor: 156
[05/16/2022-11:14:34] [V] [TRT] Resize_13 [Resize] outputs: [156 -> (1, 4, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_14 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 156
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block0.convs.block.0.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block0.convs.block.0.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_14 [Conv] inputs: [156 -> (1, 4, 512, 512)[FLOAT]], [encoder.block0.convs.block.0.block.0.weight -> (32, 4, 3, 3)[FLOAT]], [encoder.block0.convs.block.0.block.0.bias -> (32)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 4, 512, 512)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_14 for ONNX node: Conv_14
[05/16/2022-11:14:34] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 32
[05/16/2022-11:14:34] [V] [TRT] Convolution output dimensions: (1, 32, 512, 512)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 157 for ONNX tensor: 157
[05/16/2022-11:14:34] [V] [TRT] Conv_14 [Conv] outputs: [157 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_15 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 157
[05/16/2022-11:14:34] [V] [TRT] Relu_15 [Relu] inputs: [157 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_15 for ONNX node: Relu_15
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 158 for ONNX tensor: 158
[05/16/2022-11:14:34] [V] [TRT] Relu_15 [Relu] outputs: [158 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_16 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 158
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block0.convs.block.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block0.convs.block.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_16 [Conv] inputs: [158 -> (1, 32, 512, 512)[FLOAT]], [encoder.block0.convs.block.1.block.0.weight -> (32, 32, 3, 3)[FLOAT]], [encoder.block0.convs.block.1.block.0.bias -> (32)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 32, 512, 512)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_16 for ONNX node: Conv_16
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 159 for ONNX tensor: 159
[05/16/2022-11:14:34] [V] [TRT] Conv_16 [Conv] outputs: [159 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_17 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 159
[05/16/2022-11:14:34] [V] [TRT] Relu_17 [Relu] inputs: [159 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_17 for ONNX node: Relu_17
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 160 for ONNX tensor: 160
[05/16/2022-11:14:34] [V] [TRT] Relu_17 [Relu] outputs: [160 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: MaxPool_18 [MaxPool]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 160
[05/16/2022-11:14:34] [V] [TRT] MaxPool_18 [MaxPool] inputs: [160 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: MaxPool_18 for ONNX node: MaxPool_18
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 161 for ONNX tensor: 161
[05/16/2022-11:14:34] [V] [TRT] MaxPool_18 [MaxPool] outputs: [161 -> (1, 32, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_19 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 161
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block1.convs.block.0.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block1.convs.block.0.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_19 [Conv] inputs: [161 -> (1, 32, 256, 256)[FLOAT]], [encoder.block1.convs.block.0.block.0.weight -> (64, 32, 3, 3)[FLOAT]], [encoder.block1.convs.block.0.block.0.bias -> (64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 32, 256, 256)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_19 for ONNX node: Conv_19
[05/16/2022-11:14:34] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 64
[05/16/2022-11:14:34] [V] [TRT] Convolution output dimensions: (1, 64, 256, 256)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 162 for ONNX tensor: 162
[05/16/2022-11:14:34] [V] [TRT] Conv_19 [Conv] outputs: [162 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_20 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 162
[05/16/2022-11:14:34] [V] [TRT] Relu_20 [Relu] inputs: [162 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_20 for ONNX node: Relu_20
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 163 for ONNX tensor: 163
[05/16/2022-11:14:34] [V] [TRT] Relu_20 [Relu] outputs: [163 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_21 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 163
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block1.convs.block.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: encoder.block1.convs.block.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_21 [Conv] inputs: [163 -> (1, 64, 256, 256)[FLOAT]], [encoder.block1.convs.block.1.block.0.weight -> (64, 64, 3, 3)[FLOAT]], [encoder.block1.convs.block.1.block.0.bias -> (64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 64, 256, 256)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_21 for ONNX node: Conv_21
