The following error in attached screenshot is coming while using Tensorrt. Kindly help. Also I want to save the serialized engine to be used in Deepstream
**• Hardware Platform (Jetson / GPU)**T4
• DeepStream Version 4.0
• TensorRT Version 5.1.5
@GalibaSashi
Please share us your caffemodel , especially the prototxt file.
Sharing the file How do i share the model and prototxt to you as I cannot attach the same. I have pasted the prototxt to you.
input: “data”
input_shape {
dim: 1
dim: 3
dim: 300
dim: 300
layer {
type: “Convolution”
bottom: “data”
top: “conv1_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_1”
top: “conv1_1”
layer {
type: “Convolution”
bottom: “conv1_1”
top: “conv1_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_2”
top: “conv1_2”
layer {
type: “Pooling”
bottom: “conv1_2”
top: “pool1”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool1”
top: “conv2_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_1”
top: “conv2_1”
layer {
type: “Convolution”
bottom: “conv2_1”
top: “conv2_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_2”
top: “conv2_2”
layer {
type: “Pooling”
bottom: “conv2_2”
top: “pool2”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool2”
top: “conv3_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_1”
top: “conv3_1”
layer {
type: “Convolution”
bottom: “conv3_1”
top: “conv3_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_2”
top: “conv3_2”
layer {
type: “Convolution”
bottom: “conv3_2”
top: “conv3_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_3”
top: “conv3_3”
layer {
type: “Pooling”
bottom: “conv3_3”
top: “pool3”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool3”
top: “conv4_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_1”
top: “conv4_1”
layer {
type: “Convolution”
bottom: “conv4_1”
top: “conv4_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_2”
top: “conv4_2”
layer {
type: “Convolution”
bottom: “conv4_2”
top: “conv4_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_3”
top: “conv4_3”
layer {
type: “Pooling”
bottom: “conv4_3”
top: “pool4”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool4”
top: “conv5_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_1”
top: “conv5_1”
layer {
type: “Convolution”
bottom: “conv5_1”
top: “conv5_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_2”
top: “conv5_2”
layer {
type: “Convolution”
bottom: “conv5_2”
top: “conv5_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 1
layer {
type: “ReLU”
bottom: “conv5_3”
top: “conv5_3”
layer {
type: “Pooling”
bottom: “conv5_3”
top: “pool5”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “pool5”
top: “fc6”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1024
pad: 6
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
dilation: 6
layer {
type: “ReLU”
bottom: “fc6”
top: “fc6”
layer {
type: “Convolution”
bottom: “fc6”
top: “fc7”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1024
kernel_size: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “fc7”
top: “fc7”
layer {
type: “Convolution”
bottom: “fc7”
top: “conv6_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_1”
top: “conv6_1”
layer {
type: “Convolution”
bottom: “conv6_1”
top: “conv6_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_2”
top: “conv6_2”
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv7_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_1”
top: “conv7_1”
layer {
type: “Convolution”
bottom: “conv7_1”
top: “conv7_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_2”
top: “conv7_2”
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv8_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_1”
top: “conv8_1”
layer {
type: “Convolution”
bottom: “conv8_1”
top: “conv8_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_2”
top: “conv8_2”
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv9_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_1”
top: “conv9_1”
layer {
type: “Convolution”
bottom: “conv9_1”
top: “conv9_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_2”
top: “conv9_2”
layer {
type: “Normalize”
bottom: “conv4_3”
top: “conv4_3_norm”
norm_param {
across_spatial: false
scale_filler {
type: “constant”
value: 20
channel_shared: false
layer {
type: “Convolution”
bottom: “conv4_3_norm”
top: “conv4_3_norm_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv4_3_norm_mbox_loc”
top: “conv4_3_norm_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv4_3_norm_mbox_loc_perm”
top: “conv4_3_norm_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
top: “conv4_3_norm_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv4_3_norm_mbox_conf”
top: “conv4_3_norm_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv4_3_norm_mbox_conf_perm”
top: “conv4_3_norm_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “data”
top: “conv4_3_norm_mbox_priorbox”
prior_box_param {
min_size: 30.0
max_size: 60.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 8
offset: 0.5
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “fc7_mbox_loc”
top: “fc7_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “fc7_mbox_loc_perm”
top: “fc7_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “fc7_mbox_conf”
top: “fc7_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “fc7_mbox_conf_perm”
