Description
I am trying to run the official EfficientDet-D4 in TensorRT. It just won’t work.
Prior to that, I am using tf2onnx.convert to convert the TF saved-model to onnx.
When running trtexec on the onnx file it results in no traceback at all.
If I am using “verbose” logging, I at least get the information where the import of the model stops but there it still no real traceback.
It seems that he “Unsqueeze” is the problem, but I cannot see why.
Any help would be appreciated. I really want to use TensorRT, but for that it is necessary that the model is working, ofc.
Let me know if any additional information is needed!
I had to crop the traceback/verbose output to match the maximal thread size…
Environment
TensorRT Version: 7.2.3.4
GPU Type: RTX3090
Nvidia Driver Version: 27.21.14.5148
CUDA Version: 11.2
CUDNN Version: 8.0
Operating System + Version: Windows
Python Version: 3.8.8
TensorFlow Version (if applicable): 2.4.1
ONNX_Tensorflow Version: 1.9
Onnx Version: 1.8.1
Relevant Files
The onnx file can be found here:
*Updated File: Dropbox - Error - Simplify your life
Steps To Reproduce
Simply use
trtexec.exe --onnx=onnx_model.onnx --verbose
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
I encounter the following traceback:
(tf24) C:\Repos\TensorRT-7.2.3.4\bin>trtexec.exe --onnx=…\saved_model\onnx_float.onnx --verbose
&&&& RUNNING TensorRT.trtexec # trtexec.exe --onnx=…\saved_model\onnx_float.onnx --verbose
[03/29/2021-15:20:06] [I] === Model Options ===
[03/29/2021-15:20:06] [I] Format: ONNX
[03/29/2021-15:20:06] [I] Model: …\saved_model\onnx_float.onnx
[03/29/2021-15:20:06] [I] Output:
[03/29/2021-15:20:06] [I] === Build Options ===
[03/29/2021-15:20:06] [I] Max batch: explicit
[03/29/2021-15:20:06] [I] Workspace: 16 MiB
[03/29/2021-15:20:06] [I] minTiming: 1
[03/29/2021-15:20:06] [I] avgTiming: 8
[03/29/2021-15:20:06] [I] Precision: FP32
[03/29/2021-15:20:06] [I] Calibration:
[03/29/2021-15:20:06] [I] Refit: Disabled
[03/29/2021-15:20:06] [I] Safe mode: Disabled
[03/29/2021-15:20:06] [I] Save engine:
[03/29/2021-15:20:06] [I] Load engine:
[03/29/2021-15:20:06] [I] Builder Cache: Enabled
[03/29/2021-15:20:06] [I] NVTX verbosity: 0
[03/29/2021-15:20:06] [I] Tactic sources: Using default tactic sources
[03/29/2021-15:20:06] [I] Input(s)s format: fp32:CHW
[03/29/2021-15:20:06] [I] Output(s)s format: fp32:CHW
[03/29/2021-15:20:06] [I] Input build shapes: model
[03/29/2021-15:20:06] [I] Input calibration shapes: model
[03/29/2021-15:20:06] [I] === System Options ===
[03/29/2021-15:20:06] [I] Device: 0
[03/29/2021-15:20:06] [I] DLACore:
[03/29/2021-15:20:06] [I] Plugins:
[03/29/2021-15:20:06] [I] === Inference Options ===
[03/29/2021-15:20:06] [I] Batch: Explicit
[03/29/2021-15:20:06] [I] Input inference shapes: model
[03/29/2021-15:20:06] [I] Iterations: 10
[03/29/2021-15:20:06] [I] Duration: 3s (+ 200ms warm up)
[03/29/2021-15:20:06] [I] Sleep time: 0ms
[03/29/2021-15:20:06] [I] Streams: 1
[03/29/2021-15:20:06] [I] ExposeDMA: Disabled
[03/29/2021-15:20:06] [I] Data transfers: Enabled
[03/29/2021-15:20:06] [I] Spin-wait: Disabled
[03/29/2021-15:20:06] [I] Multithreading: Disabled
[03/29/2021-15:20:06] [I] CUDA Graph: Disabled
[03/29/2021-15:20:06] [I] Separate profiling: Disabled
[03/29/2021-15:20:06] [I] Skip inference: Disabled
[03/29/2021-15:20:06] [I] Inputs:
[03/29/2021-15:20:06] [I] === Reporting Options ===
[03/29/2021-15:20:06] [I] Verbose: Enabled
[03/29/2021-15:20:06] [I] Averages: 10 inferences
[03/29/2021-15:20:06] [I] Percentile: 99
[03/29/2021-15:20:06] [I] Dump refittable layers:Disabled
[03/29/2021-15:20:07] [I] Dump output: Disabled
[03/29/2021-15:20:07] [I] Profile: Disabled
[03/29/2021-15:20:07] [I] Export timing to JSON file:
[03/29/2021-15:20:07] [I] Export output to JSON file:
[03/29/2021-15:20:07] [I] Export profile to JSON file:
[03/29/2021-15:20:07] [I] === Device Information ===
[03/29/2021-15:20:07] [I] Selected Device: GeForce RTX 3090
[03/29/2021-15:20:07] [I] Compute Capability: 8.6
[03/29/2021-15:20:07] [I] SMs: 82
[03/29/2021-15:20:07] [I] Compute Clock Rate: 1.86 GHz
[03/29/2021-15:20:07] [I] Device Global Memory: 24576 MiB
[03/29/2021-15:20:07] [I] Shared Memory per SM: 100 KiB
[03/29/2021-15:20:07] [I] Memory Bus Width: 384 bits (ECC disabled)
[03/29/2021-15:20:07] [I] Memory Clock Rate: 9.751 GHz
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::Proposal version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::Split version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[03/29/2021-15:20:07] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
Input filename: Y:\Flindt\Data\Datasets\Objectdetection\IHFood\Front\Objectdetection\EfficientDet4\models\my_model_dir2\final_model\saved_model\onnx_float.onnx
ONNX IR version: 0.0.7
Opset version: 13
Producer name:
Producer version:
Domain:
Model version: 0
Doc string:
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::BatchedNMSDynamic_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::Split version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[03/29/2021-15:20:14] [V] [TRT] ModelImporter.cpp:202: Adding network input: input_tensor:0 with dtype: float32, dimensions: (1, 3, 1024, 1024)
