Migrated from DeepStream 4 to Deepstream 5 and got errors
So, got myself a neat and cozy program with DeepStream 4 and detection, running smooth on Jetson Nano. Migrated to DeepStream 5, because DP4 got errors with NvTracker and memory fails on test Jetson Nano.
And right now i cannot use old models and engines for DP4. Also, when
Jetson Nano i am trying to use ONNX model on DP5, which was built into engine on DP5, it is crashes.
So i have copied from DP5 /models/ all needed caffemodels and have recreated all needed DP engines, but ONNX model cannot been converted.
DeepStream 5 (was DeepStream 4)
JetPack 4.4 (was JetPack 4.3)
TensorRT 7.1
CUDA 10.2
Here is error message:
0:00:08.130491178 11060 0x55775236a0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 2]: Trying to create engine from model files
Input filename: resnet50-caffe2-v1-9.onnx
ONNX IR version: 0.0.3
Opset version: 9
Producer name: onnx-caffe2
Producer version:
Domain:
Model version: 0
Doc string:
WARNING: [TRT]: onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
ERROR: [TRT]: ../builder/cudnnBuilderBlockChooser.cpp (117) - Assertion Error in buildMemGraph: 0 (mg.nodes[mg.regionIndices[outputRegion]].size == mg.nodes[mg.regionIndices[inputRegion]].size)
ERROR: Build engine failed from config file
ERROR: failed to build trt engine.
0:01:54.536473360 11060 0x55775236a0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 2]: build engine file failed
0:01:54.542278094 11060 0x55775236a0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 2]: build backend context failed
0:01:54.542763489 11060 0x55775236a0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 2]: generate backend failed, check config file settings
0:01:54.543378266 11060 0x55775236a0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:01:54.543879287 11060 0x55775236a0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Config file path: sgie4.conf, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
…Initialization complete…
…Running…
ERROR from element secondary4-nvinference-engine: Failed to create NvDsInferContext instance
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:vran-pipeline/GstNvInfer:secondary4-nvinference-engine:
Or it is I who do not installed good ONNX library?
Could you share the configure file with us?
Suppose this issue is related to the new dynamic shape feature in TensorRT 7.1 (JetPack4.4).
May I know do you use implicit batch or explicit batch for inference?
Property Meaning Type and Range Example Notes Network Types/ Applicable to GIEs (Primary/Secondary)
force-implicit-batch-dim When a network supports both implicit batch dimension and full dimension, force the implicit batch dimension mode. Boolean force-implicit-batch-dim=1 All / Both
Hello. Sure, i can. Config file for which SGIE? The problem one or all?
I do not use “force-implicit-batch-dim” in my config files.
Here is SGIE4 config:
[property]
gpu-id=0
net-scale-factor=0.000784314
onnx-file=./models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.onnx
model-engine-file=./models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.onnx_b10_fp16.engine
labelfile-path=./models/Secondary_Spec_Trans/labels.txt
batch-size=10
network-mode=2
input-object-min-width=10
input-object-min-height=10
model-color-format=0
process-mode=2
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0
is-classifier=1
classifier-async-mode=1
classifier-threshold=0.11
num-detected-classes=1000
output-tensor-meta=1
Also, why did trying to migrate is because of this migraine:
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 28, SyncPointValue = 0)
After 1-10 minutes of work, time spreads from cameras quantity, i got this message and NvTracker shadows all over detected object.
Got my Jetson Nano workplace rebuilded, recompiled my program (also got new errors, even in gstutils.h) and this is error message from 5 minutes 1 camera detection:
NvRmChannelSubmit: NvError_IoctlFailed with error code 22
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 7, SyncPointValue = 0)
fence_set_name ioctl failed with 22
0:02:58.120955270 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: Internal data stream error.
0:02:58.121016784 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: streaming stopped, reason error (-5)
0:02:58.139280880 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: Internal data stream error.
0:02:58.139363229 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: streaming stopped, reason error (-5)
0:02:58.139538604 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: Internal data stream error.
0:02:58.139581888 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: streaming stopped, reason error (-5)
0:02:58.139656736 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: Internal data stream error.
0:02:58.139692467 14051 0x5594ef04f0 WARN nvinfer gstnvinfer.cpp:1803:gst_nvinfer_submit_input_buffer: error: streaming stopped, reason error (-5)
[NvTiler::Composite] ERROR: 349; NvBufSurfTransformComposite failed(-2)
ERROR from element secondary3-nvinference-engine: Internal data stream error.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1803): gst_nvinfer_submit_input_buffer (): /GstPipeline:vran-pipeline/GstNvInfer:secondary3-nvinference-engine:
…Returned, stopping playback…
[NvDCF] De-initialized
On JetPack 4.3 this error almost always got Jetson Nano into crashed state. Now it is exiting, whew, not need to wait for reboot.
