Unsupported onnx type DOUBLE 11
Description
while trying to convert an ONNX model to tensorRT using trtexec we are having this error
Environment
TensorRT Version: 7.1.3
GPU Type: gtx 1080
Nvidia Driver Version: 460.80
CUDA Version: 11.2
CUDNN Version: 8
Operating System + Version:
Python Version (if applicable): 3.6
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.6.0
Baremetal or Container (if container which image + tag): nvcr.io/nvidia/tensorrt:20.09-py3
attached the screenshot for you reference
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
attached the model link
command we used
trtexec --onnx= jde_608x1088_11.onnx --explicitBatch --workspace=16382 --optShapes=input:1x3x608x1088 --maxShapes=input:1x3x608x1088 --minShapes=input:1x3x608x1088 --saveEngine=model.plan
@NVES the details given are enough to replicate the issue?
Hi @sivagurunathan.a,
Based on error, looks like you’re using Double data type in your model. Old version of TensorRT doesn’t support Double data type. On latest TRT version 8.0, we have support for Double data type. On latest version we are unable to reproduce this issue and able to successfully build TRT engine.
Please refer onnx-tensorrt/operators.md at main · onnx/onnx-tensorrt · GitHub for more details.
Thank you.
