Sourcing and running a model with both Bounding Boxes and Keypoints in Deepstream
GPU
• DeepStream Version
Any / Latest
• TensorRT Version
Any / Latest
Any / Latest
Questions
I would like to run a model that does both Bounding Boxes and Keypoints (2 keypoints, not human) in Deepstream. My application has 100’s of cameras so I need deepstream for the decode/infer throughput capabilities.
Pytorch has an official model called Keypoint R-CNN here: Link
I have tried and failed to use this with trtexec after exporting ONNX model: Link
I have also tried and failed to export this using torch2trt: Link
Questions:
  • Ideally I would like to use the Pytorch Keypoint R-CNN model, or at least try it first since I have already trained it with a small amount of data. Are there any other paths aside from the failed onnx and torch2trt routes to getting the model running in Deepstream?
  • If the Pytorch Keypoint R-CNN model is not able to be used in Deepstream, what is the recommended model with both keypoints and bounding boxes to be used with Deepstream? I see the TF2 Model Zoo has some models with both, but is there any other “official” (easy!) way supported by NVIDIA?
Hi @brian0b6iu ,
You could use nvinferserver (Triton) with torch as backend.
nvinferserver - Gst-nvinferserver — DeepStream documentation
you can refer to python DeepStream sample - https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps/deepstream-ssd-parser or C++ DeepStream sample /opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-infer-tensor-meta-test .
How about TAO peopledet + bodypose2d
TAO peoplenet: Overview — Tao Toolkit , https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/blob/master/deepstream_app_tao_configs/README.md
bodypose2d:
https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/blob/master/apps/tao_others/deepstream-bodypose2d-app/deepstream_bodypose2d_app.cpp
or
Thanks for the response.
Do you mean the bodypose as mentioned here? https://developer.nvidia.com/blog/training-optimizing-2d-pose-estimation-model-with-tao-toolkit-part-1/
So I could used e.g. YOLOv3 as to get the box, then use bodypose as a secondary inference SGIE on this?
I think the deepstream_bodypose2d_app.cpp you linked has the bodypose as a PGIE, is this correct?
If my assumptions are correct, is it possible to retrain the bodypose for custom keypoints? My target object is not a human.
Hi @brian0b6iu ,
I think peoplenet is ligher than YoloV3 with high detect accuracy.
Not sure, you may could take a try
