I had execute trtexec like this but error…
What is the problem? Help me…
Env : Jetpack 4.3
jetson@jetson-nano:~/my-project/Deep-Stream-ONNX/yolov3$ trtexec --onnx=yolov3.onnx
&&&& RUNNING TensorRT.trtexec # trtexec --onnx=yolov3.onnx
[02/02/2020-22:16:18] [I] === Model Options ===
[02/02/2020-22:16:18] [I] Format: ONNX
[02/02/2020-22:16:18] [I] Model: yolov3.onnx
[02/02/2020-22:16:18] [I] Output:
[02/02/2020-22:16:18] [I] === Build Options ===
[02/02/2020-22:16:18] [I] Max batch: 1
[02/02/2020-22:16:18] [I] Workspace: 16 MB
[02/02/2020-22:16:18] [I] minTiming: 1
[02/02/2020-22:16:18] [I] avgTiming: 8
[02/02/2020-22:16:18] [I] Precision: FP32
[02/02/2020-22:16:18] [I] Calibration:
[02/02/2020-22:16:18] [I] Safe mode: Disabled
[02/02/2020-22:16:18] [I] Save engine:
[02/02/2020-22:16:18] [I] Load engine:
[02/02/2020-22:16:18] [I] Inputs format: fp32:CHW
[02/02/2020-22:16:18] [I] Outputs format: fp32:CHW
[02/02/2020-22:16:18] [I] Input build shapes: model
[02/02/2020-22:16:18] [I] === System Options ===
[02/02/2020-22:16:18] [I] Device: 0
[02/02/2020-22:16:18] [I] DLACore:
[02/02/2020-22:16:18] [I] Plugins:
[02/02/2020-22:16:18] [I] === Inference Options ===
[02/02/2020-22:16:18] [I] Batch: 1
[02/02/2020-22:16:18] [I] Iterations: 10 (200 ms warm up)
[02/02/2020-22:16:18] [I] Duration: 10s
[02/02/2020-22:16:18] [I] Sleep time: 0ms
[02/02/2020-22:16:18] [I] Streams: 1
[02/02/2020-22:16:18] [I] Spin-wait: Disabled
[02/02/2020-22:16:18] [I] Multithreading: Enabled
[02/02/2020-22:16:18] [I] CUDA Graph: Disabled
[02/02/2020-22:16:18] [I] Skip inference: Disabled
[02/02/2020-22:16:18] [I] Input inference shapes: model
[02/02/2020-22:16:18] [I] === Reporting Options ===
[02/02/2020-22:16:18] [I] Verbose: Disabled
[02/02/2020-22:16:18] [I] Averages: 10 inferences
[02/02/2020-22:16:18] [I] Percentile: 99
[02/02/2020-22:16:18] [I] Dump output: Disabled
[02/02/2020-22:16:18] [I] Profile: Disabled
[02/02/2020-22:16:18] [I] Export timing to JSON file:
[02/02/2020-22:16:18] [I] Export profile to JSON file:
Input filename: yolov3.onnx
ONNX IR version: 0.0.5
Opset version: 10
Producer name: keras2onnx
Producer version: 1.5.1
Domain: onnx
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.5) than this parser was built against (0.0.3).
[02/02/2020-22:16:22] [E] [TRT] Parameter check failed at: …/builder/Network.cpp::addInput::671, condition: isValidDims(dims, hasImplicitBatchDimension())
ERROR: ModelImporter.cpp:80 In function importInput:
[8] Assertion failed: *tensor = importer_ctx->network()->addInput( input.name().c_str(), trt_dtype, trt_dims)
[02/02/2020-22:16:22] [E] Failed to parse onnx file
[02/02/2020-22:16:23] [E] Parsing model failed
[02/02/2020-22:16:23] [E] Engine could not be created
&&&& FAILED TensorRT.trtexec # trtexec --onnx=yolov3.onnx
