I have a custom PyTorch model, which I exported to onnx format (1.3 gb)
Now I wanted to run it on Jetson Xavier NX using TensorRT.
When trying to create an trt engine (similar to the yolov3 example provided on Jetson Xavier Nx in /usr/src/tensorrt/samples/python/yolov3_onnx/onnx_to_tensorrt.py) I’m getting the following errors:
[TensorRT] ERROR: Try increasing the workspace size with IBuilderConfig::setMaxWorkspaceSize() if using IBuilder::buildEngineWithConfig, or IBuilder::setMaxWorkspaceSize() if using IBuilder::buildCudaEngine.
[TensorRT] ERROR: ../builder/tacticOptimizer.cpp (1715) - TRTInternal Error in computeCosts: 0 (Could not find any implementation for node {(Unnamed Layer* 116) [Constant],(Unnamed Layer* 117) [Constant],(Unnamed Layer* 125) [Constant],(Unnamed Layer* 65) [Shuffle] + (Unnamed Layer* 77) [Shuffle],(Unnamed Layer* 73) [Constant] + (Unnamed Layer* 74) [Shuffle],(Unnamed Layer* 75) [Slice],(Unnamed Layer* 96) [Slice],(Unnamed Layer* 115) [Slice],(Unnamed Layer* 126) [TripLimit],(Unnamed Layer* 127) [Iterator],(Unnamed Layer* 128) [Shuffle],(Unnamed Layer* 131) [Matrix Multiply],(Unnamed Layer* 129) [Recurrence],(Unnamed Layer* 130) [Recurrence],(Unnamed Layer* 132) [Matrix Multiply],(Unnamed Layer* 133) [ElementWise],(Unnamed Layer* 134) [ElementWise],(Unnamed Layer* 135) [Slice],(Unnamed Layer* 138) [Slice],(Unnamed Layer* 141) [Slice],(Unnamed Layer* 147) [Slice],(Unnamed Layer* 137) [Activation],(Unnamed Layer* 140) [Activation],(Unnamed Layer* 143) [Activation],(Unnamed Layer* 149) [Activation],(Unnamed Layer* 144) [ElementWise],(Unnamed Layer* 145) [ElementWise],(Unnamed Layer* 146) [ElementWise],(Unnamed Layer* 150) [Activation],(Unnamed Layer* 151) [ElementWise],(Unnamed Layer* 155) [LoopOutput],(Unnamed Layer* 213) [Gather]_output[Constant],(Unnamed Layer* 200) [Constant],(Unnamed Layer* 201) [Constant],(Unnamed Layer* 180) [Slice],(Unnamed Layer* 199) [Slice],(Unnamed Layer* 161) [Shuffle],(Unnamed Layer* 222) [Recurrence],(Unnamed Layer* 223) [Recurrence],(Unnamed Layer* 225) [Matrix Multiply],(Unnamed Layer* 215) [Iterator],(Unnamed Layer* 214) [TripLimit],(Unnamed Layer* 221) [Shuffle],(Unnamed Layer* 224) [Matrix Multiply],(Unnamed Layer* 226) [ElementWise],(Unnamed Layer* 227) [ElementWise],(Unnamed Layer* 228) [Slice],(Unnamed Layer* 231) [Slice],(Unnamed Layer* 234) [Slice],(Unnamed Layer* 240) [Slice],(Unnamed Layer* 230) [Activation],(Unnamed Layer* 233) [Activation],(Unnamed Layer* 236) [Activation],(Unnamed Layer* 242) [Activation],(Unnamed Layer* 237) [ElementWise],(Unnamed Layer* 238) [ElementWise],(Unnamed Layer* 239) [ElementWise],(Unnamed Layer* 243) [Activation],(Unnamed Layer* 244) [ElementWise],(Unnamed Layer* 250) [LoopOutput],(Unnamed Layer* 256) [Shuffle] + (Unnamed Layer* 257) [Shuffle],(Unnamed Layer* 258) [Constant] + (Unnamed Layer* 259) [Shuffle],(Unnamed Layer* 260) [Matrix Multiply],(Unnamed Layer* 261) [Constant] + (Unnamed Layer* 262) [Shuffle],(Unnamed Layer* 263) [ElementWise]}.)
