resnet10.caffemodel_b8_fp16.engine is optimized for
I’ve understood that DeepStream sample app allows high-speed inference.
So I’m investigating “source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt” settings.
[primary-gie]
model-engine-file = … / … / models / Primary_Detector_Nano / resnet10.caffemodel_b8_fp16.engine
Here, the model called resnet10.caffemodel_b8_fp16.engine is optimized for “Only DeepStream” ?
Can’t use this model, as in the Jetson Inference example (detectnet-camera.py)?
(Python bindings for DeepStream currently state that all image frames cannot be obtained.
】 I received an answer that the corresponding version has not yet been released.
https://devtalk.nvidia.com/default/topic/1068306/deepstream-sdk/fail-to-get-frame-in-tensor-metadata/post/5412437/#5412437
Therefore, I want to use it together with the conventional image frame acquisition method)
You can use this engine in other application which run on the same platform and Jetpack version, and you need have the same pre-precess and post-process as DeepStream is doing for this model.
Thank you.
I can’t understand what you mean by “the same pre-precess and post-process as DeepStream is doing for this model”.
But I saw a similar question,
I tried the following command, but it is “Segmentation fault (core dumped)” output on the console.
Is something wrong?
https://devtalk.nvidia.com/default/topic/1027623/jetson-tx2/pretrained-models-for-detectnet-vehicles/
(* I’ve copied “Primary_Detector_Nano” from DeepStream to ~/jetson-inference/data/networks/…)
Below is log…--------------------------------------------------------------------------------------------
user-desktop:~/jetson-inference/python/examples$ python3 detectnet-console.py city_0.jpg test.jpg --prototxt=…/…/data/networks/Primary_Detector_Nano/resnet10.prototxt --model=…/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel
jetson.inference.init.py
jetson.inference – initializing Python 3.6 bindings…
jetson.inference – registering module types…
jetson.inference – done registering module types
jetson.inference – done Python 3.6 binding initialization
jetson.utils.init.py
jetson.utils – initializing Python 3.6 bindings…
jetson.utils – registering module functions…
jetson.utils – done registering module functions
jetson.utils – registering module types…
jetson.utils – done registering module types
jetson.utils – done Python 3.6 binding initialization
[image] loaded ‘city_0.jpg’ (1024 x 512, 3 channels)
jetson.inference – PyTensorNet_New()
jetson.inference – PyDetectNet_Init()
jetson.inference – detectNet loading network using argv command line params
jetson.inference – detectNet.init() argv[0] = ‘detectnet-console.py’
jetson.inference – detectNet.init() argv[1] = ‘city_0.jpg’
jetson.inference – detectNet.init() argv[2] = ‘test.jpg’
jetson.inference – detectNet.init() argv[3] = ‘–prototxt=…/…/data/networks/Primary_Detector_Nano/resnet10.prototxt’
jetson.inference – detectNet.init() argv[4] = ‘–model=…/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel’
detectNet – loading detection network model from:
– prototxt …/…/data/networks/Primary_Detector_Nano/resnet10.prototxt
– model …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel
– input_blob ‘data’
– output_cvg ‘coverage’
– output_bbox ‘bboxes’
– mean_pixel 0.000000
– mean_binary NULL
– class_labels NULL
– threshold 0.500000
– batch_size 1
[TRT] TensorRT version 5.1.6
[TRT] loading NVIDIA plugins…
[TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[TRT] Plugin Creator registration succeeded - NMS_TRT
[TRT] Plugin Creator registration succeeded - Reorg_TRT
[TRT] Plugin Creator registration succeeded - Region_TRT
[TRT] Plugin Creator registration succeeded - Clip_TRT
[TRT] Plugin Creator registration succeeded - LReLU_TRT
[TRT] Plugin Creator registration succeeded - PriorBox_TRT
[TRT] Plugin Creator registration succeeded - Normalize_TRT
[TRT] Plugin Creator registration succeeded - RPROI_TRT
[TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel.1.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
[TRT] device GPU, loading …/…/data/networks/Primary_Detector_Nano/resnet10.prototxt …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel
[TRT] failed to retrieve tensor for Output “coverage”
[TRT] failed to retrieve tensor for Output “bboxes”
Pre-preocess means the operations like resize, substract mean, etc.
Post-precess means the output parser.