Hello. Good news! With this config:
[property]
gpu-id=0
#net-scale-factor=1
model-engine-file=./models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.onnx_b1_gpu0_fp16.engine
batch-size=1
0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
process-mode=2
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
is-classifier=1
force-explicit-batch-dim=1
force-implicit-batch-dim=0
I got ONNX model into DP5.0, hurray!
But still, program crashes with [NvTiler::Composite] ERROR: 349; NvBufSurfTransformComposite failed(-2).
I watched process with tegrastats running, RAM is filling by 1-3Mb with every detection second, but when it is got to 3600/3956Mb - always crashes. Can it be, that some garbage collector empties RAM at this point and pipeline got no FRAMES in NVMM? So NvTiler got nothing to show, core segmentation fault and so on.
I did applied patches for nvvidconv.so, one patch gives me blackout on Jetson, another one gracefully quits my program.
Will try today to use videoconverter from OpenCV instead of NvVidConverter. If it will not crash - i think it is problem in NVMM and clearing of it. Because there is no SWAP used! It always crashes at 3600/3956Mb RAM point!
Hello, any help? Please.
Hello. Have set rtsp cameras quantity to 4, also batch-size of all CNN were up to 4, so right now ONNX model, even with force-implicit-batch-dim=0 are not compiling into TRT engine. Same error.
Sorry for the late update.
May I know which model format do you use first? Is it caffemodel or onnx?
It’s recommended to run you model with trtexec binary to see if the issue comes from TensorRT first.
/usr/src/tensorrt/bin/trtexec --onnx=[your/model]
Hello, AastaLLL.
I do use resnet50-caffe2-v1-9.onnx. Thanks for advise, will try it.
Hello. Have tested like you have written. Also got from another thread --saveEngine function.
[08/28/2020-18:21:23] [I] === Model Options ===
[08/28/2020-18:21:23] [I] Format: ONNX
[08/28/2020-18:21:23] [I] Model: /home/bigbrother/Desktop/Work/Release/models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.onnx
[08/28/2020-18:21:23] [I] Output:
[08/28/2020-18:21:23] [I] === Build Options ===
[08/28/2020-18:21:23] [I] Max batch: 4
[08/28/2020-18:21:23] [I] Workspace: 16 MB
[08/28/2020-18:21:23] [I] minTiming: 1
[08/28/2020-18:21:23] [I] avgTiming: 8
[08/28/2020-18:21:23] [I] Precision: FP32
[08/28/2020-18:21:23] [I] Calibration:
[08/28/2020-18:21:23] [I] Safe mode: Disabled
[08/28/2020-18:21:23] [I] Save engine: /home/bigbrother/Desktop/Work/Release/models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.engine
[08/28/2020-18:21:23] [I] Load engine:
[08/28/2020-18:21:23] [I] Builder Cache: Enabled
[08/28/2020-18:21:23] [I] NVTX verbosity: 0
[08/28/2020-18:21:23] [I] Inputs format: fp32:CHW
[08/28/2020-18:21:23] [I] Outputs format: fp32:CHW
[08/28/2020-18:21:23] [I] Input build shapes: model
[08/28/2020-18:21:23] [I] Input calibration shapes: model
[08/28/2020-18:21:23] [I] === System Options ===
[08/28/2020-18:21:23] [I] Device: 0
[08/28/2020-18:21:23] [I] DLACore:
[08/28/2020-18:21:23] [I] Plugins:
[08/28/2020-18:21:23] [I] === Inference Options ===
[08/28/2020-18:21:23] [I] Batch: 4
[08/28/2020-18:21:23] [I] Input inference shapes: model
[08/28/2020-18:21:23] [I] Iterations: 10
[08/28/2020-18:21:23] [I] Duration: 3s (+ 200ms warm up)
[08/28/2020-18:21:23] [I] Sleep time: 0ms
[08/28/2020-18:21:23] [I] Streams: 1
[08/28/2020-18:21:23] [I] ExposeDMA: Disabled
[08/28/2020-18:21:23] [I] Spin-wait: Disabled
[08/28/2020-18:21:23] [I] Multithreading: Disabled
[08/28/2020-18:21:23] [I] CUDA Graph: Disabled
[08/28/2020-18:21:23] [I] Skip inference: Disabled
[08/28/2020-18:21:23] [I] Inputs:
[08/28/2020-18:21:23] [I] === Reporting Options ===
[08/28/2020-18:21:23] [I] Verbose: Disabled
[08/28/2020-18:21:23] [I] Averages: 10 inferences
[08/28/2020-18:21:23] [I] Percentile: 99
[08/28/2020-18:21:23] [I] Dump output: Disabled
[08/28/2020-18:21:23] [I] Profile: Disabled
[08/28/2020-18:21:23] [I] Export timing to JSON file:
[08/28/2020-18:21:23] [I] Export output to JSON file:
[08/28/2020-18:21:23] [I] Export profile to JSON file:
Input filename: /home/bigbrother/Desktop/Work/Release/models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.onnx
Opset version: 9
Producer version:
Domain:
Model version: 0
Doc string:
[08/28/2020-18:21:26] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[08/28/2020-18:21:37] [I] [TRT] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[08/28/2020-18:21:58] [I] [TRT] Detected 1 inputs and 1 output network tensors.
