Conversion of FasterRCNN ONNX model to TensorRT fails
Description
I am trying to convert an ONNX FasterRCNN based object detection model to a TensorRT engine and running into an error with shapes in the ROI heads.
Here is an example script that will allow one to recreate the error:
import os
import tensorrt as trt
if __name__ == '__main__':
    x_shape = (2,2,300,400)
    DIR_NAME = os.path.dirname(__file__)
    TRT_LOGGER = trt.Logger(trt.Logger.VERBOSE)
    trt.init_libnvinfer_plugins(TRT_LOGGER, '')
    builder = trt.Builder(TRT_LOGGER)
    network = builder.create_network()
    parser = trt.OnnxParser(network, builder.logger)
    onnx_path = os.path.realpath('model_zoo_rcnn.onnx')
    with open(onnx_path, "rb") as f:
        if not parser.parse(f.read()):
            TRT_LOGGER.log(trt.Logger.ERROR, f"Failed to load ONNX file: {onnx_path}")
            for error in range(parser.num_errors):
                TRT_LOGGER.log( trt.Logger.ERROR, parser.get_error(error))
            raise RuntimeError(f'Failed to load ONNX file: {onnx_path}')
    engine_path = os.path.realpath('model_zoo_rcnn.engine')
    engine_dir = os.path.dirname(engine_path)
    os.makedirs(engine_dir, exist_ok=True)
    inputs = [network.get_input(i) for i in range(network.num_inputs)]
    config = builder.create_builder_config()
    config.profiling_verbosity = trt.ProfilingVerbosity.DETAILED
    engine_str = builder.build_serialized_network(network, config)
    with open(engine_path, "wb") as f:
        f.write(engine_str)
And here is the model used for this example:
This occurs when using the default TensorRT plugin based ROIAlign node. It occurs even when an exported ONNX model includes a fixed batch size/input and output tensor shapes. These issues appear to occur with any RCNN based model, including ones from the ONNX Model Zoo.
Does the input ONNX file/graph need to be modified to use dynamic shapes in this node or set the node’s inputs/outputs to be fixed? If so, how can this be done? If this is not the issue, what is causing this error and how can it be fixed?
Environment
TensorRT Version: 10.5
GPU Type: Nvidia Jetson Orin
Nvidia Driver Version: 540.4.0
CUDA Version: 12.6
CUDNN Version:
Operating System + Version: Ubuntu 22.04.04
Python Version (if applicable): 3.10.15
Baremetal or Container (if container which image + tag): Baremetal
Relevant Files
Log from loading ONNX graph:
faster_rcnn_ex.log (1.5 MB)
I see this previous post from May 2023. Is the ONNX to TRT converter fixed to support this file type?
I have been able to get this workaround to work. We can do this through our onnx_graphsurgeon tool by forcing the condition to be a constant. TRT is able to optimize out the conditional entirely in this case.Modification script:
import onnx_graphsurgeon as gs
import numpy as np
const_else = gs.Constant("const_else", np.array([0]).astype(np.bool_))
g = gs.import_onnx(onnx.load("fasterrcnn.onnx"))
# Overwrite condition to a constant.
for n in g.nodes:
    if n.op == "If":
        n.inputs = [const_else]
onnx.save(gs.export_onnx(g), "fasterrcnn_constelse.onnx")
While converting MaskRCNN ONNX to trt, I used the above workaround and and running into new error.
Here is an example code to recreate the error:
def simple_export():
    """Simple export process"""
    try:
        # Load original model
        print("πŸ“¦ Loading Mask R-CNN model...")
        model = torchvision.models.detection.maskrcnn_resnet50_fpn(
            pretrained=False,
            num_classes=NUM_CLASSES
        model.load_state_dict(torch.load(MODEL_PTH_PATH, map_location="cuda"))
        model.to("cuda")
        model.eval()
        # # Extract just the backbone
        # print("πŸ”§ Extracting backbone...")
        # backbone_model = BackboneOnly(model)
        # backbone_model = backbone_model.cuda()
        # backbone_model.eval()
        # Test the model first
        print("πŸ§ͺ Testing model...")
        dummy_input = torch.randn(*INPUT_SHAPE).cuda()
        with torch.no_grad():
            output = model(dummy_input)
            # print(f"βœ… Model output shape: {output.shape}")
        # Export to ONNX
        print("πŸ“€ Exporting backbone to ONNX...")
        torch.onnx.export(
            model,
            dummy_input,
            ONNX_EXPORT_PATH,
            export_params=True,
            opset_version=11,
            do_constant_folding=True,
            input_names=["input"],
            output_names=['boxes', 'labels', 'scores', 'masks'],
            verbose=False
        print("βœ… ONNX export successful")
        g = gs.import_onnx(onnx.load("maskrcnn_simple.onnx"))
        for n in g.nodes:
            if n.op == "If":
        onnx.save(gs.export_onnx(g), "maskrcnn_constelse.onnx")
        return True
    except Exception as e:
        print(f"❌ Export failed: {e}")
        return False
def convert_to_tensorrt():
    """Convert ONNX to TensorRT"""
    try:
        print("πŸ”§ Converting to TensorRT...")
        # Create builder
        logger = trt.Logger(trt.Logger.INFO)
        builder = trt.Builder(logger)
        network = builder.create_network(1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH))
        parser = trt.OnnxParser(network, logger)
        # Parse ONNX
        with open("maskrcnn_constelse.onnx", 'rb') as model_file:
            if not parser.parse(model_file.read()):
                    print(parser.get_error(error))
                return False
        print("βœ… ONNX parsed successfully")
        # Build config
        if hasattr(config, 'set_memory_pool_limit'):
            config.set_memory_pool_limit(trt.MemoryPoolType.WORKSPACE, 1 << 30)
        # Set input shape
        profile = builder.create_optimization_profile()
        input_name = network.get_input(0).name
        profile.set_shape(input_name, INPUT_SHAPE, INPUT_SHAPE, INPUT_SHAPE)
        config.add_optimization_profile(profile)
        # Build engine
        print("βš™οΈ Building engine...")
        serialized_engine = builder.build_serialized_network(network, config)
        if serialized_engine:
            with open(TRT_ENGINE_PATH, 'wb') as f:
                f.write(serialized_engine)
            print(f"βœ… Engine saved to {TRT_ENGINE_PATH}")
            return True
        else:
            print("❌ Failed to build engine")
            return False
        print(f"❌ TensorRT conversion failed: {e}")
        return False
