Tensorrt fails shapeMachine.cpp
Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version:
GPU Type - Drive Orin AGX:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
I have generated the onnx using aten_fallback, opset 16. I see this error, what could be the issue.
[02/15/2024-19:28:55] [E] Error[7]: [shapeMachine.cpp::executeContinuation::864] Error Code 7: Internal Error (IShuffleLayer /Reshape_12: reshaping failed for tensor: /GatherND_3_output_0 reshape would change volume 1516 to 24256 Instruction: RESHAPE{379 4} {379 64}.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Hi @arkos ,
Can you please help us with the onnx model and detailed logs?
ONNX 1 - Original onnx.
ONNX 2 - Repaired onnx using the code
def onnx_allowzero(modelf="model_transposed_constant_folding_bsz1_a0_b0.onnx"):
    graph = gs.import_onnx(onnx.load(modelf))
    for node in graph.nodes:
        if node.op == "Reshape":
            node.attrs["allowzero"] = 1
    onnx.save(gs.export_onnx(graph), "repaired.onnx")
error log of tensorrt
nvidia@tegra-ubuntu:/usr/src/tensorrt/bin$ ./trtexec --onnx=/home/nvidia/models/repaired.onnx --saveEngine=model_transposed_constant_folding_bsz1_a0_b0_repaired.trt
&&&& RUNNING TensorRT.trtexec [TensorRT v8611] # ./trtexec --onnx=/home/nvidia/models/repaired.onnx --saveEngine=model_transposed_constant_folding_bsz1_a0_b0_repaired.trt
[02/16/2024-06:53:42] [I] === Model Options ===
[02/16/2024-06:53:42] [I] Format: ONNX
[02/16/2024-06:53:42] [I] Model: /home/nvidia/models/repaired.onnx
[02/16/2024-06:53:42] [I] Output:
[02/16/2024-06:53:42] [I] === Build Options ===
[02/16/2024-06:53:42] [I] Max batch: explicit batch
[02/16/2024-06:53:42] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[02/16/2024-06:53:42] [I] minTiming: 1
[02/16/2024-06:53:42] [I] avgTiming: 8
[02/16/2024-06:53:42] [I] Precision: FP32
[02/16/2024-06:53:42] [I] LayerPrecisions:
[02/16/2024-06:53:42] [I] Layer Device Types:
[02/16/2024-06:53:42] [I] Calibration:
[02/16/2024-06:53:42] [I] Refit: Disabled
[02/16/2024-06:53:42] [I] Version Compatible: Disabled
[02/16/2024-06:53:42] [I] TensorRT runtime: full
[02/16/2024-06:53:42] [I] Lean DLL Path:
[02/16/2024-06:53:42] [I] Tempfile Controls: { in_memory: allow, temporary: allow }
[02/16/2024-06:53:42] [I] Exclude Lean Runtime: Disabled
[02/16/2024-06:53:42] [I] Sparsity: Disabled
[02/16/2024-06:53:42] [I] Safe mode: Disabled
[02/16/2024-06:53:42] [I] Build DLA standalone loadable: Disabled
[02/16/2024-06:53:42] [I] Allow GPU fallback for DLA: Disabled
[02/16/2024-06:53:42] [I] DirectIO mode: Disabled
[02/16/2024-06:53:42] [I] Restricted mode: Disabled
[02/16/2024-06:53:42] [I] Skip inference: Disabled
[02/16/2024-06:53:42] [I] Save engine: model_transposed_constant_folding_bsz1_a0_b0_repaired.trt
[02/16/2024-06:53:42] [I] Load engine:
[02/16/2024-06:53:42] [I] Profiling verbosity: 0
[02/16/2024-06:53:42] [I] Tactic sources: Using default tactic sources
[02/16/2024-06:53:42] [I] timingCacheMode: local
[02/16/2024-06:53:42] [I] timingCacheFile:
[02/16/2024-06:53:42] [I] Heuristic: Disabled
[02/16/2024-06:53:42] [I] Preview Features: Use default preview flags.
