Hello, I am trying to run from ONNX to tensorRT while doing that conversion I was getting this error context = engine.create_execution_context()
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
- validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
Hi Team - We were getting below error screenshots when we trying ONNX model to trt conversion. Please guide us how to proceed.
1.We are using Mask2formertransformer decoder in our panoptic segmentation model
- We are able to convert all the individual layers to trt but when we run as a whole we are getting error.
MagnaMask2Former
- MagnaMask2FormerPixelLevelModule (Torch2ONNX: Success / ONNX2TRT: Success)
- Mask2FormerTransformerModule (Torch2ONNX: Success / ONNX2TRT: Failed)
a. Mask2FormerSinePositionEmbedding (Torch2ONNX: ??? / ONNX2TRT: ???)
b. Mask2FormerMaskedAttentionDecoder (Torch2ONNX: ??? / ONNX2TRT: ???)
i. Mask2FormerMaskedAttentionDecoderLayer (Torch2ONNX: ??? / ONNX2TRT: ???) - Mask2FormerAttention (Torch2ONNX: ??? / ONNX2TRT: ???)
- MultiheadAttention (Torch2ONNX: ??? / ONNX2TRT: ???)
ii. Mask2FormerMaskPredictor (Torch2ONNX: ??? / ONNX2TRT: ???) - Mask2FormerMLPPredictionHead (Torch2ONNX: ??? / ONNX2TRT: ???)
a. Mask2FormerPredictionBlock (Torch2ONNX: ??? / ONNX2TRT: ???)
We recommend you open a new topic with the issue repro ONNX model and complete verbose logs.
Thank you.