There is not “coverage” and “bboxes” layers in resnet10.prototxt
Thank you mchi.
I added below option (from “resnet10.prototxt”)
–output_cvg=‘conv2d_cov’
–output_bbox=‘conv2d_bbox’
user-desktop:~/jetson-inference/python/examples$ python3 detectnet-console.py city_0.jpg test.jpg --prototxt=…/…/data/networks/Primary_Detector_Nano/resnet10.prototxt --model=…/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel --output_cvg=‘conv2d_cov’ --output_bbox=‘conv2d_bbox’
Then, Segmentation fault has been resolved.
However another error was printed.
jetson.inference – detectNet failed to load built-in network ‘ssd-mobilenet-v2’
Why ‘ssd-mobilenet-v2’?
[TRT] device GPU, …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 3 bindings
[TRT] binding – index 0
– name ‘input_1’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (CHANNEL)
– dim #1 272 (SPATIAL)
– dim #2 480 (SPATIAL)
[TRT] binding – index 1
– name ‘conv2d_bbox’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 16 (CHANNEL)
– dim #1 17 (SPATIAL)
– dim #2 30 (SPATIAL)
[TRT] binding – index 2
– name ‘conv2d_cov’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 4 (CHANNEL)
[TRT] binding to input 0 data binding index: -1
[TRT] binding to input 0 data dims (b=1 c=0 h=0 w=0) size=0
[TRT] failed to alloc CUDA mapped memory for tensor input, 0 bytes
detectNet – failed to initialize.
PyTensorNet_Dealloc()
File “detectnet-console.py”, line 51, in
net = jetson.inference.detectNet(opt.network, sys.argv, opt.threshold)
Exception: jetson.inference – detectNet failed to load network
jetson.utils – freeing CUDA mapped memory
I think it should be from detectnet-console.py, please look into the code.
I understand the cause. I did not specify ‘ssd-mobilenet-v2’ in the source,
but it could not load the specified “resnet10.caffemodel” so it was trying to read the default instead…
I was able to run “detectnet-console.py” improving with the below parameters.
      -- input_blob   'input_1'
      -- output_cvg   'conv2d_cov/Sigmoid'
      -- output_bbox  'conv2d_bbox'
…But the results obtained are useless…
I detected attached ‘city_0.jpg’, but detects (2016 meaningless bbox)
Why is this?
jetson.inference – detectNet.init() argv[5] = ‘–output_cvg=conv2d_cov/Sigmoid’
jetson.inference – detectNet.init() argv[6] = ‘–output_bbox=conv2d_bbox’
jetson.inference – detectNet.init() argv[7] = ‘–input_blob=input_1’
– input_blob ‘input_1’
– output_cvg ‘conv2d_cov/Sigmoid’
– output_bbox ‘conv2d_bbox’
– mean_binary NULL
– class_labels NULL
– batch_size 1
[TRT] retrieved Output tensor “conv2d_cov/Sigmoid”: 4x17x30
[TRT] retrieved Output tensor “conv2d_bbox”: 16x17x30
[TRT] retrieved Input tensor “input_1”: 3x272x480
detected 2016 objects in image
<detectNet.Detection object>
– ClassID: 0
– Confidence: 24.5156
– Left: 2.13333
– Top: 4.46564e-09
– Right: 0.747566
– Bottom: 0.00201247
– Width: -1.38577
– Height: 0.00201247
– Area: -0.00278881
– Center: (1.44045, 0.00100624)
************************************************Omission (There are 2014 useless objects with no size)
– ClassID: 3
– Confidence: 10.3906
– Left: 991.679
– Top: 481.882
– Right: 989.867
– Bottom: 481.882
– Width: -1.81195
– Height: 0
– Area: -0
– Center: (990.773, 481.882)
[TRT] device GPU, configuring CUDA engine
[TRT] device GPU, building FP16: ON
[TRT] device GPU, building INT8: OFF
[TRT] device GPU, building CUDA engine (this may take a few minutes the first time a network is loaded)
[TRT] device GPU, completed building CUDA engine
[TRT] network profiling complete, writing engine cache to …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel.1.1.GPU.FP16.engine
[TRT] device GPU, completed writing engine cache to …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel.1.1.GPU.FP16.engine
– name ‘input_1’
– type FP32
– in/out INPUT
– # dims 3
– type FP32
– in/out OUTPUT
– # dims 3
– name ‘conv2d_cov/Sigmoid’
– type FP32
– in/out OUTPUT
– # dims 3
[TRT] binding to input 0 input_1 binding index: 0
[TRT] binding to input 0 input_1 dims (b=1 c=3 h=272 w=480) size=1566720
[TRT] binding to output 0 conv2d_cov/Sigmoid binding index: 2
[TRT] binding to output 0 conv2d_cov/Sigmoid dims (b=1 c=4 h=17 w=30) size=8160
[TRT] binding to output 1 conv2d_bbox binding index: 1
[TRT] binding to output 1 conv2d_bbox dims (b=1 c=16 h=17 w=30) size=32640
device GPU, …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel initialized.