[08/28/2020-18:22:02] [I] Starting inference threads
[08/28/2020-18:22:05] [I] Warmup completed 4 queries over 200 ms
[08/28/2020-18:22:05] [I] Timing trace has 156 queries over 3.17335 s
[08/28/2020-18:22:05] [I] Trace averages of 10 runs:
[08/28/2020-18:22:05] [I] Average on 10 runs - GPU latency: 81.1181 ms - Host latency: 81.4097 ms (end to end 81.4248 ms, enqueue 7.55378 ms)
[08/28/2020-18:22:05] [I] Average on 10 runs - GPU latency: 81.0408 ms - Host latency: 81.3324 ms (end to end 81.3476 ms, enqueue 8.09339 ms)
[08/28/2020-18:22:05] [I] Average on 10 runs - GPU latency: 80.8898 ms - Host latency: 81.1816 ms (end to end 81.1971 ms, enqueue 7.97445 ms)
[08/28/2020-18:22:05] [I] Host Latency
[08/28/2020-18:22:05] [I] min: 80.325 ms (end to end 80.3409 ms)
[08/28/2020-18:22:05] [I] max: 83.3179 ms (end to end 83.3274 ms)
[08/28/2020-18:22:05] [I] mean: 81.352 ms (end to end 81.3671 ms)
[08/28/2020-18:22:05] [I] median: 81.3025 ms (end to end 81.3181 ms)
[08/28/2020-18:22:05] [I] percentile: 83.3179 ms at 99% (end to end 83.3274 ms at 99%)
[08/28/2020-18:22:05] [I] throughput: 49.1594 qps
[08/28/2020-18:22:05] [I] walltime: 3.17335 s
[08/28/2020-18:22:05] [I] Enqueue Time
[08/28/2020-18:22:05] [I] min: 3.09851 ms
[08/28/2020-18:22:05] [I] max: 13.0354 ms
[08/28/2020-18:22:05] [I] median: 7.99149 ms
[08/28/2020-18:22:05] [I] GPU Compute
[08/28/2020-18:22:05] [I] min: 80.0336 ms
[08/28/2020-18:22:05] [I] max: 83.0281 ms
[08/28/2020-18:22:05] [I] mean: 81.0604 ms
[08/28/2020-18:22:05] [I] median: 81.0103 ms
[08/28/2020-18:22:05] [I] percentile: 83.0281 ms at 99%
[08/28/2020-18:22:05] [I] total compute time: 3.16136 s
&&&& PASSED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/home/bigbrother/Desktop/Work/Release/models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.onnx --saveEngine=/home/bigbrother/Desktop/Work/Release/models/Secondary_Spec_Trans/resnet50-caffe2-v1-9.engine --batch=4
TensorRT got passed over resnet50 ONNX, with batchsize of 4.
But, when i try to compile engine file with deepstream - it is fails. Just like in this message Preprocessing between pgie and sgie - #14 by kobe2410811
But even if i set --maxBatch=4 and compile engine i got this:
0:00:11.282954490 8398 0x55999dfb30 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1642> [UID = 2]: Backend has maxBatchSize 1 whereas 4 has been requested
And this
ERROR: [TRT]: …/builder/cudnnBuilderBlockChooser.cpp (117) - Assertion Error in buildMemGraph: 0 (mg.nodes[mg.regionIndices[outputRegion]].size == mg.nodes[mg.regionIndices[inputRegion]].size)
Hello.
Small update: i removed batch check, set all to 1 and it does it’s job.
But still falls down with same error.
Hello, again :-)
I got culprit of my error, it is image getting from NvBuf. When i remove it - program works until i shut it down. So i got recoded using of it, basically make OpenCV to release all buffer images, used for conversion from NvBuf to OCR code.
