Description
I am trying to execute sampleSSD from /usr/src/tensorrt/sample/sampleSSD folder.
I have made the changes specified inthe README file as:
replaced type: Flatten → Reshape
replaced flatten_param { … } → reshape_param{…}
also replaced detect_out top: with keep_count.
But I am getting this error.
Can someone throw some suggestion to it to make it work.
&&&& RUNNING TensorRT.sample_ssd # ./sample_ssd
[05/08/2020-11:45:45] [I] Building and running a GPU inference engine for SSD
Plugin layer output count is not equal to caffe output count
If i do not chnage anything in deploy.prototxt, I am gettin this error.
[05/08/2020-12:36:04] [I] Building and running a GPU inference engine for SSD
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
[05/08/2020-12:36:05] [E] [TRT] mbox_loc: all concat input tensors must have the same dimensions except on the concatenation axis (0), but dimensions mismatched at input 1 at index 1. Input 0 shape: [38,38,16], Input 1 shape: [19,19,24]
[05/08/2020-12:36:05] [E] [TRT] mbox_conf: all concat input tensors must have the same dimensions except on the concatenation axis (0), but dimensions mismatched at input 1 at index 1. Input 0 shape: [38,38,84], Input 1 shape: [19,19,126]
Caffe Parser: Invalid axis in softmax layer - TensorRT expects NCHW input. Negative axis is not supported in TensorRT, please use positive axis indexing
error parsing layer type Softmax index 98
Thank you
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Here is the file:
ssd.prototxt
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
