Description
Same version TensorRT(8.6.1) with two methods to convert same onnx model,One used trtexec[FAILED] , the other used python[Success]
Hi, I am trying to convert an Onnx model with dynamic inputs to TensorRT format. I used two methods to convert this model ,but I get error when using trtexec.
Environment
TensorRT Version: 8.6.1
GPU Type: NVIDIA GeForce RTX 2060
Nvidia Driver Version: 530.41.03
CUDA Version: 11.4
CUDNN Version: 8.6
Operating System + Version: ubuntu 18.04
Python Version (if applicable): 3.8
PyTorch Version (if applicable): 1.9
Use python to convert our model:
Here is the python code:
We generated the .trt file successfully but with warning:
onnx2trt.py:25: DeprecationWarning: Use build_serialized_network instead.
engine = builder.build_engine(network, config)
[09/07/2023-19:41:33] [TRT] [W] [RemoveDeadLayers] Input Tensor center_objects_type is unused or used only at compile-time, but is not being removed.
success generate trtfile
Use trtexec to convert our model:
ERROR log:
[09/07/2023-20:04:41] [V] [TRT] --------------- Timing Runner: {ForeignNode[Unsqueeze_11…Slice_2392]} (Myelin)
[09/07/2023-20:05:17] [W] [TRT] Skipping tactic 0 due to Myelin error: No results returned from cublas heuristic search
[09/07/2023-20:05:17] [V] [TRT] Fastest Tactic: -3360065831133338131 Time: inf
[09/07/2023-20:05:17] [V] [TRT] Deleting timing cache: 145 entries, 633 hits
[09/07/2023-20:05:17] [E] Error[10]: [optimizer.cpp::computeCosts::2011] Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[Unsqueeze_11…Slice_2392]}.)
[09/07/2023-20:05:17] [E] Error[2]: [builder.cpp::buildSerializedNetwork::609] Error Code 2: Internal Error (Assertion enginePtr != nullptr failed. )
[09/07/2023-20:05:17] [E] Engine could not be created from network
[09/07/2023-20:05:17] [E] Building engine failed
[09/07/2023-20:05:17] [E] Failed to create engine from model.
[09/07/2023-20:05:17] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8205] # ./trtexec --onnx=/home/root/haomo/dpc/onnx/simplified_model.onnx --saveEngine=/home/root/haomo/dpc/onnx/test.trt --verbose --workspace=100000
How to fix the error with trtexec? I really appreciate the help.