detectNet – number object classes: 4
detectNet – maximum bounding boxes: 2040
[cuda] cudaDetectionOverlay((float4*)input, (float4*)output, width, height, detections, numDetections, (float4*)mClassColors[1])
[cuda] invalid configuration argument (error 9) (hex 0x09)
[cuda] /home/gk40002251/jetson-inference/c/detectNet.cpp:945
[TRT] detectNet::Detect() – failed to render overlay
[TRT] ------------------------------------------------
[TRT] Timing Report …/…/data/networks/Primary_Detector_Nano/resnet10.caffemodel
[TRT] Pre-Process CPU 0.12172ms CUDA 0.80625ms
[TRT] Network CPU 20.92214ms CUDA 20.25526ms
[TRT] Post-Process CPU 166.44992ms CUDA 166.67921ms
[cuda] cudaEventElapsedTime(&cuda_time, mEventsGPU[evt], mEventsGPU[evt+1])
[cuda] invalid resource handle (error 33) (hex 0x21)
[cuda] /home/gk40002251/jetson-inference/build/aarch64/include/jetson-inference/tensorNet.h:499
[TRT] Visualize CPU 0.00000ms CUDA 0.00000ms
[TRT] Total CPU 187.49377ms CUDA 187.74072ms
[TRT] note – when processing a single image, run ‘sudo jetson_clocks’ before
to disable DVFS for more accurate profiling/timing measurements
jetson.inference – PyDetection_Dealloc()
************************************************Omission(Large amount of Dealloc)
As I mentioned previously, have you added the same pre-precess and post-process as DeepStream does for ResNet10?
If you use the post-precess/parser of ssd-mobilenet-v2 to parse the output of ResNet10, I don’t think it will work.
1.About pre-process
Examining the DeepStream pre-process (https://www.nvidia.com/content/apac/gtc/ja/pdf/2018/1025.pdf) 34 pages, sorry in Japanese
“YUV” data is passed from the stage preceding the inferring nvinfer.
I think it is a specification to infer “YUV” data.
So,Using Img (RGBA)data read by jetson.utils.loadImageRGBA of detectnet-console.py
net.Detect (img, width, height, opt.overlay) doesn’t work.
You say
Have you added the same pre-precess and post-process as DeepStream does for ResNet10?
That said, I read the source of net.Detect, but it seems that RGBA is expected to come
I think it is necessary to detect it using YUV internally using cudaRGBAToYUV etc.
Do I have to make PyDetectNet.cpp myself to convert to YUV?
jetson-inference / python / bindings / PyDetectNet.cpp
If so, it is not so easy. .
  1. About post-process
I think that post-process / parser processing is done by below setting.
Correct?
(This value is obtained from output-blob-names of “dstest1_pgie_config.txt”
Output-blob-names = conv2d_bbox; conv2d_cov / Sigmoid)
-output_cvg ‘conv2d_cov / Sigmoid’
-output_bbox ‘conv2d_bbox’
Hi
Sorry for late response!
Fime: /opt/nvidia/deepstream/deepstream-4.0/sources/libs/nvdsinfer/nvdsinfer_context_impl_output_parsing.cpp
Pre-process function:
NvDsInferContextImpl::queueInputBatch(NvDsInferContextBatchInput &batchInput)
In this function, it calls convertFcn() to do data formation conversion, substract mean value, etc.
Post-process function:
NvDsInferContextImpl::dequeueOutputBatch(NvDsInferContextBatchOutput &batchOutput)
In this function, it calls the BBOX parser function to parse the BBOX.
You could add prints in these two functons and run deepstream-test1 to check how Pre-process and Post-process are going.
