Hi @AakankshaS,
I have attached image of error I recieved after editing with your snippet. Kindly give your expertise and assistance on the matter.
Thanks in Advance
Here giving the edited samplemnist.cpp file content
- Copyright 1993-2019 NVIDIA Corporation. All rights reserved.
- NOTICE TO LICENSEE:
- This source code and/or documentation (“Licensed Deliverables”) are
- subject to NVIDIA intellectual property rights under U.S. and
- international Copyright laws.
- These Licensed Deliverables contained herein is PROPRIETARY and
- CONFIDENTIAL to NVIDIA and is being provided under the terms and
- conditions of a form of NVIDIA software license agreement by and
- between NVIDIA and Licensee (“License Agreement”) or electronically
- accepted by Licensee. Notwithstanding any terms or conditions to
- the contrary in the License Agreement, reproduction or disclosure
- of the Licensed Deliverables to any third party without the express
- written consent of NVIDIA is prohibited.
- NOTWITHSTANDING ANY TERMS OR CONDITIONS TO THE CONTRARY IN THE
- LICENSE AGREEMENT, NVIDIA MAKES NO REPRESENTATION ABOUT THE
- SUITABILITY OF THESE LICENSED DELIVERABLES FOR ANY PURPOSE. IT IS
- PROVIDED “AS IS” WITHOUT EXPRESS OR IMPLIED WARRANTY OF ANY KIND.
- NVIDIA DISCLAIMS ALL WARRANTIES WITH REGARD TO THESE LICENSED
- DELIVERABLES, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY,
- NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
- LICENSE AGREEMENT, IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY
- SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, OR ANY
- DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
- WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
- ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
- OF THESE LICENSED DELIVERABLES.
- U.S. Government End Users. These Licensed Deliverables are a
- “commercial item” as that term is defined at 48 C.F.R. 2.101 (OCT
- 1995), consisting of “commercial computer software” and "commercial
- computer software documentation" as such terms are used in 48
- C.F.R. 12.212 (SEPT 1995) and is provided to the U.S. Government
- only as a commercial end item. Consistent with 48 C.F.R.12.212 and
- 48 C.F.R. 227.7202-1 through 227.7202-4 (JUNE 1995), all
- U.S. Government End Users acquire the Licensed Deliverables with
- only those rights set forth herein.
- Any use of the Licensed Deliverables in individual and commercial
- software must include, in the user documentation and internal
- comments to the code, the above Disclaimer and U.S. Government End
- Users Notice.
//! \file sampleMNIST.cpp
//! \brief This file contains the implementation of the MNIST sample.
//! It builds a TensorRT engine by importing a trained MNIST Caffe model. It uses the engine to run
//! inference on an input image of a digit.
//! It can be run with the following command line:
//! Command: ./sample_mnist [-h or --help] [-d=/path/to/data/dir or --datadir=/path/to/data/dir]
#include “logger.h”
#include “common.h”
#include “argsParser.h”
#include “buffers.h”
#include “NvCaffeParser.h”
#include “NvInfer.h”
#include <cuda_runtime_api.h>
#include
#include
#include
#include
#include
#include
const std::string gSampleName = “TensorRT.sample_mnist”;
//! \brief The MNISTSampleParams structure groups the additional parameters required by
//! the MNIST sample.
