Description
I want to infer a customized SSD on TensorRT at Jetson Nano.
I tried to convert onnx to TensorRT Model using the following command and encountered the following error.
command
trtexec --onnx=xxxx.onnx --explicitBatch --saveEngine=xxxx.trt
Error Message
[08/10/2021-19:20:10] [E] Error[9]: [graphShapeAnalyzer.cpp::throwIfError::1306] Error Code 9: Internal Error (Postprocessor/Reshape: -1 wildcard solution does not fit in int32_t
[08/10/2021-19:20:10] [E] [TRT] ModelImporter.cpp:720: While parsing node number 360 [Reshape -> "Postprocessor/Reshape:0"]:
[08/10/2021-19:20:10] [E] [TRT] ModelImporter.cpp:721: --- Begin node ---
[08/10/2021-19:20:10] [E] [TRT] ModelImporter.cpp:722: input: "Postprocessor/Tile:0"
input: "const_fold_opt__5985"
output: "Postprocessor/Reshape:0"
op_type: "Reshape"
[08/10/2021-19:20:10] [E] [TRT] ModelImporter.cpp:723: --- End node ---
[08/10/2021-19:20:10] [E] [TRT] ModelImporter.cpp:726: ERROR: ModelImporter.cpp:179 In function parseGraph:
[6] Invalid Node - Postprocessor/Reshape
[08/10/2021-19:20:10] [E] Failed to parse onnx file
[08/10/2021-19:20:10] [I] Finish parsing network model
[08/10/2021-19:20:10] [E] Parsing model failed
[08/10/2021-19:20:10] [E] Engine creation failed
[08/10/2021-19:20:10] [E] Engine set up failed
I want to know “-1 wildcard solution does not fit in int32_t” means.
And I also want to know if I need to change the implementation of the model.
This customized SSD is implemented in Tensorflow.
If this is a problem that can be dealt with in the command options when converting from tensorflow to ONNX or ONNX to TensorRT, I would be very happy to get a hint.
If I need to implement the model itself for success converting to TensorRT, I can do that.
However, I would like to avoid changing the implementation if possible because it would have a large impact.
Environment
Jetpack version : 4.6(L4T 6.1)
TensorRT Version: 8.0.1.6
GPU Type: GPU embeded on Jetson nano
Nvidia Driver Version:
CUDA Version: 10.2
CUDNN Version: 8.2.1
Operating System + Version: Jetpack 4.6 (L4T 6.1, Ubuntu18.04)
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.15.5
ONNX OPset version: 12
PyTorch Version (if applicable): no use
Baremetal or Container (if container which image + tag):
Full log
[08/10/2021-19:20:06] [I] === Model Options ===
[08/10/2021-19:20:06] [I] Format: ONNX
[08/10/2021-19:20:06] [I] Model: models/person_face_detection_model_frozen_960_540.onnx
[08/10/2021-19:20:06] [I] Output:
[08/10/2021-19:20:06] [I] === Build Options ===
[08/10/2021-19:20:06] [I] Max batch: explicit
[08/10/2021-19:20:06] [I] Workspace: 16 MiB
[08/10/2021-19:20:06] [I] minTiming: 1
[08/10/2021-19:20:06] [I] avgTiming: 8
[08/10/2021-19:20:06] [I] Precision: FP32
[08/10/2021-19:20:06] [I] Calibration:
[08/10/2021-19:20:06] [I] Refit: Disabled
[08/10/2021-19:20:06] [I] Sparsity: Disabled
[08/10/2021-19:20:06] [I] Safe mode: Disabled
[08/10/2021-19:20:06] [I] Restricted mode: Disabled
[08/10/2021-19:20:06] [I] Save engine: models/person_face_detection_model_frozen_960_540.trt
[08/10/2021-19:20:06] [I] Load engine:
[08/10/2021-19:20:06] [I] NVTX verbosity: 0
[08/10/2021-19:20:06] [I] Tactic sources: Using default tactic sources
