Description
I run into some shape issues (with IShuffleLayer) when trying to run trtexec on my onnx model, which is a faster rcnn model provided by pytorch model zoo .
Environment
TensorRT Version : 8.4.3-1+cuda11.6
GPU Type : 1 Quadro RTX 6000
Nvidia Driver Version :
CUDA Version : 11.6
CUDNN Version : Running nvcc --version
gives me 11.6
Operating System + Version : Ubuntu 18.02
Python Version (if applicable) : 3.9.12
PyTorch Version (if applicable) : 1.12.1+cu116
Baremetal or Container (if container which image + tag) : baremetal
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Code to Reproduce Faster-RCNN Model and Export to ONNX Model (named faster_rcnn_base.onnx
export_pytorch_onnx.py (1.6 KB)
Steps To Reproduce
Please include:
Ran export_pytorch_onnx.py
to create Faster-RCNN and export it to ONNX format.
Ran /usr/src/tensorrt/bin/trtexec --onnx=faster_rcnn_base.onnx --saveEngine=faster_rcnn_base_engine.trt --verbose
Traceback can be found in this file:
original_traceback.txt (127.2 KB)
Some additional steps I tried using to fix:
I tried using polygraphy
to fold constants outlined in another post , but I ran into another error with with IShuffleLayer.
Polygraphy I ran: polygraphy surgeon sanitize --fold-constants faster_rcnn_base.onnx -o faster_rcnn_base_sanitized.onnx
Traceback after running trtexec --onnx=faster_rcnn_base.onnx --saveEngine=faster_rcnn_base_engine.trt --verbose
polygraphy_traceback.txt (307.8 KB)
NVES
August 30, 2022, 1:07am
2
Hi ,
We recommend you to check the supported features from the below link.
These support matrices provide a look into the supported platforms, features, and hardware capabilities of the NVIDIA TensorRT 8.4.3 APIs, parsers, and layers.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
<!--- SPDX-License-Identifier: Apache-2.0 -->
# Supported ONNX Operators
TensorRT 8.4 supports operators up to Opset 17. Latest information of ONNX operators can be found [here](https://github.com/onnx/onnx/blob/master/docs/Operators.md)
TensorRT supports the following ONNX data types: DOUBLE, FLOAT32, FLOAT16, INT8, and BOOL
> Note: There is limited support for INT32, INT64, and DOUBLE types. TensorRT will attempt to cast down INT64 to INT32 and DOUBLE down to FLOAT, clamping values to `+-INT_MAX` or `+-FLT_MAX` if necessary.
See below for the support matrix of ONNX operators in ONNX-TensorRT.
## Operator Support Matrix
| Operator | Supported | Supported Types | Restrictions |
| Abs | Y | FP32, FP16, INT32 |
| Acos | Y | FP32, FP16 |
| Acosh | Y | FP32, FP16 |
| Add | Y | FP32, FP16, INT32 |
This file has been truncated. show original
After we sanitize the model using Polygraphy, facing the following error.
[09/01/2022-08:30:24] [V] [TRT] Registering layer: Reshape_1330 for ONNX node: Reshape_1330
[09/01/2022-08:30:24] [E] Error[4]: [graphShapeAnalyzer.cpp::analyzeShapes::1294] Error Code 4: Miscellaneous (IShuffleLayer Reshape_1330: reshape changes volume. Reshaping [946181376] to [1,4624].)
[09/01/2022-08:30:24] [E] [TRT] parsers/onnx/ModelImporter.cpp:773: While parsing node number 357 [Reshape -> "onnx::Sigmoid_2547"]:
[09/01/2022-08:30:24] [E] [TRT] parsers/onnx/ModelImporter.cpp:774: --- Begin node ---
[09/01/2022-08:30:24] [E] [TRT] parsers/onnx/ModelImporter.cpp:775: input: "onnx::Reshape_2545"
input: "onnx::Reshape_2546"
output: "onnx::Sigmoid_2547"
op_type: "Reshape"
[09/01/2022-08:30:24] [E] [TRT] parsers/onnx/ModelImporter.cpp:776: --- End node ---
[09/01/2022-08:30:24] [E] [TRT] parsers/onnx/ModelImporter.cpp:778: ERROR: parsers/onnx/ModelImporter.cpp:180 In function parseGraph:
[6] Invalid Node - Reshape_1330
[09/01/2022-08:30:24] [E] Failed to parse onnx file
[09/01/2022-08:30:24] [I] Finish parsing network model
[09/01/2022-08:30:24] [E] Parsing model failed
[09/01/2022-08:30:24] [E] Failed to create engine from model or file.
[09/01/2022-08:30:24] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8401] # trtexec --onnx=faster_rcnn_base_sanitized.onnx --verbose --workspace=10000
Please refer to the following similar issue and fix your onnx model.
It’s because the Reshape op has hard-coded shapes [1, 3, 85, 20, 20], which should have been [-1, 3, 85, 20, 20].
[image]
Could please let us know how you exported the ONNX model from PyT/TF? Do you use the dynamic_axes argument as in (optional) Exporting a Model from PyTorch to ONNX and Running it using ONNX Runtime — PyTorch Tutorials 1.12.1+cu102 documentation ?
If you already did it, then you need to modify the Reshape of the PyT code from [1, 3, 85, 20, 20] to [-1, 3, 85, 20, 20].
T…
opened 07:07AM - 15 Aug 22 UTC
closed 02:09AM - 06 Dec 22 UTC
triaged
hello, when i coverted my onnx model to TensorRT by the command,
`./trtexec --o… nnx=model.onnx --saveEngine=model.engine`
i got big diff between pytorch result and trt result. i located the problem which might be related to the decoder transformer part of my model. so i only coverted the transformer part to onnx and try to find out what is wrong. but when i run the command `./trtexec --onnx=decoder_transformer.onnx --saveEngine=decoder_transformer.engine`to covert onnx to trt. i got an error which didn't appear during the "model.onnx" converting.
<img width="731" alt="error" src="https://user-images.githubusercontent.com/56212446/184589569-84f0c06e-a000-43d9-b335-138787f4f7f1.png">
The error comes from the cross attention part. but the error disappears when i only covert the cross attention module to onnx and trt by `./trtexec --onnx=cross_attention.onnx --saveEngine=cross_attention.engine`. so finally i can not figure out how to solve the problem to get correct trt result and open a issue for some help. Thanks~
**Environment**
TensorRT Version: 8.4.1.5+cuda11.6
NVIDIA GPU: A100
NVIDIA Driver Version: 510.47.03
CUDA Version: 11.6
CUDNN Version: 8.4.0.27
Operating System: Ubuntu 20.04.2 LTS
Python Version: 3.7.13
PyTorch Version: 1.10
Thank you.
Thanks for your reply. How exactly do I modify the Reshape op? Is there a way to modify the onnx graph itself?
I’m using the torchvision models provided by pytorch, so I think all the reshape ops are using -1 in the first axis.
