Encountering error while trying to convert an ONNX model to TensorRT engine - Jetson Orin Nano
I’m trying to convert a ViT-B/32 Vision Transformer model from the UNICOM repository on a Jetson Orin Nano. The model’s Vision Transformer class and source code is here.
I use the following code to convert the model to ONNX:
import torch
import onnx
import onnxruntime
from unicom.vision_transformer import build_model
if __name__ == '__main__':
    model_name = "ViT-B/32"
    model_name_fp16 = "FP16-ViT-B-32"
    onnx_model_path = f"{model_name_fp16}.onnx"
    model = build_model(model_name)
    model.eval()
    model = model.to('cuda')
    torch_input = torch.randn(1, 3, 224, 224).to('cuda')
    onnx_program = torch.onnx.dynamo_export(model, torch_input)
    onnx_program.save(onnx_model_path)
    onnx_model = onnx.load(onnx_model_path)
    onnx.checker.check_model(onnx_model_path)
I then use the following command line to convert the ONNX model to a TensorRT engine:
/usr/src/tensorrt/bin/trtexec --onnx=FP16-ViT-B-32.onnx --saveEngine=FP16-ViT-B-32.trt --workspace=1024 --fp16
This results in the following error:
[07/22/2024-08:22:34] [W] --workspace flag has been deprecated by --memPoolSize flag.
[07/22/2024-08:22:34] [I] === Model Options ===
[07/22/2024-08:22:34] [I] Format: ONNX
[07/22/2024-08:22:34] [I] Model: /home/jetson/HPS/Models/FeatureExtractor/UNICOM/ONNX/FP16-ViT-B-32.onnx
[07/22/2024-08:22:34] [I] Output:
[07/22/2024-08:22:34] [I] === Build Options ===
[07/22/2024-08:22:34] [I] Max batch: explicit batch
[07/22/2024-08:22:34] [I] Memory Pools: workspace: 1024 MiB, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[07/22/2024-08:22:34] [I] minTiming: 1
[07/22/2024-08:22:34] [I] avgTiming: 8
[07/22/2024-08:22:34] [I] Precision: FP32+FP16
[07/22/2024-08:22:34] [I] LayerPrecisions:
[07/22/2024-08:22:34] [I] Layer Device Types:
[07/22/2024-08:22:34] [I] Calibration:
[07/22/2024-08:22:34] [I] Refit: Disabled
[07/22/2024-08:22:34] [I] Version Compatible: Disabled
[07/22/2024-08:22:34] [I] ONNX Native InstanceNorm: Disabled
[07/22/2024-08:22:34] [I] TensorRT runtime: full
[07/22/2024-08:22:34] [I] Lean DLL Path:
[07/22/2024-08:22:34] [I] Tempfile Controls: { in_memory: allow, temporary: allow }
[07/22/2024-08:22:34] [I] Exclude Lean Runtime: Disabled
[07/22/2024-08:22:34] [I] Sparsity: Disabled
[07/22/2024-08:22:34] [I] Safe mode: Disabled
[07/22/2024-08:22:34] [I] Build DLA standalone loadable: Disabled
[07/22/2024-08:22:34] [I] Allow GPU fallback for DLA: Disabled
[07/22/2024-08:22:34] [I] DirectIO mode: Disabled
[07/22/2024-08:22:34] [I] Restricted mode: Disabled
[07/22/2024-08:22:34] [I] Skip inference: Disabled
[07/22/2024-08:22:34] [I] Save engine: /home/jetson/HPS/Models/FeatureExtractor/UNICOM/ONNX/FP16-ViT-B-32.trt
[07/22/2024-08:22:34] [I] Load engine:
[07/22/2024-08:22:34] [I] Profiling verbosity: 0
[07/22/2024-08:22:34] [I] Tactic sources: Using default tactic sources
[07/22/2024-08:22:34] [I] timingCacheMode: local
[07/22/2024-08:22:34] [I] timingCacheFile:
[07/22/2024-08:22:34] [I] Heuristic: Disabled
[07/22/2024-08:22:34] [I] Preview Features: Use default preview flags.
