EDIT Dec 3rd, 11:32 (GMT+1):
- Fixed some mistakes in the description of the problem
- The final command to be run to reproduce the error was launching the wrong script and actually worked. Added the right command.
Description
I’ve spent the past few days trying to convert a PyTorch model into a TensorRT engine for fast inference, but I always get some strange errors related to the output of the model.
# Initialize ONNX parser
parser = trt.OnnxParser(network, TRT_LOGGER)
# Parse ONNX model
print('TENSORRT CONVERTER: Parsing ONNX model...')
with open(self.onnx_path, 'rb') as model:
parser.parse(model.read())
print('TENSORRT CONVERTER: Completed parsing of ONNX file.')
last_layer = network.get_layer(network.num_layers - 1)
# Check if last layer recognizes it's output
if not last_layer.get_output(0):
print("TENSORRT CONVERTER: Manually marking output...")
# If not, then mark the output using TensorRT API
network.mark_output(last_layer.get_output(0))
print("Network layers: {}".format(network.num_layers))
print("Num inputs: {}".format(network.num_inputs))
print("Num outputs: {}".format(network.num_outputs))
print("Output shape: {}".format(last_layer.get_output(0).shape))
print("Output: {}".format(network.get_output(0)))
My output is:
[TensorRT] WARNING: onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
Network layers: 586
Num inputs: 1
Num outputs: 0
Output shape: (1, 1, 60, 80)
Output: None
TENSORRT CONVERTER: Using FP16.
TENSORRT CONVERTER: Building conversion engine...
[TensorRT] ERROR: Network must have at least one output
[TensorRT] ERROR: Network validation failed.
TENSORRT CONVERTER: Completed creating engine!
TENSORRT CONVERTER: Serializing engine on models/bts_161_8m_640x480_pre_nyu_optimized_fp16.engine
File "pytorch_to_tensortrt/convert_to_TensorRT.py", line 131, in <module>
trt_c.convert_model()
File "pytorch_to_tensortrt/convert_to_TensorRT.py", line 50, in convert_model
f.write(engine.serialize())
AttributeError: 'NoneType' object has no attribute 'serialize'
Now, apart from the AttributeError, there are some strange things going on here:
- The number of layers is lower than expected
- The network has apparently 0 outputs, but the last layer does have one output of shape (1,1,60,80)
- The output of the last layer has an unexpected size. The output of the model should be [1,1,480,640]
Honestly, it looks like the parser stopped at a certain layer, but never informed me of any errors.
The original model I’m trying to convert is this one: bts/pytorch at master · cleinc/bts · GitHub, but I’ve added some minor optimizations like reducing the number of outputs to 1 (I just don’t need the other outputs) and replacing the repeat_interleave torch function, which is not yet supported by ONNX, with a similar sequence of functions that eventually return the same result.
Then, I wrote some scripts to load a checkpoint for the model, convert it in ONNX format and saving the result on disk.
For the conversion to ONNX, I use:
torch.onnx.export(self.model, self.inputs, self.ONNX_FILE_PATH,
input_names=['input'], output_names=['output'],
export_params=True, opset_version=11)
A lower opset results in the following warning:
/home/volpepe/anaconda3/lib/python3.7/site-packages/torch/onnx/symbolic_helper.py:267: UserWarning: You are trying to export the model with onnx:Upsample for ONNX opset version 9. This operator might cause results to not match the expected results by PyTorch.
ONNX's Upsample/Resize operator did not match Pytorch's Interpolation until opset 11. Attributes to determine how to transform the input were added in onnx:Resize in opset 11 to support Pytorch's behavior (like coordinate_transformation_mode and nearest_mode).
We recommend using opset 11 and above for models using this operator.
"" + str(_export_onnx_opset_version) + ". "
and several errors after that, so I’d rather stick to opset 11, if possible.
I then simplified the ONNX model with this tool GitHub - daquexian/onnx-simplifier: Simplify your onnx model (I’m talking about this step for the sake of being accurate, but the same error happens even without the simplification).
I assume that the conversion to ONNX was successful for the following reasons:
- After the export, I check the model with:
onnx_model = onnx.load(self.ONNX_FILE_PATH) onnx.checker.check_model(onnx_model) - I have built a small test with onnxruntime that loads both the PyTorch model and the generated ONNX translation, runs inference on them with the same random input and checks if the output is similar. The output is indeed similar if not equal.
- Netron (https://netron.app/) correctly shows the outline of the network when loading the .onnx model. It also shows the correct input and output shapes.
Therefore, I believe it must be a problem of TensorRT’s OnnxParser or some incompatibility error.
bts_trt.zip (407.8 KB)
Environment
TensorRT Version: 7.2.1.6
GPU Type: GeForce 1660 Ti Mobile
Nvidia Driver Version: 455.45.01
CUDA Version: 11.1
CUDNN Version: 8.0.5
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.7.7
TensorFlow Version (if applicable): None
PyTorch Version (if applicable): 1.7.0
Baremetal or Container (if container which image + tag): Baremetal
Relevant Files and Steps to Reproduce
I have attached a zip with all relevant scripts. The weights for the model are downloaded from the original repository (https://cogaplex-bts.s3.ap-northeast-2.amazonaws.com/bts_nyu_v2_pytorch_densenet161.zip). Once downloaded, they should be put into the “models” folder. bts_saver.py can then be run in order to produce the .pth file. Then,
python pytorch_to_tensortrt/convert_to_ONNX.py -m models/bts_161_8m_640x480_pre_nyu.pth -n
bts_161_8m_640x480_pre_nyu -o models
to create the .onnx file.
python -m onnxsim models/bts_161_8m_640x480_pre_nyu.onnx models/bts_161_8m_640x480_pre_nyu_optimized.onnx
is the additional step to simplify the model (GitHub - daquexian/onnx-simplifier: Simplify your onnx model).
Finally, the error is produced when running:
python pytorch_to_tensortrt/convert_to_TensorRT.py -m models/bts_161_8m_640x480_pre_nyu_optimized.onnx -o models -n bts_161_8m_640x480_pre_nyu_optimized -t fp32