struct MNISTSampleParams : public samplesCommon::CaffeSampleParams
std::string meanFileName;
//! \brief The SampleMNIST class implements the MNIST sample
//! \details It creates the network using a trained Caffe MNIST classification model
class SampleMNIST
template
using SampleUniquePtr = std::unique_ptr<T, samplesCommon::InferDeleter>;
public:
SampleMNIST(const MNISTSampleParams& params)
: mParams(params)
//! \brief Function builds the network engine
bool build();
//! \brief This function runs the TensorRT inference engine for this sample
bool infer();
//! \brief This function can be used to clean up any state created in the sample class
bool teardown();
private:
//! \brief This function uses a Caffe parser to create the MNIST Network and marks the
//! output layers
void constructNetwork(SampleUniquePtrnvinfer1::IBuilder& builder, SampleUniquePtrnvinfer1::INetworkDefinition& network, SampleUniquePtrnvcaffeparser1::ICaffeParser& parser);
//! \brief Reads the input and mean data, preprocesses, and stores the result in a managed buffer
bool processInput(const samplesCommon::BufferManager& buffers, const std::string& inputTensorName, int inputFileIdx) const;
//! \brief Verifies that the output is correct and prints it
bool verifyOutput(const samplesCommon::BufferManager& buffers, const std::string& outputTensorName, int groundTruthDigit) const;
std::shared_ptr<nvinfer1::ICudaEngine> mEngine = nullptr; //!< The TensorRT engine used to run the network
MNISTSampleParams mParams; //!< The parameters for the sample.
nvinfer1::Dims mInputDims; //!< The dimensions of the input to the network.
SampleUniquePtr<nvcaffeparser1::IBinaryProtoBlob> mMeanBlob; //! the mean blob, which we need to keep around until build is done
//! \brief This function creates the network, configures the builder and creates the network engine
//! \details This function creates the MNIST network by parsing the caffe model and builds
//! the engine that will be used to run MNIST (mEngine)
//! \return Returns true if the engine was created successfully and false otherwise
bool SampleMNIST::build()
auto builder = SampleUniquePtrnvinfer1::IBuilder(nvinfer1::createInferBuilder(gLogger.getTRTLogger()));
if (!builder)
return false;
auto network = SampleUniquePtr<nvinfer1::INetworkDefinition>(builder->createNetwork());
if (!network)
return false;
auto parser = SampleUniquePtr<nvcaffeparser1::ICaffeParser>(nvcaffeparser1::createCaffeParser());
if (!parser)
return false;
constructNetwork(builder, network, parser);
builder->setMaxBatchSize(mParams.batchSize);
builder->setMaxWorkspaceSize(16_MB);
builder->allowGPUFallback(true);
builder->setFp16Mode(mParams.fp16);
builder->setInt8Mode(mParams.int8);
builder->setStrictTypeConstraints(true);
builder->setInt8Calibrator(calibrator.get());
samplesCommon::enableDLA(builder.get(), mParams.dlaCore);
mEngine = std::shared_ptr<nvinfer1::ICudaEngine>(builder->buildCudaEngine(*network), samplesCommon::InferDeleter());
if (!mEngine)
return false;
if (mParams.saveEngine.size() > 0)
std::ofstream p(mParams.saveEngine, std::ios::binary);
if (!p)
return false;
nvinfer1::IHostMemory* ptr = mEngine->serialize();
assert(ptr);
p.write(reinterpret_cast<const char*>(ptr->data()), ptr->size());
ptr->destroy();
assert(network->getNbInputs() == 1);
mInputDims = network->getInput(0)->getDimensions();
assert(mInputDims.nbDims == 3);
return true;
bool SampleMNIST::processInput(const samplesCommon::BufferManager& buffers, const std::string& inputTensorName, int inputFileIdx) const
const int inputH = mInputDims.d[1];
const int inputW = mInputDims.d[2];
// Read a random digit file
srand(unsigned(time(nullptr)));
std::vector<uint8_t> fileData(inputH * inputW);
readPGMFile(locateFile(std::to_string(inputFileIdx) + ".pgm", mParams.dataDirs), fileData.data(), inputH, inputW);
// Print ASCII representation of digit
gLogInfo << "Input:\n";
for (int i = 0; i < inputH * inputW; i++)
gLogInfo << (" .:-=+*#%@"[fileData[i] / 26]) << (((i + 1) % inputW) ? "" : "\n");
gLogInfo << std::endl;
float* hostInputBuffer = static_cast<float*>(buffers.getHostBuffer(inputTensorName));
input: “data”
input_shape {
dim: 1
dim: 3
dim: 300
dim: 300
layer {
type: “Convolution”
bottom: “data”
top: “conv1_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_1”
top: “conv1_1”
layer {
type: “Convolution”
bottom: “conv1_1”
top: “conv1_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_2”
