root@caper-desktop:/media/sbot1/wilbur/models# /usr/src/tensorrt/bin/trtexec --onnx=saved_model_qat_no_auto.onnx --saveEngine=saved_model_qat.trt --minShapes=input_1:1x224x224x1 --optShapes=input_1:2x224x224x1 --maxShapes=input_1:2x224x224x1 --int8 --verbose
&&&& RUNNING TensorRT.trtexec [TensorRT v8401] # /usr/src/tensorrt/bin/trtexec --onnx=saved_model_qat_no_auto.onnx --saveEngine=saved_model_qat.trt --minShapes=input_1:1x224x224x1 --optShapes=input_1:2x224x224x1 --maxShapes=input_1:2x224x224x1 --int8 --verbose
[12/22/2022-04:34:52] [I] === Model Options ===
[12/22/2022-04:34:52] [I] Format: ONNX
[12/22/2022-04:34:52] [I] Model: saved_model_qat_no_auto.onnx
[12/22/2022-04:34:52] [I] Output:
[12/22/2022-04:34:52] [I] === Build Options ===
[12/22/2022-04:34:52] [I] Max batch: explicit batch
[12/22/2022-04:34:52] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[12/22/2022-04:34:52] [I] minTiming: 1
[12/22/2022-04:34:52] [I] avgTiming: 8
[12/22/2022-04:34:52] [I] Precision: FP32+INT8
[12/22/2022-04:34:52] [I] LayerPrecisions:
[12/22/2022-04:34:52] [I] Calibration: Dynamic
[12/22/2022-04:34:52] [I] Refit: Disabled
[12/22/2022-04:34:52] [I] Sparsity: Disabled
[12/22/2022-04:34:52] [I] Safe mode: Disabled
[12/22/2022-04:34:52] [I] DirectIO mode: Disabled
[12/22/2022-04:34:52] [I] Restricted mode: Disabled
[12/22/2022-04:34:52] [I] Build only: Disabled
[12/22/2022-04:34:52] [I] Save engine: saved_model_qat.trt
[12/22/2022-04:34:52] [I] Load engine:
[12/22/2022-04:34:52] [I] Profiling verbosity: 0
[12/22/2022-04:34:52] [I] Tactic sources: Using default tactic sources
[12/22/2022-04:34:52] [I] timingCacheMode: local
[12/22/2022-04:34:52] [I] timingCacheFile:
[12/22/2022-04:34:52] [I] Input(s)s format: fp32:CHW
[12/22/2022-04:34:52] [I] Output(s)s format: fp32:CHW
[12/22/2022-04:34:52] [I] Input build shape: input_1=1x224x224x1+2x224x224x1+2x224x224x1
[12/22/2022-04:34:52] [I] Input calibration shapes: model
[12/22/2022-04:34:52] [I] === System Options ===
[12/22/2022-04:34:52] [I] Device: 0
[12/22/2022-04:34:52] [I] DLACore:
[12/22/2022-04:34:52] [I] Plugins:
[12/22/2022-04:34:52] [I] === Inference Options ===
[12/22/2022-04:34:52] [I] Batch: Explicit
[12/22/2022-04:34:52] [I] Input inference shape: input_1=2x224x224x1
[12/22/2022-04:34:52] [I] Iterations: 10
[12/22/2022-04:34:52] [I] Duration: 3s (+ 200ms warm up)
[12/22/2022-04:34:52] [I] Sleep time: 0ms
[12/22/2022-04:34:52] [I] Idle time: 0ms
[12/22/2022-04:34:52] [I] Streams: 1
[12/22/2022-04:34:52] [I] ExposeDMA: Disabled
[12/22/2022-04:34:52] [I] Data transfers: Enabled
[12/22/2022-04:34:52] [I] Spin-wait: Disabled
[12/22/2022-04:34:52] [I] Multithreading: Disabled
[12/22/2022-04:34:52] [I] CUDA Graph: Disabled
[12/22/2022-04:34:52] [I] Separate profiling: Disabled
[12/22/2022-04:34:52] [I] Time Deserialize: Disabled
[12/22/2022-04:34:52] [I] Time Refit: Disabled
[12/22/2022-04:34:52] [I] Inputs:
[12/22/2022-04:34:52] [I] === Reporting Options ===
[12/22/2022-04:34:52] [I] Verbose: Enabled
[12/22/2022-04:34:52] [I] Averages: 10 inferences
[12/22/2022-04:34:52] [I] Percentile: 99
[12/22/2022-04:34:52] [I] Dump refittable layers:Disabled
[12/22/2022-04:34:52] [I] Dump output: Disabled
[12/22/2022-04:34:52] [I] Profile: Disabled
[12/22/2022-04:34:52] [I] Export timing to JSON file:
[12/22/2022-04:34:52] [I] Export output to JSON file:
[12/22/2022-04:34:52] [I] Export profile to JSON file:
[12/22/2022-04:34:52] [I] === Device Information ===
[12/22/2022-04:34:52] [I] Selected Device: Xavier
[12/22/2022-04:34:52] [I] Compute Capability: 7.2
[12/22/2022-04:34:52] [I] SMs: 8
[12/22/2022-04:34:52] [I] Compute Clock Rate: 1.377 GHz
[12/22/2022-04:34:52] [I] Device Global Memory: 31002 MiB
[12/22/2022-04:34:52] [I] Shared Memory per SM: 96 KiB
[12/22/2022-04:34:52] [I] Memory Bus Width: 256 bits (ECC disabled)
[12/22/2022-04:34:52] [I] Memory Clock Rate: 1.377 GHz
[12/22/2022-04:34:52] [I] TensorRT version: 8.4.1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::ScatterND version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::BatchTilePlugin_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::CropAndResizeDynamic version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::ProposalDynamic version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::Proposal version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::Split version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 2
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::CoordConvAC version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::DecodeBbox3DPlugin version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::GenerateDetection_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::NMSDynamic_TRT version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::PillarScatterPlugin version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::VoxelGeneratorPlugin version 1
[12/22/2022-04:34:52] [V] [TRT] Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1
[12/22/2022-04:34:53] [I] [TRT] [MemUsageChange] Init CUDA: CPU +185, GPU +0, now: CPU 209, GPU 5902 (MiB)
[12/22/2022-04:34:55] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +131, GPU +123, now: CPU 359, GPU 6042 (MiB)
[12/22/2022-04:34:55] [I] Start parsing network model
[12/22/2022-04:34:55] [I] [TRT] ----------------------------------------------------------------
[12/22/2022-04:34:55] [I] [TRT] Input filename: saved_model_qat_no_auto.onnx
[12/22/2022-04:34:55] [I] [TRT] ONNX IR version: 0.0.7
[12/22/2022-04:34:55] [I] [TRT] Opset version: 13
[12/22/2022-04:34:55] [I] [TRT] Producer name: tf2onnx
[12/22/2022-04:34:55] [I] [TRT] Producer version: 1.10.1 a37f29
[12/22/2022-04:34:55] [I] [TRT] Domain:
[12/22/2022-04:34:55] [I] [TRT] Model version: 0
[12/22/2022-04:34:55] [I] [TRT] Doc string:
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::GridAnchorRect_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::ScatterND version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::BatchedNMSDynamic_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::BatchTilePlugin_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::CropAndResizeDynamic version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::EfficientNMS_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::EfficientNMS_ONNX_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Explicit_TF_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::EfficientNMS_Implicit_TF_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::ProposalDynamic version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::Split version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 2
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::CoordConvAC version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::DecodeBbox3DPlugin version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::GenerateDetection_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::MultilevelCropAndResize_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::MultilevelProposeROI_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::NMSDynamic_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::PillarScatterPlugin version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::VoxelGeneratorPlugin version 1
