I wangt to install nvshmem2.10 on Ubuntu 16.04 with 8 *P100 ,and it does not have infiniband.
I follow the guidance https://docs.nvidia.com/nvshmem/release-notes-install-guide/install-guide/nvshmem-install-proc.html,and this is the makefile:
> # Copyright (c) 2016-2021, NVIDIA CORPORATION. All rights reserved.
> # See COPYRIGHT for license information
> # Define this variable for the Include Variable in common.mk
> mkfile_path := $(abspath $(firstword $(MAKEFILE_LIST)))
> mkfile_dir := $(dir $(mkfile_path))
> # External dependencies
> include common.mk
> include version.mk
> # Build/install location
> # location where the build will be installed
> NVSHMEM_PREFIX ?= /home/xxx/nvshmem/
> # build location
> NVSHMEM_BUILDDIR ?= $(abspath build)
> # MPI/SHMEM Support
> NVSHMEM_IBRC_SUPPORT=0
> NVSHMEM_IBGDA_SUPPORT=0
> NVSHMEM_IBGDA_SUPPORT_GPUMEM_ONLY=0
> # GDRCopy install/headers location
> GDRCOPY_HOME ?= /home/xxx/mpi/gdrcopy/gdrcopy-2.3
> # NCCL install/headers location
> NCCL_HOME ?= /usr/local/nccl
> NVSHMEM_USE_NCCL ?= 0
> # Whether to build with MPI support. If yes, MPI_HOME should be set
> NVSHMEM_USE_GDRCOPY ?= 1
> # Include support for PMIx as the process manager interface
> PMIX_HOME ?= /usr
> # One of the below can be set to 1 to override the default PMI
> NVSHMEM_DEFAULT_PMIX ?= 0
> NVSHMEM_DEFAULT_PMI2 ?= 0
> # This can be set to override the default remote transport.
> NVSHMEM_DEFAULT_UCX ?= 0
> # NVSHMEM internal features
> NVSHMEM_TRACE ?= 0
> NVSHMEM_NVTX ?= 1
> NVSHMEM_DISABLE_COLL_POLL ?= 1
> NVSHMEM_GPU_COLL_USE_LDST ?= 0
> # Timeout if stuck for long in wait loops in device
> NVSHMEM_TIMEOUT_DEVICE_POLLING ?= 0
> # Use dlmalloc (instead of custom_malloc) as heap
> # allocator (will work only if not using CUDA VMM)
> NVSHMEM_USE_DLMALLOC ?= 0
> CXXFLAGS+=-std=c++11
> NVSHMEM_UCX_SUPPORT=1
> UCX_HOME=/home/xxx/ucx
In the end ,it fails whith:
> In file included from src/host/mem/mem.cpp:39:0:
> src/include/common/nvshmem_common_ibgda.h:12:31: fatal error: infiniband/mlx5dv.h: No such file or directory
> compilation terminated.
> Makefile:676: recipe for target '/home/xxx/nvshmem_src_2.10.1-3/build/obj_nvshmem/host/mem/mem.o' failed
> make: *** [/home/xxx/nvshmem_src_2.10.1-3/build/obj_nvshmem/host/mem/mem.o] Error 1
What should i do?