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 164 for ONNX tensor: 164
[05/16/2022-11:14:34] [V] [TRT] Conv_21 [Conv] outputs: [164 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_22 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 164
[05/16/2022-11:14:34] [V] [TRT] Relu_22 [Relu] inputs: [164 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_22 for ONNX node: Relu_22
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 165 for ONNX tensor: 165
[05/16/2022-11:14:34] [V] [TRT] Relu_22 [Relu] outputs: [165 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: MaxPool_23 [MaxPool]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 165
[05/16/2022-11:14:34] [V] [TRT] MaxPool_23 [MaxPool] inputs: [165 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: MaxPool_23 for ONNX node: MaxPool_23
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 166 for ONNX tensor: 166
[05/16/2022-11:14:34] [V] [TRT] MaxPool_23 [MaxPool] outputs: [166 -> (1, 64, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_24 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 166
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 388
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 389
[05/16/2022-11:14:34] [V] [TRT] Conv_24 [Conv] inputs: [166 -> (1, 64, 128, 128)[FLOAT]], [388 -> (128, 64, 3, 3)[FLOAT]], [389 -> (128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 64, 128, 128)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_24 for ONNX node: Conv_24
[05/16/2022-11:14:34] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 128
[05/16/2022-11:14:34] [V] [TRT] Convolution output dimensions: (1, 128, 128, 128)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 387 for ONNX tensor: 387
[05/16/2022-11:14:34] [V] [TRT] Conv_24 [Conv] outputs: [387 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_25 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 387
[05/16/2022-11:14:34] [V] [TRT] Relu_25 [Relu] inputs: [387 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_25 for ONNX node: Relu_25
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 169 for ONNX tensor: 169
[05/16/2022-11:14:34] [V] [TRT] Relu_25 [Relu] outputs: [169 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_26 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 169
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 391
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 392
[05/16/2022-11:14:34] [V] [TRT] Conv_26 [Conv] inputs: [169 -> (1, 128, 128, 128)[FLOAT]], [391 -> (128, 128, 3, 3)[FLOAT]], [392 -> (128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 128, 128, 128)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_26 for ONNX node: Conv_26
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 390 for ONNX tensor: 390
[05/16/2022-11:14:34] [V] [TRT] Conv_26 [Conv] outputs: [390 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_27 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 390
[05/16/2022-11:14:34] [V] [TRT] Relu_27 [Relu] inputs: [390 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_27 for ONNX node: Relu_27
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 172 for ONNX tensor: 172
[05/16/2022-11:14:34] [V] [TRT] Relu_27 [Relu] outputs: [172 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: MaxPool_28 [MaxPool]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 172
[05/16/2022-11:14:34] [V] [TRT] MaxPool_28 [MaxPool] inputs: [172 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: MaxPool_28 for ONNX node: MaxPool_28
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 173 for ONNX tensor: 173
[05/16/2022-11:14:34] [V] [TRT] MaxPool_28 [MaxPool] outputs: [173 -> (1, 128, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_29 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 173
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 394
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 395
[05/16/2022-11:14:34] [V] [TRT] Conv_29 [Conv] inputs: [173 -> (1, 128, 64, 64)[FLOAT]], [394 -> (256, 128, 3, 3)[FLOAT]], [395 -> (256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 128, 64, 64)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_29 for ONNX node: Conv_29
[05/16/2022-11:14:34] [V] [TRT] Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 256
[05/16/2022-11:14:34] [V] [TRT] Convolution output dimensions: (1, 256, 64, 64)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 393 for ONNX tensor: 393
[05/16/2022-11:14:34] [V] [TRT] Conv_29 [Conv] outputs: [393 -> (1, 256, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_30 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 393
[05/16/2022-11:14:34] [V] [TRT] Relu_30 [Relu] inputs: [393 -> (1, 256, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_30 for ONNX node: Relu_30
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 176 for ONNX tensor: 176
[05/16/2022-11:14:34] [V] [TRT] Relu_30 [Relu] outputs: [176 -> (1, 256, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_31 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 176