[TensorRT] ERROR: ../builder/tacticOptimizer.cpp (1715) - TRTInternal Error in computeCosts: 0 ()
Additionally, I’m getting the following warnings:
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:604] Reading dangerously large protocol message. If the message turns out to be larger than 2147483647 bytes, parsing will be halted for security reasons. To increase the limit (or to disable these warnings), see CodedInputStream::SetTotalBytesLimit() in google/protobuf/io/coded_stream.h.
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:81] The total number of bytes read was 1335373289
[TensorRT] WARNING: onnx2trt_utils.cpp:217: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[TensorRT] WARNING: onnx2trt_utils.cpp:243: One or more weights outside the range of INT32 was clamped
[TensorRT] WARNING: Calling isShapeTensor before the entire network is constructed may result in an inaccurate result.
Checking the onnx model using onnx.checker passed. The memory consumption for running the onnx model is ~ 4.5 GB.
I also tried converting my model using the trtexec tool:
/usr/src/tensorrt/bin/trtexec --onnx=model.onnx --shapes=input:1x6x3x278x920 --maxBatch=1 --workspace=4800 --verbose
which resulted in the process getting killed by the system:
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=model.onnx --shapes=input:1x6x3x278x920 --maxBatch=1 --workspace=4800 --verbose
[06/17/2020-16:34:21] [I] === Model Options ===
[06/17/2020-16:34:21] [I] Format: ONNX
[06/17/2020-16:34:21] [I] Model: model.onnx
[06/17/2020-16:34:21] [I] Output:
[06/17/2020-16:34:21] [I] === Build Options ===
[06/17/2020-16:34:21] [I] Max batch: explicit
[06/17/2020-16:34:21] [I] Workspace: 4800 MB
[06/17/2020-16:34:21] [I] minTiming: 1
[06/17/2020-16:34:21] [I] avgTiming: 8
[06/17/2020-16:34:21] [I] Precision: FP32
[06/17/2020-16:34:21] [I] Calibration:
[06/17/2020-16:34:21] [I] Safe mode: Disabled
[06/17/2020-16:34:21] [I] Save engine:
[06/17/2020-16:34:21] [I] Load engine:
[06/17/2020-16:34:21] [I] Builder Cache: Enabled
[06/17/2020-16:34:21] [I] NVTX verbosity: 0
[06/17/2020-16:34:21] [I] Inputs format: fp32:CHW
[06/17/2020-16:34:21] [I] Outputs format: fp32:CHW
[06/17/2020-16:34:21] [I] Input build shape: input=1x6x3x278x920+1x6x3x278x920+1x6x3x278x920
[06/17/2020-16:34:21] [I] Input calibration shapes: model
[06/17/2020-16:34:21] [I] === System Options ===
[06/17/2020-16:34:21] [I] Device: 0
[06/17/2020-16:34:21] [I] DLACore:
[06/17/2020-16:34:21] [I] Plugins:
[06/17/2020-16:34:21] [I] === Inference Options ===
[06/17/2020-16:34:21] [I] Batch: Explicit
[06/17/2020-16:34:21] [I] Input inference shape: input=1x6x3x278x920
[06/17/2020-16:34:21] [I] Iterations: 10
[06/17/2020-16:34:21] [I] Duration: 3s (+ 200ms warm up)
[06/17/2020-16:34:21] [I] Sleep time: 0ms
[06/17/2020-16:34:21] [I] Streams: 1
[06/17/2020-16:34:21] [I] ExposeDMA: Disabled
[06/17/2020-16:34:21] [I] Spin-wait: Disabled
[06/17/2020-16:34:21] [I] Multithreading: Disabled
[06/17/2020-16:34:21] [I] CUDA Graph: Disabled
[06/17/2020-16:34:21] [I] Skip inference: Disabled
[06/17/2020-16:34:21] [I] Inputs:
[06/17/2020-16:34:21] [I] === Reporting Options ===
[06/17/2020-16:34:21] [I] Verbose: Enabled
[06/17/2020-16:34:21] [I] Averages: 10 inferences
[06/17/2020-16:34:21] [I] Percentile: 99
[06/17/2020-16:34:21] [I] Dump output: Disabled
[06/17/2020-16:34:21] [I] Profile: Disabled
[06/17/2020-16:34:21] [I] Export timing to JSON file:
[06/17/2020-16:34:21] [I] Export output to JSON file:
[06/17/2020-16:34:21] [I] Export profile to JSON file:
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::GridAnchor_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::NMS_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::Reorg_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::Region_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::Clip_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::LReLU_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::PriorBox_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::Normalize_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::RPROI_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::BatchedNMS_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::FlattenConcat_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::CropAndResize
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::DetectionLayer_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::Proposal
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::ProposalLayer_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::PyramidROIAlign_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::ResizeNearest_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::Split
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::SpecialSlice_TRT
[06/17/2020-16:34:21] [V] [TRT] Plugin creator registration succeeded - ::InstanceNormalization_TRT
Input filename: deepvo.onnx
ONNX IR version: 0.0.4
Opset version: 10
Producer name: pytorch
Producer version: 1.3
Domain:
Model version: 0
Doc string:
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::NMS_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::Reorg_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::Region_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::Clip_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::LReLU_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::Normalize_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::RPROI_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::CropAndResize
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::Proposal
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::Split
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT
[06/17/2020-16:34:46] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:205: Adding network input: input with dtype: float32, dimensions: (-1, 6, 3, 278, 920)
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:97: Registering tensor: input for ONNX tensor: input
