make ARCH="arm64" CROSS32CC="/home/ryan/usr/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc-7.3.1" CROSS_COMPILE="aarch64-linux-gnu-" -j8
I don’t actually type that every time, but it lives in a little script file in my $PATH.
The error I see is from the linker related to multiple definitions of many things found in arch/arm/cpu/armv8/start.S, which is weird because I can only find one definition and any inclusion guards I have tried to use have not made any affect on the linking step. Here is the error message
LD u-boot
arch/arm/cpu/armv8/start.o: In function `_start':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/./arch/arm64/include/asm/boot0-linux-kernel-header.h:40: multiple definition of `_start'
arch/arm64/cpu/armv8/start.o:/home/ryan/RegOS/public_sources_R32.2.3/u-boot/./arch/arm64/include/asm/boot0-linux-kernel-header.h:40: first defined here
arch/arm/cpu/armv8/start.o: In function `_TEXT_BASE':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/./arch/arm64/include/asm/boot0-linux-kernel-header.h:40: multiple definition of `_TEXT_BASE'
arch/arm/cpu/armv8/start.o: In function `_end_ofs':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/./arch/arm64/include/asm/boot0-linux-kernel-header.h:40: multiple definition of `_end_ofs'
arch/arm/cpu/armv8/start.o: In function `_bss_start_ofs':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/./arch/arm64/include/asm/boot0-linux-kernel-header.h:40: multiple definition of `_bss_start_ofs'
arch/arm/cpu/armv8/start.o: In function `_bss_end_ofs':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/./arch/arm64/include/asm/boot0-linux-kernel-header.h:40: multiple definition of `_bss_end_ofs'
arch/arm/cpu/armv8/start.o: In function `save_boot_params_ret':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/arch/arm/cpu/armv8/start.S:71: multiple definition of `save_boot_params_ret'
arch/arm64/cpu/armv8/start.o:/home/ryan/RegOS/public_sources_R32.2.3/u-boot/arch/arm/cpu/armv8/start.S:71: first defined here
arch/arm/cpu/armv8/start.o: In function `c_runtime_cpu_setup':
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/arch/arm/cpu/armv8/start.S:307: multiple definition of `c_runtime_cpu_setup'
arch/arm64/cpu/armv8/start.o:/home/ryan/RegOS/public_sources_R32.2.3/u-boot/arch/arm/cpu/armv8/start.S:307: first defined here
make: *** [u-boot] Error 1
The uname -a from the machine I am compiling on currently is
Linux tetris 3.19.0-41-generic #46~14.04.2-Ubuntu SMP Tue Dec 8 17:46:10 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
I will be very disappointed if somebody recommends I upgrade to a newer Ubuntu. I highly doubt this is the problem as I have attempted the same thing, and have run into the exact same error message using a recently built x86_64 Gentoo VM (kernel 4.19.72) using an aarch64-unknown-linux-gnueabi-8.3.0 toolchain
I hope somebody can help me with this. Thanks for spending time looking into it.
export CROSS_COMPILE=<toolchain_install_path>/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
tar xpvf u-boot_src.tbz2
cd u-boot
make distclean
make p2371-2180_defconfig
make
ryan@tetris:~/RegOS/public_sources_R32.2.3/u-boot$ make ARCH="arm64" CROSS_COMPILE="/home/ryan/usr/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-" distclean
ryan@tetris:~/RegOS/public_sources_R32.2.3/u-boot$ make ARCH="arm64" CROSS_COMPILE="/home/ryan/usr/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-" p2371-2180_defconfig
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
# configuration written to .config
ryan@tetris:~/RegOS/public_sources_R32.2.3/u-boot$ make ARCH="arm64" CROSS_COMPILE="/home/ryan/usr/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-" -j8 > /dev/null
/home/ryan/RegOS/public_sources_R32.2.3/u-boot/arch/arm/cpu/armv8/start.S:98: multiple definition of `save_boot_params_ret'
arch/arm64/cpu/armv8/start.o:/home/ryan/RegOS/public_sources_R32.2.3/u-boot/arch/arm/cpu/armv8/start.S:98: first defined here
For posterity, here is the diff between the default config(left) and the one I uploaded earlier(right):
ryan@tetris:~/RegOS/public_sources_R32.2.3/u-boot$ diff .config /tmp/u-boot.config
32c32
< # CONFIG_POSITION_INDEPENDENT is not set
> CONFIG_POSITION_INDEPENDENT=y
36d35
< CONFIG_STATIC_RELA=y
192,193c191,192
< CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-2180"
< # CONFIG_AHCI is not set