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 397
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 398
[05/16/2022-11:14:34] [V] [TRT] Conv_31 [Conv] inputs: [176 -> (1, 256, 64, 64)[FLOAT]], [397 -> (256, 256, 3, 3)[FLOAT]], [398 -> (256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 256, 64, 64)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_31 for ONNX node: Conv_31
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 396 for ONNX tensor: 396
[05/16/2022-11:14:34] [V] [TRT] Conv_31 [Conv] outputs: [396 -> (1, 256, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_32 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 396
[05/16/2022-11:14:34] [V] [TRT] Relu_32 [Relu] inputs: [396 -> (1, 256, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_32 for ONNX node: Relu_32
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 179 for ONNX tensor: 179
[05/16/2022-11:14:34] [V] [TRT] Relu_32 [Relu] outputs: [179 -> (1, 256, 64, 64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_33 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_33 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_33 [Constant] outputs: [180 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_34 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_34 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_34 [Constant] outputs: [181 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_35 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_35 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_35 [Constant] outputs: [182 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_36 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_36 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_36 [Constant] outputs: [183 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Slice_37 [Slice]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 181
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 182
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 180
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 183
[05/16/2022-11:14:34] [V] [TRT] Slice_37 [Slice] inputs: [156 -> (1, 4, 512, 512)[FLOAT]], [181 -> (1)[INT32]], [182 -> (1)[INT32]], [180 -> (1)[INT32]], [183 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Slice_37 for ONNX node: Slice_37
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 184 for ONNX tensor: 184
[05/16/2022-11:14:34] [V] [TRT] Slice_37 [Slice] outputs: [184 -> (1, 3, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_38 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_38 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_38 [Constant] outputs: [185 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_39 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_39 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_39 [Constant] outputs: [186 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_40 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_40 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Weight at index 0: 9223372036854775807 is out of range. Clamping to: 2147483647
[05/16/2022-11:14:34] [W] [TRT] onnx2trt_utils.cpp:390: One or more weights outside the range of INT32 was clamped
[05/16/2022-11:14:34] [V] [TRT] Constant_40 [Constant] outputs: [187 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_41 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_41 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_41 [Constant] outputs: [188 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Slice_42 [Slice]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 186
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 187
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 185
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 188
[05/16/2022-11:14:34] [V] [TRT] Slice_42 [Slice] inputs: [156 -> (1, 4, 512, 512)[FLOAT]], [186 -> (1)[INT32]], [187 -> (1)[INT32]], [185 -> (1)[INT32]], [188 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Slice_42 for ONNX node: Slice_42
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 189 for ONNX tensor: 189
[05/16/2022-11:14:34] [V] [TRT] Slice_42 [Slice] outputs: [189 -> (1, 1, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_43 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_43 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_43 [Constant] outputs: [193 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Resize_44 [Resize]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 179
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 193
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 430
[05/16/2022-11:14:34] [V] [TRT] Resize_44 [Resize] inputs: [179 -> (1, 256, 64, 64)[FLOAT]], [193 -> ()[FLOAT]], [430 -> (4)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Resize_44 for ONNX node: Resize_44
[05/16/2022-11:14:34] [V] [TRT] Running resize layer with:
Transformation mode: align_corners
Resize mode: linear
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 194 for ONNX tensor: 194
