OpenACC usage inside OpenMP constructs
we have users who write MPI + OpenMP + OpenACC code like this:
! rank = MPI rank
call acc_set_device_num(mod(rank,4),acc_device_nvidia)
! allocate memory on the device
! do a lot of calculation here
!$OMP PARALLEL
      !$OMP MASTER
            ! do a lot OpenACC calculation here
      !$OMP END MASTER
      !$OMP SINGLE
            ! use device memory data allocated before the
            ! OMP PARALLEL construct and do some calculation
      !$OMP END SINGLE
!OMP END_PARALLEL
I’m wondering if the usage of OpenACC within the OMP PARALLEL construct is valid.
Is it correct to set the device (using the MPI rank) for each OpenMP thread again so they can access the data allocated before the OMP PARALLEL construct?
Is this usage correct?
Thank you for your help
Using OpenACC within an OpenMP parallel construct is valid, though can be a bit tricky at times. Here it appears that they are using a single GPU per MPI ranks so all OpenMP threads would be using the same GPU and device data which is easier. It gets more challenging to synchronize shared data when each OpenMP thread uses different devices.
It shouldn’t hurt but is extraneous. All the OpenMP threads will inherent the same device as the master thread so the extra call to set device is only needed if the threads were using different devices.
From what you show, I think it should be fine. I’m not clear if there is a dependency between the MASTER and SINGLE constructs, but if there is, they may need a BARRIER.
If you can provide a full example, that may help identify an potential issues.
-Mat
Thank you for your answer! There is no dependency between master and single.
I will try to create a small example.
But if I remove the acc_set_device(…) from the OMP PARALLEL construct the program crashes with a lot of error messages like:
FATAL ERROR: data in PRESENT clause was not found on device 1: name=var1 host:0x22273da40
Hmm, I could be wrong about that. Once you put the example together, I’ll investigate. Things might have changed in our new LLVM based compilers since it uses a different OpenMP runtime. It’s been a few years since I did any coding like this and was using our older OpenMP runtime.
-Mat
I have now created an example.
I created the four files:
  1. main.f
  2. kernel.f90
  3. params.f
  4. makefile
The code crashes when the call acc_set_device_num(…) call is removed from
the !$OMP PARALLEL section inside the the kernel.f90 file.
FATAL ERROR: data in PRESENT clause was not found on device 1: name=gcol_n host:0x73d5900
 lfpim_inner_loop line:17
The code should be run with n>1 otherwise it does not crash:
mpiexec -n 8 ./run
We are using the PGI 19.1 compiler and OpenMPI 2.1.5 on a DGX2.
Is something wrong with this code?
Thank you for your help!
main.f
      implicit real*8 (a-h,o-z)
      include "params.f"
      include "mpif.h"
      include "accel_lib.h"
      dimension
     1     f(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb,nsp),
