Link to onnx (hope this works!): https://we.tl/t-g5js0rjILs
md5sum is:c9c1cc469bd087f48a94909da2441117
There is no output from onnx.checker.check_model(model) - is this expected?:
>>> import sys
>>> import onnx
>>> model = onnx.load("keypoint_rcnn.onnx")
verbose:
&&&& RUNNING TensorRT.trtexec [TensorRT v8205] # /opt/tensorrt/bin/trtexec --onnx=keypoint_rcnn.onnx --verbose
[06/24/2022-16:34:13] [I] === Model Options ===
[06/24/2022-16:34:13] [I] Format: ONNX
[06/24/2022-16:34:13] [I] Model: keypoint_rcnn.onnx
[06/24/2022-16:34:13] [I] Output:
[06/24/2022-16:34:13] [I] === Build Options ===
[06/24/2022-16:34:13] [I] Max batch: explicit batch
[06/24/2022-16:34:13] [I] Workspace: 16 MiB
[06/24/2022-16:34:13] [I] minTiming: 1
[06/24/2022-16:34:13] [I] avgTiming: 8
[06/24/2022-16:34:13] [I] Precision: FP32
[06/24/2022-16:34:13] [I] Calibration:
[06/24/2022-16:34:13] [I] Refit: Disabled
[06/24/2022-16:34:13] [I] Sparsity: Disabled
[06/24/2022-16:34:13] [I] Safe mode: Disabled
[06/24/2022-16:34:13] [I] DirectIO mode: Disabled
[06/24/2022-16:34:13] [I] Restricted mode: Disabled
[06/24/2022-16:34:13] [I] Save engine:
[06/24/2022-16:34:13] [I] Load engine:
[06/24/2022-16:34:13] [I] Profiling verbosity: 0
[06/24/2022-16:34:13] [I] Tactic sources: Using default tactic sources
[06/24/2022-16:34:13] [I] timingCacheMode: local
[06/24/2022-16:34:13] [I] timingCacheFile:
[06/24/2022-16:34:13] [I] Input(s)s format: fp32:CHW
[06/24/2022-16:34:13] [I] Output(s)s format: fp32:CHW
[06/24/2022-16:34:13] [I] Input build shapes: model
[06/24/2022-16:34:13] [I] Input calibration shapes: model
[06/24/2022-16:34:13] [I] === System Options ===
[06/24/2022-16:34:13] [I] Device: 0
[06/24/2022-16:34:13] [I] DLACore:
[06/24/2022-16:34:13] [I] Plugins:
[06/24/2022-16:34:13] [I] === Inference Options ===
[06/24/2022-16:34:13] [I] Batch: Explicit
[06/24/2022-16:34:13] [I] Input inference shapes: model
[06/24/2022-16:34:13] [I] Iterations: 10
[06/24/2022-16:34:13] [I] Duration: 3s (+ 200ms warm up)
[06/24/2022-16:34:13] [I] Sleep time: 0ms
[06/24/2022-16:34:13] [I] Idle time: 0ms
[06/24/2022-16:34:13] [I] Streams: 1
[06/24/2022-16:34:13] [I] ExposeDMA: Disabled
[06/24/2022-16:34:13] [I] Data transfers: Enabled
[06/24/2022-16:34:13] [I] Spin-wait: Disabled
[06/24/2022-16:34:13] [I] Multithreading: Disabled
[06/24/2022-16:34:13] [I] CUDA Graph: Disabled
[06/24/2022-16:34:13] [I] Separate profiling: Disabled
[06/24/2022-16:34:13] [I] Time Deserialize: Disabled
[06/24/2022-16:34:13] [I] Time Refit: Disabled
[06/24/2022-16:34:13] [I] Skip inference: Disabled
[06/24/2022-16:34:13] [I] Inputs:
[06/24/2022-16:34:13] [I] === Reporting Options ===
[06/24/2022-16:34:13] [I] Verbose: Enabled
[06/24/2022-16:34:13] [I] Averages: 10 inferences
[06/24/2022-16:34:13] [I] Percentile: 99
[06/24/2022-16:34:13] [I] Dump refittable layers:Disabled
[06/24/2022-16:34:13] [I] Dump output: Disabled
[06/24/2022-16:34:13] [I] Profile: Disabled
[06/24/2022-16:34:13] [I] Export timing to JSON file:
[06/24/2022-16:34:13] [I] Export output to JSON file:
[06/24/2022-16:34:13] [I] Export profile to JSON file:
[06/24/2022-16:34:13] [I] === Device Information ===
[06/24/2022-16:34:13] [I] Selected Device: NVIDIA GeForce RTX 3090
[06/24/2022-16:34:13] [I] Compute Capability: 8.6
[06/24/2022-16:34:13] [I] SMs: 82
[06/24/2022-16:34:13] [I] Compute Clock Rate: 1.785 GHz
[06/24/2022-16:34:13] [I] Device Global Memory: 24245 MiB
[06/24/2022-16:34:13] [I] Shared Memory per SM: 100 KiB
[06/24/2022-16:34:13] [I] Memory Bus Width: 384 bits (ECC disabled)
[06/24/2022-16:34:13] [I] Memory Clock Rate: 9.751 GHz
[06/24/2022-16:34:13] [I] TensorRT version: 8.2.5
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::BatchTilePlugin_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::CoordConvAC version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::CropAndResizeDynamic version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::DecodeBbox3DPlugin version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::GenerateDetection_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::DMHA version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::NMSDynamic_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::PillarScatterPlugin version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::Proposal version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::ProposalDynamic version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::ScatterND version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::Split version 1
[06/24/2022-16:34:13] [V] [TRT] Registered plugin creator - ::VoxelGeneratorPlugin version 1
[06/24/2022-16:34:13] [I] [TRT] [MemUsageChange] Init CUDA: CPU +472, GPU +0, now: CPU 484, GPU 15565 (MiB)
[06/24/2022-16:34:13] [I] [TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 484 MiB, GPU 15564 MiB
[06/24/2022-16:34:14] [I] [TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 638 MiB, GPU 15606 MiB
[06/24/2022-16:34:14] [I] Start parsing network model
[06/24/2022-16:34:14] [I] [TRT] ----------------------------------------------------------------
[06/24/2022-16:34:14] [I] [TRT] Input filename: keypoint_rcnn.onnx
[06/24/2022-16:34:14] [I] [TRT] ONNX IR version: 0.0.6
[06/24/2022-16:34:14] [I] [TRT] Opset version: 11
[06/24/2022-16:34:14] [I] [TRT] Producer name: pytorch
[06/24/2022-16:34:14] [I] [TRT] Producer version: 1.12.0
[06/24/2022-16:34:14] [I] [TRT] Domain:
[06/24/2022-16:34:14] [I] [TRT] Model version: 0
[06/24/2022-16:34:14] [I] [TRT] Doc string:
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::BatchTilePlugin_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::BatchedNMSDynamic_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::CoordConvAC version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::CropAndResizeDynamic version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::DecodeBbox3DPlugin version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::EfficientNMS_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::EfficientNMS_ONNX_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Explicit_TF_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Implicit_TF_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::GenerateDetection_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::GridAnchorRect_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::MultilevelCropAndResize_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::MultilevelProposeROI_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::DMHA version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::NMSDynamic_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::PillarScatterPlugin version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::ProposalDynamic version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::ScatterND version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::Split version 1
[06/24/2022-16:34:14] [V] [TRT] Plugin creator already registered - ::VoxelGeneratorPlugin version 1
[06/24/2022-16:34:14] [V] [TRT] Adding network input: image.1 with dtype: float32, dimensions: (3, 300, 400)
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: image.1 for ONNX tensor: image.1
[06/24/2022-16:34:14] [V] [TRT] Adding network input: image.5 with dtype: float32, dimensions: (3, 500, 400)
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: image.5 for ONNX tensor: image.5
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.0.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.0.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.0.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.0.downsample.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.1.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.1.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.1.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.2.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.2.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer1.2.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.0.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.0.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.0.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.0.downsample.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.1.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.1.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.1.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.2.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.2.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.2.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.3.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.3.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer2.3.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.0.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.0.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.0.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.0.downsample.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.1.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.1.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.1.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.2.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.2.