[05/16/2022-11:14:34] [V] [TRT] Resize_44 [Resize] outputs: [194 -> (1, 256, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_45 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 194
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.0.upconv.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.0.upconv.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_45 [Conv] inputs: [194 -> (1, 256, 128, 128)[FLOAT]], [decoder.up_blocks.0.upconv.1.block.0.weight -> (128, 256, 3, 3)[FLOAT]], [decoder.up_blocks.0.upconv.1.block.0.bias -> (128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 256, 128, 128)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_45 for ONNX node: Conv_45
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 195 for ONNX tensor: 195
[05/16/2022-11:14:34] [V] [TRT] Conv_45 [Conv] outputs: [195 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_46 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 195
[05/16/2022-11:14:34] [V] [TRT] Relu_46 [Relu] inputs: [195 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_46 for ONNX node: Relu_46
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 196 for ONNX tensor: 196
[05/16/2022-11:14:34] [V] [TRT] Relu_46 [Relu] outputs: [196 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_47 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 196
[05/16/2022-11:14:34] [V] [TRT] Concat_47 [Concat] inputs: [172 -> (1, 128, 128, 128)[FLOAT]], [196 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_47 for ONNX node: Concat_47
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 197 for ONNX tensor: 197
[05/16/2022-11:14:34] [V] [TRT] Concat_47 [Concat] outputs: [197 -> (1, 256, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_48 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 197
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 400
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 401
[05/16/2022-11:14:34] [V] [TRT] Conv_48 [Conv] inputs: [197 -> (1, 256, 128, 128)[FLOAT]], [400 -> (128, 256, 3, 3)[FLOAT]], [401 -> (128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_48 for ONNX node: Conv_48
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 399 for ONNX tensor: 399
[05/16/2022-11:14:34] [V] [TRT] Conv_48 [Conv] outputs: [399 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_49 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 399
[05/16/2022-11:14:34] [V] [TRT] Relu_49 [Relu] inputs: [399 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_49 for ONNX node: Relu_49
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 200 for ONNX tensor: 200
[05/16/2022-11:14:34] [V] [TRT] Relu_49 [Relu] outputs: [200 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_50 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 200
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 403
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 404
[05/16/2022-11:14:34] [V] [TRT] Conv_50 [Conv] inputs: [200 -> (1, 128, 128, 128)[FLOAT]], [403 -> (128, 128, 3, 3)[FLOAT]], [404 -> (128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_50 for ONNX node: Conv_50
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 402 for ONNX tensor: 402
[05/16/2022-11:14:34] [V] [TRT] Conv_50 [Conv] outputs: [402 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_51 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 402
[05/16/2022-11:14:34] [V] [TRT] Relu_51 [Relu] inputs: [402 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_51 for ONNX node: Relu_51
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 203 for ONNX tensor: 203
[05/16/2022-11:14:34] [V] [TRT] Relu_51 [Relu] outputs: [203 -> (1, 128, 128, 128)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_52 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_52 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_52 [Constant] outputs: [207 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Resize_53 [Resize]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 203
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 207
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 431
[05/16/2022-11:14:34] [V] [TRT] Resize_53 [Resize] inputs: [203 -> (1, 128, 128, 128)[FLOAT]], [207 -> ()[FLOAT]], [431 -> (4)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Resize_53 for ONNX node: Resize_53
Resize mode: linear
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 208 for ONNX tensor: 208
[05/16/2022-11:14:34] [V] [TRT] Resize_53 [Resize] outputs: [208 -> (1, 128, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_54 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 208
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.1.upconv.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.1.upconv.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_54 [Conv] inputs: [208 -> (1, 128, 256, 256)[FLOAT]], [decoder.up_blocks.1.upconv.1.block.0.weight -> (64, 128, 3, 3)[FLOAT]], [decoder.up_blocks.1.upconv.1.block.0.bias -> (64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 128, 256, 256)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_54 for ONNX node: Conv_54
