manager@manager-desktop:~$ sudo systemctl status docker
[sudo] password for manager:
β docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2022-01-25 19:30:26 KST; 39s ago
Docs: https://docs.docker.com
Process: 7544 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/
Main PID: 7544 (code=exited, status=1/FAILURE)
1μ 25 19:30:26 manager-desktop systemd[1]: docker.service: Service hold-off time over, scheduling restart.
1μ 25 19:30:26 manager-desktop systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
1μ 25 19:30:26 manager-desktop systemd[1]: Stopped Docker Application Container Engine.
1μ 25 19:30:26 manager-desktop systemd[1]: docker.service: Start request repeated too quickly.
1μ 25 19:30:26 manager-desktop systemd[1]: docker.service: Failed with result βexit-codeβ.
1μ 25 19:30:26 manager-desktop systemd[1]: Failed to start Docker Application Container Engine.
Iβm using an Xavier NX R32.5.2.
What am I supposed to do?
Thank you.