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.2.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.3.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.3.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.3.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.4.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.4.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.4.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.5.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.5.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer3.5.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.0.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.0.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.0.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.0.downsample.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.1.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.1.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.1.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.2.conv1.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.2.conv2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.body.layer4.2.conv3.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.0.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.0.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.1.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.1.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.2.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.2.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.3.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.inner_blocks.3.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.0.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.0.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.1.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.1.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.2.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.2.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.3.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: backbone.fpn.layer_blocks.3.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: rpn.head.conv.0.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: rpn.head.conv.0.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: rpn.head.cls_logits.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: rpn.head.cls_logits.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: rpn.head.bbox_pred.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: rpn.head.bbox_pred.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_head.fc6.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_head.fc6.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_head.fc7.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_head.fc7.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_predictor.cls_score.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_predictor.cls_score.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_predictor.bbox_pred.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.box_predictor.bbox_pred.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.0.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.0.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.2.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.2.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.4.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.4.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.6.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.6.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.8.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.8.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.10.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.10.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.12.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.12.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.14.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_head.14.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_predictor.kps_score_lowres.weight
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: roi_heads.keypoint_predictor.kps_score_lowres.bias
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Sub_4372
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4387
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4389
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4397
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4399
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4407
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4409
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4417
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4419
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4427
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4429
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4437
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4439
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4447
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4449
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4457
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4459
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4467
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4469
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4477
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4479
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4487
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4489
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4497
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4499
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4507
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4509
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4517
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4519
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4527
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4529
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4537
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4539
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4547
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4549
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4557
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4559
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4567
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4569
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4577
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4579
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4587
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4589
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4597
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4599
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4607
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4609
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4617
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4619
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4627
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4629
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4637
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4639
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4647
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4649
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4657
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4659
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4667
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4669
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4677
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4679
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4687
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4689
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4697
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4699
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4707
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4709
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4717
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4719
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4727
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4729
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4737
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4739
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4747
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4749
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4757
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4759
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4767
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4769
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4777
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4779
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4787
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4789
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4797
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4799
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4807
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4809