top: “conv1_2”
layer {
type: “Pooling”
bottom: “conv1_2”
top: “pool1”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool1”
top: “conv2_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_1”
top: “conv2_1”
layer {
type: “Convolution”
bottom: “conv2_1”
top: “conv2_2”
param {
lr_mult: 1
decay_mult: 1name: “VGG_VOC0712_SSD_300x300_deploy”
input: “data”
input_shape {
dim: 1
dim: 3
dim: 300
dim: 300
layer {
type: “Convolution”
bottom: “data”
top: “conv1_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_1”
top: “conv1_1”
layer {
type: “Convolution”
bottom: “conv1_1”
top: “conv1_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_2”
top: “conv1_2”
layer {
type: “Pooling”
bottom: “conv1_2”
top: “pool1”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool1”
top: “conv2_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_1”
top: “conv2_1”
layer {
type: “Convolution”
bottom: “conv2_1”
top: “conv2_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_2”
top: “conv2_2”
layer {
type: “Pooling”
bottom: “conv2_2”
top: “pool2”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool2”
top: “conv3_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_1”
top: “conv3_1”
layer {
type: “Convolution”
bottom: “conv3_1”
top: “conv3_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_2”
top: “conv3_2”
layer {
type: “Convolution”
bottom: “conv3_2”
top: “conv3_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_3”
top: “conv3_3”
layer {
type: “Pooling”
bottom: “conv3_3”
top: “pool3”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool3”
top: “conv4_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_1”
top: “conv4_1”
layer {
type: “Convolution”
bottom: “conv4_1”
top: “conv4_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_2”
top: “conv4_2”
layer {
type: “Convolution”
bottom: “conv4_2”
top: “conv4_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_3”
top: “conv4_3”
layer {
type: “Pooling”
bottom: “conv4_3”
top: “pool4”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool4”
top: “conv5_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_1”
top: “conv5_1”
layer {
type: “Convolution”
bottom: “conv5_1”
top: “conv5_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_2”
top: “conv5_2”
layer {
type: “Convolution”
bottom: “conv5_2”
top: “conv5_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_3”
top: “conv5_3”
layer {
type: “Pooling”
bottom: “conv5_3”
top: “pool5”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “pool5”
top: “fc6”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1024
pad: 6
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 6
layer {
type: “ReLU”
bottom: “fc6”
top: “fc6”
layer {
type: “Convolution”
bottom: “fc6”
top: “fc7”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1024
kernel_size: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “fc7”
top: “fc7”
layer {
type: “Convolution”
bottom: “fc7”
top: “conv6_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_1”
top: “conv6_1”
layer {
type: “Convolution”
bottom: “conv6_1”
top: “conv6_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_2”
top: “conv6_2”
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv7_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_1”
top: “conv7_1”
layer {
type: “Convolution”
bottom: “conv7_1”
top: “conv7_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_2”
top: “conv7_2”
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv8_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_1”
top: “conv8_1”
layer {
type: “Convolution”
bottom: “conv8_1”
top: “conv8_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_2”
top: “conv8_2”
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv9_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_1”
top: “conv9_1”
layer {
type: “Convolution”
bottom: “conv9_1”
top: “conv9_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_2”
top: “conv9_2”
layer {
type: “Normalize”
bottom: “conv4_3”
top: “conv4_3_norm”
norm_param {
across_spatial: false
scale_filler {
type: “constant”
value: 20
channel_shared: false
layer {
type: “Convolution”
bottom: “conv4_3_norm”
top: “conv4_3_norm_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv4_3_norm_mbox_loc”
top: “conv4_3_norm_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv4_3_norm_mbox_loc_perm”
top: “conv4_3_norm_mbox_loc_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