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 252
[06/17/2020-16:34:46] [W] [TRT] onnx2trt_utils.cpp:217: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 253
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 271
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 272
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 273
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 291
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 292
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 293
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: 294
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv1.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv1.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv1.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv1.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv1.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3_1.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3_1.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3_1.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3_1.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv3_1.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4_1.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4_1.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4_1.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4_1.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv4_1.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5_1.0.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5_1.1.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5_1.1.running_mean
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5_1.1.running_var
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv5_1.1.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv6.weight
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:90: Importing initializer: linear.bias
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Constant]
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:125: [Constant] inputs:
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [60 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [61 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [62 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [63 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Slice]
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: input
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 61
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 62
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 60
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 63
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:125: [Slice] inputs: [input -> (-1, 6, 3, 278, 920)], [61 -> (1)], [62 -> (1)], [60 -> (1)], [63 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 0) [Shape] for ONNX node:
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 64 for ONNX tensor: 64
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Slice] outputs: [64 -> (-1, -1, -1, -1, -1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [65 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [66 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] onnx2trt_utils.cpp:233: Weight at index 0: 9223372036854775807 is out of range. Clamping to: 2147483647
[06/17/2020-16:34:46] [W] [TRT] onnx2trt_utils.cpp:243: One or more weights outside the range of INT32 was clamped
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [67 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [68 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 66
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 67
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 65
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 68
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:125: [Slice] inputs: [input -> (-1, 6, 3, 278, 920)], [66 -> (1)], [67 -> (1)], [65 -> (1)], [68 -> (1)],
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 19) [Shape] for ONNX node:
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 69 for ONNX tensor: 69
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Slice] outputs: [69 -> (-1, -1, -1, -1, -1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Concat]
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 64
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 69
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:125: [Concat] inputs: [64 -> (-1, -1, -1, -1, -1)], [69 -> (-1, -1, -1, -1, -1)],
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 38) [Concatenation] for ONNX node:
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 70 for ONNX tensor: 70
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Concat] outputs: [70 -> (-1, -1, -1, -1, -1)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [71 -> (4)],
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Reshape]
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 70
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:119: Searching for input: 71
[06/17/2020-16:34:46] [V] [TRT] ModelImporter.cpp:125: [Reshape] inputs: [70 -> (-1, -1, -1, -1, -1)], [71 -> (4)],
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 39) [Shuffle] for ONNX node:
[06/17/2020-16:34:46] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 72 for ONNX tensor: 72
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Reshape] outputs: [72 -> (80, 6, 278, 920)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Conv]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 72
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv1.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [72 -> (80, 6, 278, 920)], [conv1.0.weight -> (64, 6, 7, 7)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:446: Convolution input dimensions: (80, 6, 278, 920)
[06/17/2020-16:34:47] [V] [TRT] Bias weights are not set yet. Bias weights can be set using setInput(2, bias_tensor) API call.