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4817
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4819
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4827
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4829
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4837
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4839
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4847
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4849
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4857
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4859
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4867
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4869
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4877
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4879
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4887
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4889
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4897
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4899
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Mul_4907
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Add_4909
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Clip_4962
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Clip_4970
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Clip_4971
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Resize_4981
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Clip_4983
[06/24/2022-16:34:14] [V] [TRT] Importing initializer: onnx::Concat_4987
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_0 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4987
[06/24/2022-16:34:14] [V] [TRT] Identity_0 [Identity] inputs: [onnx::Concat_4987 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4987 for ONNX node: onnx::Concat_4987
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_0 for ONNX node: Identity_0
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4994 for ONNX tensor: onnx::Concat_4994
[06/24/2022-16:34:14] [V] [TRT] Identity_0 [Identity] outputs: [onnx::Concat_4994 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_1 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Identity_1 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_1 for ONNX node: Identity_1
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4993 for ONNX tensor: onnx::Concat_4993
[06/24/2022-16:34:14] [V] [TRT] Identity_1 [Identity] outputs: [onnx::Concat_4993 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_2 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Clip_4983
[06/24/2022-16:34:14] [V] [TRT] Identity_2 [Identity] inputs: [onnx::Clip_4983 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4983 for ONNX node: onnx::Clip_4983
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_2 for ONNX node: Identity_2
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4992 for ONNX tensor: onnx::Clip_4992
[06/24/2022-16:34:14] [V] [TRT] Identity_2 [Identity] outputs: [onnx::Clip_4992 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_3 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_3 [Identity] inputs: [onnx::Clip_4983 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4983_0 for ONNX node: onnx::Clip_4983
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_3 for ONNX node: Identity_3
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4990 for ONNX tensor: onnx::Clip_4990
[06/24/2022-16:34:14] [V] [TRT] Identity_3 [Identity] outputs: [onnx::Clip_4990 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_4 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_4 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_1 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_4 for ONNX node: Identity_4
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4986 for ONNX tensor: onnx::Concat_4986
[06/24/2022-16:34:14] [V] [TRT] Identity_4 [Identity] outputs: [onnx::Concat_4986 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_5 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_5 [Identity] inputs: [onnx::Clip_4983 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4983_2 for ONNX node: onnx::Clip_4983
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_5 for ONNX node: Identity_5
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4985 for ONNX tensor: onnx::Clip_4985
[06/24/2022-16:34:14] [V] [TRT] Identity_5 [Identity] outputs: [onnx::Clip_4985 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_6 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Clip_4971
[06/24/2022-16:34:14] [V] [TRT] Identity_6 [Identity] inputs: [onnx::Clip_4971 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4971 for ONNX node: onnx::Clip_4971
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_6 for ONNX node: Identity_6
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4980 for ONNX tensor: onnx::Clip_4980
[06/24/2022-16:34:14] [V] [TRT] Identity_6 [Identity] outputs: [onnx::Clip_4980 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_7 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Clip_4970
[06/24/2022-16:34:14] [V] [TRT] Identity_7 [Identity] inputs: [onnx::Clip_4970 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4970 for ONNX node: onnx::Clip_4970
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_7 for ONNX node: Identity_7
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4979 for ONNX tensor: onnx::Clip_4979
[06/24/2022-16:34:14] [V] [TRT] Identity_7 [Identity] outputs: [onnx::Clip_4979 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_8 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Identity_8 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_8 for ONNX node: Identity_8
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4978 for ONNX tensor: onnx::Concat_4978
[06/24/2022-16:34:14] [V] [TRT] Identity_8 [Identity] outputs: [onnx::Concat_4978 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_9 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Identity_9 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_9 for ONNX node: Identity_9
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4977 for ONNX tensor: onnx::Concat_4977
[06/24/2022-16:34:14] [V] [TRT] Identity_9 [Identity] outputs: [onnx::Concat_4977 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_10 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Clip_4962
[06/24/2022-16:34:14] [V] [TRT] Identity_10 [Identity] inputs: [onnx::Clip_4962 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4962 for ONNX node: onnx::Clip_4962
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_10 for ONNX node: Identity_10
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4976 for ONNX tensor: onnx::Clip_4976
[06/24/2022-16:34:14] [V] [TRT] Identity_10 [Identity] outputs: [onnx::Clip_4976 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_11 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_11 [Identity] inputs: [onnx::Clip_4962 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4962_3 for ONNX node: onnx::Clip_4962
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_11 for ONNX node: Identity_11
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4974 for ONNX tensor: onnx::Clip_4974
[06/24/2022-16:34:14] [V] [TRT] Identity_11 [Identity] outputs: [onnx::Clip_4974 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_12 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_12 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_4 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_12 for ONNX node: Identity_12
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4972 for ONNX tensor: onnx::Concat_4972
[06/24/2022-16:34:14] [V] [TRT] Identity_12 [Identity] outputs: [onnx::Concat_4972 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_13 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_13 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_5 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_13 for ONNX node: Identity_13
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Reshape_4969 for ONNX tensor: onnx::Reshape_4969
[06/24/2022-16:34:14] [V] [TRT] Identity_13 [Identity] outputs: [onnx::Reshape_4969 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_14 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_14 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_6 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_14 for ONNX node: Identity_14
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Reshape_4968 for ONNX tensor: onnx::Reshape_4968
[06/24/2022-16:34:14] [V] [TRT] Identity_14 [Identity] outputs: [onnx::Reshape_4968 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_15 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_15 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_7 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_15 for ONNX node: Identity_15
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4967 for ONNX tensor: onnx::Concat_4967
[06/24/2022-16:34:14] [V] [TRT] Identity_15 [Identity] outputs: [onnx::Concat_4967 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_16 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_16 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_8 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_16 for ONNX node: Identity_16