top: “fc7_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “fc7”
bottom: “data”
top: “fc7_mbox_priorbox”
prior_box_param {
min_size: 60.0
max_size: 111.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 16
offset: 0.5
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv6_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv6_2_mbox_loc”
top: “conv6_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv6_2_mbox_loc_perm”
top: “conv6_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv6_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv6_2_mbox_conf”
top: “conv6_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv6_2_mbox_conf_perm”
top: “conv6_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv6_2”
bottom: “data”
top: “conv6_2_mbox_priorbox”
prior_box_param {
min_size: 111.0
max_size: 162.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 32
offset: 0.5
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv7_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv7_2_mbox_loc”
top: “conv7_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv7_2_mbox_loc_perm”
top: “conv7_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv7_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv7_2_mbox_conf”
top: “conv7_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv7_2_mbox_conf_perm”
top: “conv7_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv7_2”
bottom: “data”
top: “conv7_2_mbox_priorbox”
prior_box_param {
min_size: 162.0
max_size: 213.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 64
offset: 0.5
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv8_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv8_2_mbox_loc”
top: “conv8_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv8_2_mbox_loc_perm”
top: “conv8_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv8_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv8_2_mbox_conf”
top: “conv8_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv8_2_mbox_conf_perm”
top: “conv8_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv8_2”
bottom: “data”
top: “conv8_2_mbox_priorbox”
prior_box_param {
min_size: 213.0
max_size: 264.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 100
offset: 0.5
layer {
type: “Convolution”
bottom: “conv9_2”
top: “conv9_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv9_2_mbox_loc”
top: “conv9_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv9_2_mbox_loc_perm”
top: “conv9_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv9_2”
top: “conv9_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv9_2_mbox_conf”
top: “conv9_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv9_2_mbox_conf_perm”
top: “conv9_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv9_2”
bottom: “data”
top: “conv9_2_mbox_priorbox”
prior_box_param {
min_size: 264.0
max_size: 315.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 300
offset: 0.5
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_loc_flat”
bottom: “fc7_mbox_loc_flat”
bottom: “conv6_2_mbox_loc_flat”
bottom: “conv7_2_mbox_loc_flat”
bottom: “conv8_2_mbox_loc_flat”
bottom: “conv9_2_mbox_loc_flat”
top: “mbox_loc”
concat_param {
axis: 1
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_conf_flat”
bottom: “fc7_mbox_conf_flat”
bottom: “conv6_2_mbox_conf_flat”
bottom: “conv7_2_mbox_conf_flat”
bottom: “conv8_2_mbox_conf_flat”
bottom: “conv9_2_mbox_conf_flat”
top: “mbox_conf”
concat_param {
axis: 1
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_priorbox”
bottom: “fc7_mbox_priorbox”
bottom: “conv6_2_mbox_priorbox”
bottom: “conv7_2_mbox_priorbox”
bottom: “conv8_2_mbox_priorbox”
bottom: “conv9_2_mbox_priorbox”
top: “mbox_priorbox”
concat_param {
axis: 2
layer {
type: “Reshape”
bottom: “mbox_conf”
top: “mbox_conf_reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 21
layer {
type: “Softmax”
bottom: “mbox_conf_reshape”
top: “mbox_conf_softmax”
softmax_param {
axis: 2
layer {
type: “Flatten”
bottom: “mbox_conf_softmax”
top: “mbox_conf_flatten”
flatten_param {
axis: 1
layer {
type: “DetectionOutput”
bottom: “mbox_loc”
bottom: “mbox_conf_flatten”
bottom: “mbox_priorbox”
top: “detection_out”
include {
phase: TEST
detection_output_param {
num_classes: 21
share_location: true
background_label_id: 0
nms_param {
nms_threshold: 0.45
top_k: 400
save_output_param {
label_map_file: “data/VOC0712/labelmap_voc.prototxt”
code_type: CENTER_SIZE
keep_top_k: 200
confidence_threshold: 0.01
@GalibaSashi
Since we will no longer add new fixes to tensorRT’s caffe parser, one quick workaround is to replace all flatten layers with reshape layers.
For example, if flatten is to convert (b, c, h, w) into (b, c * h * w) , then the alternative reshape layer could do something similar like this to convert (b, c, h, w) into (b, c * h * w, 1, 1) :
layer {
type: "Reshape"
bottom: "conv4_3_norm_mbox_loc_perm"
top: "conv4_3_norm_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
Hi @ersheng ,
So in 5.0 can we directly give .caffemodel and .prototxt in the NVINFER_config.txt. Are you suggesting to us to move to 5.0
@GalibaSashi
You can move to DS 5.0, but TensorRT in DS 5.0 does not support caffe flatten layers either.
