I didn’t run the python script, I implemented the function in another script with no args (values to pass are in the script).
I also made some changes in the library, I will upload the files soon.
// Init
static int PyDetectNet_Init( PyDetectNet_Object* self, PyObject *args, PyObject *kwds )
LogDebug(LOG_PY_INFERENCE “PyDetectNet_Init()\n”);
// parse arguments
PyObject* argList = NULL;
const char* network = “ssd-mobilenet-v2”;
float threshold = DETECTNET_DEFAULT_THRESHOLD;
const char* precision = “FP16”;
// precisionType PrecisionType=TYPE_FP32;
const char* device = “GPU”;
// deviceType DeviceType = DEVICE_GPU;
int allowGPUFallback = false;
static char* kwlist = {“network”, “threshold”, “precision”, “device”, “allowGPUFallback”, NULL};
// |sOf
if( !PyArg_ParseTupleAndKeywords(args, kwds, “|sfssp”, kwlist, &network, &threshold, &precision, &device, &allowGPUFallback))
PyErr_SetString(PyExc_Exception, LOG_PY_INFERENCE “detectNet.init() failed to parse args tuple”);
printf("%s\n", network);
printf("%f\n", threshold);
printf("%s\n", precision);
printf("%s\n", device);
// printf("%b\n", allowGPUFallback);
return -1;
LogVerbose(LOG_PY_INFERENCE “detectNet loading build-in network ‘%s’\n”, network);
// parse the selected built-in network
detectNet::NetworkType networkType = detectNet::NetworkTypeFromStr(network);
uint32_t maxBatchSize=DEFAULT_MAX_BATCH_SIZE;
precisionType precision_type = precisionTypeFromStr(precision);
deviceType device_type = deviceTypeFromStr(device);
// bool allowGPUFallback=true;
if( networkType == detectNet::CUSTOM )
PyErr_SetString(PyExc_Exception, LOG_PY_INFERENCE “detectNet invalid built-in network was requested”);
printf(LOG_PY_INFERENCE “detectNet invalid built-in network was requested (’%s’)\n”, network);
return -1;
// load the built-in network
// self->net = detectNet::Create(networkType, threshold, maxBatchSize, precision_type, device_type, allowGPUFallback);
// confirm the network loaded
if( !self->net )
PyErr_SetString(PyExc_Exception, LOG_PY_INFERENCE “detectNet failed to load network”);
LogError(LOG_PY_INFERENCE “detectNet failed to load network\n”);
return -1;
self->base.net = self->net;
return 0;
detectNet* detectNet::Create( NetworkType networkType, float threshold, uint32_t maxBatchSize,
precisionType precision, deviceType device, bool allowGPUFallback )
#if 1
if( networkType == PEDNET_MULTI )
return Create(“networks/multiped-500/deploy.prototxt”, “networks/multiped-500/snapshot_iter_178000.caffemodel”, 117.0f, “networks/multiped-500/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else if( networkType == FACENET )
return Create(“networks/facenet-120/deploy.prototxt”, “networks/facenet-120/snapshot_iter_24000.caffemodel”, 0.0f, “networks/facenet-120/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else if( networkType == PEDNET )
return Create(“networks/ped-100/deploy.prototxt”, “networks/ped-100/snapshot_iter_70800.caffemodel”, 0.0f, “networks/ped-100/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else if( networkType == COCO_AIRPLANE )
return Create(“networks/DetectNet-COCO-Airplane/deploy.prototxt”, “networks/DetectNet-COCO-Airplane/snapshot_iter_22500.caffemodel”, 0.0f, “networks/DetectNet-COCO-Airplane/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else if( networkType == COCO_BOTTLE )
return Create(“networks/DetectNet-COCO-Bottle/deploy.prototxt”, “networks/DetectNet-COCO-Bottle/snapshot_iter_59700.caffemodel”, 0.0f, “networks/DetectNet-COCO-Bottle/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else if( networkType == COCO_CHAIR )
return Create(“networks/DetectNet-COCO-Chair/deploy.prototxt”, “networks/DetectNet-COCO-Chair/snapshot_iter_89500.caffemodel”, 0.0f, “networks/DetectNet-COCO-Chair/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else if( networkType == COCO_DOG )
return Create(“networks/DetectNet-COCO-Dog/deploy.prototxt”, “networks/DetectNet-COCO-Dog/snapshot_iter_38600.caffemodel”, 0.0f, “networks/DetectNet-COCO-Dog/class_labels.txt”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
#if NV_TENSORRT_MAJOR > 4
else if( networkType == SSD_INCEPTION_V2 )
return Create(“networks/SSD-Inception-v2/ssd_inception_v2_coco.uff”, “networks/SSD-Inception-v2/ssd_coco_labels.txt”, threshold, “Input”, Dims3(3,300,300), “NMS”, “NMS_1”, maxBatchSize, precision, device, allowGPUFallback);
else if( networkType == SSD_MOBILENET_V1_ONNX )
return Create(“networks/SSD-Mobilenet-v1-ONNX/ssd-mobilenet.onnx”, “networks/SSD-Mobilenet-v1-ONNX/labels.txt”, threshold, “Input”, Dims3(3,300,300), “NMS”, “NMS_1”, maxBatchSize, precision, device, allowGPUFallback);
