I already using onnx.checker.check_model(model) method in my extract_onnx.py code
f0_onnx = torch.ones((1, 64, 160, 256)).cuda()
f1_onnx = torch.ones((1, 64, 80, 128)).cuda()
f2_onnx = torch.ones((1, 128, 40, 64)).cuda()
f3_onnx = torch.ones((1, 256, 20, 32)).cuda()
f4_onnx = torch.ones((1, 512, 10, 16)).cuda()
torch.onnx.export(depth_decoder,
(f0_onnx, f1_onnx, f2_onnx, f3_onnx, f4_onnx),
"md2_decoder.onnx",
export_params=True,
do_constant_folding=True,
opset_version=11,
input_names = ['encoder_output_0', 'encoder_output_1', 'encoder_output_2', 'encoder_output_3', 'encoder_output_4'],
output_names = ['decoder_output_0', 'decoder_output_1', 'decoder_output_2', 'decoder_output_final'],
dynamic_axes={'encoder_output_0' : {0 : 'batch_size'},
'encoder_output_1' : {0 : 'batch_size'},
'encoder_output_2' : {0 : 'batch_size'},
'encoder_output_3' : {0 : 'batch_size'},
'encoder_output_4' : {0 : 'batch_size'},
'decoder_output_0' : {0 : 'batch_size'},
'decoder_output_1' : {0 : 'batch_size'},
'decoder_output_2' : {0 : 'batch_size'},
'decoder_output_final' : {0 : 'batch_size'}})
onnx_decoder = onnx.load("md2_decoder.onnx")
onnx.checker.check_model(onnx_decoder)
print("Done: converting decoder to onnx format!")
And there is no error message. Also I try to new text with onnx file using check_model.py then there is no warning or error message.
Printed message from trtexec with --verbose option is as follows,
[08/05/2021-14:53:14] [I] === Model Options ===
[08/05/2021-14:53:14] [I] Format: ONNX
[08/05/2021-14:53:14] [I] Model: /home/jinho-sesol/monodepth2_trt/md2_decoder.onnx
[08/05/2021-14:53:14] [I] Output:
[08/05/2021-14:53:14] [I] === Build Options ===
[08/05/2021-14:53:14] [I] Max batch: explicit
[08/05/2021-14:53:14] [I] Workspace: 16 MB
[08/05/2021-14:53:14] [I] minTiming: 1
[08/05/2021-14:53:14] [I] avgTiming: 8
[08/05/2021-14:53:14] [I] Precision: FP16
**[08/05/2021-14:53:14] [I] Calibration: **
[08/05/2021-14:53:14] [I] Safe mode: Disabled
[08/05/2021-14:53:14] [I] Save engine: /home/jinho-sesol/monodepth2_trt/md2_decoder.trt
**[08/05/2021-14:53:14] [I] Load engine: **
[08/05/2021-14:53:14] [I] Inputs format: fp32:CHW
[08/05/2021-14:53:14] [I] Outputs format: fp32:CHW
[08/05/2021-14:53:14] [I] Input build shape: encoder_output_1=1x64x80x128+1x64x80x128+1x64x80x128
[08/05/2021-14:53:14] [I] Input build shape: encoder_output_0=1x64x160x256+1x64x160x256+1x64x160x256
[08/05/2021-14:53:14] [I] Input build shape: encoder_output_4=1x512x10x16+1x512x10x16+1x512x10x16
[08/05/2021-14:53:14] [I] Input build shape: encoder_output_2=1x128x40x64+1x128x40x64+1x128x40x64
[08/05/2021-14:53:14] [I] Input build shape: encoder_output_3=1x256x20x32+1x256x20x32+1x256x20x32
[08/05/2021-14:53:14] [I] === System Options ===
[08/05/2021-14:53:14] [I] Device: 0
**[08/05/2021-14:53:14] [I] DLACore: **
[08/05/2021-14:53:14] [I] Plugins:
[08/05/2021-14:53:14] [I] === Inference Options ===
[08/05/2021-14:53:14] [I] Batch: Explicit
[08/05/2021-14:53:14] [I] Iterations: 10
[08/05/2021-14:53:14] [I] Duration: 3s (+ 200ms warm up)
[08/05/2021-14:53:14] [I] Sleep time: 0ms
[08/05/2021-14:53:14] [I] Streams: 1
[08/05/2021-14:53:14] [I] ExposeDMA: Disabled
[08/05/2021-14:53:14] [I] Spin-wait: Disabled
[08/05/2021-14:53:14] [I] Multithreading: Disabled
[08/05/2021-14:53:14] [I] CUDA Graph: Disabled
[08/05/2021-14:53:14] [I] Skip inference: Disabled
[08/05/2021-14:53:14] [I] Inputs:
[08/05/2021-14:53:14] [I] === Reporting Options ===
[08/05/2021-14:53:14] [I] Verbose: Enabled
[08/05/2021-14:53:14] [I] Averages: 10 inferences
[08/05/2021-14:53:14] [I] Percentile: 99
[08/05/2021-14:53:14] [I] Dump output: Disabled
[08/05/2021-14:53:14] [I] Profile: Disabled
**[08/05/2021-14:53:14] [I] Export timing to JSON file: **
**[08/05/2021-14:53:14] [I] Export output to JSON file: **
**[08/05/2021-14:53:14] [I] Export profile to JSON file: **
**[08/05/2021-14:53:14] [I] **
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::GridAnchor_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::NMS_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::Reorg_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::Region_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::Clip_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::LReLU_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::PriorBox_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::Normalize_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::RPROI_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::BatchedNMS_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::FlattenConcat_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::CropAndResize
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::DetectionLayer_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::Proposal
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::ProposalLayer_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::PyramidROIAlign_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::ResizeNearest_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::Split
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::SpecialSlice_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ::InstanceNormalization_TRT
Input filename: /home/jinho-sesol/monodepth2_trt/md2_decoder.onnx
ONNX IR version: 0.0.6
Opset version: 11
Producer name: pytorch
Producer version: 1.6
**Domain: **
Model version: 0
**Doc string: **
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::GridAnchor_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::NMS_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Reorg_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Region_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Clip_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::LReLU_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::PriorBox_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Normalize_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::RPROI_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::BatchedNMS_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::FlattenConcat_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::CropAndResize
