Thanks, I’ll try your code as well.
This is the code I’ve been using (it’s not my code, it’s just some code I’ve taken from the internet that I’ve modified):
program matrix_multiply
! use omp_lib
use openacc
use mpi
implicit none
integer :: i, j, k, myid, m, n, compiled_for, option
integer, parameter :: fd = 11
integer :: t1, t2, dt, count_rate, count_max
real, allocatable, dimension(:,:) :: a, b, c
real :: tmp, secs
integer :: ngpus
integer :: ierror, provided
! call MPI_Init(ierror)
open(fd,file='wallclocktime',form='formatted')
option = compiled_for(fd) ! 1-serial, 2-OpenMP, 3-OpenACC, 4-both
write(*,*) 'before acc_get_num_devices'
ngpus = acc_get_num_devices( acc_device_nvidia )
write(*,*) 'after acc_get_num_devices',ngpus
!$omp parallel
!$ myid = OMP_GET_THREAD_NUM()
!$ if (myid .eq. 0) then
!$ write(fd,"('Number of procs is ',i4)") OMP_GET_NUM_THREADS()
!$ endif
!$omp end parallel
call system_clock(count_max=count_max, count_rate=count_rate)
do m=1,4 ! compute for different size matrix multiplies
call system_clock(t1)
n = 1000*2**(m-1) ! 1000, 2000, 4000, 8000
allocate( a(n,n), b(n,n), c(n,n) )
! Initialize matrices
do j=1,n
do i=1,n
a(i,j) = real(i + j)
b(i,j) = real(i - j)
enddo
enddo
!$omp parallel do shared(a,b,c,n,tmp) reduction(+: tmp)
!$acc data copyin(a,b) copy(c)
!$acc kernels
! Compute matrix multiplication.
do j=1,n
do i=1,n
tmp = 0.0 ! enables ACC parallelism for k-loop
do k=1,n
tmp = tmp + a(i,k) * b(k,j)
enddo
c(i,j) = tmp
enddo
enddo
!$acc end kernels
!$acc end data
!$omp end parallel do
call system_clock(t2)
dt = t2-t1
secs = real(dt)/real(count_rate)
write(fd,"('For n=',i4,', wall clock time is ',f12.2,' seconds')") &
n, secs
deallocate(a, b, c)
enddo
close(fd)
call MPI_Finalize(ierror)
end program matrix_multiply
integer function compiled_for(fd)
implicit none
integer :: fd
#if defined _OPENMP && defined _OPENACC
compiled_for = 4
write(fd,"('This code is compiled with OpenMP & OpenACC')")
#elif defined _OPENACC
compiled_for = 3
write(fd,"('This code is compiled with OpenACC')")
#elif defined _OPENMP
compiled_for = 2
write(fd,"('This code is compiled with OpenMP')")
#else
compiled_for = 1
write(fd,"('This code is compiled for serial operations')")
#endif
end function compiled_for
Moving the MPI_Init between the two definitions breaks it on the system I’m using.