top: “conv4_3_norm_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv4_3_norm_mbox_conf”
top: “conv4_3_norm_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv4_3_norm_mbox_conf_perm”
top: “conv4_3_norm_mbox_conf_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “data”
top: “conv4_3_norm_mbox_priorbox”
prior_box_param {
min_size: 30.0
max_size: 60.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 8
offset: 0.5
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “fc7_mbox_loc”
top: “fc7_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “fc7_mbox_loc_perm”
top: “fc7_mbox_loc_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “fc7_mbox_conf”
top: “fc7_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “fc7_mbox_conf_perm”
top: “fc7_mbox_conf_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “fc7”
bottom: “data”
top: “fc7_mbox_priorbox”
prior_box_param {
min_size: 60.0
max_size: 111.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 16
offset: 0.5
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv6_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv6_2_mbox_loc”
top: “conv6_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv6_2_mbox_loc_perm”
top: “conv6_2_mbox_loc_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv6_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv6_2_mbox_conf”
top: “conv6_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv6_2_mbox_conf_perm”
top: “conv6_2_mbox_conf_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv6_2”
bottom: “data”
top: “conv6_2_mbox_priorbox”
prior_box_param {
min_size: 111.0
max_size: 162.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 32
offset: 0.5
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv7_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv7_2_mbox_loc”
top: “conv7_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv7_2_mbox_loc_perm”
top: “conv7_2_mbox_loc_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv7_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv7_2_mbox_conf”
top: “conv7_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv7_2_mbox_conf_perm”
top: “conv7_2_mbox_conf_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv7_2”
bottom: “data”
top: “conv7_2_mbox_priorbox”
prior_box_param {
min_size: 162.0
max_size: 213.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 64
offset: 0.5
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv8_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv8_2_mbox_loc”
top: “conv8_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv8_2_mbox_loc_perm”
top: “conv8_2_mbox_loc_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv8_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv8_2_mbox_conf”
top: “conv8_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv8_2_mbox_conf_perm”
top: “conv8_2_mbox_conf_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv8_2”
bottom: “data”
top: “conv8_2_mbox_priorbox”
prior_box_param {
min_size: 213.0
max_size: 264.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 100
offset: 0.5
layer {
type: “Convolution”
bottom: “conv9_2”
top: “conv9_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv9_2_mbox_loc”
top: “conv9_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv9_2_mbox_loc_perm”
top: “conv9_2_mbox_loc_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv9_2”
top: “conv9_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv9_2_mbox_conf”
top: “conv9_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
bottom: “conv9_2_mbox_conf_perm”
top: “conv9_2_mbox_conf_flat”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv9_2”
bottom: “data”
top: “conv9_2_mbox_priorbox”
prior_box_param {
min_size: 264.0
max_size: 315.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 300
offset: 0.5
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_loc_flat”
bottom: “fc7_mbox_loc_flat”
bottom: “conv6_2_mbox_loc_flat”
bottom: “conv7_2_mbox_loc_flat”
bottom: “conv8_2_mbox_loc_flat”
bottom: “conv9_2_mbox_loc_flat”
top: “mbox_loc”
concat_param {
axis: 1
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_conf_flat”
bottom: “fc7_mbox_conf_flat”
bottom: “conv6_2_mbox_conf_flat”
bottom: “conv7_2_mbox_conf_flat”
bottom: “conv8_2_mbox_conf_flat”
bottom: “conv9_2_mbox_conf_flat”
top: “mbox_conf”
concat_param {
axis: 1
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_priorbox”
bottom: “fc7_mbox_priorbox”
bottom: “conv6_2_mbox_priorbox”
bottom: “conv7_2_mbox_priorbox”