[03/29/2021-15:20:14] [V] [TRT] ImporterContext.hpp:120: Registering tensor: input_tensor:0 for ONNX tensor: input_tensor:0
[03/29/2021-15:20:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/ClipToWindow/Greater/y:0
[03/29/2021-15:20:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_fold_opt__3869
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/map/while/maximum_iterations:0
[03/29/2021-15:20:15] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/range_2/start:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/map/TensorArrayV2Stack_1/TensorListStack/element_shape:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_starts__2943
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/map/TensorArrayV2Stack/TensorListStack/element_shape:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stem_conv2d/Conv2D_weights_fused_bn
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stem_conv2d/Conv2D_bias_fused_bn
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/depthwise_conv2d/depthwise_weights_fused_bn
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/depthwise_conv2d/depthwise_bias_fused_bn
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_fold_opt__3754
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: new_shape__3682
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/se_reduce_conv2d/Conv2D/ReadVariableOp:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/se_reduce_conv2d/BiasAdd/ReadVariableOp:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/se_expand_conv2d/Conv2D/ReadVariableOp:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/se_expand_conv2d/BiasAdd/ReadVariableOp:0
[03/29/2021-15:20:15] [V] [TRT] ModelImporter.cpp:90: Importing initializer: StatefulPartitionedCall/EfficientDet-D4/model/stack_0/block_0/project_conv2d/Conv2D_weights_fused_bn
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_axes__196
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_fold_opt__3976
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_starts__206
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_ends__207
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_axes__208
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:90: Importing initializer: const_axes__210
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:103: Parsing node: map/while/add [Add]
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:119: Searching for input: map_while_placeholder:0
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:119: Searching for input: map/while/add/y:0
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:125: map/while/add [Add] inputs: [map_while_placeholder:0 → ()], [map/while/add/y:0 → ()],
[03/29/2021-15:20:39] [V] [TRT] ImporterContext.hpp:150: Registering constant layer: map/while/add/y:0 for ONNX initializer: map/while/add/y:0
[03/29/2021-15:20:39] [V] [TRT] ImporterContext.hpp:154: Registering layer: map/while/add for ONNX node: map/while/add
[03/29/2021-15:20:39] [V] [TRT] ImporterContext.hpp:120: Registering tensor: map/while/Identity_2:0 for ONNX tensor: map/while/Identity_2:0
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:179: map/while/add [Add] outputs: [map/while/Identity_2:0 → ()],
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:103: Parsing node: cond___map/while/Less__6 [Cast]
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:119: Searching for input: map/while/Identity_2:0
[03/29/2021-15:20:39] [V] [TRT] ModelImporter.cpp:125: cond___map/while/Less__6 [Cast] inputs: [map/while/Identity_2:0 → ()],
[03/29/2021-15:20:39] [V] [TRT] builtin_op_importers.cpp:320: Casting to type: float32
[03/29/2021-15:20:39] [V] [TRT] ImporterContext.hpp:154: Registering layer: cond___map/while/Less__6 for ONNX node: cond___map/while/Less__6
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: cond___map/while/Less__6:0 for ONNX tensor: cond___map/while/Less__6:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: cond___map/while/Less__6 [Cast] outputs: [cond___map/while/Less__6:0 → ()],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: cond___map/while/Less_1__4 [Cast]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: map_while_map_while_loop_counter:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: cond___map/while/Less_1__4 [Cast] inputs: [map_while_map_while_loop_counter:0 → (1)],
[03/29/2021-15:20:40] [V] [TRT] builtin_op_importers.cpp:320: Casting to type: float32
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: cond___map/while/Less_1__4 for ONNX node: cond___map/while/Less_1__4
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: cond___map/while/Less_1__4:0 for ONNX tensor: cond___map/while/Less_1__4:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: cond___map/while/Less_1__4 [Cast] outputs: [cond___map/while/Less_1__4:0 → (1)],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: cond___map/while/Less_1 [Less]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: cond___map/while/Less_1__4:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: const_fold_opt__4088