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4966 for ONNX tensor: onnx::Concat_4966
[06/24/2022-16:34:14] [V] [TRT] Identity_16 [Identity] outputs: [onnx::Concat_4966 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_17 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_17 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_9 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_17 for ONNX node: Identity_17
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4965 for ONNX tensor: onnx::Concat_4965
[06/24/2022-16:34:14] [V] [TRT] Identity_17 [Identity] outputs: [onnx::Concat_4965 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_18 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_18 [Identity] inputs: [onnx::Clip_4962 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Clip_4962_10 for ONNX node: onnx::Clip_4962
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_18 for ONNX node: Identity_18
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Clip_4964 for ONNX tensor: onnx::Clip_4964
[06/24/2022-16:34:14] [V] [TRT] Identity_18 [Identity] outputs: [onnx::Clip_4964 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_19 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_19 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_11 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_19 for ONNX node: Identity_19
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4960 for ONNX tensor: onnx::Concat_4960
[06/24/2022-16:34:14] [V] [TRT] Identity_19 [Identity] outputs: [onnx::Concat_4960 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_20 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_20 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_12 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_20 for ONNX node: Identity_20
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4959 for ONNX tensor: onnx::Concat_4959
[06/24/2022-16:34:14] [V] [TRT] Identity_20 [Identity] outputs: [onnx::Concat_4959 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_21 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_21 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_13 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_21 for ONNX node: Identity_21
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4958 for ONNX tensor: onnx::Concat_4958
[06/24/2022-16:34:14] [V] [TRT] Identity_21 [Identity] outputs: [onnx::Concat_4958 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_22 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_22 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_14 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_22 for ONNX node: Identity_22
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4957 for ONNX tensor: onnx::Concat_4957
[06/24/2022-16:34:14] [V] [TRT] Identity_22 [Identity] outputs: [onnx::Concat_4957 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_23 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_23 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_15 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_23 for ONNX node: Identity_23
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4956 for ONNX tensor: onnx::Concat_4956
[06/24/2022-16:34:14] [V] [TRT] Identity_23 [Identity] outputs: [onnx::Concat_4956 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_24 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_24 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_16 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_24 for ONNX node: Identity_24
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4955 for ONNX tensor: onnx::Concat_4955
[06/24/2022-16:34:14] [V] [TRT] Identity_24 [Identity] outputs: [onnx::Concat_4955 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_25 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_25 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_17 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_25 for ONNX node: Identity_25
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4954 for ONNX tensor: onnx::Concat_4954
[06/24/2022-16:34:14] [V] [TRT] Identity_25 [Identity] outputs: [onnx::Concat_4954 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_26 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_26 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_18 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_26 for ONNX node: Identity_26
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4953 for ONNX tensor: onnx::Concat_4953
[06/24/2022-16:34:14] [V] [TRT] Identity_26 [Identity] outputs: [onnx::Concat_4953 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_27 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_27 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_19 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_27 for ONNX node: Identity_27
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4952 for ONNX tensor: onnx::Concat_4952
[06/24/2022-16:34:14] [V] [TRT] Identity_27 [Identity] outputs: [onnx::Concat_4952 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_28 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_28 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_20 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_28 for ONNX node: Identity_28
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4951 for ONNX tensor: onnx::Concat_4951
[06/24/2022-16:34:14] [V] [TRT] Identity_28 [Identity] outputs: [onnx::Concat_4951 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_29 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_29 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_21 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_29 for ONNX node: Identity_29
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4950 for ONNX tensor: onnx::Concat_4950
[06/24/2022-16:34:14] [V] [TRT] Identity_29 [Identity] outputs: [onnx::Concat_4950 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_30 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_30 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_22 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_30 for ONNX node: Identity_30
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4949 for ONNX tensor: onnx::Concat_4949
[06/24/2022-16:34:14] [V] [TRT] Identity_30 [Identity] outputs: [onnx::Concat_4949 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_31 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_31 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_23 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_31 for ONNX node: Identity_31
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4948 for ONNX tensor: onnx::Concat_4948
[06/24/2022-16:34:14] [V] [TRT] Identity_31 [Identity] outputs: [onnx::Concat_4948 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_32 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_32 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_24 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_32 for ONNX node: Identity_32
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4947 for ONNX tensor: onnx::Concat_4947
[06/24/2022-16:34:14] [V] [TRT] Identity_32 [Identity] outputs: [onnx::Concat_4947 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_33 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_33 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_25 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_33 for ONNX node: Identity_33
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4946 for ONNX tensor: onnx::Concat_4946
[06/24/2022-16:34:14] [V] [TRT] Identity_33 [Identity] outputs: [onnx::Concat_4946 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_34 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_34 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_26 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_34 for ONNX node: Identity_34
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4945 for ONNX tensor: onnx::Concat_4945
[06/24/2022-16:34:14] [V] [TRT] Identity_34 [Identity] outputs: [onnx::Concat_4945 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_35 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_35 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_27 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_35 for ONNX node: Identity_35
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4944 for ONNX tensor: onnx::Concat_4944
[06/24/2022-16:34:14] [V] [TRT] Identity_35 [Identity] outputs: [onnx::Concat_4944 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_36 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_36 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_28 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_36 for ONNX node: Identity_36
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4943 for ONNX tensor: onnx::Concat_4943
[06/24/2022-16:34:14] [V] [TRT] Identity_36 [Identity] outputs: [onnx::Concat_4943 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_37 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_37 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_29 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_37 for ONNX node: Identity_37
