See the error below which occurs when I try to convert an ONNX model to TensorRT engine. I’m not sure how to fix this or how to go about debugging it. I have found the TopK layer using Netron, but I can’t associate it to where it is in my network (I am using a custom CNN architecture).
The command I run is ./trtexec.exe --onnx=C:\Users\timf3\PycharmProjects\BallNet\footandball_model.onnx --minShapes=input:1x3x1080x1920 --optShapes=input:1x3x1080x1920 --maxShapes=input:1x3x1080x1920 --fp16 --saveEngine=resnet_engine.trt which I run from TensorRT-10.0.1.6\bin directory.
Error portion of logs:
Error[4]: [graphShapeAnalyzer.cpp::nvinfer1::builder::`anonymous-namespace'::ShapeAnalyzerImpl::analyzeShapes::2084] Error Code 4: Miscellaneous (ITopKLayer /TopK: /TopK: K exceeds the maximum value allowed (3840).)
[05/07/2024-15:50:04] [E] Engine could not be created from network
[05/07/2024-15:50:04] [E] Building engine failed
[05/07/2024-15:50:04] [E] Failed to create engine from model or file.
[05/07/2024-15:50:04] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v100001] # C:\Program Files\TensorRT-10.0.1.6\bin\trtexec.exe --onnx=C:\Users\timf3\PycharmProjects\BallNet\footandball_model.onnx --minShapes=input:1x3x1080x1920 --optShapes=input:1x3x1080x1920 --maxShapes=input:1x3x1080x1920 --fp16 --saveEngine=resnet_engine.trt
I am running this on the most recent version of TensorRT, and am using an Nvidia GeForce 3050Ti on a Windows 11 laptop.
Here is the output from nvcc --version:
PS C:\Program Files\TensorRT-10.0.1.6\bin> nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:41:10_Pacific_Daylight_Time_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
Here are the full logs:
PS C:\Program Files\TensorRT-10.0.1.6\bin> ./trtexec.exe --onnx=C:\Users\timf3\PycharmProjects\BallNet\footandball_model.onnx --minShapes=input:1x3x1080x1920 --optShapes=input:1x3x1080x1920 --maxShapes=input:1x3x1080x1920 --fp16 --sav
&&&& RUNNING TensorRT.trtexec [TensorRT v100001] # C:\Program Files\TensorRT-10.0.1.6\bin\trtexec.exe --onnx=C:\Users\timf3\PycharmProjects\BallNet\footandball_model.onnx --minShapes=input:1x3x1080x1920 --optShapes=input:1x3x1080x1920 --maxShapes=input:1x3x1080x1920 --fp16 --saveEngine=resnet_engine.trt
[05/07/2024-15:49:51] [I] === Model Options ===
[05/07/2024-15:49:51] [I] Format: ONNX
[05/07/2024-15:49:51] [I] Model: C:\Users\timf3\PycharmProjects\BallNet\footandball_model.onnx
[05/07/2024-15:49:51] [I] Output:
[05/07/2024-15:49:51] [I] === Build Options ===
[05/07/2024-15:49:51] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default, tacticSharedMem: default
[05/07/2024-15:49:51] [I] avgTiming: 8
[05/07/2024-15:49:51] [I] Precision: FP32+FP16
[05/07/2024-15:49:51] [I] LayerPrecisions:
[05/07/2024-15:49:51] [I] Layer Device Types:
[05/07/2024-15:49:51] [I] Calibration:
[05/07/2024-15:49:51] [I] Refit: Disabled
[05/07/2024-15:49:51] [I] Strip weights: Disabled
[05/07/2024-15:49:51] [I] Version Compatible: Disabled
[05/07/2024-15:49:51] [I] ONNX Plugin InstanceNorm: Disabled
[05/07/2024-15:49:51] [I] TensorRT runtime: full
[05/07/2024-15:49:51] [I] Lean DLL Path:
[05/07/2024-15:49:51] [I] Tempfile Controls: { in_memory: allow, temporary: allow }
[05/07/2024-15:49:51] [I] Exclude Lean Runtime: Disabled
[05/07/2024-15:49:51] [I] Sparsity: Disabled
[05/07/2024-15:49:51] [I] Safe mode: Disabled
[05/07/2024-15:49:51] [I] Build DLA standalone loadable: Disabled
[05/07/2024-15:49:51] [I] Allow GPU fallback for DLA: Disabled
[05/07/2024-15:49:51] [I] DirectIO mode: Disabled
[05/07/2024-15:49:51] [I] Restricted mode: Disabled
[05/07/2024-15:49:51] [I] Skip inference: Disabled
[05/07/2024-15:49:51] [I] Save engine: resnet_engine.trt
[05/07/2024-15:49:51] [I] Load engine:
[05/07/2024-15:49:51] [I] Profiling verbosity: 0
[05/07/2024-15:49:51] [I] Tactic sources: Using default tactic sources
[05/07/2024-15:49:51] [I] timingCacheMode: local
[05/07/2024-15:49:51] [I] timingCacheFile:
[05/07/2024-15:49:51] [I] Enable Compilation Cache: Enabled
[05/07/2024-15:49:51] [I] errorOnTimingCacheMiss: Disabled
[05/07/2024-15:49:51] [I] Preview Features: Use default preview flags.
