NVSHMEM fails to compile using nvcc
Hi, I am trying to build NVSHMEM and use it in my program.
I follow the instruction on NVSHMEM Installation to build.
My software are:
OpenMPI: 4.1.4
UCX: 1.13.1
CUDA: 11.8
GCC: 8.5.0
CMAKE: 3.26.3
NVSHMEM: 2.5.0-19
NCCL: 2.23
I use the following command to compile nvshmem:
export CUDA_HOME=/opt/cuda/11.8
export NVSHMEM_USE_GDRCOPY=1
export NVSHMEM_MPI_SUPPORT=1
export MPI_HOME=/ompi/install
export NVSHMEM_GPUINITIATED_SUPPORT=1
export NVSHMEM_PREFIX=/nvshmem_src_2.5.0-19/install
export NVSHMEM_USE_NCCL=1
export NCCL_HOME=/nccl/build
export GDRCOPY_HOME=/opt/gdrcopy/2.3
cd nvshmem_src_2.5.0-19
make -j install
After compilation, I got
which seems succeeded.
Then I use nvcc to compile the offical example:
#include <stdio.h>
#include <cuda.h>
#include <nvshmem.h>
#include <nvshmemx.h>
__global__ void simple_shift(int *destination) {
    int mype = nvshmem_my_pe();
    int npes = nvshmem_n_pes();
    int peer = (mype + 1) % npes;
    nvshmem_int_p(destination, mype, peer);
int main(void) {
    int mype_node, msg;
    cudaStream_t stream;
    nvshmem_init();
    mype_node = nvshmem_team_my_pe(NVSHMEMX_TEAM_NODE);
    cudaSetDevice(mype_node);
    cudaStreamCreate(&stream);
    int *destination = (int *) nvshmem_malloc(sizeof(int));
    simple_shift<<<1, 1, 0, stream>>>(destination);
    nvshmemx_barrier_all_on_stream(stream);
    cudaMemcpyAsync(&msg, destination, sizeof(int), cudaMemcpyDeviceToHost, stream);
    cudaStreamSynchronize(stream);
    printf("%d: received message %d\n", nvshmem_my_pe(), msg);
    nvshmem_free(destination);
    nvshmem_finalize();
    return 0;
nvcc nvShmemTest.cu -o nvShmemTest -arch=compute_80 -code=sm_80 -L/ompi/install/lib -I/ompi/install/include -L/nccl/build/lib -I/nccl/build/include -I/nvshmem_src_2.5.0-19/install/include -L/nvshmem_src_2.5.0-19/install/lib -lmpi -lnccl -lnvshmem
But it gives the following error:
ptxas fatal   : Unresolved extern function 'nvshmem_my_pe'
It seems like link error but I have configured the correct include and lib path to nvShmem.
Any help is appreciated!!
Since this forum is for the NVHPC Compilers, I’m moving your post over to the GPU Accelerated Library forum.
-Mat
In this case it is necessary to compile with relocatable device code linking. Try adding -rdc=true to your compile command line.
Thanks @Robert_Crovella !!! It works!
