I follow this link and I can get the deep stream working, but I stuck at the trt-pose, export fail. (Not json file something…)
nvidia@nvidia-desktop:~/trt_pose/trt_pose/utils$ sudo python export_for_isaac.py --input_checkpoint resnet18_baseline_att_224x224_A_epoch_249.pth
[sudo] password for nvidia:
File "export_for_isaac.py", line 56, in <module>
import torch # Please refer to: https://pytorch.org/get-started/locally/
ImportError: No module named torch
nvidia@nvidia-desktop:~/trt_pose/trt_pose/utils$ sudo python3 export_for_isaac.py --input_checkpoint resnet18_baseline_att_224x224_A_epoch_249.pth
Input model is not specified, using resnet18_baseline_att as a default.
Input width/height are not specified, using 224x224 as a default.
Output path is not specified, using resnet18_baseline_att_224x224_A_epoch_249.onnx as a default.
Input topology human_pose.json is not a valid (.json) file.
Is there any tutorial or complete guide of installation?
I saw it can be done, Deepstream_pose_estimation
But I guess may be some library has changed…
Shall I use deepstream 6.0?
I have read this post, but they can run it, but I cannot, is there any library version issue?
vnvidia@nvidia-desktop:~/deepstream_pose_estimation$ sudo ./deepstream-pose-estimation-app video.mp4 .
One element could not be created. Exiting.
Here is what I did for a month of trial and error. >_<
Following this link
https://github.com/NVIDIA-AI-IOT/deepstream_pose_estimation#:~:text=Human%20pose%20estimation%20is%20the,a%20video%20or%20a%20photo.
1. Install DeepStream on your platform, verify it is working by running deepstream-app.
Download DeepStream 5.0to my Downloads folder
https://developer.nvidia.com/assets/Deepstream/5.0/ga/secure/deepstream_sdk_5.0_jetson.tbz2
Follow the setup guide "Install Jetson SDK compenents"
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#jetson-setup
nvidia@nvidia-desktop:~$ sudo apt install \
> libssl1.0.0 \
> libgstreamer1.0-0 \
> gstreamer1.0-tools \
> gstreamer1.0-plugins-good \
> gstreamer1.0-plugins-bad \
> gstreamer1.0-plugins-ugly \
> gstreamer1.0-libav \
> libgstrtspserver-1.0-0 \
> libjansson4=2.11-1
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libgstrtspserver-1.0-0
E: Couldn't find any package by glob 'libgstrtspserver-1.0-0'
E: Couldn't find any package by regex 'libgstrtspserver-1.0-0'
Follow this link, https://zoomadmin.com/HowToInstall/UbuntuPackage/libgstrtspserver-1.0-0
sudo apt-get update -y
sudo apt-get install -y libgstrtspserver-1.0-0
> libssl1.0.0 \
> libgstreamer1.0-0 \
> libjansson4=2.11-1
git clone https://github.com/edenhill/librdkafka.git
cd librdkafka
git reset --hard 7101c2310341ab3f4675fc565f64f0967e135a6a
./configure
make
sudo make install
#need to modify for 5.0
sudo mkdir -p /opt/nvidia/deepstream/deepstream-5.0/lib
sudo cp /usr/local/lib/librdkafka* /opt/nvidia/deepstream/deepstream-5.0/lib
sudo vi /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
Modify the code to
deb https://repo.download.nvidia.com/jetson/common r32.6 main
deb https://repo.download.nvidia.com/jetson/t194 r32.6 main
sudo apt update
sudo apt install --reinstall nvidia-l4t-gstreamer
sudo apt install --reinstall nvidia-l4t-multimedia
sudo apt install --reinstall nvidia-l4t-core
cd
cd Downloads
sudo tar -xvf deepstream_sdk_5.0_jetson.tbz2 -C /
cd /opt/nvidia/deepstream/deepstream-5.0