     1     f0(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb),
     1     fc(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb),
     1     ef0(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb),
     1     efc(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb),
     1     f1(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb),
     1     ef(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb),
     1     df3(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb,0:nsp),
     1     ebbs(1-nb1:nx+nb1,1-nb1:ny+nb1,nv),
     1     bbs(1-nb1:nx+nb1,1-nb1:ny+nb1,nv,nsp),
     1     bb(1-nb2:nx+nb2,1-nb2:ny+nb2)
      real*8 dvs_GPU(0:nsp)
      real*8 dws_GPU(0:nsp)
      real*8 ams_GPU(0:nsp)
      real*8 qs_GPU(0:nsp)
      real*8 tms_GPU(0:nsp)
      real*8 vts_GPU(0:nsp)
      integer numdevices
      ! Init MPI
      call MPI_Init(ierr)
      call MPI_Comm_size(mpi_comm_world,npe0,ierr)
      call MPI_Comm_rank(mpi_comm_world,iam0,ierr)
      if(iam0.eq.0)write(*,*)"Programstart"
      numdevices = acc_get_num_devices(acc_device_nvidia)
      if(iam0.eq.0)then
        write(*,*)"Setting up OpenACC"
        write(*,*)"GPUs per node: ",numdevices
      endif
      call acc_set_device_num(mod(iam0,numdevices),acc_device_nvidia)
      istart=0
      !$OMP DO
      !$OMP& COLLAPSE(3)
      !$OMP& SCHEDULE(dynamic,1)
                     do i=1,nx
                        do j=1,ny
                           do k=1,nz
                              do l=1,nv
                              f(l,k,j,i,1)= f(l,k,j,i,1)+3.0*f0(l,k,j,i)
                              enddo
                           enddo
                        enddo
                     enddo
      !$OMP END DO NOWAIT
      key0=1
      key1=2
      key2=2
      npx_GPU=npx
      npy_GPU=npy
      npw_GPU=npw
      ncom1=1
      nsp1_GPU =nsp+1
      adt=4200*1.5
      dvs_GPU=88
      dvs_GPU=99
      ams_GPU = 1.0
      qs_GPU  = 2.0
      tms_GPU = 3.0
      vts_GPU = 4.0
      nx_GPU =nx
      ny_GPU =ny
      nz_GPU =nz
      nv_GPU =nv
      nb_GPU =nb
      nb1_GPU  =nb1
      nb2_GPU  =nb2
      nxy_GPU=nxy
      nnx_GPU=nnx
      nny_GPU=nny
      gdne_GPU=gdne
      ifcol_GPU=ifcol
      ifcfm_GPU=ifcfm
      b0_GPU =b0
      c_GPU  =c
      pi_GPU=pi
!$acc data copy(
!$acc& key0,key1,key2,
!$acc& npx_GPU,npy_GPU,ncom1,nsp1_GPU,adt,
!$acc& dvs_GPU,dws_GPU,
!$acc& ams_GPU,qs_GPU,tms_GPU,vts_GPU,
!$acc& ef, df3, ebbs,
!$acc& f, bbs,
!$acc& nx_GPU,ny_GPU,nz_GPU,nv_GPU,npw_GPU,
!$acc& nb_GPU,nb1_GPU,nb2_GPU,nxy_GPU,
!$acc& ifcol_GPU,ifcfm_GPU,
!$acc& bb,b0_GPU,c_GPU,gdne_GPU,pi_GPU
!$acc& )
      do it = istart,1
          call lfpim_GPU(ct,
     1              key0, key1, key2,
     1              nnx_GPU, nny_GPU, ncom1, nsp1_GPU, adt,
     1              dvs_GPU,dws_GPU,
     1              ams_GPU,qs_GPU,tms_GPU,vts_GPU,
     1              ef,df3(in,in,in,in,0),ebbs,
     1              f,df3(in,in,in,in,1),bbs,