[07/22/2024-08:22:34] [I] MaxAuxStreams: -1
[07/22/2024-08:22:34] [I] BuilderOptimizationLevel: -1
[07/22/2024-08:22:34] [I] Input(s)s format: fp32:CHW
[07/22/2024-08:22:34] [I] Output(s)s format: fp32:CHW
[07/22/2024-08:22:34] [I] Input build shapes: model
[07/22/2024-08:22:34] [I] Input calibration shapes: model
[07/22/2024-08:22:34] [I] === System Options ===
[07/22/2024-08:22:34] [I] Device: 0
[07/22/2024-08:22:34] [I] DLACore:
[07/22/2024-08:22:34] [I] Plugins:
[07/22/2024-08:22:34] [I] setPluginsToSerialize:
[07/22/2024-08:22:34] [I] dynamicPlugins:
[07/22/2024-08:22:34] [I] ignoreParsedPluginLibs: 0
[07/22/2024-08:22:34] [I] === Inference Options ===
[07/22/2024-08:22:34] [I] Batch: Explicit
[07/22/2024-08:22:34] [I] Input inference shapes: model
[07/22/2024-08:22:34] [I] Iterations: 10
[07/22/2024-08:22:34] [I] Duration: 3s (+ 200ms warm up)
[07/22/2024-08:22:34] [I] Sleep time: 0ms
[07/22/2024-08:22:34] [I] Idle time: 0ms
[07/22/2024-08:22:34] [I] Inference Streams: 1
[07/22/2024-08:22:34] [I] ExposeDMA: Disabled
[07/22/2024-08:22:34] [I] Data transfers: Enabled
[07/22/2024-08:22:34] [I] Spin-wait: Disabled
[07/22/2024-08:22:34] [I] Multithreading: Disabled
[07/22/2024-08:22:34] [I] CUDA Graph: Disabled
[07/22/2024-08:22:34] [I] Separate profiling: Disabled
[07/22/2024-08:22:34] [I] Time Deserialize: Disabled
[07/22/2024-08:22:34] [I] Time Refit: Disabled
[07/22/2024-08:22:34] [I] NVTX verbosity: 0
[07/22/2024-08:22:34] [I] Persistent Cache Ratio: 0
[07/22/2024-08:22:34] [I] Inputs:
[07/22/2024-08:22:34] [I] === Reporting Options ===
[07/22/2024-08:22:34] [I] Verbose: Enabled
[07/22/2024-08:22:34] [I] Averages: 10 inferences
[07/22/2024-08:22:34] [I] Percentiles: 90,95,99
[07/22/2024-08:22:34] [I] Dump refittable layers:Disabled
[07/22/2024-08:22:34] [I] Dump output: Disabled
[07/22/2024-08:22:34] [I] Profile: Disabled
[07/22/2024-08:22:34] [I] Export timing to JSON file:
[07/22/2024-08:22:34] [I] Export output to JSON file:
[07/22/2024-08:22:34] [I] Export profile to JSON file:
[07/22/2024-08:22:34] [I] === Device Information ===
[07/22/2024-08:22:34] [I] Selected Device: Orin
[07/22/2024-08:22:34] [I] Compute Capability: 8.7
[07/22/2024-08:22:34] [I] SMs: 8
[07/22/2024-08:22:34] [I] Device Global Memory: 7620 MiB
[07/22/2024-08:22:34] [I] Shared Memory per SM: 164 KiB
[07/22/2024-08:22:34] [I] Memory Bus Width: 128 bits (ECC disabled)
[07/22/2024-08:22:34] [I] Application Compute Clock Rate: 0.624 GHz
[07/22/2024-08:22:34] [I] Application Memory Clock Rate: 0.624 GHz
[07/22/2024-08:22:34] [I] Note: The application clock rates do not reflect the actual clock rates that the GPU is currently running at.