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4942 for ONNX tensor: onnx::Concat_4942
[06/24/2022-16:34:14] [V] [TRT] Identity_37 [Identity] outputs: [onnx::Concat_4942 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_38 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_38 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_30 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_38 for ONNX node: Identity_38
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4941 for ONNX tensor: onnx::Concat_4941
[06/24/2022-16:34:14] [V] [TRT] Identity_38 [Identity] outputs: [onnx::Concat_4941 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_39 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_39 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_31 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_39 for ONNX node: Identity_39
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4940 for ONNX tensor: onnx::Concat_4940
[06/24/2022-16:34:14] [V] [TRT] Identity_39 [Identity] outputs: [onnx::Concat_4940 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_40 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_40 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_32 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_40 for ONNX node: Identity_40
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4939 for ONNX tensor: onnx::Concat_4939
[06/24/2022-16:34:14] [V] [TRT] Identity_40 [Identity] outputs: [onnx::Concat_4939 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_41 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_41 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_33 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_41 for ONNX node: Identity_41
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4938 for ONNX tensor: onnx::Concat_4938
[06/24/2022-16:34:14] [V] [TRT] Identity_41 [Identity] outputs: [onnx::Concat_4938 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_42 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_42 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_34 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_42 for ONNX node: Identity_42
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4937 for ONNX tensor: onnx::Concat_4937
[06/24/2022-16:34:14] [V] [TRT] Identity_42 [Identity] outputs: [onnx::Concat_4937 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_43 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_43 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_35 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_43 for ONNX node: Identity_43
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4936 for ONNX tensor: onnx::Concat_4936
[06/24/2022-16:34:14] [V] [TRT] Identity_43 [Identity] outputs: [onnx::Concat_4936 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_44 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_44 [Identity] inputs: [onnx::Concat_4933 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4933_36 for ONNX node: onnx::Concat_4933
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_44 for ONNX node: Identity_44
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4935 for ONNX tensor: onnx::Concat_4935
[06/24/2022-16:34:14] [V] [TRT] Identity_44 [Identity] outputs: [onnx::Concat_4935 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_45 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_45 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_37 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_45 for ONNX node: Identity_45
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4934 for ONNX tensor: onnx::Concat_4934
[06/24/2022-16:34:14] [V] [TRT] Identity_45 [Identity] outputs: [onnx::Concat_4934 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_46 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_46 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_38 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_46 for ONNX node: Identity_46
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4932 for ONNX tensor: onnx::Concat_4932
[06/24/2022-16:34:14] [V] [TRT] Identity_46 [Identity] outputs: [onnx::Concat_4932 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_47 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_47 [Identity] inputs: [onnx::Concat_4930 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4930_39 for ONNX node: onnx::Concat_4930
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_47 for ONNX node: Identity_47
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4931 for ONNX tensor: onnx::Concat_4931
[06/24/2022-16:34:14] [V] [TRT] Identity_47 [Identity] outputs: [onnx::Concat_4931 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_48 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Identity_48 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_48 for ONNX node: Identity_48
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4929 for ONNX tensor: onnx::Range_4929
[06/24/2022-16:34:14] [V] [TRT] Identity_48 [Identity] outputs: [onnx::Range_4929 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_49 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Identity_49 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_49 for ONNX node: Identity_49
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4928 for ONNX tensor: onnx::Range_4928
[06/24/2022-16:34:14] [V] [TRT] Identity_49 [Identity] outputs: [onnx::Range_4928 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_50 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_50 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_40 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_50 for ONNX node: Identity_50
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4927 for ONNX tensor: onnx::Range_4927
[06/24/2022-16:34:14] [V] [TRT] Identity_50 [Identity] outputs: [onnx::Range_4927 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_51 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_51 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_41 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_51 for ONNX node: Identity_51
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4926 for ONNX tensor: onnx::Range_4926
[06/24/2022-16:34:14] [V] [TRT] Identity_51 [Identity] outputs: [onnx::Range_4926 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_52 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_52 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_42 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_52 for ONNX node: Identity_52
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4925 for ONNX tensor: onnx::Range_4925
[06/24/2022-16:34:14] [V] [TRT] Identity_52 [Identity] outputs: [onnx::Range_4925 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_53 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_53 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_43 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_53 for ONNX node: Identity_53
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4924 for ONNX tensor: onnx::Range_4924
[06/24/2022-16:34:14] [V] [TRT] Identity_53 [Identity] outputs: [onnx::Range_4924 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_54 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_54 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_44 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_54 for ONNX node: Identity_54
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4923 for ONNX tensor: onnx::Range_4923
[06/24/2022-16:34:14] [V] [TRT] Identity_54 [Identity] outputs: [onnx::Range_4923 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_55 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_55 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_45 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_55 for ONNX node: Identity_55
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4922 for ONNX tensor: onnx::Range_4922
[06/24/2022-16:34:14] [V] [TRT] Identity_55 [Identity] outputs: [onnx::Range_4922 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_56 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_56 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_46 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_56 for ONNX node: Identity_56
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4921 for ONNX tensor: onnx::Range_4921
[06/24/2022-16:34:14] [V] [TRT] Identity_56 [Identity] outputs: [onnx::Range_4921 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_57 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_57 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_47 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_57 for ONNX node: Identity_57
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4920 for ONNX tensor: onnx::Range_4920
[06/24/2022-16:34:14] [V] [TRT] Identity_57 [Identity] outputs: [onnx::Range_4920 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_58 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_58 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_48 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_58 for ONNX node: Identity_58
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4919 for ONNX tensor: onnx::Range_4919