[02/16/2024-06:53:42] [I] MaxAuxStreams: -1
[02/16/2024-06:53:42] [I] BuilderOptimizationLevel: -1
[02/16/2024-06:53:42] [I] Calibration Profile Index: 0
[02/16/2024-06:53:42] [I] Input(s)s format: fp32:CHW
[02/16/2024-06:53:42] [I] Output(s)s format: fp32:CHW
[02/16/2024-06:53:42] [I] Input build shapes: model
[02/16/2024-06:53:42] [I] Input calibration shapes: model
[02/16/2024-06:53:42] [I] === System Options ===
[02/16/2024-06:53:42] [I] Device: 0
[02/16/2024-06:53:42] [I] DLACore:
[02/16/2024-06:53:42] [I] Plugins:
[02/16/2024-06:53:42] [I] setPluginsToSerialize:
[02/16/2024-06:53:42] [I] dynamicPlugins:
[02/16/2024-06:53:42] [I] ignoreParsedPluginLibs: 0
[02/16/2024-06:53:42] [I] === Inference Options ===
[02/16/2024-06:53:42] [I] Batch: Explicit
[02/16/2024-06:53:42] [I] Input inference shapes: model
[02/16/2024-06:53:42] [I] Iterations: 10
[02/16/2024-06:53:42] [I] Duration: 3s (+ 200ms warm up)
[02/16/2024-06:53:42] [I] Sleep time: 0ms
[02/16/2024-06:53:42] [I] Idle time: 0ms
[02/16/2024-06:53:42] [I] Inference Streams: 1
[02/16/2024-06:53:42] [I] ExposeDMA: Disabled
[02/16/2024-06:53:42] [I] Data transfers: Enabled
[02/16/2024-06:53:42] [I] Spin-wait: Disabled
[02/16/2024-06:53:42] [I] Multithreading: Disabled
[02/16/2024-06:53:42] [I] CUDA Graph: Disabled
[02/16/2024-06:53:42] [I] Separate profiling: Disabled
[02/16/2024-06:53:42] [I] Time Deserialize: Disabled
[02/16/2024-06:53:42] [I] Time Refit: Disabled
[02/16/2024-06:53:42] [I] NVTX verbosity: 0
[02/16/2024-06:53:42] [I] Persistent Cache Ratio: 0
[02/16/2024-06:53:42] [I] Optimization Profile Index: 0
[02/16/2024-06:53:42] [I] Inputs:
[02/16/2024-06:53:42] [I] === Reporting Options ===
[02/16/2024-06:53:42] [I] Verbose: Disabled
[02/16/2024-06:53:42] [I] Averages: 10 inferences
[02/16/2024-06:53:42] [I] Percentiles: 90,95,99
[02/16/2024-06:53:42] [I] Dump refittable layers:Disabled
[02/16/2024-06:53:42] [I] Dump output: Disabled
[02/16/2024-06:53:42] [I] Profile: Disabled
[02/16/2024-06:53:42] [I] Export timing to JSON file:
[02/16/2024-06:53:42] [I] Export output to JSON file:
[02/16/2024-06:53:42] [I] Export profile to JSON file:
[02/16/2024-06:53:42] [I] === Device Information ===
[02/16/2024-06:53:42] [I] Selected Device: Orin
[02/16/2024-06:53:42] [I] Compute Capability: 8.7
[02/16/2024-06:53:42] [I] SMs: 16
[02/16/2024-06:53:42] [I] Device Global Memory: 28902 MiB
[02/16/2024-06:53:42] [I] Shared Memory per SM: 164 KiB
[02/16/2024-06:53:42] [I] Memory Bus Width: 128 bits (ECC disabled)
[02/16/2024-06:53:42] [I] Application Compute Clock Rate: 1.275 GHz
[02/16/2024-06:53:42] [I] Application Memory Clock Rate: 1.275 GHz
[02/16/2024-06:53:42] [I] Note: The application clock rates do not reflect the actual clock rates that the GPU is currently running at.
[02/16/2024-06:53:42] [I] TensorRT version: 8.6.11
[02/16/2024-06:53:42] [I] Loading standard plugins
[02/16/2024-06:53:43] [I] [TRT] [MemUsageChange] Init CUDA: CPU +443, GPU +0, now: CPU 463, GPU 9089 (MiB)
[02/16/2024-06:53:45] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +834, GPU +991, now: CPU 1329, GPU 10106 (MiB)
[02/16/2024-06:53:45] [I] Start parsing network model.
[02/16/2024-06:53:45] [I] [TRT] ----------------------------------------------------------------
[02/16/2024-06:53:45] [I] [TRT] Input filename:   /home/nvidia/models/repaired.onnx
[02/16/2024-06:53:45] [I] [TRT] ONNX IR version:  0.0.9
[02/16/2024-06:53:45] [I] [TRT] Opset version:    16
[02/16/2024-06:53:45] [I] [TRT] Producer name:    pytorch
[02/16/2024-06:53:45] [I] [TRT] Producer version: 2.1.1
[02/16/2024-06:53:45] [I] [TRT] Domain:
[02/16/2024-06:53:45] [I] [TRT] Model version:    0
[02/16/2024-06:53:45] [I] [TRT] Doc string:
[02/16/2024-06:53:45] [W] [TRT] onnx2trt_utils.cpp:372: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[02/16/2024-06:53:45] [W] [TRT] onnx2trt_utils.cpp:400: One or more weights outside the range of INT32 was clamped
[02/16/2024-06:53:45] [W] [TRT] builtin_op_importers.cpp:4875: TensorRT is using FLOAT32 precision to run an INT32 TopK. Rounding errors may occur for large integer values
[02/16/2024-06:53:45] [I] Finished parsing network model. Parse time: 0.145678
[02/16/2024-06:53:45] [I] [TRT] Graph optimization time: 0.122808 seconds.