bottom: “conv8_2_mbox_priorbox”
bottom: “conv9_2_mbox_priorbox”
top: “mbox_priorbox”
concat_param {
axis: 2
layer {
type: “Reshape”
bottom: “mbox_conf”
top: “mbox_conf_reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 21
layer {
type: “Softmax”
bottom: “mbox_conf_reshape”
top: “mbox_conf_softmax”
softmax_param {
axis: 2
layer {
type: “Reshape”
bottom: “mbox_conf_softmax”
top: “mbox_conf_flatten”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “DetectionOutput”
bottom: “mbox_loc”
bottom: “mbox_conf_flatten”
bottom: “mbox_priorbox”
top: “detection_out”
include {
phase: TEST
detection_output_param {
num_classes: 21
share_location: true
background_label_id: 0
nms_param {
nms_threshold: 0.45
top_k: 400
save_output_param {
label_map_file: “data/VOC0712/labelmap_voc.prototxt”
code_type: CENTER_SIZE
keep_top_k: 200
confidence_threshold: 0.01
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_2”
top: “conv2_2”
layer {
type: “Pooling”
bottom: “conv2_2”
top: “pool2”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool2”
top: “conv3_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_1”
top: “conv3_1”
layer {
type: “Convolution”
bottom: “conv3_1”
top: “conv3_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_2”
top: “conv3_2”
layer {
type: “Convolution”
bottom: “conv3_2”
top: “conv3_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_3”
top: “conv3_3”
layer {
type: “Pooling”
bottom: “conv3_3”
top: “pool3”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool3”
top: “conv4_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_1”
top: “conv4_1”
layer {
type: “Convolution”
bottom: “conv4_1”
top: “conv4_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_2”
top: “conv4_2”
layer {
type: “Convolution”
bottom: “conv4_2”
top: “conv4_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_3”
top: “conv4_3”
layer {
type: “Pooling”
bottom: “conv4_3”
top: “pool4”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool4”
top: “conv5_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_1”
top: “conv5_1”
layer {
type: “Convolution”
bottom: “conv5_1”
top: “conv5_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_2”
top: “conv5_2”
layer {
type: “Convolution”
bottom: “conv5_2”
top: “conv5_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_3”
top: “conv5_3”
layer {
type: “Pooling”
bottom: “conv5_3”
top: “pool5”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “pool5”
top: “fc6”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1024
pad: 6
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 6
layer {
type: “ReLU”
bottom: “fc6”
top: “fc6”
layer {
type: “Convolution”
bottom: “fc6”
top: “fc7”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1024
kernel_size: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “fc7”
top: “fc7”
layer {
type: “Convolution”
bottom: “fc7”
top: “conv6_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_1”
top: “conv6_1”
layer {
type: “Convolution”
bottom: “conv6_1”
top: “conv6_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_2”
top: “conv6_2”
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv7_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_1”
top: “conv7_1”
layer {
type: “Convolution”
bottom: “conv7_1”
top: “conv7_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_2”
top: “conv7_2”
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv8_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_1”
top: “conv8_1”
layer {
type: “Convolution”
bottom: “conv8_1”
top: “conv8_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_2”
top: “conv8_2”
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv9_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_1”
top: “conv9_1”
layer {
type: “Convolution”
bottom: “conv9_1”
top: “conv9_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_2”
top: “conv9_2”
layer {
type: “Normalize”
bottom: “conv4_3”
top: “conv4_3_norm”
norm_param {
scale_filler {
type: “constant”
value: 20
layer {
type: “Convolution”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “data”
prior_box_param {
min_size: 30.0
max_size: 60.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 8
offset: 0.5
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “fc7”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “fc7”
bottom: “data”
prior_box_param {
min_size: 60.0
max_size: 111.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 16
offset: 0.5
layer {