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (7, 7), strides: (2, 2), prepadding: (3, 3), postpadding: (3, 3), dilations: (1, 1), numOutputs: 64
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:529: Convolution output dimensions: (80, 64, 139, 460)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 40) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 73 for ONNX tensor: 73
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [73 -> (80, 64, 139, 460)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [BatchNormalization]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 73
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv1.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv1.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv1.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv1.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [73 -> (80, 64, 139, 460)], [conv1.1.weight -> (64)], [conv1.1.bias -> (64)], [conv1.1.running_mean -> (64)], [conv1.1.running_var -> (64)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 41) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 74 for ONNX tensor: 74
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [74 -> (80, 64, 139, 460)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [LeakyRelu]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 74
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [74 -> (80, 64, 139, 460)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 42) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 75 for ONNX tensor: 75
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [75 -> (80, 64, 139, 460)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 75
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [75 -> (80, 64, 139, 460)], [conv2.0.weight -> (128, 64, 5, 5)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:446: Convolution input dimensions: (80, 64, 139, 460)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (5, 5), strides: (2, 2), prepadding: (2, 2), postpadding: (2, 2), dilations: (1, 1), numOutputs: 128
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:529: Convolution output dimensions: (80, 128, 70, 230)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 43) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 76 for ONNX tensor: 76
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [76 -> (80, 128, 70, 230)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 76
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [76 -> (80, 128, 70, 230)], [conv2.1.weight -> (128)], [conv2.1.bias -> (128)], [conv2.1.running_mean -> (128)], [conv2.1.running_var -> (128)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 44) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 77 for ONNX tensor: 77
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [77 -> (80, 128, 70, 230)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 77
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [77 -> (80, 128, 70, 230)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 45) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 78 for ONNX tensor: 78
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [78 -> (80, 128, 70, 230)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 78
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [78 -> (80, 128, 70, 230)], [conv3.0.weight -> (256, 128, 5, 5)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:446: Convolution input dimensions: (80, 128, 70, 230)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (5, 5), strides: (2, 2), prepadding: (2, 2), postpadding: (2, 2), dilations: (1, 1), numOutputs: 256
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:529: Convolution output dimensions: (80, 256, 35, 115)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 46) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 79 for ONNX tensor: 79
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [79 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 79
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [79 -> (80, 256, 35, 115)], [conv3.1.weight -> (256)], [conv3.1.bias -> (256)], [conv3.1.running_mean -> (256)], [conv3.1.running_var -> (256)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 47) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 80 for ONNX tensor: 80
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [80 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 80
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [80 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 48) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 81 for ONNX tensor: 81
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [81 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 81
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3_1.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [81 -> (80, 256, 35, 115)], [conv3_1.0.weight -> (256, 256, 3, 3)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:446: Convolution input dimensions: (80, 256, 35, 115)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 256
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 49) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 82 for ONNX tensor: 82
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [82 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 82
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3_1.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3_1.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3_1.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv3_1.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [82 -> (80, 256, 35, 115)], [conv3_1.1.weight -> (256)], [conv3_1.1.bias -> (256)], [conv3_1.1.running_mean -> (256)], [conv3_1.1.running_var -> (256)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 50) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 83 for ONNX tensor: 83
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [83 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 83
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [83 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 51) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 84 for ONNX tensor: 84
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [84 -> (80, 256, 35, 115)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 84
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [84 -> (80, 256, 35, 115)], [conv4.0.weight -> (512, 256, 3, 3)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (3, 3), strides: (2, 2), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 512
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:529: Convolution output dimensions: (80, 512, 18, 58)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 52) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 85 for ONNX tensor: 85
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [85 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 85
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [85 -> (80, 512, 18, 58)], [conv4.1.weight -> (512)], [conv4.1.bias -> (512)], [conv4.1.running_mean -> (512)], [conv4.1.running_var -> (512)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 53) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 86 for ONNX tensor: 86
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [86 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 86
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [86 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 54) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 87 for ONNX tensor: 87
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [87 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 87
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4_1.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [87 -> (80, 512, 18, 58)], [conv4_1.0.weight -> (512, 512, 3, 3)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:446: Convolution input dimensions: (80, 512, 18, 58)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (3, 3), strides: (1, 1), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 512
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 55) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 88 for ONNX tensor: 88
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [88 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 88
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4_1.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4_1.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4_1.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv4_1.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [88 -> (80, 512, 18, 58)], [conv4_1.1.weight -> (512)], [conv4_1.1.bias -> (512)], [conv4_1.1.running_mean -> (512)], [conv4_1.1.running_var -> (512)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 56) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 89 for ONNX tensor: 89