[02/16/2024-06:53:45] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[02/16/2024-06:57:11] [I] [TRT] Detected 6 inputs and 1 output network tensors.
[02/16/2024-06:57:18] [I] [TRT] Total Host Persistent Memory: 693776
[02/16/2024-06:57:18] [I] [TRT] Total Device Persistent Memory: 0
[02/16/2024-06:57:18] [I] [TRT] Total Scratch Memory: 17487360
[02/16/2024-06:57:18] [I] [TRT] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 9 MiB, GPU 96 MiB
[02/16/2024-06:57:18] [I] [TRT] [BlockAssignment] Started assigning block shifts. This will take 297 steps to complete.
[02/16/2024-06:57:18] [I] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 44.0758ms to assign 8 blocks to 297 nodes requiring 56313344 bytes.
[02/16/2024-06:57:18] [I] [TRT] Total Activation Memory: 56312320
[02/16/2024-06:57:18] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in building engine: CPU +0, GPU +64, now: CPU 0, GPU 64 (MiB)
[02/16/2024-06:57:18] [I] Engine built in 216.186 sec.
[02/16/2024-06:57:19] [I] [TRT] Loaded engine size: 50 MiB
[02/16/2024-06:57:19] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +48, now: CPU 0, GPU 48 (MiB)
[02/16/2024-06:57:19] [I] Engine deserialized in 0.0500841 sec.
[02/16/2024-06:57:19] [I] [TRT] [MS] Running engine with multi stream info
[02/16/2024-06:57:19] [I] [TRT] [MS] Number of aux streams is 2
[02/16/2024-06:57:19] [I] [TRT] [MS] Number of total worker streams is 3
[02/16/2024-06:57:19] [I] [TRT] [MS] The main stream provided by execute/enqueue calls is the first worker stream
[02/16/2024-06:57:19] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +1, GPU +54, now: CPU 1, GPU 102 (MiB)
[02/16/2024-06:57:19] [I] Setting persistentCacheLimit to 0 bytes.
[02/16/2024-06:57:19] [I] Using random values for input input_0
[02/16/2024-06:57:19] [I] Input binding for input_0 with dimensions 1x6x3x128x352 is created.
[02/16/2024-06:57:19] [I] Using random values for input input_1
[02/16/2024-06:57:19] [I] Input binding for input_1 with dimensions 1x6x3x3 is created.
[02/16/2024-06:57:19] [I] Using random values for input input_2
[02/16/2024-06:57:19] [I] Input binding for input_2 with dimensions 1x6x3 is created.
[02/16/2024-06:57:19] [I] Using random values for input input_5
[02/16/2024-06:57:19] [I] Input binding for input_5 with dimensions 1x6x3 is created.
[02/16/2024-06:57:19] [I] Using random values for input input_6
[02/16/2024-06:57:19] [I] Input binding for input_6 with dimensions 1x6x3x3 is created.
[02/16/2024-06:57:19] [I] Using random values for input input_7
[02/16/2024-06:57:19] [I] Input binding for input_7 with dimensions 1x6x3x3 is created.
[02/16/2024-06:57:19] [I] Output binding for output with dimensions 1x2x104x104 is created.
[02/16/2024-06:57:19] [I] Starting inference
[02/16/2024-06:57:19] [E] Error[7]: [shapeMachine.cpp::executeContinuation::864] Error Code 7: Internal Error (IShuffleLayer /Reshape_12: reshaping failed for tensor: /GatherND_3_output_0 reshape would change volume 1516 to 24256 Instruction: RESHAPE{379 4} {379 64}.)
[02/16/2024-06:57:19] [E] Error occurred during inference
&&&& FAILED TensorRT.trtexec [TensorRT v8611] # ./trtexec --onnx=/home/nvidia/models/repaired.onnx --saveEngine=model_transposed_constant_folding_bsz1_a0_b0_repaired.trt
ONNX 1-
model_transposed_constant_folding_bsz1_a0_b0 (copy).txt (52.0 MB)
ONNX 2 -
repaired.txt (48.5 MB)