sudo ./install.sh
sudo ldconfig
cd /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps
sudo git clone https://github.com/NVIDIA-AI-IOT/deepstream_pose_estimation.git
cd
#Goto trtpose
#Install pytorch and torchyvision
#Follow: https://forums.developer.nvidia.com/t/pytorch-for-jetson-version-1-10-now-available/72048
wget https://nvidia.box.com/shared/static/p57jwntv436lfrd78inwl7iml6p13fzh.whl -O torch-1.8.0-cp36-cp36m-linux_aarch64.whl
sudo apt-get install python3-pip libopenblas-base libopenmpi-dev
pip3 install Cython
pip3 install numpy torch-1.8.0-cp36-cp36m-linux_aarch64.whl
##torchvision
sudo apt-get install libjpeg-dev zlib1g-dev libpython3-dev libavcodec-dev libavformat-dev libswscale-dev
git clone --branch v0.9.0 https://github.com/pytorch/vision torchvision
cd torchvision
export BUILD_VERSION=0.9.0
python3 setup.py install --user
cd ../
pip install 'pillow<7'
# pip not found
apt-get install python-pip
git clone https://github.com/NVIDIA-AI-IOT/torch2trt
cd torch2trt
sudo python3 setup.py install --plugins
#ModuleNotFoundError: No module named 'packaging'
#from this link, https://stackoverflow.com/questions/42222096/no-module-named-packaging
pip3 install --upgrade pip
pip3 install packaging
sudo pip3 install tqdm cython pycocotools
sudo apt-get install python3-matplotlib
cd
git clone https://github.com/NVIDIA-AI-IOT/trt_pose
cd trt_pose
#Download the two model
https://drive.google.com/file/d/1XYDdCUdiF2xxx4rznmLb62SdOUZuoNbd/view?usp=drive_open
https://drive.google.com/file/d/13FkJkx7evQ1WwP54UmdiDXWyFMY1OxDU/view?usp=drive_open
#copy these two models to Place the downloaded weights in the tasks/human_pose directory
#copy these two models to Place the downloaded weights in the ~trt_pose/trt_pose/utils directory
cd
cd trt_pose/trt_pose/utils
#error
# follow this link
https://forums.developer.nvidia.com/t/conversion-of-model-weights-for-human-pose-estimation-model-to-onnx-results-in-nonsensical-pose-estimation/164417/11
#freeze
#need to increase the swap memory
python3 export_for_isaac.py --input_checkpoint resnet18_baseline_att_224x224_A_epoch_249.pth --input_topology ../../tasks/human_pose/human_pose.json
cd
#copy the onnx file to deepstream_pose_estimation
#Replace the OSD binaries (x86 or Jetson) in $DEEPSTREAM_DIR/libs with the ones provided in this #repository under bin/. Please note that these are not inter-compatible across platforms.
nvidia@nvidia-desktop:~/deepstream_pose_estimation/bin$ ls
Jetson x86
nvidia@nvidia-desktop:~/deepstream_pose_estimation/bin$ cd Jetson/
nvidia@nvidia-desktop:~/deepstream_pose_estimation/bin/Jetson$ ls
libnvds_osd.so
nvidia@nvidia-desktop:~/deepstream_pose_estimation/bin/Jetson$ sudo cp libnvds_osd.so /opt/nvidia/deepstream/deepstream-5.0/lib
nvidia@nvidia-desktop:~/deepstream_pose_estimation$ sudo make
Package json-glib-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `json-glib-1.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'json-glib-1.0' found
g++ -c -o deepstream_pose_estimation_app.o -DPLATFORM_TEGRA -I../../apps-common/includes -I../../../includes -I../deepstream-app/ -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=5 deepstream_pose_estimation_app.cpp
In file included from deepstream_pose_estimation_app.cpp:4:0:
post_process.cpp:8:10: fatal error: gst/gst.h: No such file or directory
#include <gst/gst.h>
compilation terminated.