[12/22/2022-04:34:55] [V] [TRT] Plugin creator already registered - ::MultiscaleDeformableAttnPlugin_TRT version 1
[12/22/2022-04:34:55] [V] [TRT] Adding network input: input_1 with dtype: float32, dimensions: (-1, 224, 224, 1)
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: input_1 for ONNX tensor: input_1
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: const_fold_opt__540
[12/22/2022-04:34:55] [W] [TRT] onnx2trt_utils.cpp:367: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: const_fold_opt__538
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: const_fold_opt__529
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: const_fold_opt__527
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: const_axes__81
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: const_axes__543
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_zpy__94
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_scaley__93
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_9_relu/MovingAvgQuantize/FakeQuantWithMinMaxVars_scaley__386
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_9/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_9/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_8/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_8/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_7/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_7/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_6/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_6/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_5_relu/MovingAvgQuantize/FakeQuantWithMinMaxVars_zpy__263
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_5/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_5/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_4/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_4/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_3_relu/Relu6_max__199
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_3/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_3/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_2/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_2/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_13/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_13/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_12/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_12/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_11/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_11/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_10/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_10/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_1/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_pw_1/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_9/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_9/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_8/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_8/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_7/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_7/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_6/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_6/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_5_relu/Relu6_min__246
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_5/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_5/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_4/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_4/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_3/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_3/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_2_relu/MovingAvgQuantize/FakeQuantWithMinMaxVars_scaley__155
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_2/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_2/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_1_relu/MovingAvgQuantize/FakeQuantWithMinMaxVars_scaley__124
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_13/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_13/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_12/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_12/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_11/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_11/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_10/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_10/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_1/depthwise_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv_dw_1/depthwise_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv1_relu/MovingAvgQuantize/FakeQuantWithMinMaxVars_zpy__108
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv1_relu/MovingAvgQuantize/FakeQuantWithMinMaxVars_scaley__107
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv1/Conv2D_weights_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quant_conv1/Conv2D_bias_fused_bn
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/dense/MatMul/ReadVariableOp:0
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1/y:0
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_5__37
[12/22/2022-04:34:55] [V] [TRT] Importing initializer: StatefulPartitionedCall/angle_model/coordinate_channel/Cast_3__35
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/Shape [Shape]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: input_1
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Shape [Shape] inputs: [input_1 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/Shape for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/Shape
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Shape:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Shape:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Shape [Shape] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Shape:0 -> (4)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45 [Cast]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/Shape:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45 [Cast] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Shape:0 -> (4)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Casting to type: int32
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45 [Cast] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45:0 -> (4)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice [Slice]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: const_axes__81
[12/22/2022-04:34:55] [V] [TRT] Searching for input: const_fold_opt__540
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice [Slice] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Shape__45:0 -> (4)[INT32]], [const_axes__81 -> (1)[INT32]], [const_fold_opt__540 -> (1)[INT32]], [const_axes__81 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice [Slice] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice:0 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85 [Concat]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: const_fold_opt__529
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85 [Concat] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice:0 -> (1)[INT32]], [const_fold_opt__529 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: const_fold_opt__529 for ONNX node: const_fold_opt__529
