FAILED TensorRT.trtexec
I am able to create an ONNX file of a simple resnet model, but creating TesnsorRT fails with the following error:
[09/04/2021-08:23:17] [I] === Model Options ===
[09/04/2021-08:23:17] [I] Format: ONNX
[09/04/2021-08:23:17] [I] Model: resnet50_onnx_model.onnx
[09/04/2021-08:23:17] [I] Output:
[09/04/2021-08:23:17] [I] === Build Options ===
[09/04/2021-08:23:17] [I] Max batch: explicit
[09/04/2021-08:23:17] [I] Workspace: 16 MB
[09/04/2021-08:23:17] [I] minTiming: 1
[09/04/2021-08:23:17] [I] avgTiming: 8
[09/04/2021-08:23:17] [I] Precision: FP32
[09/04/2021-08:23:17] [I] Calibration:
[09/04/2021-08:23:17] [I] Safe mode: Disabled
[09/04/2021-08:23:17] [I] Save engine: resnet_engine.trt
[09/04/2021-08:23:17] [I] Load engine:
[09/04/2021-08:23:17] [I] Inputs format: fp32:CHW
[09/04/2021-08:23:17] [I] Outputs format: fp32:CHW
[09/04/2021-08:23:17] [I] Input build shapes: model
[09/04/2021-08:23:17] [I] === System Options ===
[09/04/2021-08:23:17] [I] Device: 0
[09/04/2021-08:23:17] [I] DLACore:
[09/04/2021-08:23:17] [I] Plugins:
[09/04/2021-08:23:17] [I] === Inference Options ===
[09/04/2021-08:23:17] [I] Batch: Explicit
[09/04/2021-08:23:17] [I] Iterations: 10 (200 ms warm up)
[09/04/2021-08:23:17] [I] Duration: 10s
[09/04/2021-08:23:17] [I] Sleep time: 0ms
[09/04/2021-08:23:17] [I] Streams: 1
[09/04/2021-08:23:17] [I] Spin-wait: Disabled
[09/04/2021-08:23:17] [I] Multithreading: Enabled
[09/04/2021-08:23:17] [I] CUDA Graph: Disabled
[09/04/2021-08:23:17] [I] Skip inference: Disabled
[09/04/2021-08:23:17] [I] === Reporting Options ===
[09/04/2021-08:23:17] [I] Verbose: Disabled
[09/04/2021-08:23:17] [I] Averages: 10 inferences
[09/04/2021-08:23:17] [I] Percentile: 99
[09/04/2021-08:23:17] [I] Dump output: Disabled
[09/04/2021-08:23:17] [I] Profile: Disabled
[09/04/2021-08:23:17] [I] Export timing to JSON file:
[09/04/2021-08:23:17] [I] Export profile to JSON file:
Input filename:   resnet50_onnx_model.onnx
ONNX IR version:  0.0.4
Opset version:    9
Producer name:    pytorch
Producer version: 1.1
Domain:
Model version:    0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.4) than this parser was built against (0.0.3).
[09/04/2021-08:23:18] [E] [TRT] (Unnamed Layer* 0) [Convolution]: at least 4 dimensions are required for input
While parsing node number 1 [BatchNormalization]:
ERROR: builtin_op_importers.cpp:695 In function importBatchNormalization:
[6] Assertion failed: scale_weights.shape == weights_shape
[09/04/2021-08:23:18] [E] Failed to parse onnx file
[09/04/2021-08:23:18] [E] Parsing model failed
[09/04/2021-08:23:18] [E] Engine could not be created
My ONNX generation code is:
import torchvision.models as models
resnet50 = models.resnet50(pretrained=True, progress=False).eval()
import torch
BATCH_SIZE = 32
dummy_input=torch.randn(BATCH_SIZE, 3, 224, 224)
import torch.onnx
torch.onnx.export(resnet50, dummy_input, "resnet50_onnx_model.onnx",
                  input_names=['input'],
                  output_names=['output'],
                  verbose = False,
The command that I use for creating the tensorrt file is:
trtexec --onnx=resnet50_onnx_model.onnx --saveEngine=resnet_engine.trt  --explicitBatch
I am using:
TensorRT 6.0.1.5
CUDA 10.0
ONNX 1.5.0
Pytorch 1.1
Any help is appreciated.
Thanks in advance.
Hi @s00024957,
Looks like you’re using old version of TensorRT. With latest verison we are unable to reproduce the issue.
We recommend you to please try on the latest TensorRT verison 8.2 EA.
You can download and upgrade to latest version from here.
https://developer.nvidia.com/nvidia-tensorrt-8x-download
Thank you.