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::DetectionLayer_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Proposal
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::ProposalLayer_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::PyramidROIAlign_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::ResizeNearest_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Split
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::SpecialSlice_TRT
[08/05/2021-14:53:14] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::InstanceNormalization_TRT
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:203: Adding network input: encoder_output_0 with dtype: float32, dimensions: (-1, 64, 160, 256)
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: encoder_output_0 for ONNX tensor: encoder_output_0
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:203: Adding network input: encoder_output_1 with dtype: float32, dimensions: (-1, 64, 80, 128)
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: encoder_output_1 for ONNX tensor: encoder_output_1
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:203: Adding network input: encoder_output_2 with dtype: float32, dimensions: (-1, 128, 40, 64)
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: encoder_output_2 for ONNX tensor: encoder_output_2
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:203: Adding network input: encoder_output_3 with dtype: float32, dimensions: (-1, 256, 20, 32)
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: encoder_output_3 for ONNX tensor: encoder_output_3
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:203: Adding network input: encoder_output_4 with dtype: float32, dimensions: (-1, 512, 10, 16)
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: encoder_output_4 for ONNX tensor: encoder_output_4
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 463
[08/05/2021-14:53:14] [W] [TRT] onnx2trt_utils.cpp:198: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 464
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 469
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 473
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 474
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 478
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 479
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 484
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 488
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 489
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 493
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 494
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 498
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 499
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 504
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 508
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 509
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 513
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 514
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 518
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 519
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 524
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 528
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 529
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 533
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 534
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 538
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 539
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 544
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 548
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 549
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 553
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 554
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.0.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.0.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.1.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.1.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.10.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.10.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.11.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.11.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.12.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.12.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.13.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.13.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.2.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.2.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.3.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.3.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.4.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.4.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.5.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.5.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.6.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.6.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.7.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.7.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.8.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.8.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.9.conv.conv.bias
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:90: Importing initializer: decoder.9.conv.conv.weight
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: ConstantOfShape_0 [ConstantOfShape]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 463
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: ConstantOfShape_0 [ConstantOfShape] inputs: [463 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: ConstantOfShape_0 for ONNX node: ConstantOfShape_0