else if( networkType == SSD_MOBILENET_V1 )
return Create(“networks/SSD-Mobilenet-v1/ssd_mobilenet_v1_coco.uff”, “networks/SSD-Mobilenet-v1/ssd_coco_labels.txt”, threshold, “Input”, Dims3(3,300,300), “Postprocessor”, “Postprocessor_1”, maxBatchSize, precision, device, allowGPUFallback);
else if( networkType == SSD_MOBILENET_V2 )
return Create(“networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff”, “networks/SSD-Mobilenet-v2/ssd_coco_labels.txt”, threshold, “Input”, Dims3(3,300,300), “NMS”, “NMS_1”, maxBatchSize, precision, device, allowGPUFallback);
#endif
else
return NULL;
#else
return Create(“networks/multiped-500/deploy.prototxt”, “networks/multiped-500/snapshot_iter_178000.caffemodel”, “networks/multiped-500/mean.binaryproto”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
return Create(“networks/facenet-120/deploy.prototxt”, “networks/facenet-120/snapshot_iter_24000.caffemodel”, NULL, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
return Create(“networks/ped-100/deploy.prototxt”, “networks/ped-100/snapshot_iter_70800.caffemodel”, “networks/ped-100/mean.binaryproto”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
return Create(“networks/DetectNet-COCO-Airplane/deploy.prototxt”, “networks/DetectNet-COCO-Airplane/snapshot_iter_22500.caffemodel”, “networks/DetectNet-COCO-Airplane/mean.binaryproto”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
return Create(“networks/DetectNet-COCO-Bottle/deploy.prototxt”, “networks/DetectNet-COCO-Bottle/snapshot_iter_59700.caffemodel”, “networks/DetectNet-COCO-Bottle/mean.binaryproto”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
return Create(“networks/DetectNet-COCO-Chair/deploy.prototxt”, “networks/DetectNet-COCO-Chair/snapshot_iter_89500.caffemodel”, “networks/DetectNet-COCO-Chair/mean.binaryproto”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
return Create(“networks/DetectNet-COCO-Dog/deploy.prototxt”, “networks/DetectNet-COCO-Dog/snapshot_iter_38600.caffemodel”, “networks/DetectNet-COCO-Dog/mean.binaryproto”, threshold, DETECTNET_DEFAULT_INPUT, DETECTNET_DEFAULT_COVERAGE, DETECTNET_DEFAULT_BBOX, maxBatchSize, precision, device, allowGPUFallback );
else
return NULL;
#endif
// Create
detectNet* detectNet::Create( const commandLine& cmdLine )
detectNet* net = NULL;
// parse command line parameters
const char* modelName = cmdLine.GetString(“network”);
if( !modelName )
modelName = cmdLine.GetString(“model”, “ssd-mobilenet-v2”);
float threshold = cmdLine.GetFloat(“threshold”);
if( threshold == 0.0f )
int maxBatchSize = cmdLine.GetInt(“batch_size”);
if( maxBatchSize < 1 )
maxBatchSize = DEFAULT_MAX_BATCH_SIZE;
const char* precisionName = cmdLine.GetString(“precision”);
if( !precisionName )
precisionName = cmdLine.GetString(“precision”, “FP16”);
// parse the model type
const precisionType type_precision = precisionTypeFromStr(precisionName);
const char* deviceName = cmdLine.GetString(“device”);
if( !deviceName )
deviceName = cmdLine.GetString(“device”, “GPU”);
// parse the device type
const deviceType type_device = deviceTypeFromStr(deviceName);
bool allowGPUFallback_value = cmdLine.GetBool(“allowGPUFallback”);
if( !allowGPUFallback_value )
allowGPUFallback_value = cmdLine.GetBool(“allowGPUFallback”, false);
const detectNet::NetworkType type = NetworkTypeFromStr(modelName);
if( type == detectNet::CUSTOM )
const char* prototxt = cmdLine.GetString(“prototxt”);
const char* input = cmdLine.GetString(“input_blob”);
const char* out_blob = cmdLine.GetString(“output_blob”);
const char* out_cvg = cmdLine.GetString(“output_cvg”);
const char* out_bbox = cmdLine.GetString(“output_bbox”);
const char* class_labels = cmdLine.GetString(“class_labels”);
if( !input )
input = DETECTNET_DEFAULT_INPUT;
if( !out_blob )
if( !out_cvg ) out_cvg = DETECTNET_DEFAULT_COVERAGE;
if( !out_bbox ) out_bbox = DETECTNET_DEFAULT_BBOX;
if( !class_labels )
class_labels = cmdLine.GetString("labels");
float meanPixel = cmdLine.GetFloat("mean_pixel");
net = detectNet::Create(prototxt, modelName, meanPixel, class_labels, threshold, input,
out_blob ? NULL : out_cvg, out_blob ? out_blob : out_bbox, maxBatchSize);
else
// create detectNet from pretrained model
// net = detectNet::Create(type, threshold, maxBatchSize);
net = detectNet::Create(type, threshold, maxBatchSize, type_precision, type_device, allowGPUFallback_value);
if( !net )
return NULL;
// enable layer profiling if desired
if( cmdLine.GetFlag(“profile”) )
net->EnableLayerProfiler();
// set overlay alpha value
net->SetOverlayAlpha(cmdLine.GetFloat(“alpha”, DETECTNET_DEFAULT_ALPHA));
return net;