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [89 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 89
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [89 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 57) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 90 for ONNX tensor: 90
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [90 -> (80, 512, 18, 58)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 90
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [90 -> (80, 512, 18, 58)], [conv5.0.weight -> (512, 512, 3, 3)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:529: Convolution output dimensions: (80, 512, 9, 29)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 58) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 91 for ONNX tensor: 91
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [91 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 91
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [91 -> (80, 512, 9, 29)], [conv5.1.weight -> (512)], [conv5.1.bias -> (512)], [conv5.1.running_mean -> (512)], [conv5.1.running_var -> (512)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 59) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 92 for ONNX tensor: 92
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [92 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 92
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [92 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 60) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 93 for ONNX tensor: 93
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [93 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 93
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5_1.0.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [93 -> (80, 512, 9, 29)], [conv5_1.0.weight -> (512, 512, 3, 3)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:446: Convolution input dimensions: (80, 512, 9, 29)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 61) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 94 for ONNX tensor: 94
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [94 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 94
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5_1.1.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5_1.1.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5_1.1.running_mean
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv5_1.1.running_var
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [BatchNormalization] inputs: [94 -> (80, 512, 9, 29)], [conv5_1.1.weight -> (512)], [conv5_1.1.bias -> (512)], [conv5_1.1.running_mean -> (512)], [conv5_1.1.running_var -> (512)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 62) [Scale] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 95 for ONNX tensor: 95
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [BatchNormalization] outputs: [95 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 95
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LeakyRelu] inputs: [95 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 63) [Activation] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 96 for ONNX tensor: 96
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LeakyRelu] outputs: [96 -> (80, 512, 9, 29)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 96
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv6.weight
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Conv] inputs: [96 -> (80, 512, 9, 29)], [conv6.weight -> (1024, 512, 3, 3)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:528: Using kernel: (3, 3), strides: (2, 2), prepadding: (1, 1), postpadding: (1, 1), dilations: (1, 1), numOutputs: 1024
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:529: Convolution output dimensions: (80, 1024, 5, 15)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 64) [Convolution] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 97 for ONNX tensor: 97
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Conv] outputs: [97 -> (80, 1024, 5, 15)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Constant]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Constant] inputs:
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [98 -> (3)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Reshape]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 97
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 98
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Reshape] inputs: [97 -> (80, 1024, 5, 15)], [98 -> (3)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 65) [Shuffle] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 99 for ONNX tensor: 99
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Reshape] outputs: [99 -> (16, 5, 76800)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Shape]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 99
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Shape] inputs: [99 -> (16, 5, 76800)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 66) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 100 for ONNX tensor: 100
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Shape] outputs: [100 -> (3)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [101 -> ()],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Gather]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 100
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 101
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Gather] inputs: [100 -> (3)], [101 -> ()],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:978: Using Gather axis: 0
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 67) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 102 for ONNX tensor: 102
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Gather] outputs: [102 -> ()],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Unsqueeze]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 102
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Unsqueeze] inputs: [102 -> ()],
[06/17/2020-16:34:47] [V] [TRT] onnx2trt_utils.cpp:1574: Original shape: (), unsqueezing to: (1,)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 69) [Shuffle] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 106 for ONNX tensor: 106
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Unsqueeze] outputs: [106 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Concat]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 252
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 106
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 253
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Concat] inputs: [252 -> (1)], [106 -> (1)], [253 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 70) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 108 for ONNX tensor: 108
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Concat] outputs: [108 -> (3)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [ConstantOfShape]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 108
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [ConstantOfShape] inputs: [108 -> (3)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 73) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 109 for ONNX tensor: 109
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [ConstantOfShape] outputs: [109 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Transpose]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Transpose] inputs: [99 -> (16, 5, 76800)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 77) [Shuffle] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 110 for ONNX tensor: 110
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Transpose] outputs: [110 -> (5, 16, 76800)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [168 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [169 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [170 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Slice]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 109
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 169
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 170
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 168
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Slice] inputs: [109 -> (-1, -1, -1)], [169 -> (1)], [170 -> (1)], [168 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 78) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 171 for ONNX tensor: 171
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Slice] outputs: [171 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [172 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [173 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [174 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 173