     1              nx_GPU,ny_GPU,nz_GPU,nv_GPU,npw_GPU,
     1              nb_GPU,nb1_GPU,nb2_GPU,nxy_GPU,
     1              ifcol_GPU,ifcfm_GPU,
     1              bb,b0_GPU,c_GPU,gdne_GPU,pi_GPU)
      enddo
!$acc end data
      call MPI_Finalize(ierr)
      end
kernel.f90
subroutine lfpim_inner_loop( &
          nx,ny,nz,nv,npw,nb,nb1,nb2,nxy,npa, &
          gcol_n &
  implicit none
  include "mpif.h"
  integer nx,ny,nz,nv
  integer npw
  integer nb,nb1,nb2
  integer nxy
  integer npa
  real*8  gcol_n(1-nb1:nv+nb1,1-nb1:npw+nb1,npa,nxy)
  !$acc kernels &
  !$acc present( &
  !$acc gcol_n&
  !$acc  )
  gcol_n=0.d0
  !$acc end kernels
end subroutine lfpim_inner_loop
subroutine lfpim_GPU( &
     ct,key0,key1,key2,&
     nnx,nny,&
     ncom1,npa,adt, &
     dv,dw,ami,qi,&
     ti,vti, &
     f1,df1,bbs1, &
     f2,df2,bbs2, &
     nx,ny,nz,nv,npw,&
     nb,nb1,nb2,nxy,ifcol,ifcfm, &
     bb,b0,c,gdne,pi)
  use omp_lib
  implicit none
  include "mpif.h"
  real*8 ct(20)
  integer key0,key1,key2
  integer nnx,nny,ncom1
  integer npa
  real*8 adt
  real*8 dv(npa)
  real*8 dw(npa)
  real*8 ami(npa)
  real*8 qi(npa)
  real*8 ti(npa)
  real*8 vti(npa)
  real*8 f1(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb)
  real*8 df1(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb)
  real*8 bbs1(1-nb1:nx+nb1,1-nb1:ny+nb1,nv)
  real*8 f2(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb,2:npa)
  real*8 df2(1-nb:nv+nb,1-nb:nz+nb,1-nb:ny+nb,1-nb:nx+nb,2:npa)
  real*8 bbs2(1-nb1:nx+nb1,1-nb1:ny+nb1,nv,2:npa)
  integer nx,ny,nz,nv
  integer npw
  integer nb,nb1,nb2
  integer nxy
  integer ifcol,ifcfm
  real*8 bb(1-nb2:nx+nb2,1-nb2:ny+nb2)
  real*8 b0,c,gdne,pi
  real*8,parameter :: sic  = 2.99792458d8
  real*8,parameter :: sie  = 1.60217733d-19
  real*8,parameter :: sime = 9.1093897d-31
  real*8,parameter :: gc   = sic*1.d2
  real*8,parameter :: ge   = sie*gc*1.d-1
  real*8,parameter :: gme  = sime*1.d3
  integer i
  integer j
  integer ij
  integer is
  integer l
  integer m
  integer n
  real*8  tmp
  integer k,kk
  real*8 gwpe
  real*8 bbs(1-nb1:nx+nb1,1-nb1:ny+nb1,nv,npa)
  real*8 gdx
  real*8 evn
  real*8 rbuf1(npa,1-nb:nv+nb,1,nxy,npw)
  real*8 rbuf2(npa,1-nb:nv+nb,1,nxy,npw)
  real*8 sbuf1(npa,1-nb:nv+nb,1,nxy,npw)
  real*8 sbuf2(npa,1-nb:nv+nb,1,nxy,npw)
  integer ierr
  integer ndata
  real*8 g(1-nb1:nv+nb1,1-nb1:npw+nb1,1,nxy,npa)
  real*8 dummy
  real*8 ct1,ct2
  real*8 tmp1,tmp2
  real*8 dummy1,dummy2
  integer iam0
  real*8  alpha(nxy)
  real*8  bb_n(nxy)
  real*8  beta(nxy)
  real*8  cfmav(nv,npw,nxy)
  real*8  cfmav_int_n(nxy)
  real*8  cfmax2(nv,npw,nxy)
  real*8  cfmax2_int_n(nxy)
  real*8  cmr(3,npa,npa,nxy)
  real*8  cms_n(3,npa,npa,nxy)
  real*8  col_n(10,nv,npw,npa,npa,nxy)
  real*8  colf(nv,npw,npa)
  real*8  colt_n(nv,npw,npa,nxy)
  real*8  dn_all_n(npa,nxy)
  real*8  dti_n(nxy)
  real*8  dvp_n(nxy)
  real*8  dzb_n(npw,npa,nxy)
  real*8  dzbs_n(nv,npw,npa,nxy)
  real*8  erfb_xb(nv,npw,nxy)