[07/22/2024-08:22:34] [I] TensorRT version: 8.6.2
[07/22/2024-08:22:34] [I] Loading standard plugins
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::BatchTilePlugin_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::CoordConvAC version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::CropAndResizeDynamic version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::DecodeBbox3DPlugin version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::GenerateDetection_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 2
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::ModulatedDeformConv2d version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::NMSDynamic_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::PillarScatterPlugin version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::ProposalDynamic version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::Proposal version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::ROIAlign_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::ScatterND version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::Split version 1
[07/22/2024-08:22:34] [V] [TRT] Registered plugin creator - ::VoxelGeneratorPlugin version 1
[07/22/2024-08:22:34] [I] [TRT] [MemUsageChange] Init CUDA: CPU +2, GPU +0, now: CPU 33, GPU 5167 (MiB)
[07/22/2024-08:22:34] [V] [TRT] Trying to load shared library libnvinfer_builder_resource.so.8.6.2
[07/22/2024-08:22:34] [V] [TRT] Loaded shared library libnvinfer_builder_resource.so.8.6.2
[07/22/2024-08:22:43] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +1154, GPU +995, now: CPU 1223, GPU 6203 (MiB)
[07/22/2024-08:22:43] [V] [TRT] CUDA lazy loading is enabled.
[07/22/2024-08:22:43] [I] Start parsing network model.
[07/22/2024-08:22:49] [I] [TRT] ----------------------------------------------------------------
[07/22/2024-08:22:49] [I] [TRT] Input filename:   /home/jetson/HPS/Models/FeatureExtractor/UNICOM/ONNX/FP16-ViT-B-32.onnx
[07/22/2024-08:22:49] [I] [TRT] ONNX IR version:  0.0.8
[07/22/2024-08:22:49] [I] [TRT] Opset version:    1
[07/22/2024-08:22:49] [I] [TRT] Producer name:    pytorch
[07/22/2024-08:22:49] [I] [TRT] Producer version: 2.3.0
[07/22/2024-08:22:49] [I] [TRT] Domain:
[07/22/2024-08:22:49] [I] [TRT] Model version:    0
[07/22/2024-08:22:49] [I] [TRT] Doc string:
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::BatchedNMSDynamic_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::BatchTilePlugin_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::CoordConvAC version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::CropAndResizeDynamic version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::DecodeBbox3DPlugin version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Explicit_TF_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Implicit_TF_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::EfficientNMS_ONNX_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::EfficientNMS_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::GenerateDetection_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::GridAnchorRect_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 2
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::ModulatedDeformConv2d version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::MultilevelCropAndResize_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::MultilevelProposeROI_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::MultiscaleDeformableAttnPlugin_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::NMSDynamic_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::PillarScatterPlugin version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::ProposalDynamic version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::ROIAlign_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::ScatterND version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::Split version 1
[07/22/2024-08:22:56] [V] [TRT] Plugin creator already registered - ::VoxelGeneratorPlugin version 1
[07/22/2024-08:22:56] [V] [TRT] Adding network input: l_x_ with dtype: float32, dimensions: (1, 3, 224, 224)
[07/22/2024-08:22:56] [V] [TRT] Registering tensor: l_x_ for ONNX tensor: l_x_
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: patch_embed.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: patch_embed.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: pos_embed
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.0.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.1.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.2.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.3.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.4.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.5.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.6.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.7.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.8.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.9.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.10.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.norm1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.norm1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.attn.qkv.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.attn.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.attn.proj.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.norm2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.norm2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.mlp.fc1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.mlp.fc1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.mlp.fc2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: blocks.11.mlp.fc2.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: norm.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: norm.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.0.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.1.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.1.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.1.running_mean
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.1.running_var
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.2.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.3.weight
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.3.bias
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.3.running_mean
[07/22/2024-08:22:56] [V] [TRT] Importing initializer: feature.3.running_var
[07/22/2024-08:22:56] [V] [TRT] Parsing node: unicom_vision_transformer_PatchEmbedding_patch_embed_1_1 [unicom_vision_transformer_PatchEmbedding_patch_embed_1]
[07/22/2024-08:22:56] [V] [TRT] Searching for input: l_x_
[07/22/2024-08:22:56] [V] [TRT] Searching for input: patch_embed.proj.weight
[07/22/2024-08:22:56] [V] [TRT] Searching for input: patch_embed.proj.bias
[07/22/2024-08:22:56] [V] [TRT] unicom_vision_transformer_PatchEmbedding_patch_embed_1_1 [unicom_vision_transformer_PatchEmbedding_patch_embed_1] inputs: [l_x_ -> (1, 3, 224, 224)[FLOAT]], [patch_embed.proj.weight -> (768, 3, 32, 32)[FLOAT]], [patch_embed.proj.bias -> (768)[FLOAT]],
[07/22/2024-08:22:56] [I] [TRT] No importer registered for op: unicom_vision_transformer_PatchEmbedding_patch_embed_1. Attempting to import as plugin.