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 174
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 172
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Slice] inputs: [109 -> (-1, -1, -1)], [173 -> (1)], [174 -> (1)], [172 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 97) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 175 for ONNX tensor: 175
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Slice] outputs: [175 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [LSTM]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 110
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 271
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 272
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 273
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 171
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 175
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LSTM] inputs: [110 -> (5, 16, 76800)], [271 -> (1, 4000, 76800)], [272 -> (1, 4000, 1000)], [273 -> (1, 8000)], [optional input, not set], [171 -> (-1, -1, -1)], [175 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1790: Bias shape is: (1, 8000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1794: Reshaping bias to: (1, 2, 4000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1799: After reduction, bias shape is: (1, 1, 4000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1808: numDirectionsTensor shape: (1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1812: hiddenSizeTensor shape: (1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1814: batchSizeTensor shape: (1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1821: Gate output rank (equal to initial hidden/cell state rank): (3)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1835: Initial hidden state shape: (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1838: Initial cell state shape: (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1840: Entering Loop
[06/17/2020-16:34:47] [V] [TRT] onnx2trt_utils.cpp:1574: Original shape: (16, 76800), unsqueezing to: (1, 16, 76800)
[06/17/2020-16:34:47] [V] [TRT] RNNHelpers.cpp:42: Input shape: (1, 16, 76800)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1852: Hidden state shape: (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1856: Cell state shape: (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1864: X(t) * W^T -> (1, 16, 4000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1870: H(t-1) * R^T -> (-1, -1, 4000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1877: intermediate(t) -> (-1, 16, 4000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1948: c(t) -> (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1957: C(t) -> (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1980: H(t) -> (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 116) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 176 for ONNX tensor: 176
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 177 for ONNX tensor: 177
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 178 for ONNX tensor: 178
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LSTM] outputs: [176 -> (-1, -1, -1, -1)], [177 -> (-1, -1, -1)], [178 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Squeeze]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 176
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Squeeze] inputs: [176 -> (-1, -1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] onnx2trt_utils.cpp:1430: Original shape: (_, _, _, _), squeezing to: (_, _, _)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 158) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 179 for ONNX tensor: 179
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Squeeze] outputs: [179 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [236 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [237 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [238 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 237
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 238
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 236
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Slice] inputs: [109 -> (-1, -1, -1)], [237 -> (1)], [238 -> (1)], [236 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 162) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 239 for ONNX tensor: 239
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Slice] outputs: [239 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [240 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [241 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Constant] outputs: [242 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 241
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 242
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 240
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Slice] inputs: [109 -> (-1, -1, -1)], [241 -> (1)], [242 -> (1)], [240 -> (1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 181) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 243 for ONNX tensor: 243
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Slice] outputs: [243 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 179
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 291
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 292
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 293
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 239
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 243
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [LSTM] inputs: [179 -> (-1, -1, -1)], [291 -> (1, 4000, 1000)], [292 -> (1, 4000, 1000)], [293 -> (1, 8000)], [optional input, not set], [239 -> (-1, -1, -1)], [243 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] onnx2trt_utils.cpp:1574: Original shape: (_, _), unsqueezing to: (_, _, _)
[06/17/2020-16:34:47] [V] [TRT] RNNHelpers.cpp:42: Input shape: (-1, -1, -1)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1864: X(t) * W^T -> (-1, -1, 4000)
[06/17/2020-16:34:47] [V] [TRT] builtin_op_importers.cpp:1877: intermediate(t) -> (-1, -1, 4000)
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 200) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 244 for ONNX tensor: 244
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 245 for ONNX tensor: 245
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 246 for ONNX tensor: 246
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [LSTM] outputs: [244 -> (-1, -1, -1, -1)], [245 -> (-1, -1, -1)], [246 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 244
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Squeeze] inputs: [244 -> (-1, -1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 253) [Shape] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 247 for ONNX tensor: 247
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Squeeze] outputs: [247 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 247
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Transpose] inputs: [247 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 257) [Shuffle] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 248 for ONNX tensor: 248
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Transpose] outputs: [248 -> (-1, -1, -1)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [MatMul]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 248
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 294
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [MatMul] inputs: [248 -> (-1, -1, -1)], [294 -> (1000, 6)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 258) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 250 for ONNX tensor: 250
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [MatMul] outputs: [250 -> (-1, -1, 6)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:103: Parsing node: [Add]
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: 250
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:119: Searching for input: linear.bias
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:125: [Add] inputs: [250 -> (-1, -1, 6)], [linear.bias -> (6)],
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:122: Registering layer: (Unnamed Layer* 261) [Constant] for ONNX node:
[06/17/2020-16:34:47] [V] [TRT] ImporterContext.hpp:97: Registering tensor: output_1 for ONNX tensor: output
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:182: [Add] outputs: [output -> (-1, -1, 6)],
[06/17/2020-16:34:47] [V] [TRT] ModelImporter.cpp:494: Marking output_1 as output: output
[06/17/2020-16:34:47] [W] [TRT] Calling isShapeTensor before the entire network is constructed may result in an inaccurate result.