[05/07/2024-15:49:51] [I] MaxAuxStreams: -1
[05/07/2024-15:49:51] [I] BuilderOptimizationLevel: -1
[05/07/2024-15:49:51] [I] Calibration Profile Index: 0
[05/07/2024-15:49:51] [I] Weight Streaming: Disabled
[05/07/2024-15:49:51] [I] Debug Tensors:
[05/07/2024-15:49:51] [I] Input(s)s format: fp32:CHW
[05/07/2024-15:49:51] [I] Output(s)s format: fp32:CHW
[05/07/2024-15:49:51] [I] Input build shape (profile 0): input=1x3x1080x1920+1x3x1080x1920+1x3x1080x1920
[05/07/2024-15:49:51] [I] Input calibration shapes: model
[05/07/2024-15:49:51] [I] === System Options ===
[05/07/2024-15:49:51] [I] Device: 0
[05/07/2024-15:49:51] [I] DLACore:
[05/07/2024-15:49:51] [I] Plugins:
[05/07/2024-15:49:51] [I] setPluginsToSerialize:
[05/07/2024-15:49:51] [I] dynamicPlugins:
[05/07/2024-15:49:51] [I] ignoreParsedPluginLibs: 0
[05/07/2024-15:49:51] [I] === Inference Options ===
[05/07/2024-15:49:51] [I] Batch: Explicit
[05/07/2024-15:49:51] [I] Input inference shape : input=1x3x1080x1920
[05/07/2024-15:49:51] [I] Iterations: 10
[05/07/2024-15:49:51] [I] Duration: 3s (+ 200ms warm up)
[05/07/2024-15:49:51] [I] Sleep time: 0ms
[05/07/2024-15:49:51] [I] Idle time: 0ms
[05/07/2024-15:49:51] [I] Inference Streams: 1
[05/07/2024-15:49:51] [I] ExposeDMA: Disabled
[05/07/2024-15:49:51] [I] Data transfers: Enabled
[05/07/2024-15:49:51] [I] Spin-wait: Disabled
[05/07/2024-15:49:51] [I] Multithreading: Disabled
[05/07/2024-15:49:51] [I] CUDA Graph: Disabled
[05/07/2024-15:49:51] [I] Separate profiling: Disabled
[05/07/2024-15:49:51] [I] Time Deserialize: Disabled
[05/07/2024-15:49:51] [I] Time Refit: Disabled
[05/07/2024-15:49:51] [I] NVTX verbosity: 0
[05/07/2024-15:49:51] [I] Persistent Cache Ratio: 0
[05/07/2024-15:49:51] [I] Optimization Profile Index: 0
[05/07/2024-15:49:51] [I] Weight Streaming Budget: Disabled
[05/07/2024-15:49:51] [I] Inputs:
[05/07/2024-15:49:51] [I] Debug Tensor Save Destinations:
[05/07/2024-15:49:51] [I] === Reporting Options ===
[05/07/2024-15:49:51] [I] Verbose: Disabled
[05/07/2024-15:49:51] [I] Averages: 10 inferences
[05/07/2024-15:49:51] [I] Percentiles: 90,95,99
[05/07/2024-15:49:51] [I] Dump refittable layers:Disabled
[05/07/2024-15:49:51] [I] Dump output: Disabled
[05/07/2024-15:49:51] [I] Profile: Disabled
[05/07/2024-15:49:51] [I] Export timing to JSON file:
[05/07/2024-15:49:51] [I] Export output to JSON file:
[05/07/2024-15:49:51] [I] Export profile to JSON file:
[05/07/2024-15:49:51] [I] === Device Information ===
