Hello, I’m trying to render something in a OpenGL FBO and output the result to a DMABuf.
Here is the code I’m using to check for the image content:
void * virtual_addr = nullptr;
NvBufferMemMap(_dmabuf_fd, 0, NvBufferMem_Read, &virtual_addr);
NvBufferMemSyncForCpu (_dmabuf_fd, 0, &virtual_addr);
cv::Mat outputImageNvBuffer( _height, _width, CV_8UC4, virtual_addr );
cv::imwrite( "output_nvbuffer.jpg", outputImageNvBuffer );
NvBufferMemUnMap (_dmabuf_fd, 0, &virtual_addr);
unsigned char * outBuffer;
size_t bufSize = _width * _height * 4;
outBuffer = (unsigned char*)malloc(bufSize);
glBindTexture(GL_TEXTURE_2D, _texId);
glGetTexImage(GL_TEXTURE_2D,
0,
GL_RGBA,
GL_UNSIGNED_BYTE,
outBuffer);
cv::Mat outputImageTexImage( _height, _width, CV_8UC4, outBuffer );
cv::imwrite( "output_teximage.jpg", outputImageTexImage );
I’m using OpenCV for simple image I/O.
The image I get from glGetTexImage is correct, while the image I get from NvBufferMemMap is not (see attached files).
Also, here is the code I use to “map” the texture to my dmabuf :
NvBufferCreate(&_dmabuf_fd, _width, _height, NvBufferLayout_BlockLinear, NvBufferColorFormat_ABGR32);
_eglImage = NvEGLImageFromFd (_display, _dmabuf_fd);
_initialized = true;
glBindTexture (GL_TEXTURE_2D, _texId);
glEGLImageTargetTexture2DOES (GL_TEXTURE_2D, _eglImage);
glFramebufferTexture2D (GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, _texId, 0);
What am I doing wrong ?