----- Parsing of ONNX model deepvo.onnx is Done ----
[06/17/2020-16:34:47] [V] [TRT] Applying generic optimizations to the graph for inference.
[06/17/2020-16:34:47] [V] [TRT] Original: 105 layers
[06/17/2020-16:34:47] [V] [TRT] After dead-layer removal: 105 layers
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 73) [Constant] with (Unnamed Layer* 74) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 118) [Constant] with (Unnamed Layer* 119) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 202) [Constant] with (Unnamed Layer* 203) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 65) [Shuffle] with (Unnamed Layer* 77) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 256) [Shuffle] with (Unnamed Layer* 257) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 258) [Constant] with (Unnamed Layer* 259) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] Fusing (Unnamed Layer* 261) [Constant] with (Unnamed Layer* 262) [Shuffle]
[06/17/2020-16:34:47] [V] [TRT] After Myelin optimization: 34 layers
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 40) [Convolution] with scale (Unnamed Layer* 41) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 43) [Convolution] with scale (Unnamed Layer* 44) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 46) [Convolution] with scale (Unnamed Layer* 47) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 49) [Convolution] with scale (Unnamed Layer* 50) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 52) [Convolution] with scale (Unnamed Layer* 53) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 55) [Convolution] with scale (Unnamed Layer* 56) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 58) [Convolution] with scale (Unnamed Layer* 59) [Scale]
[06/17/2020-16:34:47] [V] [TRT] Fusing convolution weights from (Unnamed Layer* 61) [Convolution] with scale (Unnamed Layer* 62) [Scale]
[06/17/2020-16:34:47] [V] [TRT] After scale fusion: 26 layers
[06/17/2020-16:34:47] [V] [TRT] After vertical fusions: 26 layers
[06/17/2020-16:34:47] [V] [TRT] After final dead-layer removal: 26 layers
[06/17/2020-16:34:47] [V] [TRT] After tensor merging: 26 layers
[06/17/2020-16:34:47] [V] [TRT] Eliminating concatenation (Unnamed Layer* 38) [Concatenation]
[06/17/2020-16:34:47] [V] [TRT] Retargeting 64 to 70
[06/17/2020-16:34:47] [V] [TRT] Retargeting 69 to 70
[06/17/2020-16:34:47] [V] [TRT] After concat removal: 25 layers
[06/17/2020-16:34:47] [V] [TRT] Graph construction and optimization completed in 0.155402 seconds.