There will be no longer new fixes for CAFFE parser. ONNX parser will be main support in the future.
You can convert caffemodel into engine separately with trtexec in your current setup, and then give location of engine file to the nvinfer config.
ersheng:
trtexec
How do we use the trtexec can you share a link?
/usr/src/tensorrt/bin/trtexec
Hi @ersheng ,
Can you please give or suggest what command in /usr/src/tensorrt/bin/trtexec we should use or a similar example to convert the caffemodel as reference.
Do you mean trtexec --deploy=/path/to/mnist.prototxt --model=/path/to/mnist.caffemodel --output=prob --batch=16 --saveEngine=mnist16.trt
Thanks in advance
Yes, you can try this command
Hi @ersheng ,
ersheng:
Reshape
sudo ./trtexec --deploy=/usr/src/tensorrt/data/ssd/ssd.prototxt --model=/usr/src/tensorrt/data/ssd/VGG_VOC0712_SSD_300x300_iter_120000.caffemodel --output=detection_out --batch=16 --saveEngine=mnist16.trt
&&&& RUNNING TensorRT.trtexec # ./trtexec --deploy=/usr/src/tensorrt/data/ssd/ssd.prototxt --model=/usr/src/tensorrt/data/ssd/VGG_VOC0712_SSD_300x300_iter_120000.caffemodel --output=detection_out --batch=16 --saveEngine=mnist16.trt
[I] deploy: /usr/src/tensorrt/data/ssd/ssd.prototxt
[I] model: /usr/src/tensorrt/data/ssd/VGG_VOC0712_SSD_300x300_iter_120000.caffemodel
[I] output: detection_out
[I] batch: 16
[I] saveEngine: mnist16.trt
Plugin layer output count is not equal to caffe output count
[E] Engine could not be created
&&&& FAILED TensorRT.trtexec # ./trtexec --deploy=/usr/src/tensorrt/data/ssd/ssd.prototxt --model=/usr/src/tensorrt/data/ssd/VGG_VOC0712_SSD_300x300_iter_120000.caffemodel --output=detection_out --batch=16 --saveEngine=mnist16.trt
This is the error we got after following your given steps.Kindly help us out.
Thanks in advance.
@GalibaSashi
Do you mind sharing us both the prototxt and caffemodel so that we can reproduce it.
You can share via google drive.
Hi @ersheng ,
I had solved it.It was due to incorrect output layers.
But can you help me in telling me if this batch size given in trtexec command will affect the performance in Deepstream when taking the engine.
@GalibaSashi
Batch size configuration in DeepStream should agree with batch size of TRT engine.
There may be error otherwise.
Larger batch size may improve speed of inference in both TRT standalone and DS pipeline scenarios.
But optimal batch size will vary depending on what DL model you are using and what hardware you are working on.
For example, optimal batch size for YoloV3 and YoloV4 may be around 8 ~ 16 for TRT standalone.
Hi @ersheng ,
When you mean batch size configuration in DeepStream do you mean batch size of NVstreammux and NVInFER plugin or just the NVINFER plugin?
Thanks in advance
@GalibaSashi Both of them
I recommend to configure the same batch size for NVstreammux and NvInfer even though they allow different values.
Hi @ersheng , @kayccc ,
Kindly give me your help in parsing a normal ssd model where model can be generated in trtexec but parsing of this model cannot be done in deepstream.
sudo deepstream-app -c deepstream_app_config_ssd.txt
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1408 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/ssd_trt2.trt open error
0:00:00.975582342 2951 0x55ceb4698c90 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1566> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/ssd_trt2.trt failed
0:00:00.975630861 2951 0x55ceb4698c90 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1673> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/ssd_trt2.trt failed, try rebuild
0:00:00.975644022 2951 0x55ceb4698c90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
Warning, setting batch size to 1. Update the dimension after parsing due to using explicit batch size.
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: conv4_3_norm: PluginV2Layer must be V2Ext or V2IOExt or V2DynamicExt when there is no implicit batch dimension.
deepstream-app: ./parserHelper.h:99: nvinfer1::DimsCHW parserhelper::getCHW(const nvinfer1::Dims&): Assertion `d.nbDims >= 3’ failed.
Aborted
