ONNX Slice Operator issue : Incorrect output shape when built by TensorRT
Description
I have pytorch model that crops 46x146 input to multiple 32x32 region and each region is fed to classifiers.
The (simplified) model is exported as “model_dummy.onnx” .
I checked the onnx file by the visualizer and
I confirmed that the onnx “Slice” operator is used and it has expected attributes (axis, starts, ends).
When I build the model by tensorRT on Jetson Xavier,
The debug output shows that slice operator outputs 1x1 regions instead of 32x32 regions.
The build script is “trt_runner_dummy.py” and the log file is “trt_runner_dummy.py.log”.
Part of the log is :
[TensorRT] VERBOSE: 3:Slice → (3, 46, 146)
[TensorRT] VERBOSE: 4:Slice → (3, 46, 146)
[TensorRT] VERBOSE: 5:Slice → (3, 1, 146)
[TensorRT] VERBOSE: 6:Slice → (3, 1, 1)
In the project, I use CNN as classifiers. So the incorrect 1x1 shape results in broken predictions.
How Can I fix this issue?
Environment
Environment A (where Model is trained and ONNX model is exported)
TensorRT Version: None
GPU Type: RTX1080
Nvidia Driver Version: 410.48
CUDA Version: 10.0
CUDNN Version: 7
Operating System + Version: Ubuntu16.04
Python Version (if applicable): 3.5.2
TensorFlow Version (if applicable): None
PyTorch Version (if applicable): 1.0.0
Baremetal or Container (if container which image + tag): Container based on nvidia/cuda:10.0-cudnn7-devel-ubuntu16.04
pip package ONNX Version: 1.5
Environment B (where build script (using TensorRT) is run)
Jetson Xavier
Jetpack Version: 4.3
Python Version (if applicable): 3.6.9
Relevant Files
Steps To Reproduce
Premise:
  • tesnorrt python source is at ‘/usr/src/tensorrt/samples/python’
  • “model_dummy.onnx” is in current directory
Command:
python3 trt_runner_dummy.py
Merge these four slices into one slice where
slice = {0, 1, 2, 3}, start = {0, 0, 14, 28}, end = {1, 3, 46, 60}
Thanks for your response.
I merged 4x4 slice ops to 4 slice ops as you suggested
(Actually, I dont need slice for axes 0,1. So I omitted them)
the figure below is the visualization of sub-graph after merge:
and the log by tensorrt is:
$ python3 trt_runner.py
[TensorRT] VERBOSE: 128:Slice → (3, 1, 18)
[TensorRT] VERBOSE: 132:Slice → (3, 1, 1)
[TensorRT] VERBOSE: 136:Slice → (3, 1, 1)
[TensorRT] VERBOSE: 140:Slice → (3, 1, 1)
[TensorRT] VERBOSE: /home/jenkins/workspace/TensorRT/helpers/rel-6.0/L1_Nightly/build/source/parsers/onnxOpenSource/builtin_op_importers.cpp:773: Convolution input dimensions: (3, 1, 18)
[TensorRT] VERBOSE: /home/jenkins/workspace/TensorRT/helpers/rel-6.0/L1_Nightly/build/source/parsers/onnxOpenSource/builtin_op_importers.cpp:840: Using kernel: (7, 7), strides: (2, 2), padding: (3, 3), dilations: (1, 1), numOutputs: 64
[TensorRT] VERBOSE: /home/jenkins/workspace/TensorRT/helpers/rel-6.0/L1_Nightly/build/source/parsers/onnxOpenSource/builtin_op_importers.cpp:841: Convolution output dimensions: (64, 1, 9)
[TensorRT] VERBOSE: 141:Conv → (64, 1, 9)
[TensorRT] VERBOSE: 142:BatchNormalization → (64, 1, 9)
[TensorRT] VERBOSE: 143:Relu → (64, 1, 9)
[TensorRT] VERBOSE: 144:MaxPool → (64, 1, 5)
As you can see, I got another incorrect shape after merge.
I looks like a bug of the build engine.
What should I do to fix this?
I remember this problem was due to the bug of onnx-tensorrt when importing onnx.
close this issue.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
This issue has been resolved and no support is needed.
Thank you.