Makefile:44: recipe for target 'deepstream_pose_estimation_app.o' failed
make: *** [deepstream_pose_estimation_app.o] Error 1
sudo apt-get install libgstreamer1.0-dev
sudo apt install libjson-glib-dev
g++ -c -o deepstream_pose_estimation_app.o -DPLATFORM_TEGRA -I../../apps-common/includes -I../../../includes -I../deepstream-app/ -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=5 -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/json-glib-1.0 -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include deepstream_pose_estimation_app.cpp
post_process.cpp:12:10: fatal error: gstnvdsmeta.h: No such file or directory
#include "gstnvdsmeta.h"
#copy all files in /opt/nvidia/deepstream/deepstream-5.1/sources/includes/ to deepstream_pose_estimation
sudo make
#download a crowd video from https://www.pexels.com/search/videos/crowd/
$copy the video.mp4 to :~/deepstream_pose_estimation
sudo ./deepstream-pose-estimation-app test.mp4
nvidia@nvidia-desktop:~/deepstream_pose_estimation$ sudo ./deepstream-pose-estimation-app test.mp4 .
nvidia@nvidia-desktop:~/deepstream_pose_estimation$ sudo ./deepstream-pose-estimation-app test.mp4 Pose_Estimation.mp4
#edit deepstream_pose_estimation_config.txt
[property]
gpu-id=0
net-scale-factor=0.0174292
offsets=123.675;116.28;103.53
onnx-file=resnet18_baseline_att_224x224_A_epoch_249.onnx
labelfile-path=labels.txt
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=4
interval=0
gie-unique-id=1
model-engine-file=pose_estimation.onnx_b1_gpu0_fp16.engine
network-type=100
workspace-size=3000
I use Deepstream 5.0, I tried deepstream6.0 before but it has error.
For my way, I just copy all header file to deepstream_pose_estimation
Up to now, I stuck at the very last step.
nvidia@nvidia-desktop:~/deepstream_pose_estimation$ ./deepstream-pose-estimation-app test.mp4 .
Should do the whole thing again using deepstream6.0. >_<
I don’t mind as soon as there is a clear instruction.
I have been working on this for 2 weeks already…
Thx
nvidia@nvidia-desktop:~/deepstream_pose_estimation$ ls
bin
CLA_LICENSE.md
cover_table.hpp
deepstream_pose_estimation_config.bak
gstnvdsbufferpool.h
gstnvdsinfer.h
gstnvdsmeta.h
gst-nvdssr.h
gst-nvevent.h
gst-nvmessage.h
gst-nvquery.h
images
LICENSE.md
Makefile
munkres_algorithm.cpp
nvbufsurface.h
nvbufsurftransform.h
nvds_analytics_meta.h
nvds_dewarper_meta.h
nvdsgstutils.h
nvdsinfer_context.h
nvdsinfer_custom_impl.h
nvdsinfer_dbscan.h
nvdsinfer.h
nvdsinferserver_config.proto
nvdsinferserver_plugin.proto
nvdsinfer_tlt.h
nvdsinfer_utils.h
nvds_latency_meta.h
nvds_logger.h
nvds_mask_utils.h
nvdsmeta.h
nvdsmeta_schema.h
nvds_msgapi.h
nvds_obj_encode.h
nvds_opticalflow_meta.h
nvdstracker.h
nvds_tracker_meta.h
nvds_version.h
nvll_osd_api.h
nvll_osd_struct.h
nvmsgbroker.h
pair_graph.hpp
post_process.cpp
README.md
test.mp4
video.mp4
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation$ sudo make
deepstream_pose_estimation_app.cpp: In function ‘GstPadProbeReturn osd_sink_pad_buffer_probe(GstPad*, GstPadProbeInfo*, gpointer)’:
deepstream_pose_estimation_app.cpp:231:77: warning: zero-length gnu_printf format string [-Wformat-zero-length]
offset = snprintf(txt_params->display_text + offset, MAX_DISPLAY_LEN, "");
deepstream_pose_estimation_app.cpp:236:41: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
txt_params->font_params.font_name = "Mono";
g++ -o deepstream-pose-estimation-app deepstream_pose_estimation_app.o -L/opt/nvidia/deepstream/deepstream-5.0/lib/ -lnvdsgst_meta -lnvds_meta -lnvds_utils -lm -lpthread -ldl -Wl,-rpath,/opt/nvidia/deepstream/deepstream-5.0/lib/ -lgstvideo-1.0 -lgstbase-1.0 -lgstreamer-1.0 -lX11 -ljson-glib-1.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation$ sudo ./deepstream-pose-estimation-app test.mp4 .