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85 [Concat] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ones__86 [Cast]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ones__86 [Cast] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/stack_Concat__85:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ones__86 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ones__86
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ones__86:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ones__86:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ones__86 [Cast] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ones__86:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ones [Expand]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ones__86:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ones [Expand] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0 -> ()[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/ones__86:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ones for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ones
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ones:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ones:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ones [Expand] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ones:0 -> (-1, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55 [Concat]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: const_fold_opt__527
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55 [Concat] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/strided_slice:0 -> (1)[INT32]], [const_fold_opt__527 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: const_fold_opt__527 for ONNX node: const_fold_opt__527
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55 [Concat] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77 [Cast]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77 [Cast] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/stack_3_Concat__55:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77 [Cast] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/Tile [Tile]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_5__37
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Tile [Tile] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_5__37 -> (1, 224)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/Tile__77:0 -> (2)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_5__37 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_5__37
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/Tile for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/Tile
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Tile:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/Tile:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/Tile [Tile] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Tile:0 -> (-1, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6 [Unsqueeze]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/Tile:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: const_fold_opt__538
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6 [Unsqueeze] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Tile:0 -> (-1, 224)[FLOAT]], [const_fold_opt__538 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Original shape: (_, 224), unsqueezing to: (_, _, _)
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6 [Unsqueeze] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6:0 -> (-1, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4 [Unsqueeze]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ones:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4 [Unsqueeze] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ones:0 -> (-1, 224)[FLOAT]], [const_fold_opt__540 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4 [Unsqueeze] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4:0 -> (-1, 1, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1 [MatMul]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1 [MatMul] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_6:0 -> (-1, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_4:0 -> (-1, 1, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1 [MatMul] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1:0 -> (-1, 224, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7 [Unsqueeze]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7 [Unsqueeze] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/MatMul_1:0 -> (-1, 224, 224)[FLOAT]], [const_fold_opt__538 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Original shape: (_, 224, 224), unsqueezing to: (_, _, _, _)
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7 [Unsqueeze] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1 [Transpose]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1 [Transpose] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_7:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1 [Transpose] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2 [Unsqueeze]
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2 [Unsqueeze] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/Tile:0 -> (-1, 224)[FLOAT]], [const_fold_opt__540 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2 [Unsqueeze] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2:0 -> (-1, 1, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims [Unsqueeze]
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims [Unsqueeze] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ones:0 -> (-1, 224)[FLOAT]], [const_fold_opt__538 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims [Unsqueeze] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims:0 -> (-1, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul [MatMul]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/MatMul [MatMul] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims:0 -> (-1, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_2:0 -> (-1, 1, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/MatMul [MatMul] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/MatMul:0 -> (-1, 224, 224)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3 [Unsqueeze]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/MatMul:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3 [Unsqueeze] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/MatMul:0 -> (-1, 224, 224)[FLOAT]], [const_fold_opt__538 -> (1)[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3 [Unsqueeze] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/transpose [Transpose]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/transpose [Transpose] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/ExpandDims_3:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/transpose for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/transpose
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/transpose:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/transpose:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/transpose [Transpose] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/transpose:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1 [Div]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/Cast_3__35