[08/10/2021-19:20:06] [I] timingCacheMode: local
[08/10/2021-19:20:06] [I] timingCacheFile:
[08/10/2021-19:20:06] [I] Input(s)s format: fp32:CHW
[08/10/2021-19:20:06] [I] Output(s)s format: fp32:CHW
[08/10/2021-19:20:06] [I] Input build shapes: model
[08/10/2021-19:20:06] [I] Input calibration shapes: model
[08/10/2021-19:20:06] [I] === System Options ===
[08/10/2021-19:20:06] [I] Device: 0
[08/10/2021-19:20:06] [I] DLACore:
[08/10/2021-19:20:06] [I] Plugins:
[08/10/2021-19:20:06] [I] === Inference Options ===
[08/10/2021-19:20:06] [I] Batch: Explicit
[08/10/2021-19:20:06] [I] Input inference shapes: model
[08/10/2021-19:20:06] [I] Iterations: 10
[08/10/2021-19:20:06] [I] Duration: 3s (+ 200ms warm up)
[08/10/2021-19:20:06] [I] Sleep time: 0ms
[08/10/2021-19:20:06] [I] Streams: 1
[08/10/2021-19:20:06] [I] ExposeDMA: Disabled
[08/10/2021-19:20:06] [I] Data transfers: Enabled
[08/10/2021-19:20:06] [I] Spin-wait: Disabled
[08/10/2021-19:20:06] [I] Multithreading: Disabled
[08/10/2021-19:20:06] [I] CUDA Graph: Disabled
[08/10/2021-19:20:06] [I] Separate profiling: Disabled
[08/10/2021-19:20:06] [I] Time Deserialize: Disabled
[08/10/2021-19:20:06] [I] Time Refit: Disabled
[08/10/2021-19:20:06] [I] Skip inference: Disabled
[08/10/2021-19:20:06] [I] Inputs:
[08/10/2021-19:20:06] [I] === Reporting Options ===
[08/10/2021-19:20:06] [I] Verbose: Disabled
[08/10/2021-19:20:06] [I] Averages: 10 inferences
[08/10/2021-19:20:06] [I] Percentile: 99
[08/10/2021-19:20:06] [I] Dump refittable layers:Disabled
[08/10/2021-19:20:06] [I] Dump output: Disabled
[08/10/2021-19:20:06] [I] Profile: Disabled
[08/10/2021-19:20:06] [I] Export timing to JSON file:
[08/10/2021-19:20:06] [I] Export output to JSON file:
[08/10/2021-19:20:06] [I] Export profile to JSON file:
[08/10/2021-19:20:06] [I] === Device Information ===
[08/10/2021-19:20:06] [I] Selected Device: NVIDIA Tegra X1
[08/10/2021-19:20:06] [I] Compute Capability: 5.3
[08/10/2021-19:20:06] [I] SMs: 1
[08/10/2021-19:20:06] [I] Compute Clock Rate: 0.9216 GHz
[08/10/2021-19:20:06] [I] Device Global Memory: 3956 MiB
[08/10/2021-19:20:06] [I] Shared Memory per SM: 64 KiB
[08/10/2021-19:20:06] [I] Memory Bus Width: 64 bits (ECC disabled)
[08/10/2021-19:20:06] [I] Memory Clock Rate: 0.01275 GHz
[08/10/2021-19:20:06] [I] TensorRT version: 8001
[08/10/2021-19:20:09] [I] [TRT] [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 221, GPU 3340 (MiB)
[08/10/2021-19:20:09] [I] Start parsing network model
[08/10/2021-19:20:09] [I] [TRT] ----------------------------------------------------------------
[08/10/2021-19:20:09] [I] [TRT] Input filename: models/person_face_detection_model_frozen_960_540.onnx
[08/10/2021-19:20:09] [I] [TRT] ONNX IR version: 0.0.7
[08/10/2021-19:20:09] [I] [TRT] Opset version: 12
[08/10/2021-19:20:09] [I] [TRT] Producer name: tf2onnx
[08/10/2021-19:20:09] [I] [TRT] Producer version: 1.9.1
[08/10/2021-19:20:09] [I] [TRT] Domain:
[08/10/2021-19:20:09] [I] [TRT] Model version: 0
[08/10/2021-19:20:09] [I] [TRT] Doc string:
[08/10/2021-19:20:09] [W] [TRT] onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[08/10/2021-19:20:09] [W] [TRT] onnx2trt_utils.cpp:390: One or more weights outside the range of INT32 was clamped
op_type: "Reshape"
