Failed to use GPU using Tensorflow 2.4 inside WSL2
Hi, I am testing Parameter Server Training for multi GPU training workers.
I have followed this guide in order to install a container with GPU access inside a WSL2:
. Everything installed, NO errors.
Now I am starting to follow this TF oficial guide to use Parameter Server Training:
The problem is that Parameter Server Training guide only works on TF ver 2.4
If I try to pull a tensorflow image above 2.1 GPU fails into TF.