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1 [Div] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/transpose_1:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/Cast_3__35 -> ()[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/Cast_3__35 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/Cast_3__35
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1 [Div] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1 [Mul]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1/y:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/mul_1 [Mul] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/truediv_1:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/mul_1/y:0 -> ()[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1/y:0 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1/y:0
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/mul_1 [Mul] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/mul_1:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/sub_3 [Sub]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/mul_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/sub_3 [Sub] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/mul_1:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0 -> ()[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/sub_3 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/sub_3
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/sub_3:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/sub_3:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/sub_3 [Sub] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/sub_3:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/truediv [Div]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/transpose:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/truediv [Div] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/transpose:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/Cast_3__35 -> ()[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/truediv for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/truediv
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/truediv:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/truediv:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/truediv [Div] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/truediv:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/mul [Mul]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/truediv:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/mul [Mul] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/truediv:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/mul_1/y:0 -> ()[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/mul for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/mul
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/mul:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/mul:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/mul [Mul] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/mul:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/sub_1 [Sub]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/mul:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/sub_1 [Sub] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/mul:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/ones_1/Const:0 -> ()[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/sub_1 for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/sub_1
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/sub_1:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/sub_1:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/sub_1 [Sub] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/sub_1:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/coordinate_channel/concat [Concat]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/sub_1:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/sub_3:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/concat [Concat] inputs: [input_1 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/sub_1:0 -> (-1, 224, 224, 1)[FLOAT]], [StatefulPartitionedCall/angle_model/coordinate_channel/sub_3:0 -> (-1, 224, 224, 1)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/coordinate_channel/concat for ONNX node: StatefulPartitionedCall/angle_model/coordinate_channel/concat
[12/22/2022-04:34:55] [V] [TRT] Registering tensor: StatefulPartitionedCall/angle_model/coordinate_channel/concat:0 for ONNX tensor: StatefulPartitionedCall/angle_model/coordinate_channel/concat:0
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/coordinate_channel/concat [Concat] outputs: [StatefulPartitionedCall/angle_model/coordinate_channel/concat:0 -> (-1, 224, 224, 3)[FLOAT]],
[12/22/2022-04:34:55] [V] [TRT] Parsing node: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_QuantizeLinear__95 [QuantizeLinear]
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/coordinate_channel/concat:0
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_scaley__93
[12/22/2022-04:34:55] [V] [TRT] Searching for input: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_zpy__94
[12/22/2022-04:34:55] [V] [TRT] StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_QuantizeLinear__95 [QuantizeLinear] inputs: [StatefulPartitionedCall/angle_model/coordinate_channel/concat:0 -> (-1, 224, 224, 3)[FLOAT]], [StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_scaley__93 -> ()[FLOAT]], [StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_zpy__94 -> ()[INT32]],
[12/22/2022-04:34:55] [V] [TRT] Registering layer: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_scaley__93 for ONNX node: StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_scaley__93
[12/22/2022-04:34:55] [E] [TRT] ModelImporter.cpp:773: While parsing node number 26 [QuantizeLinear -> "StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_QuantizeLinear__95:0"]:
[12/22/2022-04:34:55] [E] [TRT] ModelImporter.cpp:774: --- Begin node ---
[12/22/2022-04:34:55] [E] [TRT] ModelImporter.cpp:775: input: "StatefulPartitionedCall/angle_model/coordinate_channel/concat:0"
input: "StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_scaley__93"
input: "StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_zpy__94"
output: "StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_QuantizeLinear__95:0"
name: "StatefulPartitionedCall/angle_model/mobilenet_0.15_224/quantize_layer/AllValuesQuantize/FakeQuantWithMinMaxVars_QuantizeLinear__95"
op_type: "QuantizeLinear"
attribute {
i: 1
type: INT
domain: ""
[12/22/2022-04:34:55] [E] [TRT] ModelImporter.cpp:776: --- End node ---
[12/22/2022-04:34:55] [E] [TRT] ModelImporter.cpp:778: ERROR: builtin_op_importers.cpp:1173 In function QuantDequantLinearHelper:
[6] Assertion failed: shiftIsAllZeros(zeroPoint) && "TRT only supports symmetric quantization - zeroPt must be all zeros"
[12/22/2022-04:34:55] [E] Failed to parse onnx file
[12/22/2022-04:34:55] [I] Finish parsing network model
[12/22/2022-04:34:55] [E] Parsing model failed
[12/22/2022-04:34:55] [E] Failed to create engine from model or file.
[12/22/2022-04:34:55] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8401] # /usr/src/tensorrt/bin/trtexec --onnx=saved_model_qat_no_auto.onnx --saveEngine=saved_model_qat.trt --minShapes=input_1:1x224x224x1 --optShapes=input_1:2x224x224x1 --maxShapes=input_1:2x224x224x1 --int8 --verbose