[07/22/2024-08:22:56] [I] [TRT] Searching for plugin: unicom_vision_transformer_PatchEmbedding_patch_embed_1, plugin_version: 1, plugin_namespace:
[07/22/2024-08:22:56] [V] [TRT] Local registry did not find unicom_vision_transformer_PatchEmbedding_patch_embed_1 creator. Will try parent registry if enabled.
[07/22/2024-08:22:56] [V] [TRT] Global registry did not find unicom_vision_transformer_PatchEmbedding_patch_embed_1 creator. Will try parent registry if enabled.
[07/22/2024-08:22:56] [E] [TRT] 3: getPluginCreator could not find plugin: unicom_vision_transformer_PatchEmbedding_patch_embed_1 version: 1
[07/22/2024-08:22:56] [E] [TRT] ModelImporter.cpp:768: While parsing node number 0 [unicom_vision_transformer_PatchEmbedding_patch_embed_1 -> "patch_embed_1"]:
[07/22/2024-08:22:56] [E] [TRT] ModelImporter.cpp:769: --- Begin node ---
[07/22/2024-08:22:56] [E] [TRT] ModelImporter.cpp:770: input: "l_x_"
input: "patch_embed.proj.weight"
input: "patch_embed.proj.bias"
output: "patch_embed_1"
op_type: "unicom_vision_transformer_PatchEmbedding_patch_embed_1"
doc_string: ""
domain: "pkg.unicom"
[07/22/2024-08:22:56] [E] [TRT] ModelImporter.cpp:771: --- End node ---
[07/22/2024-08:22:56] [E] [TRT] ModelImporter.cpp:773: ERROR: builtin_op_importers.cpp:5403 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
[07/22/2024-08:22:56] [E] Failed to parse onnx file
[07/22/2024-08:22:56] [I] Finished parsing network model. Parse time: 13.1481
[07/22/2024-08:22:56] [E] Parsing model failed
[07/22/2024-08:22:56] [E] Failed to create engine from model or file.
[07/22/2024-08:22:56] [E] Engine set up failed
The problem seems to arise from the PatchEmbedding class here and it doesn’t seem as if the model is using any extraordinary methods and layers that aren’t convertible by TensorRT. Here’s the class’s source code:
class PatchEmbedding(nn.Module):
    def __init__(self, input_size=224, patch_size=32, in_channels: int = 3, dim: int = 768):
        super().__init__()
        if isinstance(input_size, int):
            input_size = (input_size, input_size)
        if isinstance(patch_size, int):
            patch_size = (patch_size, patch_size)
        H = input_size[0] // patch_size[0]
        W = input_size[1] // patch_size[1]
        self.num_patches = H * W
        self.proj = nn.Conv2d(
            in_channels, dim, kernel_size=patch_size, stride=patch_size)
    def forward(self, x):
        x = self.proj(x).flatten(2).transpose(1, 2)
        return x
What should I do to make the model convertible to TensorRT?
Environment
TensorRT Version: tensorrt_version_8_6_2_3
GPU Type: Jetson Orin Nano
Nvidia Driver Version:
CUDA Version: 12.2
CUDNN Version: 8.9.4.25-1+cuda12.2
Operating System + Version: Jetpack 6.0
Python Version (if applicable): 3.10
TensorFlow Version (if applicable): –
PyTorch Version (if applicable): 2.3.0
ONNX Version (if applicable): 1.16.1
onnxruntime-gpu Version (if applicable): 1.17.0
onnxscript Version (if applicable): 0.1.0.dev20240721
Baremetal or Container (if container which image + tag): –
Was this the proper place to ask this question?