[06/17/2020-16:34:47] [I] [TRT]
[06/17/2020-16:34:47] [I] [TRT] --------------- Layers running on DLA:
[06/17/2020-16:34:47] [I] [TRT] --------------- Layers running on GPU:
[06/17/2020-16:34:47] [I] [TRT] (Unnamed Layer* 118) [Constant] + (Unnamed Layer* 119) [Shuffle], (Unnamed Layer* 202) [Constant] + (Unnamed Layer* 203) [Shuffle], (Unnamed Layer* 18) [Slice], (Unnamed Layer* 37) [Slice], (Unnamed Layer* 39) [Shuffle], (Unnamed Layer* 40) [Convolution], (Unnamed Layer* 204) [Reduce], (Unnamed Layer* 120) [Reduce], (Unnamed Layer* 42) [Activation], (Unnamed Layer* 43) [Convolution], (Unnamed Layer* 45) [Activation], (Unnamed Layer* 46) [Convolution], (Unnamed Layer* 48) [Activation], (Unnamed Layer* 49) [Convolution], (Unnamed Layer* 51) [Activation], (Unnamed Layer* 52) [Convolution], (Unnamed Layer* 54) [Activation], (Unnamed Layer* 55) [Convolution], (Unnamed Layer* 57) [Activation], (Unnamed Layer* 58) [Convolution], (Unnamed Layer* 60) [Activation], (Unnamed Layer* 61) [Convolution], (Unnamed Layer* 63) [Activation], (Unnamed Layer* 64) [Convolution], {(Unnamed Layer* 116) [Constant],(Unnamed Layer* 117) [Constant],(Unnamed Layer* 125) [Constant],(Unnamed Layer* 65) [Shuffle] + (Unnamed Layer* 77) [Shuffle],(Unnamed Layer* 73) [Constant] + (Unnamed Layer* 74) [Shuffle],(Unnamed Layer* 75) [Slice],(Unnamed Layer* 96) [Slice],(Unnamed Layer* 115) [Slice],(Unnamed Layer* 126) [TripLimit],(Unnamed Layer* 127) [Iterator],(Unnamed Layer* 128) [Shuffle],(Unnamed Layer* 131) [Matrix Multiply],(Unnamed Layer* 129) [Recurrence],(Unnamed Layer* 130) [Recurrence],(Unnamed Layer* 132) [Matrix Multiply],(Unnamed Layer* 133) [ElementWise],(Unnamed Layer* 134) [ElementWise],(Unnamed Layer* 135) [Slice],(Unnamed Layer* 138) [Slice],(Unnamed Layer* 141) [Slice],(Unnamed Layer* 147) [Slice],(Unnamed Layer* 137) [Activation],(Unnamed Layer* 140) [Activation],(Unnamed Layer* 143) [Activation],(Unnamed Layer* 149) [Activation],(Unnamed Layer* 144) [ElementWise],(Unnamed Layer* 145) [ElementWise],(Unnamed Layer* 146) [ElementWise],(Unnamed Layer* 150) [Activation],(Unnamed Layer* 151) [ElementWise],(Unnamed Layer* 155) [LoopOutput],(Unnamed Layer* 213) [Gather]_output[Constant],(Unnamed Layer* 200) [Constant],(Unnamed Layer* 201) [Constant],(Unnamed Layer* 180) [Slice],(Unnamed Layer* 199) [Slice],(Unnamed Layer* 161) [Shuffle],(Unnamed Layer* 222) [Recurrence],(Unnamed Layer* 223) [Recurrence],(Unnamed Layer* 225) [Matrix Multiply],(Unnamed Layer* 215) [Iterator],(Unnamed Layer* 214) [TripLimit],(Unnamed Layer* 221) [Shuffle],(Unnamed Layer* 224) [Matrix Multiply],(Unnamed Layer* 226) [ElementWise],(Unnamed Layer* 227) [ElementWise],(Unnamed Layer* 228) [Slice],(Unnamed Layer* 231) [Slice],(Unnamed Layer* 234) [Slice],(Unnamed Layer* 240) [Slice],(Unnamed Layer* 230) [Activation],(Unnamed Layer* 233) [Activation],(Unnamed Layer* 236) [Activation],(Unnamed Layer* 242) [Activation],(Unnamed Layer* 237) [ElementWise],(Unnamed Layer* 238) [ElementWise],(Unnamed Layer* 239) [ElementWise],(Unnamed Layer* 243) [Activation],(Unnamed Layer* 244) [ElementWise],(Unnamed Layer* 250) [LoopOutput],(Unnamed Layer* 256) [Shuffle] + (Unnamed Layer* 257) [Shuffle],(Unnamed Layer* 258) [Constant] + (Unnamed Layer* 259) [Shuffle],(Unnamed Layer* 260) [Matrix Multiply],(Unnamed Layer* 261) [Constant] + (Unnamed Layer* 262) [Shuffle],(Unnamed Layer* 263) [ElementWise]},
Killed
I’m using TensorRT 7.1.0 with Python 3 and Cuda 10.2 on a Jetson Xavier NX.