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: cond___map/while/Less_1 [Less] inputs: [cond___map/while/Less_1__4:0 → (1)], [const_fold_opt__4088 → ()],
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:150: Registering constant layer: const_fold_opt__4088 for ONNX initializer: const_fold_opt__4088
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: cond___map/while/Less_1 for ONNX node: cond___map/while/Less_1
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: cond___map/while/Less_1:0 for ONNX tensor: cond___map/while/Less_1:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: cond___map/while/Less_1 [Less] outputs: [cond___map/while/Less_1:0 → (1)],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: cond___map/while/Less [Less]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: cond___map/while/Less__6:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: const_fold_opt__3968
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: cond___map/while/Less [Less] inputs: [cond___map/while/Less__6:0 → ()], [const_fold_opt__3968 → ()],
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:150: Registering constant layer: const_fold_opt__3968 for ONNX initializer: const_fold_opt__3968
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: cond___map/while/Less for ONNX node: cond___map/while/Less
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: cond___map/while/Less:0 for ONNX tensor: cond___map/while/Less:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: cond___map/while/Less [Less] outputs: [cond___map/while/Less:0 → ()],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: cond___map/while/LogicalAnd [And]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: cond___map/while/Less_1:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: cond___map/while/Less:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: cond___map/while/LogicalAnd [And] inputs: [cond___map/while/Less_1:0 → (1)], [cond___map/while/Less:0 → ()],
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: cond___map/while/LogicalAnd for ONNX node: cond___map/while/LogicalAnd
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: cond___map/while/Identity:0 for ONNX tensor: cond___map/while/Identity:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: cond___map/while/LogicalAnd [And] outputs: [cond___map/while/Identity:0 → (1)],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: Transpose__3107 [Transpose]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: input_tensor:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: Transpose__3107 [Transpose] inputs: [input_tensor:0 → (1, 3, 1024, 1024)],
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: Transpose__3107 for ONNX node: Transpose__3107
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: Transpose__3107:0 for ONNX tensor: Transpose__3107:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: Transpose__3107 [Transpose] outputs: [Transpose__3107:0 → (1, 1024, 1024, 3)],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: map/while/TensorArrayV2Read/TensorListGetItem [Gather]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: Transpose__3107:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: map_while_placeholder:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: map/while/TensorArrayV2Read/TensorListGetItem [Gather] inputs: [Transpose__3107:0 → (1, 1024, 1024, 3)], [map_while_placeholder:0 → ()],
[03/29/2021-15:20:40] [V] [TRT] builtin_op_importers.cpp:996: Using Gather axis: 0
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: map/while/TensorArrayV2Read/TensorListGetItem for ONNX node: map/while/TensorArrayV2Read/TensorListGetItem
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: map/while/TensorArrayV2Read/TensorListGetItem:0 for ONNX tensor: map/while/TensorArrayV2Read/TensorListGetItem:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: map/while/TensorArrayV2Read/TensorListGetItem [Gather] outputs: [map/while/TensorArrayV2Read/TensorListGetItem:0 → (1024, 1024, 3)],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: map/while/Cast [Cast]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: map/while/TensorArrayV2Read/TensorListGetItem:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: map/while/Cast [Cast] inputs: [map/while/TensorArrayV2Read/TensorListGetItem:0 → (1024, 1024, 3)],
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:154: Registering layer: map/while/Cast for ONNX node: map/while/Cast
[03/29/2021-15:20:40] [V] [TRT] ImporterContext.hpp:120: Registering tensor: map/while/Cast:0 for ONNX tensor: map/while/Cast:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:179: map/while/Cast [Cast] outputs: [map/while/Cast:0 → (1024, 1024, 3)],
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:103: Parsing node: Unsqueeze__80 [Unsqueeze]
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: map/while/Cast:0
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:119: Searching for input: const_axes__79
[03/29/2021-15:20:40] [V] [TRT] ModelImporter.cpp:125: Unsqueeze__80 [Unsqueeze] inputs: [map/while/Cast:0 → (1024, 1024, 3)], [const_axes__79 → (1)],