> CONFIG_DEFAULT_DEVICE_TREE="tegra210-jetson-tx1-p2597-2180-a01-devkit"
> CONFIG_AHCI=y
199c198
< CONFIG_LOCALVERSION=""
> CONFIG_LOCALVERSION="LRI-Ryan"
201c200
< CONFIG_CC_OPTIMIZE_FOR_SIZE=y
> # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
211c210
< CONFIG_OF_SYSTEM_SETUP=y
> # CONFIG_OF_SYSTEM_SETUP is not set
229,230c228,229
< # CONFIG_SATA_BOOT is not set
< # CONFIG_SD_BOOT is not set
> CONFIG_SATA_BOOT=y
> CONFIG_SD_BOOT=y
232c231
< CONFIG_BOOTDELAY=2
> CONFIG_BOOTDELAY=3
240c239
< CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # "
> CONFIG_SYS_PROMPT="hush> "
246c245,250
< # CONFIG_AUTOBOOT_KEYED is not set
> CONFIG_AUTOBOOT_KEYED=y
> CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds\n"
> # CONFIG_AUTOBOOT_ENCRYPTION is not set
> CONFIG_AUTOBOOT_DELAY_STR=""
> CONFIG_AUTOBOOT_STOP_STR=""
> # CONFIG_AUTOBOOT_KEYED_CTRLC is not set
265c269
< # CONFIG_CMD_BOOTZ is not set
> CONFIG_CMD_BOOTZ=y
271c275
< # CONFIG_CMD_IMI is not set
> CONFIG_CMD_IMI=y
282c286
< # CONFIG_CMD_GREPENV is not set
> CONFIG_CMD_GREPENV=y
303c307
< # CONFIG_CMD_FLASH is not set
> CONFIG_CMD_FLASH=y
307,308c311,312
< CONFIG_CMD_SF=y
< CONFIG_CMD_SPI=y
> # CONFIG_CMD_SF is not set
> # CONFIG_CMD_SPI is not set
311,313c315,317
< CONFIG_CMD_DFU=y
< CONFIG_CMD_USB_MASS_STORAGE=y
< # CONFIG_CMD_FPGA is not set
> # CONFIG_CMD_DFU is not set
> # CONFIG_CMD_USB_MASS_STORAGE is not set
> CONFIG_CMD_FPGA=y
322c326
< # CONFIG_CMD_SETEXPR is not set
> CONFIG_CMD_SETEXPR=y
333,334c337,338
< CONFIG_CMD_MII=y
< CONFIG_CMD_PING=y
> # CONFIG_CMD_MII is not set
> # CONFIG_CMD_PING is not set
343c347
< # CONFIG_CMD_CACHE is not set
> CONFIG_CMD_CACHE=y
392c396
< # CONFIG_SPL_DM_SEQ_ALIAS is not set
> CONFIG_SPL_DM_SEQ_ALIAS=y
427c431
< # CONFIG_DMA is not set
> CONFIG_DMA=y
511,523c515
< CONFIG_SPI_FLASH=y
< # CONFIG_SPI_FLASH_BAR is not set
< # CONFIG_SPI_FLASH_ATMEL is not set
< # CONFIG_SPI_FLASH_EON is not set
< # CONFIG_SPI_FLASH_GIGADEVICE is not set
< # CONFIG_SPI_FLASH_MACRONIX is not set
< # CONFIG_SPI_FLASH_SPANSION is not set
< # CONFIG_SPI_FLASH_STMICRO is not set
< # CONFIG_SPI_FLASH_SST is not set
< CONFIG_SPI_FLASH_WINBOND=y
< CONFIG_SPI_FLASH_USE_4K_SECTORS=y
< # CONFIG_SPI_FLASH_DATAFLASH is not set
< # CONFIG_SPI_FLASH_MTD is not set
> # CONFIG_SPI_FLASH is not set
526,533c518
< CONFIG_NETDEVICES=y
< # CONFIG_ALTERA_TSE is not set
< # CONFIG_DWC_ETH_QOS is not set
< # CONFIG_E1000 is not set
< # CONFIG_ETH_DESIGNWARE is not set
< # CONFIG_PCH_GBE is not set
< # CONFIG_RTL8139 is not set
< CONFIG_RTL8169=y
> # CONFIG_NETDEVICES is not set
540c525
< CONFIG_PCI_TEGRA=y
> # CONFIG_PCI_TEGRA is not set
588c573
< CONFIG_SYS_NS16550=y
> # CONFIG_SYS_NS16550 is not set
607c592
< CONFIG_TEGRA114_SPI=y
> # CONFIG_TEGRA114_SPI is not set
640d624
< # CONFIG_USB_DWC3 is not set
657,666c641
< CONFIG_USB_GADGET=y
< # CONFIG_USB_GADGET_ATMEL_USBA is not set
< # CONFIG_USB_GADGET_DWC2_OTG is not set
< CONFIG_CI_UDC=y
< CONFIG_USB_GADGET_VBUS_DRAW=2
< CONFIG_USB_GADGET_DUALSPEED=y
< CONFIG_USB_GADGET_DOWNLOAD=y
< CONFIG_G_DNL_MANUFACTURER="NVIDIA"
< CONFIG_G_DNL_VENDOR_NUM=0x0955
< CONFIG_G_DNL_PRODUCT_NUM=0x701a
> # CONFIG_USB_GADGET is not set
I am by no means saying the one I uploaded is acceptable. I didn’t start from the default config, which I should have. I’ll use the default one in the future, but as far as I can tell, the default config will still be unable to link.
I noticed this excerpt in your original compile line:
...ARCH="arm64" CROSS32CC="...
“CROSS32CC” is for arm32, not arm64. I don’t know about this particular bootloader code, but I don’t think you need CROSS32CC anymore. Back when arm64 was new the only 64-bit code was in the Linux kernel itself, and everything else (bootloader, user space, so on) was still 32-bit. The CROSS32CC was used only when two compilers were used simultaneously (there was a vdso kernel feature which needed 32-bit in the first releases).
That is very useful and interesting information. Thank you. I had just included that environment variable definition because the guy before me had done the same.
If you are building just U-Boot, then you may need “ARCH=armhf” instead since U-Boot (so far as I know) has always been 32-bit even on 64-bit ARM systems (you’d need a different cross compiler for 32-bit, which is ARMv7-a). Any error message you get would be useful.