[06/24/2022-16:34:14] [V] [TRT] Identity_58 [Identity] outputs: [onnx::Range_4919 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_59 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_59 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_49 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_59 for ONNX node: Identity_59
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4918 for ONNX tensor: onnx::Range_4918
[06/24/2022-16:34:14] [V] [TRT] Identity_59 [Identity] outputs: [onnx::Range_4918 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_60 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_60 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_50 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_60 for ONNX node: Identity_60
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4917 for ONNX tensor: onnx::Range_4917
[06/24/2022-16:34:14] [V] [TRT] Identity_60 [Identity] outputs: [onnx::Range_4917 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_61 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_61 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_51 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_61 for ONNX node: Identity_61
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4916 for ONNX tensor: onnx::Range_4916
[06/24/2022-16:34:14] [V] [TRT] Identity_61 [Identity] outputs: [onnx::Range_4916 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_62 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_62 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_52 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_62 for ONNX node: Identity_62
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4915 for ONNX tensor: onnx::Range_4915
[06/24/2022-16:34:14] [V] [TRT] Identity_62 [Identity] outputs: [onnx::Range_4915 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_63 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_63 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_53 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_63 for ONNX node: Identity_63
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4914 for ONNX tensor: onnx::Range_4914
[06/24/2022-16:34:14] [V] [TRT] Identity_63 [Identity] outputs: [onnx::Range_4914 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_64 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_64 [Identity] inputs: [onnx::Range_4911 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4911_54 for ONNX node: onnx::Range_4911
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_64 for ONNX node: Identity_64
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4913 for ONNX tensor: onnx::Range_4913
[06/24/2022-16:34:14] [V] [TRT] Identity_64 [Identity] outputs: [onnx::Range_4913 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_65 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_65 [Identity] inputs: [onnx::Range_4910 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Range_4910_55 for ONNX node: onnx::Range_4910
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_65 for ONNX node: Identity_65
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Range_4912 for ONNX tensor: onnx::Range_4912
[06/24/2022-16:34:14] [V] [TRT] Identity_65 [Identity] outputs: [onnx::Range_4912 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_66 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Sub_4372
[06/24/2022-16:34:14] [V] [TRT] Identity_66 [Identity] inputs: [onnx::Sub_4372 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Sub_4372 for ONNX node: onnx::Sub_4372
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_66 for ONNX node: Identity_66
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Sub_4379 for ONNX tensor: onnx::Sub_4379
[06/24/2022-16:34:14] [V] [TRT] Identity_66 [Identity] outputs: [onnx::Sub_4379 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_67 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_67 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_56 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_67 for ONNX node: Identity_67
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4375 for ONNX tensor: onnx::Concat_4375
[06/24/2022-16:34:14] [V] [TRT] Identity_67 [Identity] outputs: [onnx::Concat_4375 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_68 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_68 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_57 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_68 for ONNX node: Identity_68
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4374 for ONNX tensor: onnx::Concat_4374
[06/24/2022-16:34:14] [V] [TRT] Identity_68 [Identity] outputs: [onnx::Concat_4374 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_69 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_69 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_58 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_69 for ONNX node: Identity_69
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4373 for ONNX tensor: onnx::Concat_4373
[06/24/2022-16:34:14] [V] [TRT] Identity_69 [Identity] outputs: [onnx::Concat_4373 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_70 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_70 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_59 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_70 for ONNX node: Identity_70
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4368 for ONNX tensor: onnx::Concat_4368
[06/24/2022-16:34:14] [V] [TRT] Identity_70 [Identity] outputs: [onnx::Concat_4368 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_71 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_71 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_60 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_71 for ONNX node: Identity_71
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4367 for ONNX tensor: onnx::Concat_4367
[06/24/2022-16:34:14] [V] [TRT] Identity_71 [Identity] outputs: [onnx::Concat_4367 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_72 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4993
[06/24/2022-16:34:14] [V] [TRT] Identity_72 [Identity] inputs: [onnx::Concat_4993 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_72 for ONNX node: Identity_72
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4995 for ONNX tensor: onnx::Concat_4995
[06/24/2022-16:34:14] [V] [TRT] Identity_72 [Identity] outputs: [onnx::Concat_4995 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_73 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4986
[06/24/2022-16:34:14] [V] [TRT] Identity_73 [Identity] inputs: [onnx::Concat_4986 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_73 for ONNX node: Identity_73
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4988 for ONNX tensor: onnx::Concat_4988
[06/24/2022-16:34:14] [V] [TRT] Identity_73 [Identity] outputs: [onnx::Concat_4988 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_74 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4375
[06/24/2022-16:34:14] [V] [TRT] Identity_74 [Identity] inputs: [onnx::Concat_4375 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_74 for ONNX node: Identity_74
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4378 for ONNX tensor: onnx::Concat_4378
[06/24/2022-16:34:14] [V] [TRT] Identity_74 [Identity] outputs: [onnx::Concat_4378 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_75 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4374
[06/24/2022-16:34:14] [V] [TRT] Identity_75 [Identity] inputs: [onnx::Concat_4374 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_75 for ONNX node: Identity_75
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4377 for ONNX tensor: onnx::Concat_4377
[06/24/2022-16:34:14] [V] [TRT] Identity_75 [Identity] outputs: [onnx::Concat_4377 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_76 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4373
[06/24/2022-16:34:14] [V] [TRT] Identity_76 [Identity] inputs: [onnx::Concat_4373 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_76 for ONNX node: Identity_76
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4376 for ONNX tensor: onnx::Concat_4376
[06/24/2022-16:34:14] [V] [TRT] Identity_76 [Identity] outputs: [onnx::Concat_4376 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_77 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4368
[06/24/2022-16:34:14] [V] [TRT] Identity_77 [Identity] inputs: [onnx::Concat_4368 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_77 for ONNX node: Identity_77
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4371 for ONNX tensor: onnx::Concat_4371
[06/24/2022-16:34:14] [V] [TRT] Identity_77 [Identity] outputs: [onnx::Concat_4371 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_78 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_4367
[06/24/2022-16:34:14] [V] [TRT] Identity_78 [Identity] inputs: [onnx::Concat_4367 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_78 for ONNX node: Identity_78
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4370 for ONNX tensor: onnx::Concat_4370
[06/24/2022-16:34:14] [V] [TRT] Identity_78 [Identity] outputs: [onnx::Concat_4370 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Identity_79 [Identity]
[06/24/2022-16:34:14] [V] [TRT] Identity_79 [Identity] inputs: [onnx::Concat_4366 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Concat_4366_61 for ONNX node: onnx::Concat_4366