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 209 for ONNX tensor: 209
[05/16/2022-11:14:34] [V] [TRT] Conv_54 [Conv] outputs: [209 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_55 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 209
[05/16/2022-11:14:34] [V] [TRT] Relu_55 [Relu] inputs: [209 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_55 for ONNX node: Relu_55
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 210 for ONNX tensor: 210
[05/16/2022-11:14:34] [V] [TRT] Relu_55 [Relu] outputs: [210 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_56 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 210
[05/16/2022-11:14:34] [V] [TRT] Concat_56 [Concat] inputs: [165 -> (1, 64, 256, 256)[FLOAT]], [210 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_56 for ONNX node: Concat_56
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 211 for ONNX tensor: 211
[05/16/2022-11:14:34] [V] [TRT] Concat_56 [Concat] outputs: [211 -> (1, 128, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_57 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 211
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 406
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 407
[05/16/2022-11:14:34] [V] [TRT] Conv_57 [Conv] inputs: [211 -> (1, 128, 256, 256)[FLOAT]], [406 -> (64, 128, 3, 3)[FLOAT]], [407 -> (64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_57 for ONNX node: Conv_57
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 405 for ONNX tensor: 405
[05/16/2022-11:14:34] [V] [TRT] Conv_57 [Conv] outputs: [405 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_58 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 405
[05/16/2022-11:14:34] [V] [TRT] Relu_58 [Relu] inputs: [405 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_58 for ONNX node: Relu_58
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 214 for ONNX tensor: 214
[05/16/2022-11:14:34] [V] [TRT] Relu_58 [Relu] outputs: [214 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_59 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 214
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 409
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 410
[05/16/2022-11:14:34] [V] [TRT] Conv_59 [Conv] inputs: [214 -> (1, 64, 256, 256)[FLOAT]], [409 -> (64, 64, 3, 3)[FLOAT]], [410 -> (64)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_59 for ONNX node: Conv_59
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 408 for ONNX tensor: 408
[05/16/2022-11:14:34] [V] [TRT] Conv_59 [Conv] outputs: [408 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_60 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 408
[05/16/2022-11:14:34] [V] [TRT] Relu_60 [Relu] inputs: [408 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_60 for ONNX node: Relu_60
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 217 for ONNX tensor: 217
[05/16/2022-11:14:34] [V] [TRT] Relu_60 [Relu] outputs: [217 -> (1, 64, 256, 256)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_61 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_61 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_61 [Constant] outputs: [221 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Resize_62 [Resize]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 217
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 221
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 432
[05/16/2022-11:14:34] [V] [TRT] Resize_62 [Resize] inputs: [217 -> (1, 64, 256, 256)[FLOAT]], [221 -> ()[FLOAT]], [432 -> (4)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Resize_62 for ONNX node: Resize_62
Resize mode: linear
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 222 for ONNX tensor: 222
[05/16/2022-11:14:34] [V] [TRT] Resize_62 [Resize] outputs: [222 -> (1, 64, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_63 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 222
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.2.upconv.1.block.0.weight
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.2.upconv.1.block.0.bias
[05/16/2022-11:14:34] [V] [TRT] Conv_63 [Conv] inputs: [222 -> (1, 64, 512, 512)[FLOAT]], [decoder.up_blocks.2.upconv.1.block.0.weight -> (32, 64, 3, 3)[FLOAT]], [decoder.up_blocks.2.upconv.1.block.0.bias -> (32)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 64, 512, 512)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_63 for ONNX node: Conv_63
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 223 for ONNX tensor: 223
[05/16/2022-11:14:34] [V] [TRT] Conv_63 [Conv] outputs: [223 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Relu_64 [Relu]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 223
[05/16/2022-11:14:34] [V] [TRT] Relu_64 [Relu] inputs: [223 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Relu_64 for ONNX node: Relu_64
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 224 for ONNX tensor: 224