[05/07/2024-15:49:51] [I] Available Devices:
[05/07/2024-15:49:51] [I] Device 0: "NVIDIA GeForce RTX 3050 Ti Laptop GPU" UUID: GPU-173983d4-c1c9-ad3a-5330-e883c4542db5
[05/07/2024-15:49:51] [I] Selected Device: NVIDIA GeForce RTX 3050 Ti Laptop GPU
[05/07/2024-15:49:51] [I] Selected Device ID: 0
[05/07/2024-15:49:51] [I] Selected Device UUID: GPU-173983d4-c1c9-ad3a-5330-e883c4542db5
[05/07/2024-15:49:51] [I] Compute Capability: 8.6
[05/07/2024-15:49:51] [I] SMs: 20
[05/07/2024-15:49:51] [I] Device Global Memory: 4095 MiB
[05/07/2024-15:49:51] [I] Shared Memory per SM: 100 KiB
[05/07/2024-15:49:51] [I] Memory Bus Width: 128 bits (ECC disabled)
[05/07/2024-15:49:51] [I] Application Compute Clock Rate: 1.035 GHz
[05/07/2024-15:49:51] [I] Application Memory Clock Rate: 5.501 GHz
[05/07/2024-15:49:51] [I] Note: The application clock rates do not reflect the actual clock rates that the GPU is currently running at.
[05/07/2024-15:49:51] [I] TensorRT version: 10.0.1
[05/07/2024-15:49:51] [I] Loading standard plugins
[05/07/2024-15:49:51] [I] [TRT] [MemUsageChange] Init CUDA: CPU +92, GPU +0, now: CPU 22297, GPU 792 (MiB)
[05/07/2024-15:50:04] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +2601, GPU +310, now: CPU 25624, GPU 1102 (MiB)
[05/07/2024-15:50:04] [I] Start parsing network model.
[05/07/2024-15:50:04] [I] [TRT] ----------------------------------------------------------------
[05/07/2024-15:50:04] [I] [TRT] Input filename: C:\Users\timf3\PycharmProjects\BallNet\footandball_model.onnx
[05/07/2024-15:50:04] [I] [TRT] ONNX IR version: 0.0.6
[05/07/2024-15:50:04] [I] [TRT] Opset version: 11
[05/07/2024-15:50:04] [I] [TRT] Producer name: pytorch
[05/07/2024-15:50:04] [I] [TRT] Producer version: 2.0.1
[05/07/2024-15:50:04] [I] [TRT] Domain:
[05/07/2024-15:50:04] [I] [TRT] Model version: 0
[05/07/2024-15:50:04] [I] [TRT] Doc string:
[05/07/2024-15:50:04] [W] [TRT] ModelImporter.cpp:680: Make sure output 614 has Int64 binding.
[05/07/2024-15:50:04] [I] Finished parsing network model. Parse time: 0.0570069
[05/07/2024-15:50:04] [I] Set shape of input tensor input for optimization profile 0 to: MIN=1x3x1080x1920 OPT=1x3x1080x1920 MAX=1x3x1080x1920
[05/07/2024-15:50:04] [E] Error[4]: [graphShapeAnalyzer.cpp::nvinfer1::builder::`anonymous-namespace'::ShapeAnalyzerImpl::analyzeShapes::2084] Error Code 4: Miscellaneous (ITopKLayer /TopK: /TopK: K exceeds the maximum value allowed (3840).)