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Identity_79 for ONNX node: Identity_79
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_4369 for ONNX tensor: onnx::Concat_4369
[06/24/2022-16:34:14] [V] [TRT] Identity_79 [Identity] outputs: [onnx::Concat_4369 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_80 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_80 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_80 [Constant] outputs: [onnx::Sub_315 -> (3, 1, 1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Sub_81 [Sub]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: image.1
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Sub_315
[06/24/2022-16:34:14] [V] [TRT] Sub_81 [Sub] inputs: [image.1 -> (3, 300, 400)[FLOAT]], [onnx::Sub_315 -> (3, 1, 1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Sub_315 for ONNX node: onnx::Sub_315
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Sub_81 for ONNX node: Sub_81
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Div_316 for ONNX tensor: onnx::Div_316
[06/24/2022-16:34:14] [V] [TRT] Sub_81 [Sub] outputs: [onnx::Div_316 -> (3, 300, 400)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_82 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_82 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_82 [Constant] outputs: [onnx::Div_317 -> (3, 1, 1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Div_83 [Div]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Div_316
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Div_317
[06/24/2022-16:34:14] [V] [TRT] Div_83 [Div] inputs: [onnx::Div_316 -> (3, 300, 400)[FLOAT]], [onnx::Div_317 -> (3, 1, 1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Div_317 for ONNX node: onnx::Div_317
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Div_83 for ONNX node: Div_83
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: image for ONNX tensor: image
[06/24/2022-16:34:14] [V] [TRT] Div_83 [Div] outputs: [image -> (3, 300, 400)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_84 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_84 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_84 [Constant] outputs: [onnx::ReduceMin_319 -> (2)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: ReduceMin_85 [ReduceMin]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::ReduceMin_319
[06/24/2022-16:34:14] [V] [TRT] ReduceMin_85 [ReduceMin] inputs: [onnx::ReduceMin_319 -> (2)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::ReduceMin_319 for ONNX node: onnx::ReduceMin_319
[06/24/2022-16:34:14] [V] [TRT] Registering layer: ReduceMin_85 for ONNX node: ReduceMin_85
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Cast_320 for ONNX tensor: onnx::Cast_320
[06/24/2022-16:34:14] [V] [TRT] ReduceMin_85 [ReduceMin] outputs: [onnx::Cast_320 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_86 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Cast_320
[06/24/2022-16:34:14] [V] [TRT] Cast_86 [Cast] inputs: [onnx::Cast_320 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Casting to type: float32
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_86 for ONNX node: Cast_86
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Reciprocal_321 for ONNX tensor: onnx::Reciprocal_321
[06/24/2022-16:34:14] [V] [TRT] Cast_86 [Cast] outputs: [onnx::Reciprocal_321 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: ReduceMax_87 [ReduceMax]
[06/24/2022-16:34:14] [V] [TRT] ReduceMax_87 [ReduceMax] inputs: [onnx::ReduceMin_319 -> (2)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::ReduceMin_319_62 for ONNX node: onnx::ReduceMin_319
[06/24/2022-16:34:14] [V] [TRT] Registering layer: ReduceMax_87 for ONNX node: ReduceMax_87
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Cast_322 for ONNX tensor: onnx::Cast_322
[06/24/2022-16:34:14] [V] [TRT] ReduceMax_87 [ReduceMax] outputs: [onnx::Cast_322 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_88 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Cast_322
[06/24/2022-16:34:14] [V] [TRT] Cast_88 [Cast] inputs: [onnx::Cast_322 -> ()[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_88 for ONNX node: Cast_88
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Reciprocal_323 for ONNX tensor: onnx::Reciprocal_323
[06/24/2022-16:34:14] [V] [TRT] Cast_88 [Cast] outputs: [onnx::Reciprocal_323 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Reciprocal_89 [Reciprocal]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Reciprocal_321
[06/24/2022-16:34:14] [V] [TRT] Reciprocal_89 [Reciprocal] inputs: [onnx::Reciprocal_321 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Original shape: (), unsqueezing to: (1,)
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Reciprocal_89 for ONNX node: Reciprocal_89
[06/24/2022-16:34:14] [V] [TRT] Original shape: (1,), squeezing to: ()
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Mul_324 for ONNX tensor: onnx::Mul_324
[06/24/2022-16:34:14] [V] [TRT] Reciprocal_89 [Reciprocal] outputs: [onnx::Mul_324 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_90 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_90 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_90 [Constant] outputs: [onnx::Mul_325 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Mul_91 [Mul]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_324
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_325
[06/24/2022-16:34:14] [V] [TRT] Mul_91 [Mul] inputs: [onnx::Mul_324 -> ()[FLOAT]], [onnx::Mul_325 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Mul_325 for ONNX node: onnx::Mul_325
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Mul_91 for ONNX node: Mul_91
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Min_326 for ONNX tensor: onnx::Min_326
[06/24/2022-16:34:14] [V] [TRT] Mul_91 [Mul] outputs: [onnx::Min_326 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Reciprocal_92 [Reciprocal]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Reciprocal_323
[06/24/2022-16:34:14] [V] [TRT] Reciprocal_92 [Reciprocal] inputs: [onnx::Reciprocal_323 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Reciprocal_92 for ONNX node: Reciprocal_92
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Mul_327 for ONNX tensor: onnx::Mul_327
[06/24/2022-16:34:14] [V] [TRT] Reciprocal_92 [Reciprocal] outputs: [onnx::Mul_327 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_93 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_93 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_93 [Constant] outputs: [onnx::Mul_328 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Mul_94 [Mul]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_327
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_328
[06/24/2022-16:34:14] [V] [TRT] Mul_94 [Mul] inputs: [onnx::Mul_327 -> ()[FLOAT]], [onnx::Mul_328 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Mul_328 for ONNX node: onnx::Mul_328
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Mul_94 for ONNX node: Mul_94
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Min_329 for ONNX tensor: onnx::Min_329
[06/24/2022-16:34:14] [V] [TRT] Mul_94 [Mul] outputs: [onnx::Min_329 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Min_95 [Min]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Min_326
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Min_329
[06/24/2022-16:34:14] [V] [TRT] Min_95 [Min] inputs: [onnx::Min_326 -> ()[FLOAT]], [onnx::Min_329 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Min_95 for ONNX node: Min_95
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: scale_factor for ONNX tensor: scale_factor
[06/24/2022-16:34:14] [V] [TRT] Min_95 [Min] outputs: [scale_factor -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Unsqueeze_96 [Unsqueeze]
[06/24/2022-16:34:14] [V] [TRT] Unsqueeze_96 [Unsqueeze] inputs: [image -> (3, 300, 400)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Original shape: (3, 300, 400), unsqueezing to: (1, 3, 300, 400)
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Unsqueeze_96 for ONNX node: Unsqueeze_96
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: input for ONNX tensor: input
[06/24/2022-16:34:14] [V] [TRT] Unsqueeze_96 [Unsqueeze] outputs: [input -> (1, 3, 300, 400)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_97 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: scale_factor
[06/24/2022-16:34:14] [V] [TRT] Cast_97 [Cast] inputs: [scale_factor -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_97 for ONNX node: Cast_97
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Mul_332 for ONNX tensor: onnx::Mul_332
[06/24/2022-16:34:14] [V] [TRT] Cast_97 [Cast] outputs: [onnx::Mul_332 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_98 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_98 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_98 [Constant] outputs: [onnx::Mul_333 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Mul_99 [Mul]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_333
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_332