type: “Convolution”
bottom: “conv6_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv6_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv6_2”
bottom: “data”
prior_box_param {
min_size: 111.0
max_size: 162.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 32
offset: 0.5
layer {
type: “Convolution”
bottom: “conv7_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv7_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv7_2”
bottom: “data”
prior_box_param {
min_size: 162.0
max_size: 213.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 64
offset: 0.5
layer {
type: “Convolution”
bottom: “conv8_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv8_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv8_2”
bottom: “data”
prior_box_param {
min_size: 213.0
max_size: 264.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 100
offset: 0.5
layer {
type: “Convolution”
bottom: “conv9_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “Convolution”
bottom: “conv9_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: “PriorBox”
bottom: “conv9_2”
bottom: “data”
prior_box_param {
min_size: 264.0
max_size: 315.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 300
offset: 0.5
layer {
type: “Concat”
top: “mbox_loc”
concat_param {
axis: 1
layer {
type: “Concat”
top: “mbox_conf”
concat_param {
axis: 1
layer {
type: “Concat”
concat_param {
axis: 2
layer {
type: “Reshape”
bottom: “mbox_conf”
reshape_param {
shape {
dim: 0
dim: -1
dim: 21
layer {
type: “Softmax”
softmax_param {
axis: 2
layer {
type: “Reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
bottom: “mbox_loc”
include {
phase: TEST
num_classes: 21
nms_param {
nms_threshold: 0.45
top_k: 400
save_output_param {
keep_top_k: 200
hostInputBuffer[i] = float(fileData[i]);
return true;
bool SampleMNIST::verifyOutput(const samplesCommon::BufferManager& buffers, const std::string& outputTensorName, int groundTruthDigit) const
const float* prob = static_cast<const float*>(buffers.getHostBuffer(outputTensorName));
// Print histogram of the output distribution
gLogInfo << "Output:\n";
float val{0.0f};
int idx{0};
for (unsigned int i = 0; i < 10; i++)
val = std::max(val, prob[i]);
if (val == prob[i])
idx = i;
gLogInfo << i << ": " << std::string(int(std::floor(prob[i] * 10 + 0.5f)), '*') << "\n";
return (idx == groundTruthDigit && val > 0.9f);
//! \brief This function uses a caffe parser to create the MNIST Network and marks the
//! output layers
//! \param network Pointer to the network that will be populated with the MNIST network
//! \param builder Pointer to the engine builder
void SampleMNIST::constructNetwork(SampleUniquePtrnvinfer1::IBuilder& builder, SampleUniquePtrnvinfer1::INetworkDefinition& network, SampleUniquePtrnvcaffeparser1::ICaffeParser& parser)
const nvcaffeparser1::IBlobNameToTensor* blobNameToTensor = parser->parse(
locateFile(mParams.prototxtFileName, mParams.dataDirs).c_str(),
locateFile(mParams.weightsFileName, mParams.dataDirs).c_str(),
*network,
nvinfer1::DataType::kFLOAT);
for (auto& s : mParams.outputTensorNames)
network->markOutput(*blobNameToTensor->find(s.c_str()));
// add mean subtraction to the beginning of the network
Dims inputDims = network->getInput(0)->getDimensions();
mMeanBlob = SampleUniquePtr<nvcaffeparser1::IBinaryProtoBlob>(parser->parseBinaryProto(locateFile(mParams.meanFileName, mParams.dataDirs).c_str()));
Weights meanWeights{DataType::kFLOAT, mMeanBlob->getData(), inputDims.d[1] * inputDims.d[2]};
// For this sample, a large range based on the mean data is chosen and applied to the entire network.
// The preferred method is use scales computed based on a representative data set
// and apply each one individually based on the tensor. The range here is large enough for the
// network, but is chosen for example purposes only.
float maxMean = samplesCommon::getMaxValue(static_cast<const float*>(meanWeights.values), samplesCommon::volume(inputDims));
auto mean = network->addConstant(Dims3(1, inputDims.d[1], inputDims.d[2]), meanWeights);
auto meanSub = network->addElementWise(*network->getInput(0), *mean->getOutput(0), ElementWiseOperation::kSUB);
network->getLayer(0)->setInput(0, *meanSub->getOutput(0));
samplesCommon::setAllTensorScales(network.get(), maxMean, maxMean);
//! \details This function is the main execution function of the sample. It allocates
//! the buffer, sets inputs, executes the engine, and verifies the output.