  real*8  fdif(nxy)
  real*8  fmxla(nv,npw,nxy)
  real*8  ftot_n(nxy)
  real*8  gap2(nxy)
  real*8  gap_n(1-nb1:nv+nb1,1-nb1:npw+nb1,nxy)
  real*8  gar_n(1-nb1:nv+nb1,1-nb1:npw+nb1,nxy)
  real*8  gg_n(1-nb1:nv+nb1,1-nb1:npw+nb1,npa,nxy)
  real*8  gp2(nxy)
  real*8  gp_n(1-nb1:nv+nb1,1-nb1:npw+nb1,nxy)
  real*8  gr_n(1-nb1:nv+nb1,1-nb1:npw+nb1,nxy)
  real*8  grgar(nxy)
  real*8  gx_n(1-nb1:nv+nb1,1-nb1:npw+nb1,nxy)
  real*8  pmat_n(3,3,npa,npa,nxy)
  real*8  ti_all_n(npa,nxy)
  real*8  v2_n(nv,npw,npa,nxy)
  real*8  vl_n(nv,npa,nxy)
  real*8  vp_all_n(npa,nxy)
  integer nxyMax
  ct1=0.0d0
  ct2=0.0d0
  write(*,*) "Inside function"
  gwpe = dsqrt(pi*4*gdne*ge**2/gme)
  gdx  = gc/(gwpe*c)
  evn  = gdx*gdx*gwpe*gwpe*1e-4/sie*sime
  k=1
  kk=1
  dummy=0.d0
  tmp=0.d0
  nxyMax=0
  do  n = 1,nxy
     ij=key0*nxy+n
     if(ij.le.nx*ny) then
     else
        exit
     endif
     nxyMax=nxyMax+1
  enddo
  !$acc data &
  !$acc copy( &
  !$acc k,kk,  &
  !$acc gdx,evn &
  !$acc )  &
  !$acc create( &
  !$acc bbs,  &
  !$acc rbuf1,rbuf2,sbuf1,sbuf2,  &
  !$acc g, &
  !$acc alpha, &
  !$acc bb_n, &
  !$acc beta, &
  !$acc cfmav,cfmav_int_n,cfmax2,cfmax2_int_n, &
  !$acc cmr,cms_n, &
  !$acc col_n,colf,colt_n, &
  !$acc dn_all_n, &
  !$acc dti_n,dvp_n,dzb_n,dzbs_n, &
  !$acc erfb_xb, &
  !$acc fdif,fmxla,ftot_n, &
  !$acc gap2,gap_n,gar_n,gcol_n, &
  !$acc gg_n,gp2,gp_n,gr_n, &
  !$acc grgar,gx_n, &
  !$acc pmat_n, &
  !$acc ti_all_n, &
  !$acc v2_n,vl_n, &
  !$acc vp_all_n &
  !$acc )
  ! c........................................................gather f(l) -> g(l,m)
  !$acc kernels &
  !$acc present( &
  !$acc bbs,bbs2,bbs1, &
  !$acc sbuf1,rbuf1,sbuf2,rbuf2, &
  !$acc bb_n,bb &
  !$acc )
  bbs(:,:,:,1)=bbs1(:,:,:)
  bbs(:,:,:,2:npa)=bbs2(:,:,:,2:npa)
  sbuf1=0.0
  rbuf1=0.0
  sbuf2=0.0
  rbuf2=0.0
  bb_n=0.0d0
  do  n = 1,nxyMax
     ij=key0*nxy+n
     j=mod(ij-1,ny)+1
     i=(ij-j)/ny+1
     bb_n(n)=bb(i,j)
  enddo
  !$acc end kernels
  !$acc   update device(kk)
  !$acc   kernels &
  !$acc   present( &
  !$acc   sbuf1,f1,f2, &
  !$acc   kk &
  !$acc   )
  !$acc loop independent collapse(2)
  do n=1,nxy
     do m=0,npw-1
        ij=m*nxy+n
        j=mod(ij-1,ny)+1
        i=(ij-j)/ny+1
           do l=1-nb,nv+nb
              sbuf1(1,l,k,n,m+1)=f1(l,kk,j,i)
              do is=2,npa
                 sbuf1(is,l,k,n,m+1)=f2(l,kk,j,i,is)
              enddo
           enddo
        endif
     enddo
  enddo
  !$acc   end kernels
  ndata=(nv+2*nb)*nxy*npa
#ifdef GPU_Direct
        !$acc   host_data use_device( &
        !$acc   sbuf1,rbuf1 &
        !$acc    )
#else
        !$acc   update host(sbuf1)
#endif
  call mpi_alltoall( &
       sbuf1,ndata,mpi_double_precision, &
       rbuf1,ndata,mpi_double_precision,ncom1,ierr)
#ifdef GPU_Direct
        !$acc   end host_data
#else
        !$acc   update device(rbuf1)
#endif
  do kk=1,nz
     !$acc   kernels &
     !$acc   present( &
     !$acc   g,rbuf1 &
     !$acc   )
     g=0.d0