[05/16/2022-11:14:34] [V] [TRT] Relu_64 [Relu] outputs: [224 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_65 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 224
[05/16/2022-11:14:34] [V] [TRT] Concat_65 [Concat] inputs: [160 -> (1, 32, 512, 512)[FLOAT]], [224 -> (1, 32, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_65 for ONNX node: Concat_65
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 225 for ONNX tensor: 225
[05/16/2022-11:14:34] [V] [TRT] Concat_65 [Concat] outputs: [225 -> (1, 64, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Shape_66 [Shape]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 225
[05/16/2022-11:14:34] [V] [TRT] Shape_66 [Shape] inputs: [225 -> (1, 64, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Shape_66 for ONNX node: Shape_66
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 226 for ONNX tensor: 226
[05/16/2022-11:14:34] [V] [TRT] Shape_66 [Shape] outputs: [226 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_67 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_67 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_67 [Constant] outputs: [227 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Gather_68 [Gather]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 226
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 227
[05/16/2022-11:14:34] [V] [TRT] Gather_68 [Gather] inputs: [226 -> (4)[INT32]], [227 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: 227 for ONNX node: 227
[05/16/2022-11:14:34] [V] [TRT] Using Gather axis: 0
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Gather_68 for ONNX node: Gather_68
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 228 for ONNX tensor: 228
[05/16/2022-11:14:34] [V] [TRT] Gather_68 [Gather] outputs: [228 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Shape_69 [Shape]
[05/16/2022-11:14:34] [V] [TRT] Shape_69 [Shape] inputs: [225 -> (1, 64, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Shape_69 for ONNX node: Shape_69
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 229 for ONNX tensor: 229
[05/16/2022-11:14:34] [V] [TRT] Shape_69 [Shape] outputs: [229 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_70 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_70 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_70 [Constant] outputs: [230 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Gather_71 [Gather]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 229
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 230
[05/16/2022-11:14:34] [V] [TRT] Gather_71 [Gather] inputs: [229 -> (4)[INT32]], [230 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: 230 for ONNX node: 230
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Gather_71 for ONNX node: Gather_71
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 231 for ONNX tensor: 231
[05/16/2022-11:14:34] [V] [TRT] Gather_71 [Gather] outputs: [231 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Unsqueeze_72 [Unsqueeze]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 228
[05/16/2022-11:14:34] [V] [TRT] Unsqueeze_72 [Unsqueeze] inputs: [228 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Original shape: (), unsqueezing to: (1,)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Unsqueeze_72 for ONNX node: Unsqueeze_72
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 232 for ONNX tensor: 232
[05/16/2022-11:14:34] [V] [TRT] Unsqueeze_72 [Unsqueeze] outputs: [232 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Unsqueeze_73 [Unsqueeze]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 231
[05/16/2022-11:14:34] [V] [TRT] Unsqueeze_73 [Unsqueeze] inputs: [231 -> ()[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Unsqueeze_73 for ONNX node: Unsqueeze_73
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 233 for ONNX tensor: 233
[05/16/2022-11:14:34] [V] [TRT] Unsqueeze_73 [Unsqueeze] outputs: [233 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_74 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 232
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 233
[05/16/2022-11:14:34] [V] [TRT] Concat_74 [Concat] inputs: [232 -> (1)[INT32]], [233 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_74 for ONNX node: Concat_74
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 234 for ONNX tensor: 234
[05/16/2022-11:14:34] [V] [TRT] Concat_74 [Concat] outputs: [234 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_75 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_75 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_75 [Constant] outputs: [235 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Shape_76 [Shape]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 189
[05/16/2022-11:14:34] [V] [TRT] Shape_76 [Shape] inputs: [189 -> (1, 1, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Shape_76 for ONNX node: Shape_76
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 236 for ONNX tensor: 236