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 42 for ONNX tensor: 42
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: ConstantOfShape_0 [ConstantOfShape] outputs: [42 → (-1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_1 [Concat]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 464
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 42
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Concat_1 [Concat] inputs: [464 → (4)], [42 → (-1)], **
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_1 for ONNX node: Concat_1
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 43 for ONNX tensor: 43
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Concat_1 [Concat] outputs: [43 → (-1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_2 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_2 [Constant] inputs: **
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_2 [Constant] outputs: [44 → (2)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Reshape_3 [Reshape]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 43
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 44
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Reshape_3 [Reshape] inputs: [43 → (-1)], [44 → (2)], **
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: Reshape_3 for ONNX node: Reshape_3
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 45 for ONNX tensor: 45
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Reshape_3 [Reshape] outputs: [45 → (-1, 2)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_4 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_4 [Constant] inputs: **
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_4 [Constant] outputs: [46 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_5 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_5 [Constant] inputs: **
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_5 [Constant] outputs: [47 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_6 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_6 [Constant] inputs: **
[08/05/2021-14:53:14] [V] [TRT] onnx2trt_utils.cpp:212: Weight at index 0: -9223372036854775807 is out of range. Clamping to: -2147483648
[08/05/2021-14:53:14] [W] [TRT] onnx2trt_utils.cpp:222: One or more weights outside the range of INT32 was clamped
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_6 [Constant] outputs: [48 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_7 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_7 [Constant] inputs: **
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_7 [Constant] outputs: [49 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Slice_8 [Slice]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 45
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 47
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 48
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 49
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Slice_8 [Slice] inputs: [45 → (-1, 2)], [47 → (1)], [48 → (1)], [46 → (1)], [49 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: Slice_8 for ONNX node: Slice_8
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 50 for ONNX tensor: 50
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Slice_8 [Slice] outputs: [50 → (-1, -1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Transpose_9 [Transpose]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 50
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Transpose_9 [Transpose] inputs: [50 → (-1, -1)], **
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: Transpose_9 for ONNX node: Transpose_9
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 51 for ONNX tensor: 51
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Transpose_9 [Transpose] outputs: [51 → (-1, -1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_10 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_10 [Constant] inputs: **
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_10 [Constant] outputs: [52 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Reshape_11 [Reshape]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 51
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 52
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Reshape_11 [Reshape] inputs: [51 → (-1, -1)], [52 → (1)], **
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: Reshape_11 for ONNX node: Reshape_11
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 53 for ONNX tensor: 53
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Reshape_11 [Reshape] outputs: [53 → (-1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Cast_12 [Cast]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 53
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Cast_12 [Cast] inputs: [53 → (-1)], **
[08/05/2021-14:53:14] [V] [TRT] builtin_op_importers.cpp:315: Casting to type: int32
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:122: Registering layer: Cast_12 for ONNX node: Cast_12
[08/05/2021-14:53:14] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 54 for ONNX tensor: 54
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Cast_12 [Cast] outputs: [54 → (-1)], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_13 [Constant]
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Constant_13 [Constant] inputs: **
**[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:180: Constant_13 [Constant] outputs: [55 → ()], **
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:107: Parsing node: Pad_14 [Pad]
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: encoder_output_4
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 54
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:123: Searching for input: 55
[08/05/2021-14:53:14] [V] [TRT] ModelImporter.cpp:129: Pad_14 [Pad] inputs: [encoder_output_4 → (-1, 512, 10, 16)], [54 → (-1)], [55 → ()], **
terminate called after throwing an instance of ‘std::out_of_range’
** what(): Attribute not found: pads
Aborted (core dumped)
Thanks!!!