Here it is:
static GstFlowReturn
Convert_Buf_Into_Image (NvBufSurface input_buf, gint idx,
NvOSD_RectParams * crop_rect_params, gdouble Make_Ratio, gint input_width,
gint input_height, char
filename_Adder)//NvDsObjectMeta *object_meta)
NvBufSurfTransform_Error err;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvBufSurface ip_surf;
cv::Mat in_mat, buf_mat;
ip_surf = *input_buf;
ip_surf.numFilled = ip_surf.batchSize = 1;
ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
/gint src_left = GST_ROUND_UP_2(crop_rect_params->left);
gint src_top = GST_ROUND_UP_2(crop_rect_params->top);
gint src_width = GST_ROUND_DOWN_2(crop_rect_params->width);
gint src_height = GST_ROUND_DOWN_2(crop_rect_params->height);
gint src_left = (int)crop_rect_params->left;
gint src_top = (int)crop_rect_params->top;
gint src_width = (int)crop_rect_params->width;
gint src_height = (int)crop_rect_params->height;
//g_print(“ltwh = %d %d %d %d \n”, src_left, src_top, src_width, src_height);
guint dest_width, dest_height;
gdouble Ratio = 1.0;
dest_width = src_width;
dest_height = src_height;
NvBufSurface *nvbuf;
NvBufSurfaceCreateParams create_params;
//dsexample->gpu_id = DEFAULT_GPU_ID;
char *p_str;
create_params.gpuId = DEFAULT_GPU_ID;
create_params.width = dest_width;
create_params.height = dest_height;
create_params.size = 0;
create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef aarch64
create_params.memType = NVBUF_MEM_DEFAULT;
#else
create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
NvBufSurfaceCreate (&nvbuf, 1, &create_params);
// Configure transform session parameters for the transformation
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = DEFAULT_GPU_ID;
// Set the transform session parameters for the conversions executed in this
// thread.
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
if (err != NvBufSurfTransformError_Success)
goto error;
// Calculate scaling ratio while maintaining aspect ratio
//Ratio = MIN (Make_Ratio * dest_width / src_width, Make_Ratio * dest_height / src_height);
if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0))
goto error;
#ifdef aarch64
if (Ratio <= 1.0 / 16 || Ratio >= 16.0) {
// Currently cannot scale by ratio > 16 or < 1/16 for Jetson
goto error;
#endif
// Set the transform ROIs for source and destination
src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
// Set the transform parameters
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag =
NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC |
NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
//Memset the memory
NvBufSurfaceMemSet (nvbuf, 0, 0, 0);
// Transformation scaling+format conversion if any.
err = NvBufSurfTransform (&ip_surf, nvbuf, &transform_params);
goto error;
// Map the buffer so that it can be accessed by CPU
if (NvBufSurfaceMap (nvbuf, 0, 0, NVBUF_MAP_READ) != 0)
goto error;
// Cache the mapped data for CPU access
NvBufSurfaceSyncForCpu (nvbuf, 0, 0);
// Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
// algorithm can handle padded RGBA data.
in_mat = cv::Mat (dest_height, dest_width, CV_8UC4, nvbuf->surfaceList[0].mappedAddr.addr[0],
nvbuf->surfaceList[0].pitch);
buf_mat = cv::Mat(cv::Size(dest_width * Make_Ratio, dest_height * Make_Ratio), CV_8UC4);
Detected_Vehicle_Image = cv::Mat(cv::Size(dest_width * Make_Ratio, dest_height * Make_Ratio), CV_8UC3);
cv::cvtColor(in_mat, buf_mat, cv::COLOR_RGBA2BGR);
//cv::resize(in_mat, Detected_Vehicle_Image, cv::Size(), Make_Ratio, Make_Ratio, cv::INTER_LINEAR);
cv::resize(buf_mat, Detected_Vehicle_Image, cv::Size(), Make_Ratio, Make_Ratio, cv::INTER_LINEAR);
char filename[120];
snprintf(filename, 120, “./lastframes/pic_%s.jpg”, filename_Adder);
if (!(File_Exists(filename))) cv::imwrite(filename, Detected_Vehicle_Image);
in_mat.release();
buf_mat.release();
if (NvBufSurfaceUnMap (nvbuf, 0, 0))
goto error;
NvBufSurfaceDestroy(nvbuf);
return GST_FLOW_OK;
error:
return GST_FLOW_ERROR;
But now i am facing more errors! Will make new thread for it.
Sorry for the late update and thanks for the detail update.
It seems that the model can run correctly with TensorRT separately.
Would you mind to share a reproducible source with us so we can check it for you?
Hello, thank for reply.
No, i have found MAIN error, right now i need to find better way to save images from NvBuf into OpenCV Mat, or just save images into jpeg/png/bmp files. Yes i have checked deepstream-test5-sample, but adaptating it’s code gives me nothing, but i will try it again.
All this because NvBuf and CPU share same RAM and sometimes there is bug that can overwrite into wrong sectors.
I have pasted my code for saving images, main part of which i got from this forum :-)
Please help with another bug, with NvTracker initial ID value , i have already made new thread.
Thank you,
So is the original cudnn error solved?
Just want to confirm it.