     do n=1,nxy
        do m=1,npw
           do l=1-nb,nv+nb
              do is=1,npa
                 g(l,m,k,n,is)=rbuf1(is,l,k,n,m)
              enddo
           enddo
        enddo
     enddo
     !$acc   end kernels
     !$acc   kernels &
     !$acc   present( &
     !$acc   sbuf2,rbuf2 &
     !$acc   )
     sbuf2=rbuf2
     rbuf2=0.0
     !$acc  end kernels
!$OMP PARALLEL
     call acc_set_device_num(mod(iam0,16),acc_device_nvidia)
!$OMP MASTER
     if(kk+1.le.nz) then
        !$acc   kernels &
        !$acc   present( &
        !$acc   kk &
        !$acc   )
        do n=1,nxy
           do m=0,npw-1
              ij=m*nxy+n
              j=mod(ij-1,ny)+1
              i=(ij-j)/ny+1
                 do l=1-nb,nv+nb
                    sbuf1(1,l,k,n,m+1)=f1(l,kk+1,j,i)
                    do is=2,npa
                       sbuf1(is,l,k,n,m+1)=f2(l,kk+1,j,i,is)
                    enddo
                 enddo
              endif
           enddo
        enddo
        !$acc   end kernels
     endif
     if(kk+1.le.nz) then
#ifdef GPU_Direct
        !$acc   sbuf1,rbuf1 &
        !$acc    )
#else
#endif
#ifdef GPU_Direct
        !$acc   end host_data
#else
#endif
     endif
     if(kk-1.ge.1) then
#ifdef GPU_Direct
        !$acc   sbuf2,sbuf1 &
        !$acc    )
#else
        !$acc   update host(sbuf2)
#endif
             sbuf2,ndata,mpi_double_precision, &
             sbuf1,ndata,mpi_double_precision,ncom1,ierr)
#ifdef GPU_Direct
        !$acc end host_data
#else
        !$acc update device(sbuf1)
#endif
     endif
!$OMP END MASTER
!$OMP SINGLE
     ! !$acc update device (g)
     call lfpim_inner_loop( &
          gcol_n &
!$OMP END SINGLE
!$OMP END PARALLEL
  enddo
  kk=nz
  !$acc end data
  return
end subroutine lfpim_GPU
params.f
      parameter(
     1     npx = 1, npy = 2, npw = 4, node = npx*npy, node0=node*npw,
     1     nx = 32, ny = 32, nz =  32, nv =  32,
     1     ifdbg  = 1, ifld   = 1, ifwo   = 0, ifcol  = 1,
     1     iftem  = 2, iflfpm = 1, ifcfm  = 1, ifm0   = 1,
     1     b0     =    0.99,
     1     c      =    0.25,
     1     gdne   =    5.6d13,
     1     pi   = 3.141592653589793d0,
     1     nsp= 1,
     1     nxy=(nx*ny-1)/npw+1,
     1     nb=2, nb1=nb+nb, nb2=nb1+nb
makefile
CC   = mpif90
RM   = /bin/rm
PROG = run
OBJS = main.o kernel.f90
OPTS = -O3 -ta=tesla:cc70 -acc -Minfo=accel -Minfo -mp -mcmodel=medium -DGPU_Direct -Mpreprocess
%.o : %.f
        ${CC} ${OPTS} -c  $<
%.o : %.f90
        ${CC} ${OPTS} -c  $<
all : ${PROG}
${PROG} : ${OBJS}
        ${CC} -Mcuda ${OPTS} -o $@ ${OBJS}
clean :
        ${RM} -f ${PROG} *.o
Thanks Peter85! I appreciate you pulling this together. It’s a big help.
All the OpenMP threads should inherit the device number from the master thread. It’s unclear why it’s not occurring here. I’ve added a problem report (TPR#27195) and have asked our compiler engineers to investigate.
Thanks again,
Mat
TPR #27195 should be fixed starting with release 19.7