bool SampleMNIST::infer()
// Create RAII buffer manager object
samplesCommon::BufferManager buffers(mEngine, mParams.batchSize);
auto context = SampleUniquePtr<nvinfer1::IExecutionContext>(mEngine->createExecutionContext());
if (!context)
return false;
// Pick a random digit to try to infer
srand(time(NULL));
const int digit = rand() % 10;
// Read the input data into the managed buffers
// There should be just 1 input tensor
assert(mParams.inputTensorNames.size() == 1);
if (!processInput(buffers, mParams.inputTensorNames[0], digit))
return false;
// Create CUDA stream for the execution of this inference.
cudaStream_t stream;
CHECK(cudaStreamCreate(&stream));
// Asynchronously copy data from host input buffers to device input buffers
buffers.copyInputToDeviceAsync(stream);
// Asynchronously enqueue the inference work
if (!context->enqueue(mParams.batchSize, buffers.getDeviceBindings().data(), stream, nullptr))
return false;
// Asynchronously copy data from device output buffers to host output buffers
buffers.copyOutputToHostAsync(stream);
// Wait for the work in the stream to complete
cudaStreamSynchronize(stream);
// Release stream
cudaStreamDestroy(stream);
// Check and print the output of the inference
// There should be just one output tensor
assert(mParams.outputTensorNames.size() == 1);
bool outputCorrect = verifyOutput(buffers, mParams.outputTensorNames[0], digit);
return outputCorrect;
bool SampleMNIST::teardown()
//! Clean up the libprotobuf files as the parsing is complete
//! \note It is not safe to use any other part of the protocol buffers library after
//! ShutdownProtobufLibrary() has been called.
nvcaffeparser1::shutdownProtobufLibrary();
return true;
//! \brief This function initializes members of the params struct using the command line args
MNISTSampleParams initializeSampleParams(const samplesCommon::Args& args)
MNISTSampleParams params;
if (args.dataDirs.size() != 0) //!< Use the data directory provided by the user
params.dataDirs = args.dataDirs;
else //!< Use default directories if user hasn’t provided directory paths
params.dataDirs.push_back(“data/mnist/”);
params.dataDirs.push_back(“data/samples/mnist/”);
params.prototxtFileName = “mnist.prototxt”;
params.weightsFileName = “mnist.caffemodel”;
params.meanFileName = “mnist_mean.binaryproto”;
params.inputTensorNames.push_back(“data”);
params.batchSize = 1;
params.outputTensorNames.push_back(“prob”);
params.dlaCore = args.useDLACore;
params.int8 = args.runInInt8;
params.fp16 = args.runInFp16;
params.saveEngine = args.saveEngine;
return params;
//! \brief This function prints the help information for running this sample
void printHelpInfo()
std::cout << “Usage: ./sample_mnist [-h or --help] [-d or --datadir=] [–useDLACore=]\n”;
std::cout << “–help Display help information\n”;
std::cout << “–datadir Specify path to a data directory, overriding the default. This option can be used multiple times to add multiple directories. If no data directories are given, the default is to use (data/samples/mnist/, data/mnist/)” << std::endl;
std::cout << “–useDLACore=N Specify a DLA engine for layers that support DLA. Value can range from 0 to n-1, where n is the number of DLA engines on the platform.” << std::endl;
std::cout << “–int8 Run in Int8 mode.\n”;
std::cout << “–fp16 Run in FP16 mode.\n”;
int main(int argc, char** argv)
samplesCommon::Args args;
bool argsOK = samplesCommon::parseArgs(args, argc, argv);
if (args.help)
printHelpInfo();
return EXIT_SUCCESS;
if (!argsOK)
gLogError << “Invalid arguments” << std::endl;
printHelpInfo();
return EXIT_FAILURE;
auto sampleTest = gLogger.defineTest(gSampleName, argc, const_cast<const char**>(argv));
gLogger.reportTestStart(sampleTest);
MNISTSampleParams params = initializeSampleParams(args);
SampleMNIST sample(params);
gLogInfo << "Building and running a GPU inference engine for MNIST" << std::endl;
if (!sample.build())
return gLogger.reportFail(sampleTest);
if (!sample.infer())
if (!sample.teardown())
return gLogger.reportPass(sampleTest);