[05/16/2022-11:14:34] [V] [TRT] Shape_76 [Shape] outputs: [236 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_77 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_77 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_77 [Constant] outputs: [237 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_78 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_78 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_78 [Constant] outputs: [238 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_79 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_79 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_79 [Constant] outputs: [239 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Slice_80 [Slice]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 236
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 238
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 239
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 237
[05/16/2022-11:14:34] [V] [TRT] Slice_80 [Slice] inputs: [236 -> (4)[INT32]], [238 -> (1)[INT32]], [239 -> (1)[INT32]], [237 -> (1)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Slice_80 for ONNX node: Slice_80
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 240 for ONNX tensor: 240
[05/16/2022-11:14:34] [V] [TRT] Slice_80 [Slice] outputs: [240 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Cast_81 [Cast]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 234
[05/16/2022-11:14:34] [V] [TRT] Cast_81 [Cast] inputs: [234 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Casting to type: int32
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Cast_81 for ONNX node: Cast_81
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 241 for ONNX tensor: 241
[05/16/2022-11:14:34] [V] [TRT] Cast_81 [Cast] outputs: [241 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Concat_82 [Concat]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 240
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 241
[05/16/2022-11:14:34] [V] [TRT] Concat_82 [Concat] inputs: [240 -> (2)[INT32]], [241 -> (2)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Concat_82 for ONNX node: Concat_82
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 242 for ONNX tensor: 242
[05/16/2022-11:14:34] [V] [TRT] Concat_82 [Concat] outputs: [242 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Constant_83 [Constant]
[05/16/2022-11:14:34] [V] [TRT] Constant_83 [Constant] inputs:
[05/16/2022-11:14:34] [V] [TRT] Constant_83 [Constant] outputs: [243 -> ()[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Resize_84 [Resize]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 235
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 243
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 242
[05/16/2022-11:14:34] [V] [TRT] Resize_84 [Resize] inputs: [189 -> (1, 1, 512, 512)[FLOAT]], [235 -> ()[FLOAT]], [243 -> ()[FLOAT]], [242 -> (4)[INT32]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Resize_84 for ONNX node: Resize_84
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 244 for ONNX tensor: 244
[05/16/2022-11:14:34] [V] [TRT] Resize_84 [Resize] outputs: [244 -> (1, 1, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: Conv_85 [Conv]
[05/16/2022-11:14:34] [V] [TRT] Searching for input: 244
[05/16/2022-11:14:34] [V] [TRT] Searching for input: decoder.up_blocks.2.attention.mask_blurring.weight
[05/16/2022-11:14:34] [V] [TRT] Conv_85 [Conv] inputs: [244 -> (1, 1, 512, 512)[FLOAT]], [decoder.up_blocks.2.attention.mask_blurring.weight -> (1, 1, 7, 7)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Convolution input dimensions: (1, 1, 512, 512)
[05/16/2022-11:14:34] [V] [TRT] Registering layer: Conv_85 for ONNX node: Conv_85
[05/16/2022-11:14:34] [V] [TRT] Using kernel: (7, 7), strides: (1, 1), prepadding: (3, 3), postpadding: (3, 3), dilations: (1, 1), numOutputs: 1
[05/16/2022-11:14:34] [V] [TRT] Convolution output dimensions: (1, 1, 512, 512)
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 245 for ONNX tensor: 245
[05/16/2022-11:14:34] [V] [TRT] Conv_85 [Conv] outputs: [245 -> (1, 1, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: GlobalAveragePool_86 [GlobalAveragePool]
[05/16/2022-11:14:34] [V] [TRT] GlobalAveragePool_86 [GlobalAveragePool] inputs: [225 -> (1, 64, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Registering layer: GlobalAveragePool_86 for ONNX node: GlobalAveragePool_86
[05/16/2022-11:14:34] [V] [TRT] Registering tensor: 246 for ONNX tensor: 246
[05/16/2022-11:14:34] [V] [TRT] GlobalAveragePool_86 [GlobalAveragePool] outputs: [246 -> (1, 64, 1, 1)[FLOAT]],
[05/16/2022-11:14:34] [V] [TRT] Parsing node: MaxPool_87 [MaxPool]
[05/16/2022-11:14:34] [V] [TRT] MaxPool_87 [MaxPool] inputs: [225 -> (1, 64, 512, 512)[FLOAT]],
[05/16/2022-11:14:34] [E] Error[3]: [network.cpp::addPoolingNd::884] Error Code 3: Internal Error (Parameter check failed at: optimizer/api/network.cpp::addPoolingNd::884, condition: allDimsGtEq(windowSize, 1) && volume(windowSize) < MAX_KERNEL_DIMS_PRODUCT(nbSpatialDims)
onnx model as followed:
iharm_onnx.onnx (8.6 MB)
Looking forward to your reply, or can provide some ideas to solve the problem,thanks.
