I was struggling at getting bbswitch to work successfully, as the discrete graphic card doesn’t seem to power down when issuing command
echo OFF > /proc/acpi/bbswitch
I’ve tried to narrow down the issue, here is what I’ve found soo far.
First of all, my configuration:
MSI GS60 6QE-025XFR
Debian 10 (Kernel 4.19.0-6-amd64)
Graphic cards:
with lspci -vvnn command:
00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 530 [8086:191b] (rev 06) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] HD Graphics 530 [1462:1158]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 123
Region 0: Memory at db000000 (64-bit, non-prefetchable)
Region 2: Memory at 70000000 (64-bit, prefetchable)
Region 4: I/O ports at f000
[virtual] Expansion ROM at 000c0000 [disabled]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express (v2) Root Complex Integrated Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee02004 Data: 4022
Capabilities: [d0] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Process Address Space ID (PASID)
PASIDCap: Exec+ Priv-, Max PASID Width: 14
PASIDCtl: Enable- Exec- Priv-
Capabilities: [200 v1] Address Translation Service (ATS)
ATSCap: Invalidate Queue Depth: 00
ATSCtl: Enable-, Smallest Translation Unit: 00
Capabilities: [300 v1] Page Request Interface (PRI)
PRICtl: Enable- Reset-
PRISta: RF- UPRGI- Stopped-
Page Request Capacity: 00008000, Page Request Allocation: 00000000
Kernel driver in use: i915
Kernel modules: i915
01:00.0 3D controller [0302]: NVIDIA Corporation GM204M [GeForce GTX 970M] [10de:13d8] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GM204M [GeForce GTX 970M] [1462:1158]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Interrupt: pin A routed to IRQ 127
Region 0: Memory at dc000000 (32-bit, non-prefetchable)
Region 1: Memory at b0000000 (64-bit, prefetchable)
Region 3: Memory at c0000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
[virtual] Expansion ROM at dd000000 [disabled]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee20004 Data: 4022
Capabilities: [78] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
LnkCap: Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 unlimited
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR-, OBFF Via message
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [258 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900 v1] #19
Kernel driver in use: nvidia
Kernel modules: nvidia
with <b><i>lshw</i></b> command:
*-display
description: 3D controller
product: GM204M [GeForce GTX 970M] [10DE:13D8]
vendor: NVIDIA Corporation [10DE]
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:127 memory:dc000000-dcffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:e000(size=128) memory:dd000000-dd07ffff
*-display
description: VGA compatible controller
product: HD Graphics 530 [8086:191B]
vendor: Intel Corporation [8086]
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:123 memory:db000000-dbffffff memory:70000000-7fffffff ioport:f000(size=64) memory:c0000-dffff
All packages have been installed through Debian repository. This laptop has a color LED on power button letting know which graphic card is in use:
- blue: integrated
- orange: discrete
When running command:
root@msi-gs60-6qe:~# echo OFF > /proc/acpi/bbswitch
I get this message logged:
[ 2001.428820] bbswitch: device 0000:01:00.0 is in use by driver 'nvidia', refusing OFF
For now, when Linux boots, integrated graphic card seems to be used (blue power LED). When login screen appears, the power LED switches to orange.
I tried creating a file /etc/modprobe.d/bbswitch.conf with:
options bbswitch load_state=0 unload_state=1
but just when login screen should appear, the computer freezes, stuck on text boot screen.
The file /etc/modprobe.d/bumblebee.conf contains blacklist nvidia. And from the initramfs, I think it is really blacklisted:
root@msi-gs60-6qe:~# lsinitramfs /boot/initramfs-4.19.0-6-amd64.img | egrep -i "kernel/drivers/gpu"
usr/lib/modules/4.19.0-6-amd64/kernel/drivers/gpu
usr/lib/modules/4.19.0-6-amd64/kernel/drivers/gpu/drm
usr/lib/modules/4.19.0-6-amd64/kernel/drivers/gpu/drm/drm.ko
usr/lib/modules/4.19.0-6-amd64/kernel/drivers/gpu/drm/drm_kms_helper.ko
usr/lib/modules/4.19.0-6-amd64/kernel/drivers/gpu/drm/i915
usr/lib/modules/4.19.0-6-amd64/kernel/drivers/gpu/drm/i915/i915.ko
From the command nvidia-smi, the discrete graphic card seems powered up:
| NVIDIA-SMI 418.74 Driver Version: 418.74 CUDA Version: N/A |
| 0 GeForce GTX 970M On | 00000000:01:00.0 Off | N/A |
| N/A 52C P8 5W / N/A | 0MiB / 3024MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
However, glxinfo returns this:
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 530 (Skylake GT2)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 18.3.6
and optirun glxinfo returns this:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 970M/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 418.74
Which means the discrete graphic cards is not used when not needed. At least, it’s a good start…
I’ve tried to power down/up the discrete graphic card using this guide:
https://wiki.archlinux.org/index.php/Hybrid_graphics#Fully_Power_Down_Discrete_GPU
Running the examples shows me that _SB.PCI0.PEG0.PEGP._OFF bus worked. Indeed, the laptop’s power LED has turned blue!
Then, issuing
echo '\_SB.PCI0.PEG0.PEGP._ON' > /proc/acpi/call
to turn the discrete graphic card on, the laptop’s power LED turns orange.
However, if the discrete graphic card is turned off this way, nvidia driver is still loaded and the computer hangs if it tries to access the graphic card.
I think bbswitch command would be able to correctly power down the discrete graphic card, if only nvidia driver could be unloaded!
Any idea about what might prevent nvidia driver from being unloaded?
