Documentation errors
Here are some errors I noticed in the latest TensorRT docs. I’d advise you make the necessary fixes.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
You clearly didn’t read the question if this is your response…
Thank you @cyruspk4w6 for letting us know.
Our Team will review and fix them accordingly.