[06/24/2022-16:34:14] [V] [TRT] Mul_99 [Mul] inputs: [onnx::Mul_333 -> ()[FLOAT]], [onnx::Mul_332 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Mul_333 for ONNX node: onnx::Mul_333
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Mul_99 for ONNX node: Mul_99
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Cast_334 for ONNX tensor: onnx::Cast_334
[06/24/2022-16:34:14] [V] [TRT] Mul_99 [Mul] outputs: [onnx::Cast_334 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_100 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Cast_334
[06/24/2022-16:34:14] [V] [TRT] Cast_100 [Cast] inputs: [onnx::Cast_334 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_100 for ONNX node: Cast_100
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Floor_335 for ONNX tensor: onnx::Floor_335
[06/24/2022-16:34:14] [V] [TRT] Cast_100 [Cast] outputs: [onnx::Floor_335 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Floor_101 [Floor]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Floor_335
[06/24/2022-16:34:14] [V] [TRT] Floor_101 [Floor] inputs: [onnx::Floor_335 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Floor_101 for ONNX node: Floor_101
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Unsqueeze_336 for ONNX tensor: onnx::Unsqueeze_336
[06/24/2022-16:34:14] [V] [TRT] Floor_101 [Floor] outputs: [onnx::Unsqueeze_336 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_102 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Cast_102 [Cast] inputs: [scale_factor -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_102 for ONNX node: Cast_102
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Mul_337 for ONNX tensor: onnx::Mul_337
[06/24/2022-16:34:14] [V] [TRT] Cast_102 [Cast] outputs: [onnx::Mul_337 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_103 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_103 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_103 [Constant] outputs: [onnx::Mul_338 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Mul_104 [Mul]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_338
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Mul_337
[06/24/2022-16:34:14] [V] [TRT] Mul_104 [Mul] inputs: [onnx::Mul_338 -> ()[FLOAT]], [onnx::Mul_337 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: onnx::Mul_338 for ONNX node: onnx::Mul_338
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Mul_104 for ONNX node: Mul_104
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Cast_339 for ONNX tensor: onnx::Cast_339
[06/24/2022-16:34:14] [V] [TRT] Mul_104 [Mul] outputs: [onnx::Cast_339 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_105 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Cast_339
[06/24/2022-16:34:14] [V] [TRT] Cast_105 [Cast] inputs: [onnx::Cast_339 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_105 for ONNX node: Cast_105
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Floor_340 for ONNX tensor: onnx::Floor_340
[06/24/2022-16:34:14] [V] [TRT] Cast_105 [Cast] outputs: [onnx::Floor_340 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Floor_106 [Floor]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Floor_340
[06/24/2022-16:34:14] [V] [TRT] Floor_106 [Floor] inputs: [onnx::Floor_340 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Floor_106 for ONNX node: Floor_106
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Unsqueeze_341 for ONNX tensor: onnx::Unsqueeze_341
[06/24/2022-16:34:14] [V] [TRT] Floor_106 [Floor] outputs: [onnx::Unsqueeze_341 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Unsqueeze_107 [Unsqueeze]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Unsqueeze_336
[06/24/2022-16:34:14] [V] [TRT] Unsqueeze_107 [Unsqueeze] inputs: [onnx::Unsqueeze_336 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Unsqueeze_107 for ONNX node: Unsqueeze_107
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_342 for ONNX tensor: onnx::Concat_342
[06/24/2022-16:34:14] [V] [TRT] Unsqueeze_107 [Unsqueeze] outputs: [onnx::Concat_342 -> (1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Unsqueeze_108 [Unsqueeze]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Unsqueeze_341
[06/24/2022-16:34:14] [V] [TRT] Unsqueeze_108 [Unsqueeze] inputs: [onnx::Unsqueeze_341 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Unsqueeze_108 for ONNX node: Unsqueeze_108
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_343 for ONNX tensor: onnx::Concat_343
[06/24/2022-16:34:14] [V] [TRT] Unsqueeze_108 [Unsqueeze] outputs: [onnx::Concat_343 -> (1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Concat_109 [Concat]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_342
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_343
[06/24/2022-16:34:14] [V] [TRT] Concat_109 [Concat] inputs: [onnx::Concat_342 -> (1)[FLOAT]], [onnx::Concat_343 -> (1)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Concat_109 for ONNX node: Concat_109
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Cast_344 for ONNX tensor: onnx::Cast_344
[06/24/2022-16:34:14] [V] [TRT] Concat_109 [Concat] outputs: [onnx::Cast_344 -> (2)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Shape_110 [Shape]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: input
[06/24/2022-16:34:14] [V] [TRT] Shape_110 [Shape] inputs: [input -> (1, 3, 300, 400)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Shape_110 for ONNX node: Shape_110
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Slice_345 for ONNX tensor: onnx::Slice_345
[06/24/2022-16:34:14] [V] [TRT] Shape_110 [Shape] outputs: [onnx::Slice_345 -> (4)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_111 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_111 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_111 [Constant] outputs: [onnx::Slice_346 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_112 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_112 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_112 [Constant] outputs: [onnx::Slice_347 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_113 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_113 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_113 [Constant] outputs: [onnx::Slice_348 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Slice_114 [Slice]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Slice_345
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Slice_347
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Slice_348
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Slice_346
[06/24/2022-16:34:14] [V] [TRT] Slice_114 [Slice] inputs: [onnx::Slice_345 -> (4)[INT32]], [onnx::Slice_347 -> (1)[INT32]], [onnx::Slice_348 -> (1)[INT32]], [onnx::Slice_346 -> (1)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Slice_114 for ONNX node: Slice_114
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_349 for ONNX tensor: onnx::Concat_349
[06/24/2022-16:34:14] [V] [TRT] Slice_114 [Slice] outputs: [onnx::Concat_349 -> (2)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Cast_115 [Cast]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Cast_344
[06/24/2022-16:34:14] [V] [TRT] Cast_115 [Cast] inputs: [onnx::Cast_344 -> (2)[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Casting to type: int32
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Cast_115 for ONNX node: Cast_115
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Concat_350 for ONNX tensor: onnx::Concat_350
[06/24/2022-16:34:14] [V] [TRT] Cast_115 [Cast] outputs: [onnx::Concat_350 -> (2)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Concat_116 [Concat]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_349
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Concat_350
[06/24/2022-16:34:14] [V] [TRT] Concat_116 [Concat] inputs: [onnx::Concat_349 -> (2)[INT32]], [onnx::Concat_350 -> (2)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Concat_116 for ONNX node: Concat_116
[06/24/2022-16:34:14] [V] [TRT] Registering tensor: onnx::Resize_351 for ONNX tensor: onnx::Resize_351
[06/24/2022-16:34:14] [V] [TRT] Concat_116 [Concat] outputs: [onnx::Resize_351 -> (4)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_117 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_117 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_117 [Constant] outputs: [onnx::Resize_352 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Constant_118 [Constant]
[06/24/2022-16:34:14] [V] [TRT] Constant_118 [Constant] inputs:
[06/24/2022-16:34:14] [V] [TRT] Constant_118 [Constant] outputs: [onnx::Resize_353 -> ()[FLOAT]],
[06/24/2022-16:34:14] [V] [TRT] Parsing node: Resize_119 [Resize]
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Resize_352
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Resize_353
[06/24/2022-16:34:14] [V] [TRT] Searching for input: onnx::Resize_351
[06/24/2022-16:34:14] [V] [TRT] Resize_119 [Resize] inputs: [input -> (1, 3, 300, 400)[FLOAT]], [onnx::Resize_352 -> ()[FLOAT]], [onnx::Resize_353 -> ()[FLOAT]], [onnx::Resize_351 -> (4)[INT32]],
[06/24/2022-16:34:14] [V] [TRT] Registering layer: Resize_119 for ONNX node: Resize_119
[06/24/2022-16:34:14] [I] Finish parsing network model
&&&& FAILED TensorRT.trtexec [TensorRT v8205] # /opt/tensorrt/bin/trtexec --onnx=keypoint_rcnn.onnx --verbose
